亲爱的社区,
我一直与ADC D-S的PSoC5LP没有成功地放大2个divand信号与5MVPP最大。我读过不同的文件,对此我感到很困惑。 在ADC Delta Sigma 3.30参考文献的第9页中,输入±VREF与VREF=1.024V的范围应该是:- 1.024±1.024=0V至2.048。为什么在相同条件下的CE95171上,在ADC的负引脚上VREF=1.024,在第2页中,如果ADC的正输入为0,转换值为-1.024或如果为1.024,则值为0;因此,ADC Delta Sigma 3.30的页9建立的范围不从0V到2.048。然后,工作范围可以支持直到2.048 V作为一个有效的值来工作吗????2.048?gt;1.024V?或者我甚至可以输入3V信号根本没有问题?VDD=5V? 这是非常混乱的,请您提供任何帮助,我会非常感激,谢谢。 以上来自于百度翻译 以下为原文 Dear community, I have been working with ADC D-S of psoc5lp with no success to amplify 2 diferential signals with 5mVpp as maximum. I have read different documents and I'm very confused about this. In page 9 of reference document of ADC Delta-Sigma 3.30 the range with Input ± Vref with Vref=1.024V should be: -1.024±1.024= 0V to 2.048. Why in example of CE95271 with the same condition Vref=1.024 on negative pin of ADC, in page 2 says that if positive enter of ADC is 0 the converted value is -1.024 or if is 1.024 the value is 0; so the range doesn't go from 0V to 2.048 as page 9 of ADC Delta-Sigma 3.30 established? then the range to work can support until 2.048 V as a valid value to work???? 2.048 -> 1.024V? Or can I even enter 3V signal with no problem at all? with VDD=5V? This is very confused, please any help you can provide me will be very appreciated, thanks in advance. |
12个回答
你好,奥玛尔
该范围可以达到2.048(2.044,Vdac max 1.020 + 1.024)。目前VDAC电压为1V,因此最大值为2.024V。但它是一个可用的范围。输入电压范围为0~2.024V。 最佳问候 以上来自于百度翻译 以下为原文 Hello Omar The range can go upto 2.048( 2.044,Vdac max 1.020+1.024). Currently Vdac voltage is 1V. So the maximum value will be 2.024V. The description does not specify about that range. But it is a usable range. Input voltage range is 0-2.024V. Best Regards, VSRS |
EnjoyL 发表于 2018-9-20 07:00 谢谢Vsrs, 在这些条件下,具有VREF=1.024的ADC和ADC输入=1.024 ADC SIGMA-Dela将这样工作: 0的ADC +转换将被签署为-0.1024V 在ADC + 1.024的转换将签署到0 这里有一个困惑:如果我进入ADC+2.048 V,我能期待+1.024V的签名结果吗???????或者这超出范围???? 如果在ADC+输入中输入4V会发生什么?ADC转换值将达到8000位的十六进制值,分辨率为16位? 请帮帮我,我很困惑。提前感谢。 以上来自于百度翻译 以下为原文 Thanks Vsrs, With these conditions, ADC with VREF=1.024 and ADC- input=1.024 ADC SIGMA-DELTA will work like this: With 0 at ADC+ conversion will be signed to -0.1024V with 1.024 at ADC+ conversion will be signed to 0 And here is the confusion: if I enter at ADC+ = 2.048V , Can I expect signed result of +1.024V????? or is this out of range??? What happen if I enter 4V at ADC+ input? ADC conversion value will goes to hexadecimal value of 8000 with 16 bits of resolution? Please help me I'm very confused. Thanks in advance. |
EnjoyL 发表于 2018-9-20 07:00 你好,Vsrs, 因此,差分模式和VREF= 1.024V,但在0的ADC输入中,范围将是0±1.024,那么-----和-1.024到1.024,然后: 用ADC+输入0的结果转换为0? 用ADC+输入1.024的结果转换为1.024? 那么如何获得- 1024值转换????这是什么条件?一个负值????? 谢谢。 以上来自于百度翻译 以下为原文 Hi Again Vsrs, So with differential mode and Vref=1.024V but with ADC- input in 0 the range will be 0±1.024 so-----> -1.024 to 1.024 then: with ADC+ input in 0 result conversion will be 0? with ADC+ input in 1.024 result conversion will be 1.024? Then how to get -.1024 value conversion???? what condition produce this? a negative value???? Thanks. |
wufengju 发表于 2018-9-20 07:28 以上来自于百度翻译 以下为原文 |
非常感谢您的回应,您的示意图是非常说明性的。 但是如果VREF=1.024V,ADC -输入在0范围内将是0±1.024,那么----gt;-1.024到1.024,然后: 用ADC+输入0的结果转换为0? 用ADC+输入1.024的结果转换为1.024? 那么如何获得- 1024值转换????这是什么条件?一个负值????? 谢谢。 以上来自于百度翻译 以下为原文 Many thanks for your response, your schematic was very illustrative. But what happen if Vref=1.024V with ADC- input in 0 the range will be 0±1.024 so-----> -1.024 to 1.024 then: with ADC+ input in 0 result conversion will be 0? with ADC+ input in 1.024 result conversion will be 1.024? Then how to get -.1024 value conversion???? what condition produce this? a negative value???? Thanks. |
wufengju 发表于 2018-9-20 08:02 触摸一次比看100次好) 负电压 471.8 K 以上来自于百度翻译 以下为原文 It is better to touch once than see 100 times)))
谢谢Evgeniy,考虑这个问题解决了。 以上来自于百度翻译 以下为原文 Thanks Evgeniy, consider this question solved. |
嘿,Evgeniy, 对不起我的愚蠢问题,但是你的原理图中的“RunMeID”组件是什么? 这是过滤器还是塑料桶? 你能为我做一个简短的解释吗? 谢谢Harry 来自维也纳的问候 以上来自于百度翻译 以下为原文 Hey Evgeniy, sorry my stupid question, but what is the "RunMean" component in your schematic. Is this a filter or funktion? can you PLEASE make a short explaination for me as super noob here... thanks Harry greetings from Vienna |
这个简单的移动平均值。 双击组件:设置RangeOffy过滤器 OFF滤波器-确定缓冲器大小为2的功率(n=2 ^ RangeOffy滤波器) 功能: It32 RunMeMyGET(IT32 SAMPL,IT32信号Salm斜率); Sampl -新数据 SurvialyReal-过滤器重新初始化阈值(SealAlpRealSt==0)强制重新初始化 我很高兴记得维也纳——一个非常美丽的城市。 拉链 416.4 K 以上来自于百度翻译 以下为原文 thisSimple moving average. double click on the component: set Range_of_Filter Range_of_Filter -determines the buffer size as a power of 2 (n = 2^Range_of_Filter) function: int32 RunMean_Get(int32 Sampl,int32 SIGNAL_SLOPE); Sampl - new data SIGNAL_SLOPE - filter re-initialization threshold ( SIGNAL_SLOPE==0 - forced reinitialization ) p.s. I am pleased to remember Vienna - a very beautiful city.
chenzhenbo1984 发表于 2018-9-20 08:47 谢谢Evgeniy, 我有点收费过高…但是我会通过… 我的意思是,你如何创建组件“RunMead”,用什么样的组件……如果我想像你这样做? 谢谢Harry 以上来自于百度翻译 以下为原文 thanks Evgeniy, I ´m a little bit overcharged .... , but I will go through.... I meant, how you create the component "RunMean", with what kind of component or so...if I want to do so like you? thanks Harry |
你在问一个组件的创建吗? 像这里:创建新组件 以上来自于百度翻译 以下为原文 you are asking about the creation of a component? like here: Creating New component |
天啊。。。 重型的 以上来自于百度翻译 以下为原文 omg... heavy duty |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-23 17:27 , Processed in 0.691235 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
