嗨,
我最近购买了一台带2特斯拉M60的SuperMicro服务器。 我可以设置一切但是一旦我开始午餐VDI的4GB或8GB我总是在许可证服务器中得到相同的错误: 02:47:54,478 INFO更新的功能Quadro-Virtual-DWS 5.0计数= 64 02:47:54,479 INFO在许可证更新中收到一个有效功能 02:48:13,939警告无法处理功能请求GRID-Virtual-Apps 3.0 count = 1。 原因:FEATURE_NOT_AVAILABLE。 据我所知,许可证服务器已启动并运行但不知何故我无法使用此配置文件,如果我关闭VDI并更改配置文件将授予许可证,否则这些配置文件没有许可证。 除M60-4Q,M60-8Q,M6-4Q,M6-8Q型材外,每个型材都能正常工作。 你可以帮我吗 ? 我将在短时间内购买许可证,但我必须了解我将使用哪种许可证,我只会在测试每个配置文件后知道。 提前致谢 PS:我有一些紧迫性,因为这个原因我需要关闭明年的预算,这将在Q1购买,colume将不低于500 ccusers 以上来自于谷歌翻译 以下为原文 Hi, i acquired recently a SuperMicro server with 2 Tesla M60. i could set up everything but once i started lunch VDI´s with 4GB or 8GB i always get the same error in the license server: 02:47:54,478 INFO Updated feature Quadro-Virtual-DWS 5.0 count=64 02:47:54,479 INFO Received one valid feature in license update 02:48:13,939 WARN Unable to handle request for feature GRID-Virtual-Apps 3.0 count=1. Reason: FEATURE_NOT_AVAILABLE. as i understand, that the license server is up and running but somehow i could not use this profiles, if i shutdown the VDI and change the profile the license will be granted, otherwise no license for those profiles. Every profile except M60-4Q, M60-8Q, M6-4Q, M6-8Q profiles works wonderfully. Can you help me ? i will purchase the licenses in a short time, but i have to understand what kind of licenses i will use and i only will know after testing every profile. thanks in advance PS: i have some urgency in this cause i need to close my budget for the next year, this will be purchased in Q1, the colume will be no less than 500 ccusers |
7个回答
你好
您可以从此处获取完整的功能评估许可证: http://www.nvidia.com/object/grid-evaluation.html#utm_source=shorturl&utm_medium=referrer&utm_campaign=grid-eval 单击“软件下载”按钮,转到注册页面。 使用这些许可证确定您要使用的vGPU配置文件,然后在测试完成后购买正确的许可证。 问候 以上来自于谷歌翻译 以下为原文 Hi You can obtain full feature evaluation licenses from here: http://www.nvidia.com/object/grid-evaluation.html#utm_source=shorturl&utm_medium=referrer&utm_campaign=grid-eval Click on the "Software Download" button to take you to the registration page. Use these licenses to determine which vGPU profiles you'd like to use then purchase the correct licenses once testing is complete. Regards |
嗨BJones,
谢谢你的重播。 我已经使用了eavluation许可证,我在那里做了每一步,如下所示: 功能版本计数可用到期时间 Quadro-Virtual-DWS 5.0 64 63 2018-01-01 但是我无法分配任何M60-4Q,M60-8Q,M6-4Q,M6-8Q配置文件,我读到的是为了拥有这个配置文件你必须运行3.0版本的somtheing(它不清楚) 症状/错误 当使用M60 / M6 GRID卡的4Q,8Q或Passthrough配置文件时,NVIDIA GRID驱动程序无法从许可证服务器签出许可证。 例如。 M60-4Q,M60-8Q,M6-4Q,M6-8Q型材。 原因 3.0代码发布之前的驱动程序需要4GB或更高版本的vWorkstation扩展许可证。 自2016年3月起,NVIDIA因许可变更而停止发运扩展许可。 如果客户/合作伙伴正在部署2016年3月之后获得的许可证,则他们将要求3.0或更高版本的驱动程序包使用大于2GB的配置文件。 解析度 更新到3.0驱动程序包或更高版本。 有关查找驱动程序的建议,请参见:http://nvidia.custhelp.com/app/answers/detail/a_id/4120 我有什么捆绑,我可以检查它? Quadro-Virtual-DWS 5.0版是否足够好用? 提前致谢 来源http://nvidia.custhelp.com/app/answers/detail/a_id/4136/~/nvidia-grid-driver-is-unable-to-check-out-a-license-from-the-license-server 以上来自于谷歌翻译 以下为原文 Hi BJones, thanks for the replay. i am already using the eavluation license and i did every single step there, as you can see below: Feature Version Count Available Expiry Quadro-Virtual-DWS 5.0 64 63 2018-01-01 but i cant assign any of M60-4Q, M60-8Q, M6-4Q, M6-8Q profiles, what i read is that in order to have this profiles you have to run the 3.0 versionof somtheing (it was not clear) Symptom/Error NVIDIA GRID driver is unable to check out a license from the license server when using 4Q, 8Q or Passthrough profiles for the M60/M6 GRID cards. E.g. M60-4Q, M60-8Q, M6-4Q, M6-8Q profiles. Cause Drivers prior to the 3.0 code release required a vWorkstation Extended license for 4GB or greater profiles. Since March 2016 NVIDIA ceased to ship the Extended license as a result of the changes in licensing. If customers / partners are deploying licenses acquired after March 2016 they will require the 3.0 or later driver bundle to use profiles larger than 2GB. Resolution Update to 3.0 driver bundle or later. Advice on finding the drivers is detailed here: http://nvidia.custhelp.com/app/answers/detail/a_id/4120 what bundle do i have and where i can check it ? is the Quadro-Virtual-DWS version 5.0 good enough for that ? thanks in advance source http://nvidia.custhelp.com/app/answers/detail/a_id/4136/~/nvidia-grid-driver-is-unable-to-check-out-a-license-from-the-license-server |
您需要的一切都可以在上面的软件门户中找到。
确保已升级GRID许可证服务器并安装了最新的许可证。 然后确保您的Hypervisors和VM正在运行最新的GRID 5软件 这里的所有都是它的。 问候 以上来自于谷歌翻译 以下为原文 Everything you need is available in the software portal above. Make sure you've upgraded your GRID license server and installed the latest licenses which it looks like you have. Then make sure your Hypervisors and VMs are running the latest GRID 5 software That's all there is to it. Regards |
您是否能够验证下载的GRID软件?
... 以上来自于谷歌翻译 以下为原文 Are you able to validate which GRID software you downloaded? ... |
说过,
如果您使用的是ESXi,请检查GPU合并是否设置为true。 ESXi主机设置 将其放在/ etc / vmware / config文件中。 (在文件底部添加此行) vGPU.consolidation = true 或者,如果您运行的是6.5,则可以使用Web界面在vCenter中进行设置。 有一个同类的vGPU规则。 需要应用此设置。 我还会检查您附加到父图像的vGPU配置文件。 另外,你在哪里? 以上来自于谷歌翻译 以下为原文 Said, If you are using ESXi then please check to see if the GPU consolidation is set to true. ESXi host setting Place this in the /etc/vmware/config file. (Add this line at the bottom of the file) vGPU.consolidation = true Or if you are running 6.5 you can set this within vCenter using the web interface. There's a homogeneous vGPU rule. This setting needs to be applied. I would also check the vGPU profile you have attached to the parent image. Also, where are you located? |
如果不知道您使用的是哪种GRID驱动程序,则无法提供进一步的帮助。
在运行需要GRID5.x驱动程序的最新试用密钥时,您将无法使用GRID4.x驱动程序获取许可证。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Without knowing which GRID driver you are using there is no further help possible. You won't be able to aquire a license with GRID4.x driver when running the latest trial key which expects a GRID5.x driver. regards Simon |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2818 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3212 浏览 4 评论
2238浏览 0评论
GMT+8, 2024-3-29 17:07 , Processed in 0.962267 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
