DoclD027112 Rev2。
寄存器描述8.6中CTRL_REG1的描述 DIFF_EN - 中断生成使能。默认值:0 (0:禁止中断生成; 1:启用中断生成) 文字说明是: DIFF_EN位用于计算差压输出。建议在配置REF_P_H(0Ah),REF_P_L(09h),REF_P_XL(08h),THS_P_H(31h)和THS_P_L(30h)后启用DIFF_EN。 问:该位是DIFF_EN还是中断使能? 寄存器描述8.7中CTRL_REG2的描述 FIFO_MEAN_-DEC - 在使用串行接口(I 2 C或SPI)进行多字节访问期间,寄存器地址自动递增。默认值1.(0:禁用; 1启用) 该位没有文字说明。 问题:这个位是以任何方式与FIFO操作相关的(如位名所暗示的)还是仅仅是串行总线访问的寄存器地址增量? 以上来自于谷歌翻译 以下为原文 DoclD027112 Rev2. Description for CTRL_REG1 in Register description 8.6 DIFF_EN - Interrupt generation enable. Default value: 0 (0: interrupt generation disabled; 1: interrupt generation enabled) Text description is: The DIFF_EN bit is used to enable the computing of differential pressure output. It is recommended to enable DIFF_EN after the configuration of REF_P_H (0Ah), REF_P_L (09h), REF_P_XL (08h), THS_P_H (31h) and THS_P_L (30h). Question: Is this bit a DIFF_EN or is it an Interrupt Enable? Description for CTRL_REG2 in Register description 8.7 FIFO_MEAN_-DEC - Register address automatically incremented during a multiple byte access with a serial interface (I 2 C or SPI). Default value 1. (0: disable; 1 enable) There is no text description of the bit. Question: Is this bit related to the FIFO operation in any way (as the bit name implies) or is it simply a register addr increment for the serial bus access? |
1个回答
嗨,
1。 DIFF_EN位用于计算差压输出。 压力输出值PRESS_OUT将包含从传感器输出测量值中减去的参考压力值数据(REF_P)。 从传感器输出测量值中减去参考压力值,以检测超出编程限值(THS_P)的测量压力。 为了启用压力中断,您还必须配置CTRL_REG3(0x22h)。 因此,为了使能中断,您必须使能DIFF_EN位并配置CTRL_REG3(参见数据表中的表20).2。 抱歉,FIFO_MEAN_-DEC位描述不正确。 请参见数据表的4.6节,了解该位的说明。 我们将更正数据表以供下次审核。 问候 安东内拉 以上来自于谷歌翻译 以下为原文 Hi, 1. DIFF_EN bit is used to enable the computing of differential pressure output. The pressure output value PRESS_OUT will contain the Reference pressure value data (REF_P) subtracted from the sensor output measurement. The reference pressure value is subtracted from the sensor output measurement, to detect a measured pressure beyond programmed limits ( THS_P). In order to enable the pressure interrupt, you have to configure the CTRL_REG3 (0x22h) too. So in order to enable the interrupt generation you have to enable DIFF_EN bit and configure CTRL_REG3 (see table 20 on datasheet).2. Sorry, the FIFO_MEAN_-DEC bit description is not correct. Pls, See section 4.6 on datasheet for explanation of this bit. We are going to correct the datasheet for the next review. Regards Antonella |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1217 浏览 1 评论
1839 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1499 浏览 1 评论
2727 浏览 6 评论
4955 浏览 21 评论
296浏览 4评论
344浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
263浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
341浏览 3评论
350浏览 3评论
GMT+8, 2024-3-29 21:01 , Processed in 0.779547 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
