#include
#include #include "inc/hw_memmap.h" #include "inc/hw_types.h" #include "driverlib/debug.h" #include "driverlib/gpio.h" #include "driverlib/fpu.h" #include "driverlib/pin_map.h" #include "driverlib/sysctl.h" #include "driverlib/systick.h" #include "driverlib/rom.h" #include "driverlib/uart.h" #include "utils/uartstdio.h" #include "driverlib/adc.h" void ConfigureUART(void) [ // // Enable the GPIO Peripheral used by the UART. // ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); // // Enable UART0 // ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); // // Configure GPIO Pins for UART mode. // ROM_GPIOPinConfigure(GPIO_PA0_U0RX); ROM_GPIOPinConfigure(GPIO_PA1_U0TX); ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); // // Use the internal 16MHz oscillator as the UART clock source. // UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC); // // Initialize the UART for console I/O. // UARTStdioConfig(0, 115200, 16000000); ] int main(void) [ uint32_t ui32ADC0Value[4]; volatile uint32_t ui32TempAvg; volatile uint32_t ui32TempValueC; volatile uint32_t ui32TempValueF; SysCtlClockSet(SYSCTL_SYSDIV_5|SYSCTL_USE_PLL|SYSCTL_OSC_MAIN|SYSCTL_XTAL_16MHZ); SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0); ADCSequenceConfigure(ADC0_BASE, 1, ADC_TRIGGER_PROCESSOR, 0); ADCSequenceStepConfigure(ADC0_BASE, 1, 0, ADC_CTL_TS); ADCSequenceStepConfigure(ADC0_BASE, 1, 1, ADC_CTL_TS); ADCSequenceStepConfigure(ADC0_BASE, 1, 2, ADC_CTL_TS); ADCSequenceStepConfigure(ADC0_BASE,1,3,ADC_CTL_TS|ADC_CTL_IE|ADC_CTL_END); ADCSequenceEnable(ADC0_BASE, 1); ConfigureUART(); while(1) [ ADCIntClear(ADC0_BASE, 1); ADCProcessorTrigger(ADC0_BASE, 1); while(!ADCIntStatus(ADC0_BASE, 1, false)) [ ] ADCSequenceDataGet(ADC0_BASE, 1, ui32ADC0Value); ui32TempAvg = (ui32ADC0Value[0] + ui32ADC0Value[1] + ui32ADC0Value[2] + ui32ADC0Value[3] + 2)/4; ui32TempValueC = (1475 - ((2475 * ui32TempAvg)) / 4096)/10; UARTprintf("n芯片温度%d",ui32TempValueC); ui32TempValueF = ((ui32TempValueC * 9) + 160) / 5; ] ] #10010 errors encountered during linking; "ADC_TS.out" not built #10234-D unresolved symbols remain unresolved symbol ROM_GPIOPinConfigure, first referenced in ./main.obj unresolved symbol ROM_GPIOPinTypeUART, first referenced in ./main.obj unresolved symbol ROM_SysCtlPeripheralEnable, first referenced in ./main.obj unresolved symbol UARTprintf, first referenced in ./main.obj unresolved symbol UARTStdioConfig, first referenced in ./main.obj #225-D function "ROM_GPIOPinConfigure" declared implicitly #225-D function "ROM_GPIOPinTypeUART" declared implicitly #225-D function "ROM_SysCtlPeripheralEnable" declared implicitly 出现以上错误 和警告 该如何解决 |
4 个讨论
Zijie
请加入相应的库文件driverlib.bin。 如果使用的是CCS,那么该文件在 ..TivawaredriverlibccsDebug路径下。 对于其他的开发环境,保存在相应的目录下。 针对 unresolved symbol UARTprintf, first referenced in ./main.obj unresolved symbol UARTStdioConfig, first referenced in ./main.obj 请把uartstdio.c添加到工程中, 该文件位置是..Tivawareutils目录下。 Wellin |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1872 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3613 浏览 4 评论
5019 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1725 浏览 1 评论
9311 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
654浏览 2评论
695浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
651浏览 1评论
1178浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1174浏览 1评论
GMT+8, 2024-3-29 03:52 , Processed in 0.717807 second(s), Total 71, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
