本人刚学STM32,想用stm32输出可调的PFM波,通过一个可调电阻来调节PFM波,但ADC不起作用,无论怎么调都还是输出300KHz的PFM波,即ADC为0,下面是程序,请大侠们指教。
int main(void) { u32 ad1=0; u32 ad2=0; RCC_Configuration(); GPIO_Configuration(); ADC_Configuration(); Tim1_Configuration(); while(1) { ad1=ADC_GetConversionValue(ADC1); ad2=ad1*3.3/4095; if(ad2>3) { TIM_SetAutoreload(TIM1,119); TIM_SetCompare1(TIM1,60); //设定占空比 } if((ad2>=2.5)&&(ad2<=3)) { TIM_SetAutoreload(TIM1,99); TIM_SetCompare1(TIM1,50); //设定占空比 } if((ad2>=2)&&(ad2<=2.5)) { TIM_SetAutoreload(TIM1,79); TIM_SetCompare1(TIM1,40); //设定占空比 } if((ad2>=1.5)&&(ad2<=2)) { TIM_SetAutoreload(TIM1,59); TIM_SetCompare1(TIM1,30); //设定占空比 } if(ad2<1.5) { TIM_SetAutoreload(TIM1,39); TIM_SetCompare1(TIM1,20); //设定占空比 } } } void GPIO_Configuration(void) //端口初始程序,可初始化多组管脚,串口要用到PA9、10做输入输出 { /*输出管脚初始化*/ GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; // GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; /*初始化相应的GPIO*/ GPIO_Init(GPIOA, &GPIO_InitStructure); // 输入管脚初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 初始化相应的GPIO GPIO_Init(GPIOB, &GPIO_InitStructure); //ADC输入 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 ; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOC, &GPIO_InitStructure); } void RCC_Configuration(void) //时钟初始程序 { SystemInit(); //系统时钟频率72MHz /*打开GPIOX使用的GPIO的时钟使能*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); RCC_ADCCLKConfig(RCC_PCLK2_Div6);//6分频为12M} void Tim1_Configuration(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; TIM_BDTRInitTypeDef TIM_BDTRInitStructure; //第三步,定时器基本配置 TIM_TimeBaseStructure.TIM_Period=150-1; // 自动重装载寄存器的值 TIM_TimeBaseStructure.TIM_Prescaler=6-1; // 时钟预分频数 TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1; // 采样分频 TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;//向上计数 TIM_TimeBaseStructure.TIM_RepetitionCounter=0;//重复寄存器,用于自动更新pwm占空比 TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //第四步pwm输出配置 TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2; //设置为pwm1输出模式 TIM_OCInitStructure.TIM_Pulse=75; TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High; //设置输出极性 TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable; //使能该通道输出 //下面几个参数是高级定时器才会用到,通用定时器不用配置 TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_High; //设置互补端输出极性 TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;//使能互补端输出 TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Reset; //死区后输出状态 TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset;//死区后互补端输出状态 TIM_OC1Init(TIM1,&TIM_OCInitStructure); //按照指定参数初始化 //第五步,死区和刹车功能配置,高级定时器才有的,通用定时器不用配置 TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Disable;//运行模式下输出选择 TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Disable;//空闲模式下输出选择 TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF; //锁定设置 TIM_BDTRInitStructure.TIM_DeadTime = 42; //死区时间设置 TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable; //刹车功能使能 TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_Low;//刹车输入极性 TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;//自动输出使能 TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure); //第六步,使能端的打开 TIM_Cmd(TIM1,ENABLE); //打开TIM2 TIM_CtrlPWMOutputs(TIM1, ENABLE); //pwm输出使能,一定要记得打开} void ADC_Configuration(void) //配置数模转换 { ADC_InitTypeDef ADC_InitStructure; ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; ADC_InitStructure.ADC_ScanConvMode = DISABLE;//多通道扫描模式 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//循环采样 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//转换由软件而不是外部触发启动 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 1; //转换通道数量 ADC_Init(ADC1, &ADC_InitStructure); //定义规则组 ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_239Cycles5); ADC_Cmd(ADC1, ENABLE);//ADC使能 ADC_ResetCalibration(ADC1); //ADC复位 while(ADC_GetResetCalibrationStatus(ADC1)); ADC_StartCalibration(ADC1); //ADC校准 while(ADC_GetCalibrationStatus(ADC1)); ADC_SoftwareStartConvCmd(ADC1, ENABLE);//启动ADC} |
10个回答
输出不是DAC么,ADC是输入的呀。。
太长了,顶一下吧。。。
是用ADC输入,我用一个可调电阻个给相应的引脚输入电压信号来控制PFM,但无论怎么调都没有反应。 |
你好,想请教一下,用什么方法来调试ADC采集结果,我程序中是什么地方出现问题,由于刚接触STM32有很多不懂得地方,恳请大家指教!!! |
用串口啊
PFM波是什么
要先设置AD采集通道、开启AD时钟、通过单独或者连续采集的方法,采集到数据放入到一个缓冲区中,达到缓冲区满以后,输出AD数据,并清空缓冲区重新开始采集。
支持学习
学习一下!
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1285 浏览 1 评论
1019 浏览 1 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
640 浏览 0 评论
自定义系统时钟频率后,用库函数和微带两种方式点亮LED灯,为什么灯的闪烁频率不一致?
1571 浏览 2 评论
1797 浏览 2 评论
GMT+8, 2024-4-24 23:25 , Processed in 0.625720 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
