嗨,我对Nucleo-IHM001评估套件没有太多运气,现在要放下它们,非常令人失望。我有一个STM3240G评估板,似乎得到了ST电机控制工作台的支持。任何人都可以推荐使用STM3240G评估板“已知”的IHM-XXX功率级/驱动器吗?希望“知道”由ST电机控制工作台支持吗?谢谢。
#细胞核 - ihm001-stm3240g 以上来自于谷歌翻译 以下为原文 Hi, I am not having much luck with the Nucleo-IHM001 eval kit(s), for now going to put them down, very dissapointing. I have a STM3240G eval board that appears to be supported by the ST motor control workbench. Can anyone recommend a IHM-XXX power stage/driver that is 'known' to work with STM3240G eval board? And is hopefully 'known' to be supported by the ST motor control workbench? Thanks. #nucleo-ihm001-stm3240g |
4个回答
Ciao Jack
如果您有机会安装最新版本的STM32 MC工作台(即用于配置MC固件的PC工具),您可以查看支持的ST EVAL板。 我指的是“新项目”部分,您可以根据您使用的电路板选择系统。在该部分中,您将找到MC固件(和工作台)支持的所有电源板以及使用电机分析器功能启用的所有电源板。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Jack If you had the chance to install the last version of STM32 MC workbench (that is the PC tools used to configure the MC firmware) you can take a look at the supported ST EVAL board. I'm referring to the ''new project'' section in which you can select the system according to the board that you are using. In that section you will find all the power board that are supported by the MC firmware (and workbench) and also all the power board enabled with the motor profiler feature. Ciao Gigi |
谢谢Gigi,是的,我已经安装了4.2.0(在我的帖子之前),我已经看到了STM324xG-eval的电源下拉菜单中的电源板列表。但是,我认为我们可以同意仅仅是因为下拉菜单中的特定baord并不一定意味着所有这些都是“已知”可行的。
让我直截了当地问一下,如果你面前有一块STM3240G板,你必须快速可靠地进行FOC演示,考虑到你使用这种线路产品的经验 - 你会选择哪一款IHM电源板使用MC工作台开发快速应用程序? 以上来自于谷歌翻译 以下为原文 Thanks Gigi, yes I've already installed 4.2.0 (prior to my post) and I did already see the list of power boards that are there in the power drop down menu for the STM324xG-eval. However, I think we can agree just because a particular baord is in the drop down menu doesn't necessarily mean that all of them are 'known' to work. Let me just bluntly ask, if you had an STM3240G board in front of you, and you had to get a FOC demonstration going quickly and reliably, given your experience with this line products- Which IHM power board would be the first you would select to develop a quick application using the MC workbench? |
Ciao Jack
使用兼容的板(我的意思是WB中列出的板),您可以确定您可以工作。如果您找到一个示例项目,甚至更多,但对于STM324xG-EVAL,我看到只有一个项目的MB459是MC套件的电源板,而且它有点广阔。 如果我必须从使用STM324xG-EVAL评估系统开始,我将使用新一代电源板之一,如ST-EVAL-IPMxx(所有电源板都相似,您可以根据需要选择最终申请的权力)。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Jack With a compatible board (I mean the one listed in the WB) you can be sure that you can work. Even more if you find an example project, but for the STM324xG-EVAL I see that is present only a project with the MB459 that is the power board of the MC Kit, and it is a little bit expansive. If I have to start with the evaluation of the system using the STM324xG-EVAL I'll go with one of the new generation of power boards like the ST-EVAL-IPMxx (all of them are similar and you can simply choose according the required power of your final application). Ciao Gigi |
谢谢Gigi,我也倾向于使用IPM套件。 -插口
以上来自于谷歌翻译 以下为原文 Thank you Gigi, I was leaning towards the IPM kits too. -Jack |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1217 浏览 1 评论
1839 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1499 浏览 1 评论
2727 浏览 6 评论
4955 浏览 21 评论
296浏览 4评论
344浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
263浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
341浏览 3评论
350浏览 3评论
GMT+8, 2024-3-29 20:34 , Processed in 0.739680 second(s), Total 73, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
