你好,我想把一些AptiaMIPI成像器与CX3接口。有没有人连接到AR0835 8MIX成像仪?我很难设置定时GUI,让成像器向Cx3发送信息。是否有任何样本代码允许设置AR0835寄存器?谢谢你的帮助。
以上来自于百度翻译 以下为原文 Hi, I am looking to interface some of the Aptina MIPI imagers to the CX3. Has anyone interfaced to the AR0835 8Mpixel imager? I am having trouble setting up the timing GUI to get the imager to send information to the CX3. Does anyone have sample code that allows for setting the AR0835 registers? Thanks in advance for your help. |
1个回答
你好,
1)你能告诉我们你要流的视频数据的分辨率、帧速率和格式吗? 2)探索MIPI数据和时钟通道。确保它们像预期的一样切换。 3)MIPI时钟选通还是连续?如果传感器在连续时钟模式下流动,请遵循问题中提到的步骤。 13以下链接: HTTP://www. CyPress .COM/知识基础文章/CX3-HARDICE频繁提问-KBA91295 4)使用API“CYU3PMIPICSIGETEATION”打印UART上的MIPI CSI错误计数。检查错误计数是否为非零。 如果是,请仔细检查传感器配置。 5)改变“Cyu3PMIPICSeTeSimeDelaye())API的“thsStalelDelphi”参数,以检查传感器是否为任何延迟值流。始终保持第一个参数为0x01。 6)如果视频还没有流探针以下测试点你能得到零MIPI错误 CX3 PIN 测试信号名称 H8 PCLK测试信号 G6 HSYNC测试信号 H5 VSYNC测试信号 如果只有H8切换而不是其他引脚然后MIPI CSI的配置可能不正确。MIPI CSI进入图像传感器输出正确的价值观的工具和配置PLL分频器适当地使刀具不会产生任何错误。确保使用最新的CX3配置工具插件。 7)确保所有未使用的MIPI数据通道都接地。 8)如果以上工作,请分享你的MIPI CSI配置工具截图。确保工具中输入的值是正确的。 以上来自于百度翻译 以下为原文 Hi, 1) Can you please let us know the resolution, frame rate and the format of the video data that you are trying to stream? 2) Probe the MIPI data & clock lanes. Ensure that they are toggling as expected. 3) Is the MIPI clock gated or continuous? If the sensor is streaming in continuous clock mode, follow the steps mentioned in question 13 of the following link: http://www.cypress.com/knowledge-base-article/cx3-hardware-frequently-asked-questions-kba91295 4) Print the MIPI CSI error counts over UART by using the API “CyU3PMipicsiGetErrors”. Check if any of the error count is non-zero. If yes, double check the sensor configuration. 5) Vary the ‘thsSettleDelay’ parameter of “CyU3PMipicsiSetPhyTimeDelay()” API to check if the sensor is streaming for any of the delay value. Keep the first parameter as 0x01 always. 6) If you were able to get zero MIPI errors and if the video is still not streaming probe the following test points
7) Ensure that all the unused MIPI data lanes are grounded. 8) If none of the above are working, please share the screenshot of your MIPI CSI configuration tool. Make sure that the values entered in the tool are correct. |
只有小组成员才能发言,加入小组>>
713个成员聚集在这个小组
加入小组1888 浏览 1 评论
1637 浏览 1 评论
3392 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1556 浏览 6 评论
1371 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
170浏览 2评论
170浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
304浏览 2评论
323浏览 1评论
45浏览 1评论
GMT+8, 2024-3-28 22:54 , Processed in 0.651774 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
