客户在其环境中拥有nVidia Licensing服务器(vSphere Enterprise Plus和Horizon 7)。
许可证文件在nVidia企业门户中生成,并且许可证服务器中安装了2个vDWS和2个Virtual PC许可证。 环境没有互联网访问权限,我们手动传输文件。 虚拟桌面与许可证服务器正确通信并获取所有4个许可证。 通常,许可证应在机器关闭或一天后过期时返回到许可证服务器。 在这种情况下,到期是“从不”,许可证永远不会返回。 所有4个许可证都被某些机器消耗,这些机器不再存在且无法重复使用。 在许可证服务器“许可客户端 - >客户端详细信息”中,它们被分配给计算机的mac地址,并且无法删除此分配,并且到期时间为“从不”。 他们拥有NVIDIA网站的最新版本: 驱动程序:NVIDIA-GRID-vSphere-6.0-390.42-391.03.zip 许可证管理器:NVIDIA-ls-windows-5.1.0-2017.11-0001 以上来自于谷歌翻译 以下为原文 Customer has nVidia Licensing server in his environment (vSphere Enterprise Plus and Horizon 7). License file was generated at the nVidia Enterprise Portal and 2 vDWS and 2 Virtual PC licenses were installed into the license server. Environment has no internet access and we transferred the file manually. Virtual Desktops communicate with the license server correctly and took all the 4 licenses. Normally licenses should be returned to the license server when the machine is turned off or expire after one day. In this situation expiry is “never” and licenses are never returned. All of the 4 licenses are consumed by some machines which no longer exist and cannot be reused. In the license server “Licensed Clients -> Client Details” they’re assigned to mac addresses of the machines and there is no way to delete this assignment and expiry is “never”. They have the latest versions from NVIDIA site: Drivers: NVIDIA-GRID-vSphere-6.0-390.42-391.03.zip License manager: NVIDIA-ls-windows-5.1.0-2017.11-0001 |
1个回答
嗨托马斯,
您可以删除许可证服务器的受信任存储区以释放所有许可证。 之后,您需要从门户网站重新颁发新的许可证文件,因为该文件仅在24小时内有效。 使用此过程删除受信任存储: http://nvidia.custhelp.com/app/answers/detail/a_id/4111/~/grid-license-server-fails-to-start-due-to-ip-address-change 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Tomasz, you can delete the trusted store of the license server to free up all licenses. Afterwards you need to reissue a new license file from the portal as the file is only valid for 24h. Use this procedure to delete the trusted store: http://nvidia.custhelp.com/app/answers/detail/a_id/4111/~/grid-license-server-fails-to-start-due-to-ip-address-change Regards Simon |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2832 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3225 浏览 4 评论
GMT+8, 2024-4-25 12:41 , Processed in 0.577707 second(s), Total 43, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
