扫一扫,分享给好友
你好,
我有一个应用程序将从SLaveFIFO编写和读取数据。它运行良好,我们没有看到任何问题。如果我们按下CTRL+C,它退出,如果我们试图连接执行命令(EXE),它没有检测到CyPress设备。我也检查控制中心,我们看不到任何连接到PC。如果我们重新连接USB并再次检查。这次我们可以检测到CyPress设备。你能告诉我如何解决这个问题吗? 谢谢, 阿斯温卡瓦利 以上来自于百度翻译 以下为原文 Hello, I have one application which will write and read data from slavefifo. It is working fine and we dont see any issue. If we press ctrl + c it is exiting and if we try to connect execute the command (exe) it is not detecting the cypress device. I check with control center also and we see nothing connected to the pc. If we reconnect the USB and checked again. this time we can cypress device getting detected. Could you please let me know on how to solve this issue? Thanks, Aswin kavali |
5个回答
你好,Aswin Kavali,
-请让你知道你正在使用的固件。它是一个固件还是自定义固件? 另外,和蔼,检查存在的设备的设备管理器。 最好的问候, 斯里纳斯 以上来自于百度翻译 以下为原文 Hello Aswin Kavali, - Please let know the firmware that you are using. Is it an example firmware or your custom firmware? - Also, kindly, check the device manager for the presence of the device. Best regards, Srinath S |
wangcong12138 发表于 2018-8-31 23:17 我正在使用USB拖缆固件。(斯拉维斯克) 我们可以从另一个设备上做一个柏树复位。我们对此没有任何争议。我想知道我们是否可以从应用程序本身解决这个问题。 谢谢, 阿斯温卡瓦利 以上来自于百度翻译 以下为原文 I am using USB streamer firmware. (slavesync) We can do a cypress reset from another device. we don't have any issue with that. I would like to know whether we can solve this issue from the application itself Thanks, Aswin kavali |
s934275423 发表于 2018-8-31 23:28 嗨,Aswin, 必须使用Ctrl +C关闭应用程序时调用的回调函数。请参阅下面路径中的TeleFER应用程序中的关闭函数的标准实现。 请注意你正在运行哪些应用程序? CPP:C:程序文件(x86) CyPress EZ-USB FX3SDK 1.3应用程序CPPTraveer-Strua.CPP CCHAR:C:程序文件(x86) CyPress EZ-USB FX3SDK 1.3应用程序CXHARP 拖缆 感谢和问候 阿比纳夫 以上来自于百度翻译 以下为原文 Hi Aswin, You have to implement a callback function which will be called while closing the application using ctrl + C. Please refer to the standard implementation of closing function in the streamer application in the following path. Please mention on which OS you are running your application? Cpp: C:Program Files (x86)CypressEZ-USB FX3 SDK1.3applicationcppstreamerstreamer.cpp CSharp: C:Program Files (x86)CypressEZ-USB FX3 SDK1.3applicationc_sharpstreamer Thanks & regards Abhinav |
ldliu 发表于 2018-8-31 23:46 嗨,Aswin, 我尝试用“BulkSrCink”示例固件发送文件,发现它工作正常。我在文件传输中按下“CTRL+C”,但第二次应用仍然检测FX3。你能分享你使用的固件吗? 感谢和问候 阿比纳夫 以上来自于百度翻译 以下为原文 Hi Aswin, I tried to send files with "Bulksrcsink" example firmware and found that it is working fine. I pressed "Ctrl + C" in between the file transfer but still application detect FX3 for the second time. Could you please share the exact firmware that you are using? Thanks & regards Abhinav |
ldliu 发表于 2018-8-31 23:56 您好! 你可以评论“cyfxslfifoapplndebuginit()”的固件来解决这个问题。 -问候 阿比纳夫 以上来自于百度翻译 以下为原文 Hi You can comment out "CyFxSlFifoApplnDebugInit()" in the firmware to resolve this issue. -Regards Abhinav |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-23 17:40 , Processed in 0.702068 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
