我正在远程协助另一家工厂的技术人员解决他与ECal模块和网络分析仪有关的问题。
详情是E8364B和N4693A ECal模块。 我想知道以前是否有人见过这个问题。 他对这个问题的描述如下:“我对我们的2.4毫米50 GHz Ecal模块有疑问。它有一个问题,分析仪在插入时并不总能识别设备。它曾经是你应该拥有的地方 在分析仪识别它之前将它拔掉几次,但最近它已经达到了这样的程度,你必须花15-20分钟插拔才能识别它。它接收电源和窗户发出噪音表明 USB设备已插入,但网络分析软件无法识别。您以前是否经历过这样的事情,您有什么建议吗?“ 如果有人有任何关于问题可能会有什么好处的建议。 我没有一次又一次地观察到这个问题,我现在不在现场观察它。 谢谢你,兰迪 以上来自于谷歌翻译 以下为原文 I'm remotely assisting a technician at another facility with an issue he is having with an ECal module and Network Analyzer. The particulars are an E8364B and N4693A ECal module. I'm wondering if anyone has seen this problem before. His description of the problem is as follows: "I have a question regarding our 2.4 mm 50 GHz Ecal module. It has an issue where the analyzer does not always recognize the device when it is plugged in. It used to be where you would have to unplug it a handful of times before the analyzer would recognize it, but recently it has gotten to the point that you have to spend 15-20 minutes plugging and unplugging before it is recognized. It receives power and windows makes the noise indicating that a USB device is plugged in, but the network analyzer software does not recognize it. Have you experienced anything like this before, and do you have any suggestions?" If anyone has any suggestions as to what the problem may be that would be great. I have not observed this problem before and again, I'm not onsite with him to observe it now. Thank you, Randy |
8个回答
只是一个想法。
周围有很多不良的USB线。 鉴于ECal模块中有加热器,我认为电流消耗非常高。 廉价电缆上的电压降可能太大。 我的尼康D3相机对它的USB导线很挑剔。 我没有为是德科技工作,也没有E8364B Dave.Edited:drkirkby于2015年4月30日上午7:43 以上来自于谷歌翻译 以下为原文 Just a thought. There are *lots* of poor USB cables around. Given the ECal modules have a heater in them, I assume that the current consumption is quite high. The voltage drop across a cheap cable could be too much. My Nikon D3 camera is fussy about what USB lead it has. I don't work for Keysight, neither do I have a E8364B Dave. Edited by: drkirkby on Apr 30, 2015 7:43 AM |
RMAX我在Agilent Cpu上的USB连接器上看到了很多污垢。
我还在CPU板上看到了一些破损的USB连接器。 但主要的情况是安捷伦CPU上的USB连接器磨损。 您可以从Mouser或Newark订购替换USB连接器并进行安装。 如果您不方便拆卸您的设备,请让维修实验室或校准实验室为您完成。 我建议在设备进行校准时完成这项工作,更换它们的成本应该在150.00到500.00左右,具体取决于设备上的USB连接器数量。 每个CPU组件都有不同数量的USB连接器。 您的设备的500MHZ CPU在CPU上有1个,在后背板上有4个,在前面有一个。 1.1Ghz在CPU上有4个,后面背面没有,前面有1个。 但你得到我的漂移。 所以要全部更换它们并确信它们是新的并且不会磨损。 对于昂贵单位的小额投资。 只是一个建议。 以上来自于谷歌翻译 以下为原文 RMAX I have seen a lot of dirt on the USB connectors on the Agilent Cpu's . I have also seen a few broken USB connectors on the CPU board. But the main case is just wear and tear on the USB connector on the Agilent CPU . You can order replacement USB connectors from Mouser or Newark and install them. If your not comfortable disassembling your unit let a repair lab and or cal lab do it for you. I would suggest getting this done while the unit is scheduled for calibration and replacing them should cost around 150.00 to 500.00 depending on how many USB connectors are on the unit . Each CPU assembly has a different number of USB connectors . 500MHZ CPU for your unit has 1 on the CPU and 4 on the rear back plane and one in the front . The 1.1Ghz has 4 on the CPU and none on the rear back plane and 1 in front. But you get my drift . So replace them all and get the confidence that they are new and not worn out . A small investment for a pricey unit . Just a suggestion . |
如果他们使用前面板和后面板USB有什么区别吗?
他有没有尝试更换USB线? 我以前见过不好的USB线(休息一下,它变得非常间歇)。 以上来自于谷歌翻译 以下为原文 Is there any difference if they use front vs. rear panel USB? Has he tried changing USB cables? I have seen bad USB cables before (get a break and it becomes quite intermittant). |
嗨,感谢大家到目前为止的建议。
我在这个时候从最终用户那里获得的唯一反馈是他在联系我之前尝试了各种电缆,事实证明这不是问题所在。 我已转发其他建议,正在等待更多反馈,尤其是关于后置USB端口是否会导致类似问题的问题。 再次感谢您的帮助到目前为止,我将继续发布这个问题,希望通过这个问题的成功结束。 再次感谢Randy Lenox 以上来自于谷歌翻译 以下为原文 Hi, Thanks to all of you for your suggestions thus far. The only feedback I've gotten from the end user at this time is that he did try various cables before contacting me which proved to not be the problem. I've forwarded the other suggestions along and am awaiting more feedback especially on the question regarding whether or not the rear USB ports resulted in a similar problem. Thanks again for the help so far and I'll continue to post to this thread hopefully through a successful conclusion to this issue. Thanks again, Randy Lenox |
大家好,我决定联系最终用户,发现他已经尝试了大部分建议,甚至更进一步,在几个不同的PNA上尝试Ecal模块。
他报告的结果与其他PNA的结果相同,显示了此特定Ecal模块的相同类型的行为。 此外,PNA没有显示与其他Ecal模块相同的行为,只是这里讨论的那个。 因此,我认为我的原始帖子有点误导,因为假设现在似乎Ecal是罪魁祸首,PNA可能在某种程度上有错误。 在这种情况下,我们仍然不确定原因是什么,并且可能会将模块发送到Keysight以便查看。 再次感谢,兰迪 以上来自于谷歌翻译 以下为原文 Hi All again, I decided to contact the end user and found that he has tried the majority of suggestions here, even going a step further and trying that Ecal module on several different PNA's. He reports the results are the same with the other PNA's showing the same type of behavior for this specific Ecal Module. Additionally the PNA's do not show that same behavior with other Ecal modules, just the one in question here. So I think my original post was a little misleading in that an assumption was made the PNA may have in some way been faulty when now it seems the Ecal is the culprit. We are still not sure what the cause is in this case and will probably send the module in to Keysight for a look. Thanks again, Randy |
quanmeng86 发表于 2018-9-18 16:32 我没有看到两件事。 他等了五分钟让ECAL热身了吗? READY灯亮了吗? 我不认为ECAL会在预热之前出现在PNA上。 2.他是否在PNA上选择了正确的连接器类型。 ECAL仅显示其连接器是否已选中。 他说,经过17次插拔ECAL之后,终于出现了,所以这可能没问题。 以上来自于谷歌翻译 以下为原文 Two things I didn't see asked. 1. Did he wait the five minutes for the ECAL to warm up? Did the READY light come on? I don't think the ECAL will show up on the PNA until it is warmed up. 2. Did he have the correct connector type(s) selected on the PNA. The ECAL only shows up if its connectors are selected. He said that after his 17 times plugging and unplugging the ECAL, it finally shows up, so this is probably ok. |
> {quote:title = cgantz2000写道:} {quote}>我没看到的两件事。 > 1.他等了五分钟让ECAL热身吗? READY灯亮了吗? 我不认为ECAL会在预热之前出现在PNA上。 >热身期与ECal认可无关。 您可以使用“冷”ECal进行校准,但结果可能不是很好。 > 2.他是否在PNA上选择了正确的连接器类型。 ECAL仅显示其连接器是否已选中。 他说,经过17次插拔ECAL之后,终于出现了,所以这可能没问题。 是 - 如果使用引导校准,则只有与所选连接器匹配的校准套件才会显示在列表中。 但是,您始终可以通过使用校准向导第一页上的“Electronic Calibraiton”选项或启动ECal用户特性向导来验证固件是否正确识别了您的ecal。 以上来自于谷歌翻译 以下为原文 > {quote:title=cgantz2000 wrote:}{quote} > Two things I didn't see asked. > 1. Did he wait the five minutes for the ECAL to warm up? Did the READY light come on? I don't think the ECAL will show up on the PNA until it is warmed up. > The warm-up period has nothing to do with the ECal recognition. you can calibrate with a "cold" ECal, but your results may not be very good. > 2. Did he have the correct connector type(s) selected on the PNA. The ECAL only shows up if its connectors are selected. He said that after his 17 times plugging and unplugging the ECAL, it finally shows up, so this is probably ok. Yes - if one is using the guided calibration, then only the cal kits that match the selected connectors show up in the list. However, you can always verify that your ecal is properly recognized by the firmware by using the "Electronic Calibraiton" selection on the first page of the cal wizard, or starting the ECal user characterization wizard. |
quanmeng86 发表于 2018-9-18 16:32 我不知道这是不是问题,但在早期的Ecals上,PC板上的控制器芯片安装在IC插座中。 随着时间的推移,当Ecal掉落时,芯片可以在插座外工作。 我们几年前改变了设计,将控制器焊接到电路板上,但如果你有一个较旧的设备,那可能就是问题所在。 如果它不在保修期内,那么你可以尝试打开机箱,重置芯片(我认为实际上有两个插座芯片),看看是否可以解决问题。 我不知道序列号是否打破了更改的位置,但我猜它应该是4年或更久以前。 这与E8364B的年份一致。 如果重新校准Ecal已经超过一年了,你可能只是将它送去重新校准; 如果有问题,那么它将变得清晰。 以上来自于谷歌翻译 以下为原文 I don't know if this is the issue but on early Ecals the controller chip on the PC board was mounted in an IC socket. Over time, when the Ecal is dropped, the chip can work out of the socket. We changed the design years ago to solder the controller to the board, but if you have an older unit, that might be the issue. If it is out of warranty, then you can try opening the case, resetting the chip (there are actually two socketed chips I think), and see if that cures the problem. I don't know the serial number break that where the change was made, but I would guess it should be 4 or more years ago. That's consistent with the vintage of the E8364B. If it has been more than a year since the Ecal was re-calibrated, you might just send it for recal; if there is a problem it will become clear then. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 11:15 , Processed in 0.978267 second(s), Total 52, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
