我有一台带有ESXi 6.0 Build 4192238的服务器,带有一个带驱动程序367.64的M10。
当我运行nvidia-smi时,它只显示2个GPU,只允许我运行一半的预期用户。 有任何想法吗? + ------------------------------------------------- ---------------------------- + | NVIDIA-SMI 367.64驱动程序版本:367.64 | | ------------------------------- + ----------------- ----- + ---------------------- + | GPU名称持久性-M | Bus-Id Disp.A | 挥发性的Uncorr。 ECC | | Fan Temp Perf Pwr:用法/上限| 内存使用| GPU-Util Compute M. | | =============================== + ================= ===== + ====================== | | 0特斯拉M10开| 0000:07:00.0关闭| N / A | | N / A 33C P8 10W / 53W | 6712MiB / 8191MiB | 44%默认值| + ------------------------------- + ----------------- ----- + ---------------------- + | 1特斯拉M10开| 0000:08:00.0关闭| N / A | | N / A 36C P0 17W / 53W | 6713MiB / 8191MiB | 27%默认值| + ------------------------------- + ----------------- ----- + ---------------------- + + ------------------------------------------------- ---------------------------- + | 进程:GPU内存| | GPU PID类型进程名称用法| | ================================================= ============================ | 以上来自于谷歌翻译 以下为原文 I have a server with ESXi 6.0 Build 4192238 with a single M10 with driver 367.64. When I run nvidia-smi it only shows 2 GPUs and only lets me run half of the expected users. Any ideas? +-----------------------------------------------------------------------------+ | NVIDIA-SMI 367.64 Driver Version: 367.64 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | |===============================+======================+======================| | 0 Tesla M10 On | 0000:07:00.0 Off | N/A | | N/A 33C P8 10W / 53W | 6712MiB / 8191MiB | 44% Default | +-------------------------------+----------------------+----------------------+ | 1 Tesla M10 On | 0000:08:00.0 Off | N/A | | N/A 36C P0 17W / 53W | 6713MiB / 8191MiB | 27% Default | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: GPU Memory | | GPU PID Type Process name Usage | |=============================================================================| |
2个回答
也许你的4G资源不足(ESXi驱动程序存在PCI over 4G问题)。
请参阅 - http://nvidia.custhelp.com/app/answers/detail/a_id/4119/~/incorrect-bios-settings-on-a-server-when-used-with-a-hypervisor-can-cause- MMIO 以上来自于谷歌翻译 以下为原文 Maybe you are running out of PCI resources under 4G (ESXi drivers have problems with PCI over 4G). See - http://nvidia.custhelp.com/app/answers/detail/a_id/4119/~/incorrect-bios-settings-on-a-server-when-used-with-a-hypervisor-can-cause-mmio |
感谢您的回复。
我不相信这是一个资源问题。 自从发布以来,我已经能够借用另一台M10并且在交换它们之后,看起来我的M10很糟糕。 更换按预期工作,重新安装后,我的M10继续只能使用2个GPU。 看起来我必须RMA它。 以上来自于谷歌翻译 以下为原文 Thanks for your reply. I do not believe it is a resource issue. Since posting, I've been able to borrow another M10 and after swapping them out it appears that I have a bad M10. The replacement works as expected and my M10 continues to only work with 2 GPUs after reinstalling again. Looks like I'll have to RMA it. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2830 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3223 浏览 4 评论
GMT+8, 2024-4-20 11:26 , Processed in 0.519942 second(s), Total 68, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
