你好
我本周交付了两台m60,想要检查gpu模式,所以在esxi 6.5中运行了下面的命令 lspci -n | grep 10de 什么也没有回来 这是新驱动程序的错误吗? 所有其他命令re nvidia返回信息 或者我做错了什么? NVIDIA-VMware_ESXi_6.5_Host_Driver_367.106-1OEM.650.0.0.4598673 在这个例子中,我不得不安装gpumodeswitch只是为了找出他们以图形模式运送这是我以后的lol 谢谢 以上来自于谷歌翻译 以下为原文 Hi I got two m60's delivered this week and wanted to check the gpu mode so ran the command below in esxi 6.5 lspci –n | grep 10de which returned nothing is this a bug with the new drivers ? all other commands re nvidia returned info or am i doing something wrong ? NVIDIA-VMware_ESXi_6.5_Host_Driver_367.106-1OEM.650.0.0.4598673 in this instance i had to install gpumodeswitch just to find out they shipped in graphics mode which was what i was after lol Thanks |
1个回答
None
以上来自于谷歌翻译 以下为原文 Hi Shaun, why should this be an issue with the NV drivers? lspci is a linux command and has nothing to do with NV drivers. BTW it works fine for me with ESX 6.5. And for sure this command makes no difference if you installed vGPU manager or not. In addition all Tesla M60s delivered since end of 2016 are already in Graphics mode. There are also other ways to check if the board is in Graphics mode: https://virtuallyvisual.wordpress.com/2016/04/19/nvidia-m60-m6-problems-check-your-card-in-graphics-mode/ And here the documentation that states that the M60 should already be in Graphics mode: http://images.nvidia.com/content/pdf/grid/guides/GRID-Quick-Start-Guide-August-2016.pdf *snip* NVIDIA Tesla M10 ships and support graphics mode only. NVIDIA Tesla M60 ships in graphics mode but supports both graphics and compute modes. *snip* Hope this helps to clarify regards Simon |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2831 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3225 浏览 4 评论
GMT+8, 2024-4-23 19:31 , Processed in 0.564722 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
