您好我正在尝试使用nvfir捕获Direct3D输出并下载最新的Capture SDK(6.1)...
当我查看文档和头文件时,应该(例如)方法“NvIFRSetUpHWEncoder”,但是当我尝试使用此方法时,此方法没有入口点。 当我查看dll(使用dependecy walker)时,它会向我显示类似“NvIFR_CreateCrossProcessSharedSurfaceEXT”的方法,这些方法在标题或文档中找不到。 任何人都可以帮助我开始这个吗? 我究竟做错了什么? 非常感谢你 PS:我安装了最新的驱动程序,其版本高于文档中描述的最小版本 以上来自于谷歌翻译 以下为原文 Hello I'm trying to capture Direct3D output with nvfir and donwloaded the latest Capture SDK (6.1)... When I look at the documentation and the header files there should be (for example) a method "NvIFRSetUpHWEncoder" but when I try to use this method there is no entrypoint for this method. When I look into the dll (with dependecy walker) it shows me methods like "NvIFR_CreateCrossProcessSharedSurfaceEXT" which I cannot find in the headers or documentation. Can anyone help me to get this started? What am I doing wrong? Thank you very much PS: I've installed the latest drivers which has a higher version than the min version described in the documentation |
1个回答
对不起......我的错。
当然Header文件是正确的......这些方法是create Encoder实例的方法,必须在这个实例上调用 案件结束:-) 以上来自于谷歌翻译 以下为原文 Sorry... my fault. Of course the Header files are correct... the methods are methods of the create Encoder instance and have to be called on this instance case closed :-) |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2831 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3225 浏览 4 评论
GMT+8, 2024-4-24 06:27 , Processed in 0.399754 second(s), Total 42, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
