Some info on the IntuiLink bitmap inversion…Â
 I wrote the COM server code for the IntuiLink (for the ESA) and the code to invert the images. The IntuiLinks that automatically invert an image use a library from a company called LeadTools to handle the images and any conversions.  The inversion is done via a call to “L_InvertBitmap†contained in the library ltIMG11n.dll.   Ken    _____  From: Jay Nemeth-Johannes [mailto:jay.johannes@smartsensorsystems.com] Sent: Friday, August 11, 2006 12:16 PM To: VRF Subject: RE: [vrf] Agilent E4407B Spectrum Analyser - Screen Format  I didn't do the analyzers for IntuiLink. I did the meters. That said...  There are several possibilities here. The poster seems to imply that you can reverse the bitmap from the front panel. He also said that intuiLink does it.  Intuilink could be modifying the GIF palate, or they could be pulling out a bitmap and doing a byte level inversion. The more likely answer is that most of the analyzers have commands that will simulate key presses on the front panel. Often these commands are undocumented because they are primarily used for engineering QA and production test. Since this box is SCPI based, the most likely place to look would be in the DIAGnostic subsystem. The DIAG subsystem is totally instrument dependent, so you would need to play around to find the command. The best solution would be to get a real GPIB analyzer and hook the box up via GPIB. Then run Intuilink and look at the commands going by. I believe both NI and Agilent have software analyzers available, but the better answer is a hardware analyzer as it captures everything.  If you need to try and figure out the hidden command, I would look at DIAG:KPR, DIAG:KEY:PRES, DIAG:KEY or something like that, but I'm just guessing.  Jay Nemeth-Johannes Smart Sensor Systems 720 SW 14th Street Loveland, Colorado 80537 (970) 663-0006 (Office) (970) 290-9797 (Cell) HYPERLINK "http://www.smartsensorsystems.com/"www.SmartSensorSystems.com    _____  From: Joe Flynn [mailto:jflynn@sequoiacommunications.com] Sent: Friday, August 11, 2006 9:24 AM To: VRF Cc: VRF Subject: RE: [vrf] Agilent E4407B Spectrum Analyser - Screen Format If you use an NI GPIB card, try to use NI SPY to see if it is done in a SCPI command. Perhaps Intuilink does in by modifying the GIF color palate.  Can you save the spectrum analyzer state with the image format reversed? I have a similar problem with PSA measurement personalities. It's a real PITA to save/recall states to simply select a different display option.  Best Regards, Joe Flynn    _____  From: Andrew.I.James@nokia.com [mailto:Andrew.I.James@nokia.com] Sent: Friday, August 11, 2006 3:53 AM To: VRF Subject: [vrf] Agilent E4407B Spectrum Analyser - Screen Format Hello, Does anyone know how to automate the format of the screen to reverse bitmap? Obviously it's easy to do manually but I can't find out how to automate this. The guys at Agilent say it is not possible but their IntuiLink software that comes with the unit does it when you do a screen dump. Any help appreciated, Andrew --- You are currently subscribed to vrf as: jflynn@sequoiacommunications.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- You are currently subscribed to vrf as: jay.johannes@completetest.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- You are currently subscribed to vrf as: ken_colasuonno@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
2个回答
Agilent E4407B频谱分析仪 - 屏幕格式如果您使用NI GPIB卡,请尝试使用NI SPY查看是否在SCPI命令中完成。也许Intuilink通过修改GIF颜色来完成。可以保存频谱分析仪状态
图像格式颠倒了? 我有一个类似的PSA测量个性问题。 这是一个真正的PITA来保存/回忆状态,只需选择一个不同的显示选项。最好的问候,Joe Flynn来自:Andrew.I.James@nokia.com [mailto:Andrew.I.James@nokia.com]发送:8月8日星期五 11,2006 3:53 AM:VRFS主题:[vrf] Agilent E4407B频谱分析仪 - 屏幕格式你好,有谁知道如何自动化屏幕格式来反转位图? 显然,手动操作很容易,但我无法找到如何实现自动化。 安捷伦的工作人员表示,这是不可能的,但是当你进行屏幕转储时,他们的设备附带的IntuiLink软件可以做到这一点。任何帮助表示赞赏,安德鲁---您目前订阅了vrf:jflynn@sequoiacommunications.com订阅 请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。 要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。 要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 在“www.oswegosw.com/vrf_archive/”上搜索“unofficial vrf archive”。 ---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。取消订阅发送 发送电子邮件至“leave-vrf@it.lists.it.agilent.com”。要发送邮件至此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Agilent E4407B Spectrum Analyser - Screen FormatIf you use an NI GPIB card, try to use NI SPY to see if it is done in a SCPI command.Perhaps Intuilink does in by modifying the GIF color palate. Can you save the spectrum analyzer state with the image format reversed? I have a similar problem with PSA measurement personalities. It's a real PITA to save/recall states to simply select a different display option. Best Regards,Joe Flynn From: Andrew.I.James@nokia.com [mailto:Andrew.I.James@nokia.com] Sent: Friday, August 11, 2006 3:53 AMTo: VRFSubject: [vrf] Agilent E4407B Spectrum Analyser - Screen FormatHello, Does anyone know how to automate the format of the screen to reverse bitmap? Obviously it's easy to do manually but I can't find out how to automate this. The guys at Agilent say it is not possible but their IntuiLink software that comes with the unit does it when you do a screen dump.Any help appreciated, Andrew --- You are currently subscribed to vrf as: jflynn@sequoiacommunications.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". ---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
Agilent E4407B频谱分析仪 - 屏幕格式你好,有谁知道如何自动化屏幕格式以反转位图?
显然,手动操作很容易,但我无法找到如何实现自动化。 安捷伦的工作人员表示,这是不可能的,但是当你进行屏幕转储时,他们的设备附带的IntuiLink软件可以做到这一点。任何帮助表示赞赏,安德鲁---您目前订阅的是vrf:r***@soco.agilent.comTo 订阅请发送电子邮件至:“vrf-request@lists.it.agilent.com”,邮件正文中包含subscribe一词。要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com “。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Agilent E4407B Spectrum Analyser - Screen FormatHello,Does anyone know how to automate the format of the screen to reverse bitmap? Obviously it's easy to do manually but I can't find out how to automate this. The guys at Agilent say it is not possible but their IntuiLink software that comes with the unit does it when you do a screen dump.Any help appreciated,Andrew---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2574 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1557 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-18 08:29 , Processed in 1.124513 second(s), Total 73, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
