我们在戴尔R730上部署了Horizon View设置,其GRID为k2。
我们的Win 10 Ent x64池遇到了一些问题,使用户体验不可靠。 环境概要 ESXi 6.0版 Horizon View 6.2 戴尔PE R730 NVIDIA K2; 在Host和vGPU上运行354.97驱动程序 运行Win 10 Ent 1511的客户端池 WYSE P45 Zero Client运行PCoIP - Terra 2芯片 - 来自teradici的5.2固件 双显示器设置,1920x1200 问题1。 网页浏览器(任何网络浏览器)中的全屏视频在全屏显示的几秒钟内冻结,恢复它的唯一方法是逃离全屏。 解决方法是在浏览器中禁用硬件加速,但这会破坏投资GRID基础架构的目的。 问题2。 至少每天一次,win 10 VDI客户端将遇到图形驱动程序的重大故障。 这首先表现为屏幕锁定,然后音频失败,然后会话结束,无法通过Zero Client菜单重新初始化。 解决方法是从Zero Client菜单启动VM的重新启动,该菜单重新启动整个机器,丢失所有未保存的工作。 操作系统本身似乎没有崩溃,因为重启时启动的是干净重启操作系统而不是虚拟硬件的硬重置。 任何人都可以帮助我们解决这个问题或指向我们已知的GRID驱动程序的稳定版本? 以上来自于谷歌翻译 以下为原文 We have deployed a Horizon View setup on a dell R730 with a GRID k2. Our Win 10 Ent x64 pool is experiencing a few issues which make the user experience unreliable. Summary of environment ESXi version 6.0 Horizon View 6.2 Dell PE R730 NVIDIA K2; running 354.97 driver both on Host and vGPU Client pool running Win 10 Ent 1511 WYSE P45 Zero Client running PCoIP - Terra 2 chip - 5.2 firmware from teradici Dual monitor setup, 1920x1200 Issue 1. Full screen video within a web browser (any web browser) freezes up within seconds of going full screen, the only way to restore it is to escape out of full screen. The work around is to disable hardware acceleration within the browser, but this defeats the purpose in investing in the GRID infrastructure. Issue 2. At least once a day at random the win 10 VDI client will experience a major failure of the graphics driver. This manifest itself at first as a lock up of the screen, the audio then fails followed by the session ending and unable to be reinitialized through the Zero Client menu. The workaround is to initiate a restart of the VM from the Zero Client menu which reboots the entire machine losing all unsaved work. It seems that the OS itself has not crashed as the reboot when initiated is a clean reboot of the OS not a hard reset of the Virtual hardware. Can anyone please help us address this issue or point us to a known stable build of the GRID drivers? |
8个回答
嗨,Mohb60,
我不知道这样的任何已知问题,驱动程序应该是稳定的。 您可以做的最好的事情是提出支持票,因为这是GRID 1.0产品(K2 / K1板),您需要通过提供电路板的OEM(在这种情况下为Dell)执行此操作,然后他们可以将其升级为 NVIDIA工程如果是驱动程序问题。 在GRID 2.0 SUMS支持是可用的,所以有一个过程直接用NVIDIA提高票价,但在较旧的硬件销售模式 - 我担心你需要通过卖给你卡的OEM。 最好的祝愿, 雷切尔 以上来自于谷歌翻译 以下为原文 Hi Mohb60, I don't know of any known issue like this and the drivers should be stable. The best thing you can do is to raise a support ticket because this is GRID 1.0 product (K2/K1 boards) you need to do this via the OEM who supplied the board (Dell in this case) and they in turn can escalate it into NVIDIA engineering if it's a driver issue. In the GRID 2.0 SUMS support is available so there's a process to raise tickets directly with NVIDIA but in the older hardware sales model - I'm afraid you do need to go via the OEM who sold you the card. Best wishes, Rachel |
嗨雷切尔,
感谢您的反馈意见。 无论如何,我有一些好消息,我们设法在我们的环境中找到解决问题#1的方法。 据我所知,在浏览器中全屏播放期间视频冻结是由于图像质量容差设置。 与直觉相反,似乎在PCoIP客户端上将图像质量容差设置得太低也会产生问题。 将条形设置从80%设置为感知无损似乎是我们设置中的最佳设置,并且在全屏播放期间不再导致屏幕锁定。 我希望这有助于其他人采用类似的设置并面临同样的问题。 我们仍在研究问题#2。 以上来自于谷歌翻译 以下为原文 Hi Rachel, Thanks for your feedback. Anyway, I have some good news, we managed to find a work around for issue #1 in our environment. From what I can tell, the video freezing up during full screen playback in a browser was due to the image quality tolerance settings. Counter-intuitively, it seems that setting the lower threshold too low on the image quality tolerance on the PCoIP client produces the issue. Setting the bar from 80% to perceptively lossless seems to be the best setting on our setup and no longer results in the screen locking up during full screen playback. I hope that this helps others with a similar setup and are facing the same issue. We are still looking into issue #2. |
这个问题在我们的环境中仍然存在。
我们采取了以下步骤并得出结论,新的Nvidia驱动程序不稳定。 我们的环境与上面列出的相同。 为了进行调查,我们的第一步是查看日志以确定VM随机崩溃和重新启动的原因。 日志显示很少,Windows日志显示在遇到VM操作系统故障后,窗口已从不干净的关闭中恢复。 VM日志显示错误,其中大致相同的时间戳将故障与Windows日志中显示的内容相关联。 将vib和vGPU驱动程序从348.27升级到较新的354.97之后,这种不稳定性被引入我们的环境。 这是通过在我们的一台主机上回滚振动并创建一个安装了348.27驱动程序的新的相同vGPU池来确认的。 新游泳池一直很稳定。 来自Nvidia的任何人都可以告诉我们新驱动程序不稳定的原因吗? 以上来自于谷歌翻译 以下为原文 This issue still persists in our environment. We have taken the following steps and concluded that the newer Nvidia drivers are unstable. Our environment is the same as what is listed above. To investigate, our initial step was to look into the logs to determine why VMs were randomly crashing and rebooting. The logs show very little, windows logs show that windows had recovered from an unclean shutdown after experiencing a failure of the VM's OS. The VM logs show an error with approximately the same time stamp correlating the failure with what's seen in the windows logs. This instability was introduced into our environment after upgrading both the vib and vGPU drivers from 348.27 to the newer 354.97. This was confirmed by rolling back the vib on one of our hosts and creating a new identical vGPU pool with 348.27 drivers installed. The new pool has been stable. Can anyone from Nvidia give us a reason for the instability in the newer drivers? |
感谢您的反馈非常有帮助 - 我会看到内部已知的内容。
雷切尔 以上来自于谷歌翻译 以下为原文 Thanks for the feedback very helpful - I'll see what is known internally. Rachel |
我和客户问题#2的情况相同。
从vGPU-346.68-348.27升级到vGPU-361.45.09-362.56后,我们的问题就开始了。 从那以后我们尝试了vGPU-367.43-369.17,但没有运气。 VMware已关闭此案并指向Nvidia,而Nvidia指的是向我们出售GRID K2的惠普。 到目前为止,HP的唯一建议是升级Proliant服务器BIOS。 叹! 多么令人失望。 我有几个客户可以从这项技术中受益,但在解决这个问题之前我没有再接触过它。 以上来自于谷歌翻译 以下为原文 I have the same scenario at a customer as your problem #2. Our problems began after upgrading from vGPU-346.68-348.27 to vGPU-361.45.09-362.56. Since then we tried vGPU-367.43-369.17 but no luck. VMware has closed the case and pointed at Nvidia, and Nvidia are referring to HP who sold us the GRID K2. So far the only suggestion from HP was to upgrade the Proliant server BIOS. Sigh! What a big disappointment. I have several customers who could benefit from this technology, but I am not touching it again before this is solved. |
哦,忘了https://gridforums.nvidia.com/default/topic/974/how-to-get-support-problem-with-win10-k2-vgpu-and-view7/#3417
以上来自于谷歌翻译 以下为原文 Oh, forgot https://gridforums.nvidia.com/default/topic/974/how-to-get-support-problem-with-win10-k2-vgpu-and-view7/#3417 |
我有一个更新,我与VMware合作,得出的结论是问题#2与特定场景有关。
赢得10 1511 VDI,运行更新的NVIDIA驱动程序以及来宾VM上存在模拟SATA CD-ROM和SATA控制器。 作为一项实验,我尝试从客户虚拟机中删除SATA CD-ROM和控制器,并且运行旧版和新版驱动程序的池都已证明是稳定的。 @Oletho,尝试删除你的SATA CD-ROM和控制器,也许这对你有用吗? 有人告诉我,ESXi 6.0.0 Update 2解决了崩溃VM的CD-ROM仿真问题。 我没有机会在我的环境中证实这一点。 以上来自于谷歌翻译 以下为原文 I have an update from my end, I worked with VMware and have come to the conclusion that Issue #2 has to do with a particular scenario. Win 10 1511 VDI, running newer NVIDIA drivers and the presence of an emulated SATA CD-ROM and SATA controller on the guest VM. As an experiment I've tried removing the SATA CD-ROM and controller from the guest VM and ran pools with both the older and newer drivers both have proven to be stable. @Oletho, try to remove your SATA CD-ROM and controller, perhaps this will work for you? I have been told that ESXi 6.0.0 Update 2 addresses the issue with the CD-ROM emulation crashing the VM. I have not had a chance to confirm this in my environment. |
我刚看到您的回复,将立即与客户一起设置测试CD-ROM解决方案。
非常感谢。 我们已经在运行Update2,其中包含最新的补丁。 以上来自于谷歌翻译 以下为原文 I just saw your reply and will immediately set up with the customer to test the CD-ROM solution. Thanks a lot. We are running Update2 with latest patches already. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2832 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3225 浏览 4 评论
GMT+8, 2024-4-25 16:28 , Processed in 0.651308 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
