你好,我想让RN467在我的工作板上工作,但是我遇到了一些困难。当我运用权力时,我会有奇怪的行为。TX和RX浮标,状态指示器引脚浮动,指示器LED弱,等等。我想LED可能需要一个外部电阻(数据表中的一些图表有一个,其他没有),我可能烤过没有它的设备,所以我删除了LED和回流在一个新的设备上。然而,我仍然得到相同的行为,所以这不是一个单独设备的问题,LED电路已经从图片中删除了。如果我只应用电源并让其他东西浮动,我会看到以下输出:2200:1.1V//应该被RN467 8拉高!P2Y4:1.1V//应该被RN467 8拉高!EA:0.5V//通过4.7K电阻拉低……但这不是0V.TXD:2.3V RXD:1.1VP1Y5:2.3V//STATE PIN…应该是低或高,不是浮动在2.3VP04:2.3V//STATE PIN…应该是低或高,不浮动在2.3VIF,我把它放在固件闪烁模式(P2O0低,P2O4低,EAN高)I不能得到它,它在1.6V上浮动了TXD引脚2.4V和RX。我在我的MCU上运行了一个BAR测试应用程序,所以它除了设置Py0 0,2,4,还有输入(让它们浮动)之外什么都不做。我想我可能已经把电路连接错了,但是我不确定如何…这是一个非常简单的CI。RuCIT。我不知道还有什么别的解释。有什么想法吗?
以上来自于百度翻译 以下为原文 Hello, I'm trying to get the RN4678 working on my board but I'm having some difficulty. When I apply power I get strange behavior. TX and RX float, status indicator pins float, the indicator LED is weak, etc. I thought perhaps the LED requires an external resistor (some diagrams in datasheet had one, others did not) and I may have toasted the device without it, so I removed the LED and reflowed on a new device. However I still get the same behavior, so it's not a problem with the individual device and the LED circuit has been removed from the picture. If I only apply power and let everything else float, I see the following output: P2_0: 1.1v // Should be pulled high by RN4678! P2_4: 1.1v // Should be pulled high by RN4678! EAN: 0.5v // Pulled low through 4.7k resistor...but this isn't at 0v. TXD: 2.3v RXD: 1.1v P1_5: 2.3v // Status pin...should be low or high, not floating at 2.3v P0_4: 2.3v // Status pin...should be low or high, not floating at 2.3v If I put it in firmware flashing mode (P2_0 low, P2_4 low, EAN high) I can't get comms to it and it's floating the TXD pin 2.4v and RX at 1.6v. I'm running a barebones test app on my MCU so it's not doing anything other than setting P2_0, P2_4, EAN to inputs (to let them float). I think I may have wired the circuit wrong but I'm not sure how....it's a pretty simple circuit. I'm not sure what other explanation there is. Any thoughts? Attached Image(s) |
6个回答
您好,我建议您检查用户手册中的RN467—PCT尾的电路原理图。我想您错过了连接多个信号。请务必使用最新的固件版本V1.11,您可以在这里找到升级程序。
以上来自于百度翻译 以下为原文 Hi, I recommend that you check the circuit schematic of the RN4678-PCTAIL which is in the user manual. I think you miss to connect several signals. Make also sure to use he latest firmware version v1.11 which you can find with the upgrade procedure here. Regards |
谢谢。我回顾了那里的电路并做了一些修改(直接将3.3V应用到SWY-BTN和VDDYIO)。我在LDO33O和LDO1818O上分别得到3.3V和1.8V,所以我知道内部有电源,但是大多数其余引脚(包括状态引脚)都以奇数值浮动。状态引脚是这样做的,它们应该是0或3.3,以指示正确的操作。除了GND、BATZIN和VDDYIO之外,我不需要任何其他连接来获得P04和P1Y5上的基本状态指示电压,是吗?根据PCT尾图,P2O0、P2Y4和EAN可以保持NC以保持应用模式,数据表中也存在不一致的地方,这是相当烦人的。例如,在EAN的数据表中,它说“必须用4.7K下拉到GND”(P.4)。在数据表示例电路(P.13)中,它用NC直接切换到GND。然后在PC尾灯图中,NC的开关用3.3V的10Ω电阻器拉起。非常沮丧。
以上来自于百度翻译 以下为原文 Thanks. I reviewed the circuits there and made a few changes (applied 3.3v directly to SW_BTN and VDD_IO). I get 3.3v and 1.8v on LDO33_O and LDO18_O respectively so I know there is power internally, but most of the rest of the pins (including status pins) float at odd values. Status pins are DO so they should either be 0 or 3.3 to indicate proper operation. I don't think I need any other connections besides GND, BAT_IN, and VDD_IO to just to get basic status indication voltages on P0_4 and P1_5, do I? According to the PCTAIL schematics, P2_0, P2_4 and EAN can remain NC to stay in application mode. There are also inconsistencies in the datasheets that is pretty annoying. For example, in the datasheet for EAN, it says "Must be pulled down with 4.7k to GND" (p.4). In the datasheet example circuit (p.13), it is left NC with a switch directly to GND. Then in the PCTAIL diagram it is NC with a switch to 3.3v pull up with a 10 ohm resistor. Pretty frustrating. sad: |
嗨,这些东西会让你发疯的;-我想你最好把VDDIO连接到LDO3YO如果你想用3.3V I/OI在几个月的努力之后仍然与我的斗争,数据表不是最好的,我希望我开始了一个不同的模块,但是我觉得我已经投入了太多的精力去阻止它。现在…祝你好运,让我们知道。Cheers Geoff
以上来自于百度翻译 以下为原文 Hi, These things will drive you mad ;-), I think your best to connect vdd io to ldo33_O if you want to use 3.3v I/O I'm still struggling with mine after a few months of effort the data sheets aren't the best and I wish I had started with a different module but feel I've put too much into it to stop now... Good luck, keep us posted. Cheers Geoff |
月????在文档和产品擅长的情况下,也许我应该完全避免Microchip BT模块。
以上来自于百度翻译 以下为原文 MONTHS?!? With documentation and products at good at this, maybe I should have just avoided Microchip BT modules completely.. |
不是全职的,我可以很容易地失去他们两个星期的全职时间,我想,那么我可能有点慢,我想;
以上来自于百度翻译 以下为原文 Not full time, can easy lose a couple weeks to them full time I reckon, then I could be a bit slow I suppose ;-) |
为了结束循环,我让它工作了。忽略数据表并遵循PCT尾示例图(这是一个悲伤的声明)。您需要的唯一引脚是:GNDVDD/SWY-BTN-Ap+3.3VLDR33 0和VDDYIO连接这些连接。TX/RX/CTS/RTS- DATALEAVE配置引脚NCU不需要像PC尾注图那样在数据线中串联电阻。我不知道为什么这些都在那里,希望这有助于未来的人!
以上来自于百度翻译 以下为原文 To close the loop, I got it working. Just ignore the datasheet and follow the PCTAIL example diagram (this is a sad statement). The only pins you need are: GND VDD / SW_BTN - apply +3.3v LDR33_0 and VDD_IO - Connect these together. TX/RX/CTS/RTS - Data Leave config pins NC You don't need series resistors in data lines as in the PCTAIL diagram. I have no idea why these are in there. Hopefully this helps someone in the future! |
只有小组成员才能发言,加入小组>>
4778 浏览 9 评论
1814 浏览 8 评论
1733 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2941 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2043 浏览 5 评论
419浏览 1评论
1100浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
343浏览 0评论
253浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1751浏览 0评论
GMT+8, 2024-3-29 00:07 , Processed in 1.138951 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
