大家好,
我注意到有关每个物理GPU的“nvidia-smi -q”命令输出的功率统计数据的一个有趣的事情。 如果您将最大功率限制加倍(因为每个板上有两个GPU),其等于超出板的公布最大值。 例如,K2为125W×2 = 250W,M60为162W×2 = 324W。 你可以看到它们高于K2和M60卡的公布最大值。 发布的最大值: K2:225 W M60:300 W 也许这种每GPU最大功率消耗允许单GPU暂时进入其“提升”模式。 而且,只有在电路板上的其他物理GPU远低于其最大功率消耗不超过整个电路板的公布限制的情况下才会发生这种情况。 是这样的吗? 谢谢! 理查德 以上来自于谷歌翻译 以下为原文 Hi All, I noticed an interesting thing about the power stats outputted from the "nvidia-smi -q" command for each physical GPU. If you double the Max Power Limit (as there are two GPUs per board) that equals above the published maximums for the board. For instance the K2 would be 125W x 2 = 250 W and the M60 would be 162W x 2 = 324W. You can see those are above the published maximums below for the K2 and M60 cards. Published Maximums: K2: 225 W M60: 300 W Perhaps this per-GPU maximum power draw allows the single GPU to enter it’s “boost” mode temporarily. And, that would only occur in the case that the other physical GPU on the board is far enough below its maximum power draw not to exceed the published limit for the entire board. Is this the case? Thanks! Richard |
6个回答
在同一份报告中,您将看到每个150W的GPU都有强制功率限制。
电源管理:支持 功耗:24.45 W 功率限制:150.00 W 默认功率限制:150.00 W 强制功率限制:150.00 W 最小功率限制:112.50 W 最大功率限制:162.00 W 因此,尽管GPU本身能够绘制162W,但每个都限制在150W,因此将电路板保持在300W以下。 这些限制在固件中设置,因此请勿随软件更新而更改。 驱动器中的电源管理能够控制最小功率限制和强制功率限制之间的负载。 Max更多的是报告能力与绘制的能力。 以上来自于谷歌翻译 以下为原文 In the same report you'll see that there's an enforced power limit for each GPU of 150W. Power Management : Supported Power Draw : 24.45 W Power Limit : 150.00 W Default Power Limit : 150.00 W Enforced Power Limit : 150.00 W Min Power Limit : 112.50 W Max Power Limit : 162.00 W So although the GPU itself is capable of drawing 162W each is restricted to 150W, keeping the board under the 300W published Maximum. These limits are set in the firmware, so do not change with software updates. Power management in the driver is able to control the load between the Min Power Limit and the Enforced Power Limit. The Max is more to report capability vs what would be drawn. |
大家好,
我有另一个与权力相关的问题。 在GRID 2.0文档中,我看到被动冷却的M60可配置为300W至240W。 我想知道M6是否有类似的选择。 我问,因为我看到M6的核心时钟速度规格中注明了两个功率电平。 我已经注意到下面的那些,但两个额定功率是75W和100W。 基础: 722 MHz(TGP:75 W) 950 MHz(TGP:100 W) 促进: 886 MHz(TGP:75 W) 1051 MHz(TGP:100 W) 一如既往地谢谢! 理查德 以上来自于谷歌翻译 以下为原文 Hi All, I have another power related question. In the GRID 2.0 documentation, I see that the passively cooled M60 can be configured down from 300W to 240W. I am wondering if the M6 has a similar option. I ask because I see two power levels noted in the core clock speed specs for the M6. I have noted those below but the two power ratings are 75W and 100W. Base: 722 MHz (TGP: 75 W) 950 MHz (TGP: 100 W) Boost: 886 MHz (TGP: 75 W) 1051 MHz (TGP: 100 W) Thanks as always! Richard |
大家好,
有谁知道为什么M6的“Base”和“Boost”都有两级核心时钟速度? 我发现“TGP”的意思是“Total Graphics Powerdraw”。 我知道你会在更高的核心频率下吸取更多的力量。 我现在只想知道为什么M6的总时钟速度有四个级别。 谢谢! 理查德 以上来自于谷歌翻译 以下为原文 Hi All, Does anyone know why the M6 has two levels of core clock speeds for both "Base" and "Boost?" I found that "TGP" means "Total Graphics Powerdraw." I get that you'd draw more power at higher core frequencies. I just want to know now why there are four total levels of clock speed for the M6. Thanks! Richard |
Tesla M6专为刀片服务器而设计,具有不同的功率要求,具体取决于OEM。
不同的功率水平使OEM能够优化其解决方案。 以上来自于谷歌翻译 以下为原文 Tesla M6 has been designed for blade servers which have different power requirements depending on OEM. The different power levels give OEMs the ability to optimize their solutions. |
凉。
那个级别如何设定? 我没有在vGPU用户指南等中看到有关如何更改它的任何内容。 我在nvidia-smi中探索并找到了“-pl”开关确实改变了功率限制,但是手册页说它只适用于开普勒。 见下文。 -pl, - power-limit = POWER_LIMIT 指定以瓦特为单位的最大功率限制。 接受整数和浮点数。 仅限Kepler系列支持的设备。 需要 管理员权限。 值必须在nvidia-smi报告的最小和最大功率限制之间。 谢谢米兰! 理查德 以上来自于谷歌翻译 以下为原文 Cool. And how is that level set? I didn't see anything in the vGPU users guide, etc. on how to change it. I poked around in nvidia-smi and found the "-pl" switch that does change the power limit but the manual page says it's for Kepler only. See below. -pl, --power-limit=POWER_LIMIT Specifies maximum power limit in watts. Accepts integer and floating point numbers. Only on supported devices from Kepler family. Requires administrator privileges. Value needs to be between Min and Max Power Limit as reported by nvidia-smi. Thanks Milan! Richard |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2832 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3225 浏览 4 评论
GMT+8, 2024-4-24 19:52 , Processed in 0.618803 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
