嗨,
我刚购买了一些装有NVidia Tesla M60卡的服务器,目的是在Horizon View中使用VMware vSGA。 我根本不想使用vGPU。 我正在寻找卡片的驱动程序,果然在这个论坛上有一个粘性线程描述了需要注册许可门户网站。 我的问题是:我是否需要购买和管理GRID许可才能将Tesla M60用于vSGA? 如果答案是否定的,我认为,为什么我们不得不下载并安装评估软件以获取正确的驱动程序? 这里的东西对我没有意义。 提前感谢任何指导。 以上来自于谷歌翻译 以下为原文 Hi, I've just purchased some servers that have NVidia Tesla M60 cards in, with the intent of using them with VMware vSGA in Horizon View. I do not wish to use vGPU at all. I'm looking for drivers for the cards, and sure enough there is a sticky thread on this forum describing the need to register with the licensing portal. My question is: Do I need to buy and manage GRID licenses in order to use the Tesla M60's with vSGA? If the answer is no, which I believe it is, why on earth are we forced to download and install evaluation software just to get hold of the correct drivers? Something here isn't making sense to me. Thanks in advance for any guidance. |
3个回答
嗨Ytee,
你的假设是错的。 对于运行vSGA的每个用户,您都需要vPC许可证。 这就是为什么你需要注册eval才能获得驱动程序的原因。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Ytee, your assumption is wrong. You would need vPC license for every user running vSGA. This is the reason why you need to register for eval in order to get the drivers. Regards Simon |
Nvidia是否使用硬许可?
如果您使用所有并发许可证会发生什么? 你能用GPU开启新的VM吗? 你能无限期地过度使用用户许可吗? 以上来自于谷歌翻译 以下为原文 Does Nvidia use hard licensing? What happens if you use all your concurrent licenses? Will you be able to power on new VMs with GPU? Can you indefinitely overcommit the user licensing? |
您始终可以打开启用vGPU的VM的电源。
在VM启动并与许可证服务器联系后分配许可证。 如果没有可用于分配的许可证,那么您的VM将以极低的性能/功能运行。 看看这里:https://docs.nvidia.com/grid/latest/grid-vgpu-user-guide/index.html#licensing-grid-vgpu和这里:https://docs.nvidia.com/grid /latest/grid-licensing-user-guide/index.html 问候 以上来自于谷歌翻译 以下为原文 You can always power on your vGPU enabled VMs. Licenses are allocated after the VM has booted and contacted the license server. If no licenses are available for allocation, then your VM will run with greatly reduced performance / functionality. Have a look here: https://docs.nvidia.com/grid/latest/grid-vgpu-user-guide/index.html#licensing-grid-vgpu and here: https://docs.nvidia.com/grid/latest/grid-licensing-user-guide/index.html Regards |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2830 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3223 浏览 4 评论
GMT+8, 2024-4-20 05:46 , Processed in 0.673732 second(s), Total 71, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
