当前环境;
戴尔R730,E5-2695 v3 2.3ghz 14核x 2,768GB内存,2 x 10GB NICS XenServer 7.0,Windows 2012 R2和XenApp 7.13,PVS 7.13 2 x Nvidia Tesla m10,带有GPU Pass-Through和Grid 5.1 适用于XenApp服务器的Compellent SAN和SSD 我们目前正在试验特斯拉M10。 我们运行混合端点(这些是大多数旧的戴尔PC),其中一些具有专用GPU(有些没有)。 我们最近几个月发现我们的最终用户体验一直在降低,在使用Citrix记录呼叫后,他们认为这是因为我们安装了Receiver 4.4,因为这样可以默认启用硬件加速。 这已经被禁用,但我们仍然遇到问题。 我们是一家建筑公司,主要运行各种autodesk应用程序,即AutoCAD和Revit。 我们的大多数用户抱怨都是AutoCAD性能,但我们也看到了Revit性能的问题。 在Chrome中运行Fishbowl测试我们可以看到它正在卸载GPU相关性,但它似乎也在使用我的终端CPU。 已配置服务器,用户和端点的所有Citrix策略(尽我们所知)以防止卸载到本地客户端。 我们正在阅读的大多数文献都谈到使用Grid和XenDesktop获得最佳体验,但遗憾的是,目前这不是我们的选择,因此我们正在寻找有关如何通过XenApp环境克服这一问题的最佳建议和指导? 我们试图阻止任何类型的终点卸载是不现实的吗? 谢谢 以上来自于谷歌翻译 以下为原文 Current Environment; Dell R730, E5-2695 v3 2.3ghz 14 cores x 2, 768GB Memory, 2 x 10GB NICS XenServer 7.0, Windows 2012 R2 and XenApp 7.13, PVS 7.13 2 x Nvidia Tesla m10 with GPU Pass-Through and Grid 5.1 Compellent SAN with SSD for XenApp Servers We are currently experimenting with the Tesla M10's. We run a mix of end-points (These are mostly old Dell PC's) some of which have dedicated GPU's (and some which don't). We have been finding in recent months that our end-user experience has been degrading, after logging a call with Citrix they believe that this happened since we installed Receiver 4.4 as this enables hardware acceleration by default. This has now been disabled but we are still experiencing problems. We are an architectural firm and primarily run a mix of autodesk applications, i.e. AutoCAD and Revit. Most of our user gripes are with AutoCAD performance, but we do also see issues with Revit performance. Running the Fishbowl Test in Chrome we can see that it is off-loading to the GPU correclty, but it also appears to be utilising my end-point CPU. All Citrix policies for the server, user and end-point have been configured (as best we can tell) to prevent off-loading to the local client. Most of the literature we are reading talks about using Grid with XenDesktop for the best experience, but unfortunately this isn't currently an option for us, therefore we are looking for advice and guidance on how best we can overcome this with a XenApp environment? Are we unrealistic in trying to prevent any kind of end-point offloading? Thanks |
5个回答
如果不知道您运行的是什么类型的Codec和Citrix策略,那么很难提供帮助。
但是,如果以H264为例,并且在端点上禁用硬件解码,则这是防止CPU负载的错误方法。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Without knowing what kind of Codec and Citrix policies you're running it is pretty hard to help. But if you run H264 as example and you disable hardware decoding on the endpoint this is the exactly the wrong way to prevent CPU load. Regards Simon |
我们目前设置的唯一端点策略是硬件加速 - 禁用。
以下是我们明确设定的Citrix政策,所有其他政策将被设置为默认行为。 用户 客户端软盘驱动器 - 禁止 客户端网络驱动器 - 禁止 目标最低帧速率 - 20 fps 客户端TWAIN设备重定向 - 禁止 目标帧速率 - 30 fps 视觉质量 - 始终无损 额外的颜色压缩 - 禁用 Framehawk显示通道 - 已禁用 对视频编解码器使用硬件编码 - 已启用 会话空闲计时器 - 已启用 会话空闲计时器间隔 - 360分钟 断开的会话计时器 - 已启用 断开的会话计时器间隔 - 360分钟 音质 - 中等 - 针对语音进行了优化 客户端麦克风重定向 - 允许 音频插头N播放 - 允许 Flash加速 - 已禁用 Flash默认行为 - 禁用Flash加速 音频通过UDP实时传输 - 已启用 使用GPU优化WAN上的Windows Media多媒体重定向 - 允许 客户端打印机名称 - 标准打印机名称 打印机属性保留 - 仅保留在用户配置文件中 与打印服务器的直接连接 - 已启用 单点登录 - 已禁用 桌面壁纸 - 禁止 菜单动画 - 禁止 拖动时查看窗口内容 - 禁止 客户端音频重定向 - 允许 客户端打印机重定向 - 禁止 电脑 显示内存限制 - 131072KB 允许的最大颜色深度 - 每像素16位 排队和折腾 - 启用 谢谢 以上来自于谷歌翻译 以下为原文 The only end-point policy we currently set is hardware acceleration - disabled. The below are the citrix policies we explicity set, all others will be set as the default behaviour. USER Client floppy drives - Prohibited Client network drives - Prohibited Target minimum frame rate - 20 fps Client TWAIN device redirection - Prohibited Target frame rate - 30 fps Visual quality - Always Lossless Extra color compression - Disabled Framehawk display channel - Disabled Use hardware encoding for video codec - Enabled Session idle timer - Enabled Session idle timer interval - 360 minutes Disconnected session timer - Enabled Disconnected session timer interval - 360 minutes Audio quality - Medium - optimized for speech Client microphone redirection - Allowed Audio Plug N Play - Allowed Flash acceleration - Disabled Flash default behavior - Disable Flash acceleration Audio over UDP real-time transport - Enabled Use GPU for optimizing Windows Media multimedia redirection over WAN - Allowed Client printer names - Standard printer names Printer properties retention - Retained in user profile only Direct connections to print servers - Enabled Single Sign-On - Disabled Desktop wallpaper - Prohibited Menu animation - Prohibited View window contents while dragging - Prohibited Client audio redirection - Allowed Client printer redirection - Prohibited COMPUTER Display Memory Limit - 131072KB Maximum allowed color depth - 16 bits per pixel Queuing and Tossing - Enabled Thanks |
这只是局域网吗?
为什么使用Always Lossless作为默认值? 我将从H264和Visual Quality High开始。 我也会删除最低FPS。 如果您确实希望几乎没有端点cpu利用率,则只能运行Thinwire +,但这不是CAD应用程序的最佳选择,因此您需要确定哪些更重要:用户体验或端点利用率。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Is this a LAN only scenario? Why do you use Always Lossless as default? I would start with H264 and Visual Quality High. I would also remove the minimum FPS. If you really want to have almost no endpoint cpu utilization you can only run Thinwire+ but this is not the best option for CAD apps so you need to decide what is more important: User experience or endpoint utilization. Regards Simon |
这主要是LAN,尽管我们也有WAN站点。
当我们第一次部署Nvidia Grid K1时,我们从咨询公司那里获得了建议,这些是我们在他们的指导下找到的最佳设置。 我们发现,自从升级到AutoCAD 2017(无论是由于CAD 17所需的硬件增加还是我们的端点被更多地利用),我们的性能都有所降低。 我们对戴尔的特斯拉M10进行了为期45天的试用,但到目前为止对于切换卡的性能提升并不感兴趣。 我们应该首先考虑哪些基准Citrix策略? 我们安装了“NVIDIA-GRID-XenServer-7.0-384.99-385.90”,并从此包安装我们的XenServer主机上的RPM,以及Windows平台上的许可证服务器和2012 R2驱动程序。 我们发现,当我们将策略从任何类型的无损转换为视觉质量(中等或更高)时,我们会遇到任何图形化的故障。 我们已经确认GPU正确通过并且可见。 我们的期望是不现实的吗? 我们是否应该关注XenDesktop Desktop OS以充分利用网格硬件? 根据您的经验,XenApp XenDesktop之间的性能更好吗? 谢谢 以上来自于谷歌翻译 以下为原文 This is primarily LAN, although we do have WAN sites as well. When we first deployed with Nvidia Grid K1's we took advice from a consultancy and these are the optimal settings we found with their guidance. We have found that since upgrading to AutoCAD 2017 (whether this is due to the increase hardware required of CAD 17 or that our endpoints are being utilised more) our performance has degraded. We have a 45 day trial of the Tesla M10 from Dell but so far are unimpressed with the performance gains of switching out the cards. Are there any baseline Citrix policies we should be looking to start with? We have installed 'NVIDIA-GRID-XenServer-7.0-384.99-385.90' and from this pack install the RPM on our XenServer host, and the license server, and 2012 R2 driver on our Windows platform. We are finding that when we change our policy from any type of lossless to visual quality (medium or higher) we get glitching with anything graphical. We have confirmed the GPU is passing through correctly and is visible. Are we being unrealistic in our expectations? Should we be looking at XenDesktop Desktop OS to fully utilise the Grid Hardware? In your experience, is the performance between XenApp XenDesktop better? Thanks |
问题出在哪里应该基于监控您的环境。
您可以使用进程资源管理器仔细查看VM和端点上的GPU利用率,以及虚拟机管理程序和VM中的nvidia-smi命令,以查看GPU是否是您的瓶颈 试图实现或是否涉及其他因素。 除此之外,使用的协议非常重要。 新版本的Citrix现在可以使用EDT(因此使用UDP而不是TCP)来提供更好的体验。 许多CAD应用程序仍然是单线程的,因此从更高的时钟速度中获益更多,而不是从许多CPU内核中获益。 使用基于服务器或桌面的操作系统进行部署之间存在差异,使用桌面操作系统时,您可以在安装VDA时访问HDX 3D Pro,据我所知,这可能会更好地提供更顺畅的用户 经验,特别是在引入图形加速时: https://docs.citrix.com/en-us/xenapp-and-xendesktop/7-13/hdx/gpu-acceleration-desktop.html 就Citrix政策而言,这可能值得研究: http://nvidia.custhelp.com/app/answers/detail/a_id/4131/~/optimal-citrix-graphics-policy-configuration-when-using-hdx-3d-pro-vda-and 以上来自于谷歌翻译 以下为原文 Where the problem is should be based on monitoring your environment. You can use process explorer to take a good look at the GPU utilization within your VM as well as on your endpoints, as well as nvidia-smi commands both on hypervisor and in your VM's to see if the GPU is the bottleneck for what you are trying to achieve or if there are other factors involved. Besides that, the used protocol is very important. New versions of Citrix can now use EDT (so using UDP instead of TCP) to deliver a better experience. Many CAD applications are also still singlethreaded so would benefit more from a higher clockspeed than from a lot of cpu cores. There is a difference between using a server or desktop based OS for your deployment, when using a desktop OS, you have access to HDX 3D Pro when installing VDA, which, as far as I can tell, might be better at delivering a smoother user experience, especially when introducing graphics acceleration: https://docs.citrix.com/en-us/xenapp-and-xendesktop/7-13/hdx/gpu-acceleration-desktop.html In terms of citrix policies, this might be worth looking into: http://nvidia.custhelp.com/app/answers/detail/a_id/4131/~/optimal-citrix-graphics-policy-configuration-when-using-hdx-3d-pro-vda-and |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2829 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3221 浏览 4 评论
GMT+8, 2024-4-18 03:29 , Processed in 0.341201 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
