我有一个新的6700B,在插槽1和插槽1中安装了两个6731B电源模块。
2,我无法在Dig Port的Pin 3上设置实时禁止输入。 当我导航到前面板上的* System IO DigPort Pins *显示* Pin *,* Function *和* Polarity *时,会显示字段,但我无法为它们输入值。 访问* Protect Inhibit *以选择* Live *按预期工作..我在原始6700上使用此功能没有任何问题。我错过了另一个设置或新设备是否有缺陷。 任何帮助是极大的赞赏。 更新:在发布上述内容后,我在Keysight呼叫中心与Roman进行了交谈,他尝试了我在N6700B上使用的步骤,并且工作正常。 我们还确认我的设备有最新的固件,因此我们得出结论,我们的新设备出现故障,并且已经被送回Keysight进行保修维修。编辑:LMOwego于2016年2月17日上午4:48 以上来自于谷歌翻译 以下为原文 I have a new 6700B with two 6731B power modules installed in Slots 1 & 2 and I'm unable to set up a Live Inhibit input on Pin 3 of the Dig Port. When I navigate to *SystemIODigPortPins* on the front panel display the *Pin*, *Function*, and *Polarity*, fields are displayed but I can't enter values for them. Accessing the *ProtectInhibit* to select *Live* works as expected.. I've used this function with no problems on the original 6700. Am I missing another setting or is the new unit just defective. Any help is greatly appreciated. Update: After posting the above I spoke with Roman in the Keysight Call center and he tried the steps I was using on his N6700B and it worked fine. We also confirmed my unit had the latest firmware so we concluded that our new unit was faulty and it since been sent back to Keysight for warranty repair. Edited by: LMOwego on Feb 17, 2016 4:48 AM |
2个回答
嗨,我在我的单位上尝试了这个,它对我来说似乎很好。
以下是我的步骤:1。点击菜单2.选择系统3.选择IO 4.选择DigPort 5.选择Pins 6.点击Sel 5.突出显示3并点击sel 6.点击右箭头7.点击Enter。 当我按Enter键时,会出现所有可用的功能。 按照上述步骤操作,如果不起作用,请提供以下信息:1。您拥有的固件版本2.屏幕图片谢谢! 以上来自于谷歌翻译 以下为原文 Hi, I tried this on my unit and it seems to work fine for me. Here are my steps: 1. Hit Menu 2. Select System 3. Select IO 4. Select DigPort 5. Select Pins 6. Hit Sel 5. Highlight 3 and hit sel 6. Hit the right arrow 7. Hit Enter. When I hit Enter, all of the available functions come up. Follow the steps above and if it does not work, please provide the following: 1. What firmware version you have 2. A picture of what the screen Thanks! |
我们的N6700B已经修好并运回给我们..服务报告如下:+“提供的服务:+ +手动检查偏差和批量电源是否良好。已验证客户抱怨主机有接口问题。
前面板没有注册某些按钮,例如:后退箭头键,sel,down和up键。安装PCA,问题解决,所有按钮都正常工作。验证N6700B主机的正确操作。“+ 以上来自于谷歌翻译 以下为原文 Our N6700B has been repaired and shipped back to us.. The service report is as follows: +"Services Provided:+ +Manually checked Bias and bulk power supply to be good. Verified customer's complaint that the mainframe has issue with the Interface. The front panel does not register certain buttons such as: the back arrow key, sel, down, and up keys. Installed PCA, problem resolved, all buttons are functioning. Proper operation of N6700B mainframe verified."+ |
只有小组成员才能发言,加入小组>>
2099 浏览 1 评论
1854 浏览 1 评论
1714 浏览 5 评论
2581 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1560 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2258浏览 0评论
GMT+8, 2024-4-25 13:07 , Processed in 1.040782 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
