有没有办法通过组策略或注册表设置限制用户对NVIDIA控制面板设置的修改?
以上来自于谷歌翻译 以下为原文 Is there as way to restrict modifications b通过组策略或注册表限制NVIDIA控制面板设置更改?y users to the NVIDIA Control Panel settings either via Group Policy or registry settings? |
3个回答
我认为你不能阻止用户更改设置。
但如果这是一个很大的问题,你可以隐藏使用它的选项...... 使用Canonical Names选项仅显示Windows控制面板中的特定选项。 您如何做的选项在这里: https://technet.microsoft.com/en-us/library/ee617167%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396 如果你做一点谷歌搜索,你也可以添加或删除各种上下文菜单设置: https://www.google.co.uk/search?q=Add%2C+Remove%2C+Edit+Context+Menu&oq=Add%2C+Remove%2C+Edit+Context+Menu&aqs=chrome。 .69i57j0l5.528j0j8&安培;的SourceID =铬&安培,即= UTF-8 以上来自于谷歌翻译 以下为原文 I don't think you can stop users changing the settings. But if it's that much of a concern, you can hide the option to use it ... Use the Canonical Names options to only show specific options in the Windows Control Panel. Options of how you do that are here: https://technet.microsoft.com/en-us/library/ee617167%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396 If you do a little Googling, you can also add or remove various context menu settings as well: https://www.google.co.uk/search?q=Add%2C+Remove%2C+Edit+Context+Menu&oq=Add%2C+Remove%2C+Edit+Context+Menu&aqs=chrome..69i57j0l5.528j0j8&sourceid=chrome&ie=UTF-8 |
看起来没有任何GPO管理这个。
最好的选择是隐藏或禁用Shell扩展。 有人试过Nirsoft的ShellExView来管理扩展吗? 仅供参考 - 当您拥有大量用户时(是的,随着特斯拉M10卡的出现,您确实可以在服务器中塞满许多用户),您需要能够控制它们以保证您的理智。 以上来自于谷歌翻译 以下为原文 Looks like there aren't any GPOs governing this. Best option is to hide or disable the Shell Extensions. Anyone tried Nirsoft's ShellExView to manage extensions? FYI - when you have a large pool of users (yes with the advent of the Tesla M10 card, you can indeed cram many users in a server) you need to be able to control them for your sanity. |
不是直接的,但与上面链接,你可以使用这个:
https://technet.microsoft.com/en-us/library/ee617167%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396 “仅显示指定的控制面板项” 这是一个如何使用它的指南,它将完全符合您的要求: http://www.computerstepbystep.com/show-only-specified-control-panel-items.html 上下文菜单 - 至于“右键单击”上下文菜单,再次使用我上面的搜索链接: 使用GPO删除这两个键: [HKEY_CLASSES_ROOT 目录背景 ShellEx的 ContextMenuHandlers 00nView] @ = “{1E9B04FB-F9E5-4718-997B-B8DA88302A48}” [HKEY_CLASSES_ROOT 目录背景 ShellEx的 ContextMenuHandlers NvCplDesktopContext] @ = “{3D1975AF-48C6-4f8e-A182-BE0E08FA86A9}” 以上来自于谷歌翻译 以下为原文 Not directly, but as linked to above, you can use this: https://technet.microsoft.com/en-us/library/ee617167%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396 "Show only specified Control Panel items" Here's a guide on how to use it, it will do exactly what you're asking for: http://www.computerstepbystep.com/show-only-specified-control-panel-items.html Context Menus - As for the "Right Click" Context Menus, again using my search link from above: Delete both of these keys using a GPO: [HKEY_CLASSES_ROOTDirectorybackgroundshellexContextMenuHandlers 0nView] @="{1E9B04FB-F9E5-4718-997B-B8DA88302A48}" [HKEY_CLASSES_ROOTDirectorybackgroundshellexContextMenuHandlersNvCplDesktopContext] @="{3D1975AF-48C6-4f8e-A182-BE0E08FA86A9}" |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2830 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3223 浏览 4 评论
GMT+8, 2024-4-20 12:26 , Processed in 0.550553 second(s), Total 70, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
