你能描述一下如何设置''Placement electrical angle''。 ST Motor Workbench的默认值为300度。
我有一个8极电机,120度间隔霍尔传感器。根据我在网上找到的信息,我将此设置为60度,并且我在该设置下也获得了最大的扭矩。我把它解释为不同大厅状态之间的角度差异。 我问这个问题是因为''Placement electrical angle''的值可以是0到359度,我想知道什么时候改变了。 根据我的理解,如果使用120度间隔的霍尔传感器,则60度以外的值不应该正常工作......但是,ST Motor Workbench中的选项一定不是这种情况。 问候, 萨加尔 以上来自于谷歌翻译 以下为原文 Could you describe how to set ''Placement electrical angle''. The default value in ST Motor Workbench is 300 degrees. I have an 8-pole motor with 120 degree spaced hall sensors. I have this set to 60 degrees based off information I found online and I get the most torque at that setting as well. I'm interpreting it as the angle difference between different hall states. I ask the question because the value of ''Placement electrical angle'' can be from 0 to 359 degrees and I'd like to understand when that changes. From my understanding a value other than 60 degrees shouldn't work properly if using 120 degree spaced hall sensors...but that must not be the case hence the option in ST Motor Workbench. Regards, Sagar |
5个回答
虽然数值可以从0到359,但唯一的实际选项是60和120度。对我来说,似乎不太可能在“错误”设置下你的电机运行得更好。
s.ptl.05 2016年3月5日星期六,下午10:10 ST Motor Workbench - 放置电角度 你能描述一下如何设置''Placement electrical angle''。 ST Motor Workbench的默认值为300度。 我有一个8极电机,120度间隔霍尔传感器。根据我在网上找到的信息,我将此设置为60度,并且我在该设置下也获得了最大的扭矩。我把它解释为不同大厅状态之间的角度差异。 我问这个问题是因为''Placement electrical angle''的值可以是0到359度,我想知道什么时候改变了。 根据我的理解,如果使用120度间隔的霍尔传感器,则60度以外的值不应该正常工作......但是,ST Motor Workbench中的选项一定不是这种情况。 问候, 萨加尔 以上来自于谷歌翻译 以下为原文 Although the numerical value can go from 0 to 359, the only real options are 60 and 120 degrees. To me it seems unlikely that your motor runs better with the ''wrong'' setting. s.ptl.05 Saturday, March 05, 2016 10:10 PM ST Motor Workbench - Placement electrical angle Could you describe how to set ''Placement electrical angle''. The default value in ST Motor Workbench is 300 degrees. I have an 8-pole motor with 120 degree spaced hall sensors. I have this set to 60 degrees based off information I found online and I get the most torque at that setting as well. I'm interpreting it as the angle difference between different hall states. I ask the question because the value of ''Placement electrical angle'' can be from 0 to 359 degrees and I'd like to understand when that changes. From my understanding a value other than 60 degrees shouldn't work properly if using 120 degree spaced hall sensors...but that must not be the case hence the option in ST Motor Workbench. Regards, Sagar |
谢谢。是的,我想是的。我正在使用60度。它在UI中很奇怪,默认设置为300。
以上来自于谷歌翻译 以下为原文 Thanks. Yeah I figured so. I'm using 60 degrees. Its just odd in the UI they have the default set to 300. |
再见
我试图澄清“传感器位移”和“放置电角度”之间的含义和区别。 “传感器位移”与传感器之间的角度有关。这通常是60°或120°。这意味着物理上三个传感器在60°或120°的空间中移位,产生不同的信号序列。 60°生成H1下降然后H2下降然后H3下降然后H1上升然后H2上升然后H3上升,依此类推 120°度产生H1下降然后H2上升然后H3下降然后H1上升然后H2下降然后H3上升,依此类推 “放置电角度”定义了三个传感器相对于定子的位移。因为FW需要知道与传感器的每次上升/下降相对应的角度。这不是让我说一个“绝对值”,你可以在电机的数据表中读到,因为你还必须定义一个名称(和每个角度)定子相的约定。所以我们的建议是直接在你的系统中手动计算这个参数(在固件中设置,以便从HALL传感器获得正确的角度测量)(所以在你将电机相连接到逆变器后建立定子的角度系统)。 FW用户手册中介绍了测量此参数的一些细节和步骤。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao I'm trying to clarify the meaning and difference between ''Sensor displacement'' and ''Placement electrical angle''. The ''Sensor displacement'' is related to the angle between sensors. And this is usually 60° or 120°. This mean that physically the three sensors are displaced in the space at 60° or 120° generating different sequences of signals. 60° degree generates H1 Fall then H2 Fall then H3 Fall then H1 Rise then H2 Rise then H3 Rise and so on 120° degree generates H1 Fall then H2 Rise then H3 Fall then H1 Rise then H2 Fall then H3 Rise and so on The ''Placement electrical angle'' defines the displacement of the three sensors respect the stator. Because the FW need to know the angle that corresponds to each rising/falling of the sensors. This is not let's me say an ''absolute value'' that you can read in the data sheet of the motor because you have to define also a convention with the name (and angle of each) stator phases. So our suggestion is to calculate manually this parameter (to be set in the firmware to get the correct angle measurement from the HALL sensors) directly in your system (so after you have connect the motor phases to the inverter establishing the angular system of the stator). Some details and procedure to measure this parameters is explained in the FW user manual. Ciao Gigi |
你好
UM1052第8.3节中有一个错误 我的霍尔传感器放置在电机上60°,但我必须在工作台中选择120°才能使电机旋转。来自我的3个霍尔传感器的信号与UM1052中的120°信号相同。 友好的问候 E.John 以上来自于谷歌翻译 以下为原文 Hello there is a mistake in the UM1052 Section 8.3 My Hall Sensors are placed with 60° on the Motor, but i have to choose 120° in the Workbench to get the motor spinning. The Signals from my 3 Hall sensors are the same signals like 120° in the UM1052. friendly greetings E.John |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1408 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
503浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
561浏览 3评论
479浏览 3评论
GMT+8, 2024-4-20 00:51 , Processed in 0.808304 second(s), Total 72, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
