我为我不断增长的系列增加了一个新仪表,但我无法在网上找到有关Extech版本及其手册的任何信息。
我找到的只是里德的版本,没有解释如何使用瓦特功能。 这就是为什么我得到这个,因为我的简单工匠做了我需要的所有东西,但我想要瓦特。 我可以测量伏特,安培但不是瓦特。 我弄不清楚怎么样! 如果有人有任何想法,我很乐意听到他们,所以我可以把它变成一个更有用的设备。 我打算尝试负载位置的负载和电源位置的交流电源,但后来记得我今天不觉得火在我手里。 在此先感谢您的帮助!编辑:Kawooa于2015年3月20日下午8:04 以上来自于谷歌翻译 以下为原文 I got a new meter for my growing collection but I can't find online anything about the Extech version and its manual. All I find is the Reed's version which doesn't explain how to use the watts function. That is why I got this as my simple craftsman does all I need but I wanted watts. I can measure volts, amps but not watts. I can't figure out how! If anyone has any ideas I would love to hear them I so I can turn this into a much more useful device. I was going to try the load in the load position and the ac power in the power source position but then remembered I don't feel like fire in my hand today. Thanks in advance for any help! Edited by: Kawooa on Mar 20, 2015 8:04 PM 附件
2个回答
我几乎忘记了,但我不认为在下周日外出度假时我将能够尝试任何事情。
非常需要! 以上来自于谷歌翻译 以下为原文 I almost forgot but I don't think I will be able to try anything until next Sunday as I am going out for vacation. Much needed! |
我终于弄明白了。
我必须将标有电源的两个端子直接连接到插座(一个中性,另一个热)。 然后,我将另外两根导线连接到负载端子并打开仪表。 然后我将仪表电源连接到插座,最后打开负载。 我在网上发现电源端子有一个10兆欧姆的电阻器,因为仪表中没有保险丝,所以可以防止火灾。 我经过多次搜索后在网上找到了一本手册,而在中文中它有一张小图片,显示如何设置瓦特测量。 http://www.sunwe.com.tw/lutron/DW-6060op.pdf其他拥有Reed,Lutron或Extech版本的人现在可以了解如何使用它。 花了很长时间才能找到一张简单的图像来正确解释它。 以上来自于谷歌翻译 以下为原文 I finally figured it out. I have to connect the two terminals labeled power source directly to the outlet (one neutral the other hot). I then connect the load by two more leads to the load terminals and have my meter turned on. I then connect the meter power source to the outlet and finally turn the load on. I found online the power source terminals have a 10meg ohm resistor which will prevent fire since there is no fuse in the meter. I found a manual online after much searching which while in Chinese it has a small picture showing how to set it up for watts measurement. http://www.sunwe.com.tw/lutron/DW-6060op.pdf Anyone else with the Reed's, Lutron or Extech versions can now understand how to use it. Took a long time for one simple image to explain it properly. |
只有小组成员才能发言,加入小组>>
2099 浏览 1 评论
1854 浏览 1 评论
1714 浏览 5 评论
2581 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1560 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2258浏览 0评论
GMT+8, 2024-4-25 10:01 , Processed in 0.980726 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
