我们设计的产品使用SPWF01SC + Sagrad天线(如数据表中所述),并考虑迁移到SPWF04SC + Sagrad天线。然而,查看数据表,两个模块仅经过EN 300 328 v1.9.1测试,而新的无线电设备指令(2014/53 / EU)似乎要求测试EN 300 328 v2.1.1标准,其中包括一个新接收器阻止测试。
我们希望将Sagrad天线与SPWF04SC一起使用,因此需要使用我们的电路板和天线重复EN 300 328测试至v2.1.1。我注意到有一个'etf_mode'配置变量可用但没有关于etf_mode的不同值的工程测试函数的文档。因此,我有一些关于通过合规性测试获取产品的问题: 1)etf_modes是否记录在任何地方,或者您能告诉我应该将它们设置为什么,以便根据EN 300 328测试模块? 2)v2.1.1中新的接收机阻塞测试要求模块以低于10%的分组差错率执行,信号出现在与被测试信号相邻的频率上;是否可以停止接收机的跳频以进行此测试,还可以配置另一个SPWF模块在单个RF信道上向其发送数据?如果是这样,那么验证我们是否满足&lt; = 10%PER,从一个模块向另一个模块发送大量短UDP数据包的最佳方法是什么? 非常感谢, 史蒂夫 以上来自于谷歌翻译 以下为原文 We've designed a product that uses the SPWF01SC + Sagrad antenna (as specified in the datasheet) and would like to consider migrating to the SPWF04SC + Sagrad antenna. Looking at the datasheets however, both modules have only been tested to EN 300 328 v1.9.1 whereas the new Radio Equipment Directive (2014/53/EU) appears to require testing to the EN 300 328 v2.1.1 standards which include a new receiver blocking test. We wish to use the Sagrad antenna with the SPWF04SC and so would need to repeat the EN 300 328 tests to v2.1.1 with our board and the antenna. I noticed that there's an 'etf_mode' configuration variable available but no documentation as to what the engineering test functions are for different values of etf_mode. I've therefore got a few questions about getting our product through the compliance testing: 1) Are the etf_modes documented anywhere or can you tell me what they should be set to in order to test the module under EN 300 328? 2) The new receiver blocking test in v2.1.1 requires that the module performs with less than a 10% packet error rate with a signal present on a frequency adjacent to the one under test; is it possible to stop the frequency hopping of the receiver for this test and also to configure another SPWF module to send data on a single RF channel to it? If so then what would be the best way to verify that we're meeting the <=10% PER, send lots of short UDP packets perhaps from one module to the other? Many Thanks, Steve |
4个回答
Ciao Steve,
所有SPWF01&amp; SPWF04已经根据最新的RED认证。询问文档...... 但是,如果您需要再次认证(您的PCB上还有其他RF吗?),您可以联系您的经销商或ST办公室获取使用etf_mode(工程测试固件)所需的包。 BR 杰瑞 以上来自于谷歌翻译 以下为原文 Ciao Steve, all SPWF01 & SPWF04 have been already certified according to latest RED. Ask for docs... However, if you need to certify again (do you have another RF on your PCB?), you can contact your distributor or ST office to get package required to use the etf_mode (enginnering test firmware). BR jerry |
嗨,杰里,
谢谢你快速的回复;我们想使用SPWF04SC数据表中详细说明的Sagrad天线和SPWF04SC,但ST已经使用Titanis天线进行的认证测试,所以我们需要重复测试,除非ST使用SPWF04SC +进行测试结果Sagrad天线? 我怎样才能掌握RED测试结果? 谢谢, 史蒂夫 以上来自于谷歌翻译 以下为原文 Hi Jerry, Thanks for your quick response; we'd like to use the Sagrad antenna as detailed in the SPWF01SC datasheet with the SPWF04SC but the certification tests that ST have done are using the Titanis antenna so we'll need to repeat the tests unless ST have test results performed with the SPWF04SC + Sagrad antenna? How can I get hold of the RED test results? Thanks, Steve |
如果天线(Sagrad)的峰值增益小于我们用于认证的天线(Titanis),您可以保持认证。
向您的经销商或ST直接联系询问文档。 以上来自于谷歌翻译 以下为原文 You can keep certification if antenna (Sagrad) is having smaller peak gain than the one we used for certification (Titanis). Ask for docs to your distributor or ST direct contact. |
好消息 - 感谢您的帮助;我将跟进英国销售办事处。
谢谢, 史蒂夫 以上来自于谷歌翻译 以下为原文 Excellent news - thanks for your help; I'll follow up with the UK sales office. Thanks, Steve |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1454 浏览 1 评论
2122 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1510 浏览 1 评论
2826 浏览 6 评论
5245 浏览 21 评论
362浏览 4评论
542浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
279浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
612浏览 3评论
514浏览 3评论
GMT+8, 2024-4-24 23:15 , Processed in 0.741261 second(s), Total 48, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
