你好社区,
我们有富士通RX2560 M1和450瓦电源。 我们平均使用170瓦这台服务器。 我们会购买Nvidia Grid K1,但我们不知道升级服务器中的电源? 有人可以帮助我们吗? 最好的祝福, 埃克 以上来自于谷歌翻译 以下为原文 Hello Community, we have a Fujitsu RX2560 M1 with 450Watt Power Supply. We use average 170 Watt for this server. We would buy a Nvidia Grid K1, but we didn't know to upgrade our power supply in the server? Can anyone help us? Best regards, Eike |
3个回答
RX2560不是GRID的认证服务器:http://www.nvidia.com/object/grid-certified-servers.html
我认为您需要与富士通讨论这个问题,他们也是提供电源建议的最佳场所。 有时像富士通这样的OEM可以接受认证/支持其他服务器,如果他们看到客户需求的话。 有时真正的热/电气约束意味着他们不能。 如果服务器未通过GRID(裸机)认证,则虚拟机管理程序供应商VMware / Citrix将不会在其HCL(硬件兼容性列表)上将其用于vGPU / GPU传递。 这意味着如果使用虚拟机管理程序,VMware / Citrix不会将支持呼叫视为不受支持的硬件。 最好的祝愿, 雷切尔 以上来自于谷歌翻译 以下为原文 The RX2560 is not a certified server for GRID: http://www.nvidia.com/object/grid-certified-servers.html I think you need to discuss this with Fujitsu, they are best place to advise on the power supply too. Sometimes OEMs like Fujitsu are receptive to certifying / supporting additional servers if they see custoemr demand. Sometimes there are genuine thermal/electrical constraints that mean they can't though. If a server isn't GRID (bare-metal) certified the hypervisor vendors VMware/Citrix won't have it on their HCL (hardware compatibility list) either for vGPU/GPU pass-through. That would mean if using a hypervisor VMware/Citrix wouldn't take support calls as unsupported hardware. Best wishes, Rachel |
450 W听起来很弱。
K1将自己绘制大约130 W(参见:http://www.nvidia.com/content/grid/pdf/GRID_K1_BD-06633-001_v02.pdf),典型的CPU将从80开始绘制 - 160 W,加上您拥有所有其他船上需求。 大多数具有双CPU的服务器都具有600-1100 W的电源。 雷切尔认为你应该向富士通核实他们的建议,不符合这些可能会使任何保证无效。 好消息是,在许多服务器中,如果它们是模块化的(现在大部分都是这样),你可以很容易地更换电源。 以上来自于谷歌翻译 以下为原文 450 W sounds weak. The K1 will draw up to around 130 W on its own (see: http://www.nvidia.com/content/grid/pdf/GRID_K1_BD-06633-001_v02.pdf ), and a typical CPU will draw anywhere from 80 - 160 W, plus you have all the other on-board needs. Most servers with dual CPUs have 600-1100 W power supplies. Rachel is spot on that you should check back with Fujitsu as to their recommendations and not conforming to those could void any warranties. The good news is that in many servers, you can swap out power supplies pretty easily if they are modular (which most are these days). |
我同意Rachel。富士通RX2560 M1服务器不是Grid的服务器。
但您可以使用800W热插拔,96%(钛效率),200-240V,50 / 60Hz电源。 以上来自于谷歌翻译 以下为原文 I agree with Rachel.The Fujitsu RX2560 M1 server is not a server for Grid. But you can use 800W hot-plug, 96% (Titanium efficiency), 200-240V, 50 / 60Hz power supply. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2832 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3225 浏览 4 评论
GMT+8, 2024-4-25 19:40 , Processed in 0.555492 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
