我只是发现在频率段内设置IF BW的错误。
当您以10 Hz手动键入类型时,系统有时会不接受并将其更改为7 Hz。 键入7 Hz时,它会将其更改为5Hz,依此类推。 当我们使用我们的测试程序时,这更加明显。 程序切换IFKW在1 KHz到10 Hz之间,用于连续测量。 系统不接受10Hz(无消息错误)并设置7Hz。在下一个周期,它将其改为5Hz,然后改为3,2和1Hz。 之后它变为15MHz并保持在那里。 PNA-X N5242A是在CPU升级之后推出的,它配备了FW A10.48.03,我们注意到了这个bug。 我们决定升级到最新的固件(A10.49.03),但看起来它仍然存在。 我还检查了具有FW A10.40.12&的其他PNA-X N5244A N5224A。 分别为F10 A10.40.14。 同样的问题。 是德科技的某个人可以检查一下。 问候。 以上来自于谷歌翻译 以下为原文 I just find bug in setting IF BW inside frequency segments. When you manually type type in 10 Hz the system some time not accept that and change that to 7 Hz. When you type 7 Hz it will change that to 5Hz and so on. That was even more pronounced when we use our test program. The program switching IFBW between 1 KHz to 10 Hz for successive measurement. The system did not accept 10Hz (no message error) and set 7Hz.In next cycle it change that to 5Hz, then to 3, 2 and 1Hz. After that it change to 15MHz and it stay in there. The PNA-X N5242A come after CPU upgrade and it come with FW A10.48.03 and we notice the bug. We decide to upgrade to latest firmware (A10.49.03), however it look that the bug is still in there. I also check other PNA-X N5244A N5224A that have FW A10.40.12 & FW A10.40.14 respectively. Same problem. Can somebody from Keysight check that. Regards. 附件
2个回答
嗨Mirek,看起来在UI和SCPI中设置段IF BW都存在错误。
我正在我们的缺陷跟踪系统中输入它。 在UI上,如果您单击IFBW输入字段然后使用键盘上的向上/向下箭头或编辑控件中的按钮,则可以看到所有允许的带宽设置。 以上来自于谷歌翻译 以下为原文 Hi Mirek, Looks like there is a bug in setting the segment IF BW both in the UI and from SCPI. I am entering it in our defect tracking system. On the UI, it appears that if you click in the IFBW entry field and then use the up/down arrows on the keyboard or the buttons in the edit control, then you can get to all the allowed bandwidth settings. |
Topcbpcba 发表于 2018-9-19 06:31 嗨Mirek,我有这个问题的最新消息。 我们找到并修复了缺陷。 该修复程序位于下一个A候选发布版(A.10.49.04)中。 A版本中还有许多其他更新,目前正在进行内部质量保证。 我们期待在月底公开发布。 如果您想自己测试测试版,请给我发一个PM,然后我会给您发送下载链接。 以上来自于谷歌翻译 以下为原文 Hi Mirek, I have an update on this issue. We have found and fixed the defect. the fix is in the next A release candidate (A.10.49.04). that A release has a number of other updates in it and it is undergoing internal QA at the moment. We are anticipating a public release at the end of the month. If you want to test a beta version yourself, send me a PM and I'll send you a download link. |
只有小组成员才能发言,加入小组>>
2096 浏览 1 评论
1854 浏览 1 评论
1712 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 13:54 , Processed in 1.282573 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
