论坛的技术高手:
小弟最近刚刚入手AD9364开发板,想使用FPGA纯逻辑配置AD9364,目前有一个疑惑,如果我已经有了配置文件,比如之前论坛有人提供的BBS.TXT,不知道配置的流程应该怎样,是不是按照附件的寄存器顺序用SPI接口一直写下去就可以了?(写2000多次)还是有特定的配置顺序?请技术支持或者做过的大神指点迷津,阿米托福! 附件部分数据 //************************************************************ // AD9361 R2 Auto Generated Initialization Script: This script was // generated using the AD9361 Customer software Version 2.1.3 //************************************************************ // Profile: LTE 10 MHz // REFCLK_IN: 40.000 MHz RESET_FPGA RESET_DUT BlockWrite 2,6 // Set ADI FPGA SPI to 20Mhz SPIWrite 3DF,01 // Required for proper operation ReadPartNumber SPIWrite 2A6,0E // Enable Master Bias SPIWrite 2A8,0E // Set Bandgap Trim REFCLK_Scale 40.000000,1,2 // Sets local variables in script engine, user can ignore SPIWrite 292,08 // Set DCXO Coarse Tune[5:0]. Coarse and Fine nominal values used with eval system. Other nominal values may be needed in a customer system SPIWrite 293,80 // Set DCXO Fine Tune [12:5] SPIWrite 294,00 // Set DCXO Fine Tune [4:0] SPIWrite 2AB,07 // Set RF PLL reflclk scale to REFCLK * 2 SPIWrite 2AC,FF // Set RF PLL reflclk scale to REFCLK * 2 SPIWrite 009,07 // Enable Clocks WAIT 20 // waits 20 ms //************************************************************ // Set BBPLL Frequency: 983.040000 //************************************************************ SPIWrite 045,00 // Set BBPLL reflclk scale to REFCLK /1 SPIWrite 046,03 // Set BBPLL Loop Filter Charge Pump current SPIWrite 048,E8 // Set BBPLL Loop Filter C1, R1 SPIWrite 049,5B // Set BBPLL Loop Filter R2, C2, C1 SPIWrite 04A,35 // Set BBPLL Loop Filter C3,R2 SPIWrite 04B,E0 // Allow calibration to occur and set cal count to 1024 for max accuracy SPIWrite 04E,10 // Set calibration clock to REFCLK/4 for more accuracy SPIWrite 043,29 // BBPLL Freq Word (Fractional[7:0]) SPIWrite 042,5C // BBPLL Freq Word (Fractional[15:8]) SPIWrite 041,12 // BBPLL Freq Word (Fractional[23:16]) SPIWrite 044,18 // BBPLL Freq Word (Integer[7:0]) SPIWrite 03F,05 // Start BBPLL Calibration SPIWrite 03F,01 // Clear BBPLL start calibration bit SPIWrite 04C,86 // Increase BBPLL KV and phase margin SPIWrite 04D,01 // Increase BBPLL KV and phase margin SPIWrite 04D,05 // Increase BBPLL KV and phase margin WAIT_CALDONE BBPLL,2000 // Wait for BBPLL to lock, Timeout 2sec, Max BBPLL VCO Cal Time: 345.600 us (Done when 0x05E[7]==1) SPIRead 05E // Check BBPLL locked status (0x05E[7]==1 is locked) SPIWrite 002,DE // Setup Tx Digital Filters/ Channels SPIWrite 003,DE // Setup Rx Digital Filters/ Channels SPIWrite 004,03 // Select Rx input pin(A,B,C)/ Tx out pin (A,B) SPIWrite 00A,02 // Set BBPLL post divide rate //************************************************************ // Program Tx FIR: C:Program FilesAnalog DevicesAD9361R2 // Evaluation Software 2.1.3DigitalFiltersLTE10_MHz.ftr //************************************************************ SPIWrite 065,FA // Enable clock to Tx FIR Filter and set Filter gain Setting SPIWrite 060,00 // Write FIR coefficient address SPIWrite 061,FB // Write FIR coefficient data[7:0] SPIWrite 062,FF // Write FIR coefficient data[15:8] SPIWrite 065,FE // Set Write EN to push data into FIR filter register map SPIWrite 064,00 // Write to Read only register to delay ~1us SPIWrite 064,00 // Write to Read only register to delay ~1us SPIWrite 060,01 SPIWrite 061,00 SPIWrite 062,00 SPIWrite 065,FE SPIWrite 064,00 SPIWrite 064,00 SPIWrite 060,02 SPIWrite 061,04 SPIWrite 062,00 SPIWrite 065,FE SPIWrite 064,00 SPIWrite 064,00 SPIWrite 060,03 SPIWrite 061,17 SPIWrite 062,00 SPIWrite 065,FE SPIWrite 064,00 SPIWrite 064,00 SPIWrite 060,04 SPIWrite 061,24 SPIWrite 062,00 SPIWrite 065,FE SPIWrite 064,00 SPIWrite 064,00 SPIWrite 060,05 SPIWrite 061,28 SPIWrite 062,00 SPIWrite 065,FE SPIWrite 064,00 SPIWrite 064,00 SPIWrite 060,06 |
3个回答
大神,AD9364中这句话的意思是等345.6u后查询0X5E寄存器吗?还是等待2秒(Wait for BBPLL to lock, Timeout 2sec)查询? |
只有小组成员才能发言,加入小组>>
ADP5092 SYS端口为2.09V,但是REG_OUT为0是什么原因?
1249 浏览 1 评论
ad7193差分输入ain1与ain2差是正值时,读到电压与实际值误差小,但为负值值,误差就变的很大
3895 浏览 2 评论
8549 浏览 1 评论
2897 浏览 1 评论
6683 浏览 2 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
680浏览 3评论
AD7190状态寄存器一直是0x80,连续转换模式下RDY不拉低
983浏览 2评论
3895浏览 2评论
894浏览 2评论
706浏览 1评论
GMT+8, 2024-3-28 19:39 , Processed in 0.799917 second(s), Total 83, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
