大家好。这是我在这个论坛上的第一篇文章。我是一名完成高级设计项目的电气工程专业。我正在设计一款智能手表,我购买了STEVAL MKI159V1运动传感器,这将是我第一次使用Raspberry PI 3微电脑和我第一次使用运动传感器。我的问题是,在哪里可以找到有关如何通过Raspberry PI 3上的I2C连接将包含LSM9DS1的STEVAL MKI159V1连接到Raspberry PI 3的说明?这在我的EE教育中没有教过,我想确保它正确连接。我计划测量运动传感器数据并最终滤除任何噪音。感谢您提供给我的任何意见。
#mems 以上来自于谷歌翻译 以下为原文 Hello everyone. This is my first posting on this forum. I am an electrical engineering major completing a senior design project. I am designing a smartwatch and I purchased the STEVAL MKI159V1 motion sensor and this will be my first time working with the Raspberry PI 3 microcomputer and my first time working with a motion sensor. My question is where can I find instructions on how to connect the STEVAL MKI159V1 that contains the LSM9DS1 to the Raspberry PI 3 via the I2C connection on the Raspberry PI 3.? This was not taught in my EE education and I want to make sure it is connected correctly. I plan on measuring the motion sensor data and eventually filtering out any noise. Thank you for any input you can give me. #mems |
1个回答
你好,何塞,
我已经向论坛发送了回复,但多亏了“精心设计的”ST页面没有发送任何内容,整个工作都没有了。所以从头开始。 我不是Raspberry的专家,但I2C无处不在。我会尽力回答这个问题。 您可以从ST web下载MKI159V1的原理图和LSM9DS1的数据表。 MKI159V1 Pin Raspberry GPIO引脚 13 9(GND) 1,2,18,19,23 1(直流电源3.3 V) 22 1或9(I2C地址选择,参考数据表) 20 5(I2C SCL) 21 3(I2C SDA) 20将电阻3k3上拉至引脚1 21上拉电阻3k3至引脚1这是最小配置。 如果你想使用Raspberry通知的中断,你还必须将MKI159V1引脚14..17连接到Raspberry的GPIO引脚。我希望这会有所帮助。 最好的祝福, 玛丽安 以上来自于谷歌翻译 以下为原文 Hello Jose, I already send response to the forum, but thanks to ''well-designed'' ST pages nothing was send and whole work is gone. So again from scratch. I am not an expert for Raspberry, but I2C is the same everywhere. I will try to answer the question. You can download schematic for MKI159V1 and datasheet for LSM9DS1 from ST web. MKI159V1 Pin Raspberry GPIO Pin 13 9 (GND) 1,2,18,19,23 1 (DC power 3.3 V) 22 1 or 9 (I2C address selection, refer to datasheet) 20 5 (I2C SCL) 21 3 (I2C SDA) 20 Pull-up resistor 3k3 to pin 1 21 Pull-up resistor 3k3 to pin 1This is the minimal configuration. If you want to use interrupts for Raspberry notification you have to still connect MKI159V1 pins 14..17 to GPIO pins of Raspberry.I hope that this will help. Best Regards, Marian |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1126 浏览 1 评论
1747 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1497 浏览 1 评论
2662 浏览 6 评论
4852 浏览 21 评论
238浏览 4评论
272浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
260浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
238浏览 3评论
283浏览 3评论
GMT+8, 2024-3-19 11:53 , Processed in 0.995990 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
