我想配置一个PE4,PE5两通道采样,配置采样率500k是先使能在配置,还是其他?
在获得数据的时候只有一个函数ADCSequenceDataGet();会不会两通道的数据获得重合?怎样才能精确的获得2通道数据? void ADC0_init(void) [ // Enable GPIO for ADC SysCtlADCSpeedSet(SYSCTL_ADCSPEED_500KSPS); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE); SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0); GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_4);// Enable pin PE4_AIN9 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_5);// Enable pinPE5 _AIN8 ADCSequenceConfigure(ADC0_BASE, 1, ADC_TRIGGER_PROCESSOR, 0); ADCSequenceStepConfigure(ADC0_BASE, 1, 0, ADC_CTL_CH8|ADC_CTL_CH9| ADC_CTL_IE |ADC_CTL_END); ADCSequenceEnable(ADC0_BASE, 1); ADCIntClear(ADC0_BASE, 1);// // ADCIntRegister(ADC0_BASE,1,ADC0IntHandler);// ADCIntEnable(ADC0_BASE,1);// ] |
20 个讨论
Evawang 发表于 2018-8-14 07:51 谢谢回复,你的意思是说比如我设置一个数组unsigned long ulADC0_Value[2];那我用函数才回来的值 ADCSequenceDataGet(ADC0_BASE, 1, ulADC0_Value); ulADC0_Value[0]放的CH8,ulADC0_Value[1]放的CH9是这样的嘛?;;还有这个主要涉及到一个闭环系统,采样过快调节不过来,所以我这样设置采样率对嘛 |
zoms0 发表于 2018-8-14 08:09 是这样理解。关于采样率设置,我记得早的TivaWare的库函数有点问题,后来我改成直接操作寄存器的了。把这个代码分享给您吧。 这里采样的是ADC的CH0~CH7,使能了中断,在中断中就可以直接读出8个数据,对应0~7通道的。 采样率的设置和查询我自己写的函数。 上代码: #include #include #include "inc/hw_memmap.h" #include "driverlib/adc.h" #include "driverlib/gpio.h" #include "driverlib/pin_map.h" #include "driverlib/sysctl.h" #include "driverlib/uart.h" #include "utils/uartstdio.h" #include "driverlib/interrupt.h" #include "inc/hw_ints.h" #include "inc/hw_types.h" #include "inc/hw_adc.h" //***************************************************************************** // //! addtogroup adc_examples_list //! Single Ended ADC (single_ended)//! //! This example shows how to setup ADC0 as a single ended input and take a //! single sample on AIN0/PE7. //! //! This example uses the following peripherals and I/O signals. You must //! review these and change as needed for your own board: //! - ADC0 peripheral //! - GPIO Port E peripheral (for AIN0 pin) //! - AIN0 - PE7 //! //! The following UART signals are configured only for displaying console //! messages for this example. These are not required for operation of the //! ADC. //! - UART0 peripheral //! - GPIO Port A peripheral (for UART0 pins) //! - UART0RX - PA0 //! - UART0TX - PA1 //! //! This example uses the following interrupt handlers. To use this example //! in your own application you must add these interrupt handlers to your //! vector table. //! - None. // //***************************************************************************** #define ADCSAMPLERATE_1MSPS 0x7 // 1,000,000 samples per second #define ADCSAMPLERATE_500KSPS 0x5 // 500,000 samples per second #define ADCSAMPLERATE_250KSPS 0x3 // 250,000 samples per second #define ADCSAMPLERATE_125KSPS 0x1 // 125,000 samples per second //***************************************************************************** // // This function sets up UART0 to be used for a console to display information // as the example is running. // //***************************************************************************** uint32_t pui32ADC0Value[8]; uint32_t Data[8]=[0]; uint32_t TempVal = 0; uint32_t TempVal2 = 0; void ADCSampleRateSet(uint32_t ui32Speed) [ // // Set the ADC speed // HWREG(ADC0_BASE + ADC_O_PC) = (ui32Speed); ] uint32_t ADCSampleRateGet(void) [ // // Return the current ADC speed. // return((HWREG(ADC0_BASE + ADC_O_PC) & 0x0f)); ] void InitConsole(void) [ // // Enable GPIO port A which is used for UART0 pins. // TODO: change this to whichever GPIO port you are using. // SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); // // Configure the pin muxing for UART0 functions on port A0 and A1. // This step is not necessary if your part does not support pin muxing. // TODO: change this to select the port/pin you are using. // GPIOPinConfigure(GPIO_PA0_U0RX); GPIOPinConfigure(GPIO_PA1_U0TX); // // Enable UART0 so that we can configure the clock. // SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); // // Use the internal 16MHz oscillator as the UART clock source. // UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC); // // Select the alternate (UART) function for these pins. // TODO: change this to select the port/pin you are using. // GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); // // Initialize the UART for console I/O. // UARTStdioConfig(0, 115200, 16000000); ] void ADC0Sequence0Isr(void) [ uint16_t i; // // Clear the ADC interrupt flag. // ADCIntClear(ADC0_BASE, 0); // // Read ADC Value. // ADCSequenceDataGet(ADC0_BASE, 0, pui32ADC0Value); for(i = 0;i < 8;i ++) [ Data = pui32ADC0Value*3300/4096; ] SysCtlDelay(1); ] //***************************************************************************** // // Configure ADC0 for a single-ended input and a single sample. Once the // sample is ready, an interrupt flag will be set. Using a polling method, // the data will be read then displayed on the console via UART0. // //***************************************************************************** int main(void) [ // // This array is used for storing the data read from the ADC FIFO. It // must be as large as the FIFO for the sequencer in use. This example // uses sequence 3 which has a FIFO depth of 1. If another sequence // was used with a deeper FIFO, then the array size must be changed. // //uint32_t pui32ADC0Value[8]; //uint32_t Data[8]=[0]; // // Set the clocking to run at 20 MHz (200 MHz / 10) using the PLL. When // using the ADC, you must either use the PLL or supply a 16 MHz clock // source. // TODO: The SYSCTL_XTAL_ value must be changed to match the value of the // crystal on your board. // SysCtlClockSet(SYSCTL_SYSDIV_10 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ); // // Set up the serial console to use for displaying messages. This is // just for this example program and is not needed for ADC operation. // InitConsole(); // // // // Display the setup on the console. // // UARTprintf("ADC ->n"); //UARTprintf(" Type: Single Endedn"); //UARTprintf(" Samples: Onen"); //UARTprintf(" Update Rate: 250msn"); //UARTprintf(" Input Pin: AIN0/PE7nn"); // // The ADC0 peripheral must be enabled for use. // SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0); // // For this example ADC0 is used with AIN0 on port E7. // The actual port and pins used may be different on your part, consult // the data sheet for more information. GPIO port E needs to be enabled // so these pins can be used. // TODO: change this to whichever GPIO port you are using. // SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE); // // Select the analog ADC function for these pins. // Consult the data sheet to see which functions are allocated per pin. // TODO: change this to select the port/pin you are using. // GPIOPinTypeADC(GPIO_PORTD_BASE, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3); GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3); //set sample rate ADCSampleRateSet(ADCSAMPLERATE_1MSPS); // // Enable sample sequence 3 with a processor signal trigger. Sequence 3 // will do a single sample when the processor sends a signal to start the // conversion. Each ADC module has 4 programmable sequences, sequence 0 // to sequence 3. This example is arbitrarily using sequence 3. // ADCSequenceConfigure(ADC0_BASE, 0, ADC_TRIGGER_PROCESSOR, 0); // // Configure step 0 on sequence 3. Sample channel 0 (ADC_CTL_CH0) in // single-ended mode (default) and configure the interrupt flag // (ADC_CTL_IE) to be set when the sample is done. Tell the ADC logic // that this is the last conversion on sequence 3 (ADC_CTL_END). Sequence // 3 has only one programmable step. Sequence 1 and 2 have 4 steps, and // sequence 0 has 8 programmable steps. Since we are only doing a single // conversion using sequence 3 we will only configure step 0. For more // information on the ADC sequences and steps, reference the datasheet. // ADCSequenceStepConfigure(ADC0_BASE, 0, 0, ADC_CTL_CH0 );//PE3 ADCSequenceStepConfigure(ADC0_BASE, 0, 1, ADC_CTL_CH1 );//PE2 ADCSequenceStepConfigure(ADC0_BASE, 0, 2, ADC_CTL_CH2 );//PE1 ADCSequenceStepConfigure(ADC0_BASE, 0, 3, ADC_CTL_CH3 );//PE0 ADCSequenceStepConfigure(ADC0_BASE, 0, 4, ADC_CTL_CH4 );//PD3 ADCSequenceStepConfigure(ADC0_BASE, 0, 5, ADC_CTL_CH5 );//PD2 ADCSequenceStepConfigure(ADC0_BASE, 0, 6, ADC_CTL_CH6 );//PD1 ADCSequenceStepConfigure(ADC0_BASE, 0, 7, ADC_CTL_CH7 | ADC_CTL_IE |ADC_CTL_END); ADCIntEnable(ADC0_BASE, 0); IntEnable(INT_ADC0SS0); IntMasterEnable(); ADCIntClear(ADC0_BASE, 0); // // Since sample sequence 3 is now configured, it must be enabled. // ADCSequenceEnable(ADC0_BASE, 0); // // Clear the interrupt status flag. This is done to make sure the // interrupt flag is cleared before we sample. // TempVal = ADCSampleRateGet(); // // Sample AIN0 forever. Display the value on the console. // while(1) [ // // Trigger the ADC conversion. // ADCProcessorTrigger(ADC0_BASE, 0); /* // // Wait for conversion to be completed. // while(!ADCIntStatus(ADC0_BASE, 0, false)) [ ] // // Clear the ADC interrupt flag. // ADCIntClear(ADC0_BASE, 0); // // Read ADC Value. // ADCSequenceDataGet(ADC0_BASE, 0, pui32ADC0Value); */ /* Data[0] = pui32ADC0Value[0]*3300/4096; Data[1] = pui32ADC0Value[1]*3300/4096; Data[2] = pui32ADC0Value[2]*3300/4096; Data[3] = pui32ADC0Value[3]*3300/4096; Data[4] = pui32ADC0Value[4]*3300/4096; Data[5] = pui32ADC0Value[5]*3300/4096; Data[6] = pui32ADC0Value[6]*3300/4096; Data[7] = pui32ADC0Value[7]*3300/4096; */ // // Display the AIN0 (PE7) digital value on the console. // // UARTprintf("AIN0 = %4dr", pui32ADC0Value[0]); // // This function provides a means of generating a constant length // delay. The function delay (in cycles) = 3 * parameter. Delay // 250ms arbitrarily. // SysCtlDelay(SysCtlClockGet() / 12); ] ] |
Evawang 发表于 2018-8-14 07:51 1.我在代码中没看到有中断函数,请问中断内做了操作 2.ADC的中断触发配置为采样结束触发 ,应该怎么写? 在void ADCIntEnableEx(uint32_t ui32Base,uint32_t ui32IntFlags) 中: ADC_INT_SS0 - interrupt due to ADC sample sequence 0. ADC_INT_DMA_SS0 - interrupt due to DMA on ADC sample sequence 0. ADC_INT_DCON_SS0 - interrupt due to digital comparator on ADC sample sequence 0. 这三个出发类型选择,分别是什么意思? 3.我在您的代码里没看到有配置触发方式的这一句,如果不配置,默认是什么方式触发? |
Evawang 发表于 2018-8-14 08:27 您好,我配制成4通道同时采集总是会出现固定的误差,比测试电压高300mV左右,目前就第一个通道有输入电压,其它几个通道悬空,这样其余通道也会出现挺大的电压数据,请问是怎么回事呢? 代码: #define ADC_SSx 1 //采样序列定义 /* ================================================================================ 描述 : 输入 : 输出 : ================================================================================ */ void user_adcInit(void) [ SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);//开启ADC时钟 SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);//开启相应ADC引脚时钟 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3 | GPIO_PIN_2 | GPIO_PIN_1 | GPIO_PIN_0);//通道引脚初始化 ADCSequenceConfigure(ADC0_BASE, ADC_SSx, ADC_TRIGGER_PROCESSOR, 0);//ADC模式配置 ADCSequenceStepConfigure(ADC0_BASE, ADC_SSx, 0, ADC_CTL_CH0);//采样通道配置 ADCSequenceStepConfigure(ADC0_BASE, ADC_SSx, 1, ADC_CTL_CH1);//采样通道配置 ADCSequenceStepConfigure(ADC0_BASE, ADC_SSx, 2, ADC_CTL_CH2);//采样通道配置 ADCSequenceStepConfigure(ADC0_BASE, ADC_SSx, 3, ADC_CTL_CH3 | ADC_CTL_IE | ADC_CTL_END);//采样通道配置 ADCSequenceEnable(ADC0_BASE, ADC_SSx); //使能采样序列 ADCIntClear(ADC0_BASE, ADC_SSx); //清除中断标志 ] /* ================================================================================ 描述 :主程序循环调用 输入 : 输出 : ================================================================================ */ void ADC_Read(void) [ uint32_t pui32ADC0Value[8]; u8 i; memset(pui32ADC0Value, 0, sizeof(pui32ADC0Value)); ADCProcessorTrigger(ADC0_BASE, ADC_SSx); while(!ADCIntStatus(ADC0_BASE, ADC_SSx, false)); ADCIntClear(ADC0_BASE, ADC_SSx); ADCSequenceDataGet(ADC0_BASE, ADC_SSx, pui32ADC0Value); for(i=0;i<4;i++) [ UARTprintf("ADC Value%d=%dmVn",i,pui32ADC0Value*3300/4096); ] UARTprintf("******************n"); ] 输出数据: |
#include #include #include "inc/hw_memmap.h" #include "driverlib/adc.h" #include "driverlib/gpio.h" #include "driverlib/pin_map.h" #include "driverlib/sysctl.h" #include "driverlib/uart.h" #include "utils/uartstdio.h" //***************************************************************************** // //! addtogroup adc_examples_list //! ADC Temperature Sensor (temperature_sensor)//! //! This example shows how to setup ADC0 to read the internal temperature //! sensor. //! //! NOTE: The internal temperature sensor is not calibrated. This example //! just takes the raw temperature sensor sample and converts it using the //! equation found in the LM3S9B96 datasheet. //! //! This example uses the following peripherals and I/O signals. You must //! review these and change as needed for your own board: //! - ADC0 peripheral //! //! The following UART signals are configured only for displaying console //! messages for this example. These are not required for operation of the //! ADC. //! - UART0 peripheral //! - GPIO Port A peripheral (for UART0 pins) //! - UART0RX - PA0 //! - UART0TX - PA1 //! //! This example uses the following interrupt handlers. To use this example //! in your own application you must add these interrupt handlers to your //! vector table. //! - None. // //***************************************************************************** //***************************************************************************** // // This function sets up UART0 to be used for a console to display information // as the example is running. // //***************************************************************************** void InitConsole(void) [ // // Enable GPIO port A which is used for UART0 pins. // TODO: change this to whichever GPIO port you are using. // SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); // // Configure the pin muxing for UART0 functions on port A0 and A1. // This step is not necessary if your part does not support pin muxing. // TODO: change this to select the port/pin you are using. // GPIOPinConfigure(GPIO_PA0_U0RX); GPIOPinConfigure(GPIO_PA1_U0TX); // // Enable UART0 so that we can configure the clock. // SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); // // Use the internal 16MHz oscillator as the UART clock source. // UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC); // // Select the alternate (UART) function for these pins. // TODO: change this to select the port/pin you are using. // GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); // // Initialize the UART for console I/O. // UARTStdioConfig(0, 115200, 16000000); ] int main(void) [ uint32_t ui32ADC0Value[4]; //volatile uint32_t ui32TempAvg; //volatile uint32_t ui32TempValueC; //volatile uint32_t ui32TempValueF; SysCtlClockSet(SYSCTL_SYSDIV_10|SYSCTL_USE_PLL|SYSCTL_OSC_MAIN|SYSCTL_XTAL_16MHZ); InitConsole(); // // Display the setup on the console. // UARTprintf("ADC ->n"); UARTprintf(" Type: Internal Temperature Sensorn"); UARTprintf(" Samples: Onen"); UARTprintf(" Update Rate: 250msn"); UARTprintf(" Input Pin: Internal temperature sensornn"); //5??,??PLL,????16M,system????? main osc?????40MHZ SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0); //??ADC0 //SysCtlADCSpeedSet(SYSCTL_ADCSPEED_1000KSPS); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE); GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3);// Enable pin PE4_AIN0 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_2);// Enable pinPE5 _AIN1 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_5);// Enable pin PE4_AIN8 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_4);// Enable pinPE5 _AIN9 ADCSequenceConfigure(ADC0_BASE, 1, ADC_TRIGGER_PROCESSOR, 0); //We want to use ADC0, sample sequencer 1, //we want the processor to trigger the sequence and we want to use the highest priority //ADCSequenceStepConfigure(ADC0_BASE, 1, 0, ADC_CTL_TS); //ADCSequenceStepConfigure(ADC0_BASE, 1, 1, ADC_CTL_TS); //ADCSequenceStepConfigure(ADC0_BASE, 1, 2, ADC_CTL_TS); //Configure steps 0 - 2 on sequencer 1 to sample the temperature sensor (ADC_CTL_TS). ADCSequenceStepConfigure(ADC0_BASE,1,0,ADC_CTL_CH0|ADC_CTL_CH1|ADC_CTL_CH8|ADC_CTL_CH9|ADC_CTL_IE|ADC_CTL_END); //Sample the temperature sensor (ADC_CTL_TS) and configure the interrupt flag (ADC_CTL_IE) //Tell the ADC logic that this is the last conversion on sequencer1 (ADC_CTL_END). ADCSequenceEnable(ADC0_BASE, 1); //enable ADC sequencer 1 while(1) [ ADCIntClear(ADC0_BASE, 1); ADCProcessorTrigger(ADC0_BASE, 1); //trigger the ADC conversion with software while(!ADCIntStatus(ADC0_BASE, 1, false)) [ ] //wait for the conversion to complete ADCSequenceDataGet(ADC0_BASE, 1, ui32ADC0Value); // ui32TempAvg = (ui32ADC0Value[0] + ui32ADC0Value[1] + ui32ADC0Value[2] + ui32ADC0Value[3] + 2)/4; //Since 2/4 = 1/2 = 0.5, 1.5 will be rounded to 2.0 with //the addition of 0.5. In the case of 1.0, when 0.5 is added to yield 1.5, this will be rounded //back down to 1.0 due to the rules of integer math.????? // ui32TempValueC = (1475 - ((2475 * ui32TempAvg)) / 4096)/10; //TEMP = 147.5 – ((75 * (VREFP – VREFN) * ADCVALUE) / 4096) //VREFP – VREFN=3.3V // ui32TempValueF = ((ui32TempValueC * 9) + 160) / 5; UARTprintf("%d %d %d %drn", ui32ADC0Value[0],ui32ADC0Value[1],ui32ADC0Value[2], ui32ADC0Value[3] ); //F = ( C * 9)/5 +32 ] ] 请问我这个代码哪里有错,我想接受4路数据,我使用一个16位的DA,分别发送0.5/1/2/3V四个电压,这是接收到的数据 3997 0 0 536871424 4033 0 0 536871424 4037 0 0 536871424 3997 0 0 536871424 4035 0 0 536871424 2758 0 0 536871424 2692 0 0 536871424 2708 0 0 536871424 2737 0 0 536871424 2717 0 0 536871424 3602 0 0 536871424 3953 0 0 536871424 3934 0 0 536871424 4028 0 0 536871424 3995 0 0 536871424 3237 0 0 536871424 2696 0 0 536871424 2707 0 0 536871424 2716 0 0 536871424 2750 0 0 536871424 2834 0 0 536871424 4031 0 0 536871424 4080 0 0 536871424 4004 0 0 536871424 4041 0 0 536871424 3934 0 0 536871424 2719 0 0 536871424 2691 0 0 536871424 2696 0 0 536871424 2725 0 0 536871424 2712 0 0 536871424 3858 0 0 536871424 4033 0 0 536871424 4036 0 0 536871424 4032 0 0 536871424 3975 0 0 536871424 3036 0 0 536871424 2714 0 0 536871424 2716 0 0 536871424 2757 0 0 536871424 2709 0 0 536871424 3012 0 0 536871424 4020 0 0 536871424 请帮忙看一下,谢谢 |
ljmlvmd 发表于 2018-8-14 10:40 您好,听了你的建议我把0改成了三但是结果成了 0 0 0 2826 0 0 0 2777 471 464 448 3304 1173 1155 1189 4095 1151 1153 1162 4029 1241 1159 1171 4095 1239 1227 1242 4084 771 841 747 3700 0 0 0 2721 0 0 0 2686 0 0 0 2681 0 0 0 2688 0 0 0 2727 0 0 0 2759 0 0 0 2758 447 439 458 3318 1154 1187 1134 3926 1171 1239 1166 4034 1083 1123 1179 4012 995 1095 1200 3955 895 897 904 3751 0 0 0 2702 0 0 0 2690 0 0 0 2655 0 0 0 2691 2 0 0 2754 0 0 0 2724 0 0 0 2711 286 325 232 3246 1159 1129 1160 4001 1190 1178 1199 4070 1175 1132 1100 4017 1139 1155 1148 4075 939 868 852 3775 输入是稳定的,用万用表测过了 |
这一句一个个来, ADCSequenceStepConfigure(ADC0_BASE,1,0,ADC_CTL_CH0|ADC_CTL_CH1|ADC_CTL_CH8|ADC_CTL_CH9|ADC_CTL_IE|ADC_CTL_END); 换成这样: ADCSequenceStepConfigure(ADC0_BASE,1,0,ADC_CTL_CH0); ADCSequenceStepConfigure(ADC0_BASE,1,1,ADC_CTL_CH1); ADCSequenceStepConfigure(ADC0_BASE,1,2,ADC_CTL_CH8); ADCSequenceStepConfigure(ADC0_BASE,1,3,ADC_CTL_CH9|ADC_CTL_IE|ADC_CTL_END); |
预言者J 发表于 2018-8-14 11:01 您好,我改了,现在的代码是这个样子的 int main(void) [ uint32_t ui32ADC0Value[4]; //volatile uint32_t ui32TempAvg; //volatile uint32_t ui32TempValueC; //volatile uint32_t ui32TempValueF; SysCtlClockSet(SYSCTL_SYSDIV_5 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ); InitConsole(); // // Display the setup on the console. // UARTprintf("ADC ->n"); UARTprintf(" Type: Internal Temperature Sensorn"); UARTprintf(" Samples: Onen"); UARTprintf(" Update Rate: 250msn"); UARTprintf(" Input Pin: Internal temperature sensornn"); //5??,??PLL,????16M,system????? main osc?????40MHZ SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0); //??ADC0 //SysCtlADCSpeedSet(SYSCTL_ADCSPEED_1000KSPS); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE); GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3);// Enable pin PE4_AIN0 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_2);// Enable pinPE5 _AIN1 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_5);// Enable pin PE4_AIN8 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_4);// Enable pinPE5 _AIN9 ADCSequenceConfigure(ADC0_BASE, 1, ADC_TRIGGER_PROCESSOR, 0); //We want to use ADC0, sample sequencer 1, //we want the processor to trigger the sequence and we want to use the highest priority ADCSequenceStepConfigure(ADC0_BASE, 1, 0, ADC_CTL_CH0); ADCSequenceStepConfigure(ADC0_BASE, 1, 1, ADC_CTL_CH1); ADCSequenceStepConfigure(ADC0_BASE, 1, 2, ADC_CTL_CH8); //Configure steps 0 - 2 on sequencer 1 to sample the temperature sensor (ADC_CTL_TS). ADCSequenceStepConfigure(ADC0_BASE,1,3,ADC_CTL_CH9|ADC_CTL_IE|ADC_CTL_END); //Sample the temperature sensor (ADC_CTL_TS) and configure the interrupt flag (ADC_CTL_IE) //Tell the ADC logic that this is the last conversion on sequencer1 (ADC_CTL_END). ADCSequenceEnable(ADC0_BASE, 1); //enable ADC sequencer 1 while (1) [ ADCIntClear(ADC0_BASE, 1); ADCProcessorTrigger(ADC0_BASE, 1); //trigger the ADC conversion with software while (!ADCIntStatus(ADC0_BASE, 1, false)) [ ] //wait for the conversion to complete ADCSequenceDataGet(ADC0_BASE, 1, ui32ADC0Value); // ui32TempAvg = (ui32ADC0Value[0] + ui32ADC0Value[1] + ui32ADC0Value[2] + ui32ADC0Value[3] + 2)/4; //Since 2/4 = 1/2 = 0.5, 1.5 will be rounded to 2.0 with //the addition of 0.5. In the case of 1.0, when 0.5 is added to yield 1.5, this will be rounded //back down to 1.0 due to the rules of integer math.????? // ui32TempValueC = (1475 - ((2475 * ui32TempAvg)) / 4096)/10; //TEMP = 147.5 – ((75 * (VREFP – VREFN) * ADCVALUE) / 4096) //VREFP – VREFN=3.3V // ui32TempValueF = ((ui32TempValueC * 9) + 160) / 5; UARTprintf("%d %d %d %drn", ui32ADC0Value[0], ui32ADC0Value[1], ui32ADC0Value[2], ui32ADC0Value[3]); //F = ( C * 9)/5 +32 ] ] 输入没有变化,结果却是 395 895 2118 3266 1193 1717 2790 4095 1088 1797 2970 4095 1098 1729 2848 4031 1231 1774 2970 4095 723 1371 2529 3779 0 283 1384 2821 0 303 1471 2633 0 317 1493 2765 0 391 1593 2742 0 329 1474 2714 291 909 2048 3286 1106 1819 2956 4095 1190 1707 2811 4095 1115 1827 2940 4095 1186 1755 2917 4070 726 1321 2446 3641 0 465 1490 2731 0 343 1546 2742 0 435 1492 2750 0 355 1516 2731 0 407 1578 2850 186 815 2066 3230 1242 1787 2962 4095 1091 1773 2974 4095 1143 1723 2975 4095 1142 1745 2938 4095 806 1369 2600 3714 0 401 1572 2781 0 347 1482 2726 0 619 1574 2786 0 341 1535 2732 0 365 1592 2755 343 928 2068 3311 1131 1725 2912 4095 1287 1827 2932 4095 1167 1749 2862 4016 1215 1772 2949 4095 743 1367 2498 3743 0 389 1486 2751 0 340 1560 2741 87 515 1578 2768 0 336 1485 2683 0 337 1595 2804 366 969 2157 3288 1057 1712 2867 4043 1159 1772 2818 3999 1151 1793 2932 4095 1271 1838 2978 4095 758 1299 2460 3762 0 433 1531 2732 0 369 1641 2803 0 388 1584 2756 0 309 1532 2738 0 359 1536 2740 但是我把PE4引脚和VCC接到一起,结果是这样的 939 1575 2831 4095 915 1581 2834 4095 927 1581 2833 4095 932 1573 2825 4095 917 1569 2836 4095 914 1571 2831 4095 915 1567 2835 4095 918 1573 2825 4095 924 1573 2833 4095 915 1573 2844 4095 914 1571 2832 4095 927 1575 2834 4095 915 1575 2831 4095 925 1585 2833 4095 921 1575 2820 4095 918 1563 2825 4095 911 1575 2828 4095 939 1583 2833 4095 922 1579 2829 4095 935 1577 2834 4094 924 1571 2821 4095 931 1571 2832 4095 911 1595 2822 4095 920 1569 2828 4095 927 1571 2828 4095 923 1580 2832 4095 942 1577 2833 4095 918 1587 2842 4095 935 1575 2840 4095 918 1569 2828 4095 899 1567 2824 4095 910 1579 2828 4095 926 1575 2828 4095 923 1581 2832 4095 918 1569 2830 4095 929 1575 2829 4095 918 1571 2834 4095 922 1568 2817 4095 915 1567 2827 4095 919 1577 2832 4095 923 1573 2831 4095 903 1571 2828 4095 927 1582 2832 4095 932 1584 2825 4095 927 1568 2825 4095 924 1563 2829 4095 911 1579 2834 4095 925 1571 2826 4095 921 1568 2812 4095 921 1569 2828 4095 908 1561 2825 4095 941 1578 2830 4095 926 1579 2828 4095 919 1571 2831 4095 907 1565 2831 4095 915 1571 2814 4095 923 1571 2832 4095 907 1579 2837 4095 927 1569 2824 4095 931 1593 2846 4095 925 1575 2826 4095 926 1581 2833 4095 923 1577 2829 4095 926 1576 2830 4095 927 1576 2828 4095 909 1568 2814 4095 926 1569 2831 4095 922 1575 2827 4095 926 1570 2829 4095 918 1575 2837 4095 915 1577 2833 4095 919 1581 2832 4095 923 1575 2836 4095 917 1579 2830 4095 930 1575 2830 4095 911 1573 2831 4095 926 1573 2826 4095 926 1583 2831 4095 929 1587 2828 4095 932 1579 2831 4095 922 1568 2830 4088 932 1579 2847 4095 911 1571 2828 4095 918 1571 2828 4095 928 1579 2829 4095 923 1583 2830 4095 923 1587 2833 4095 918 1566 2827 4095 919 1571 2827 4095 919 1570 2827 4095 915 1543 2834 4095 899 1571 2827 4095 927 1557 2826 4095 915 1577 2829 4095 923 1583 2828 4095 920 1573 2824 4095 919 1568 2824 4095 919 1577 2836 4095 923 1573 2833 4095 916 1571 2834 4095 915 1571 2833 4095 915 1575 2829 4095 919 1567 2824 4095 921 1569 2826 4095 923 1575 2825 4095 931 1577 2833 4095 919 1574 2827 4095 923 1579 2825 4095 935 1569 2854 4095 925 1571 2822 4095 916 1575 2820 4095 923 1583 2828 4095 914 1553 2814 4095 919 1567 2830 4095 919 1573 2834 4095 927 15 79 2810 4095 918 1575 2834 4095 926 1571 2831 4095 918 1581 2824 4087 923 1577 2834 4095 923 1575 2830 4095 933 1576 2833 4095 931 1581 2830 4095 927 1585 2828 4094 911 1571 2836 4095 923 1575 2828 4095 919 1577 2830 4095 929 1581 2817 4095 933 1575 2832 4095 919 1583 2828 4095 927 1578 2833 4095 931 1580 2828 4095 930 1577 2826 4095 928 1577 2831 4095 925 1569 2827 4095 931 1581 2830 4095 917 1571 2833 4095 |
ljmlvmd 发表于 2018-8-14 10:40 您好,我改了,现在的代码是这个样子的 int main(void) [ uint32_t ui32ADC0Value[4]; //volatile uint32_t ui32TempAvg; //volatile uint32_t ui32TempValueC; //volatile uint32_t ui32TempValueF; SysCtlClockSet(SYSCTL_SYSDIV_5 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ); InitConsole(); // // Display the setup on the console. // UARTprintf("ADC ->n"); UARTprintf(" Type: Internal Temperature Sensorn"); UARTprintf(" Samples: Onen"); UARTprintf(" Update Rate: 250msn"); UARTprintf(" Input Pin: Internal temperature sensornn"); //5??,??PLL,????16M,system????? main osc?????40MHZ SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0); //??ADC0 //SysCtlADCSpeedSet(SYSCTL_ADCSPEED_1000KSPS); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE); GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3);// Enable pin PE4_AIN0 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_2);// Enable pinPE5 _AIN1 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_5);// Enable pin PE4_AIN8 GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_4);// Enable pinPE5 _AIN9 ADCSequenceConfigure(ADC0_BASE, 1, ADC_TRIGGER_PROCESSOR, 0); //We want to use ADC0, sample sequencer 1, //we want the processor to trigger the sequence and we want to use the highest priority ADCSequenceStepConfigure(ADC0_BASE, 1, 0, ADC_CTL_CH0); ADCSequenceStepConfigure(ADC0_BASE, 1, 1, ADC_CTL_CH1); ADCSequenceStepConfigure(ADC0_BASE, 1, 2, ADC_CTL_CH8); //Configure steps 0 - 2 on sequencer 1 to sample the temperature sensor (ADC_CTL_TS). ADCSequenceStepConfigure(ADC0_BASE,1,3,ADC_CTL_CH9|ADC_CTL_IE|ADC_CTL_END); //Sample the temperature sensor (ADC_CTL_TS) and configure the interrupt flag (ADC_CTL_IE) //Tell the ADC logic that this is the last conversion on sequencer1 (ADC_CTL_END). ADCSequenceEnable(ADC0_BASE, 1); //enable ADC sequencer 1 while (1) [ ADCIntClear(ADC0_BASE, 1); ADCProcessorTrigger(ADC0_BASE, 1); //trigger the ADC conversion with software while (!ADCIntStatus(ADC0_BASE, 1, false)) [ ] //wait for the conversion to complete ADCSequenceDataGet(ADC0_BASE, 1, ui32ADC0Value); // ui32TempAvg = (ui32ADC0Value[0] + ui32ADC0Value[1] + ui32ADC0Value[2] + ui32ADC0Value[3] + 2)/4; //Since 2/4 = 1/2 = 0.5, 1.5 will be rounded to 2.0 with //the addition of 0.5. In the case of 1.0, when 0.5 is added to yield 1.5, this will be rounded //back down to 1.0 due to the rules of integer math.????? // ui32TempValueC = (1475 - ((2475 * ui32TempAvg)) / 4096)/10; //TEMP = 147.5 – ((75 * (VREFP – VREFN) * ADCVALUE) / 4096) //VREFP – VREFN=3.3V // ui32TempValueF = ((ui32TempValueC * 9) + 160) / 5; UARTprintf("%d %d %d %drn", ui32ADC0Value[0], ui32ADC0Value[1], ui32ADC0Value[2], ui32ADC0Value[3]); //F = ( C * 9)/5 +32 ] ] 输入没有变化,结果却是 395 895 2118 3266 1193 1717 2790 4095 1088 1797 2970 4095 1098 1729 2848 4031 1231 1774 2970 4095 723 1371 2529 3779 0 283 1384 2821 0 303 1471 2633 0 317 1493 2765 0 391 1593 2742 0 329 1474 2714 291 909 2048 3286 1106 1819 2956 4095 1190 1707 2811 4095 1115 1827 2940 4095 1186 1755 2917 4070 726 1321 2446 3641 0 465 1490 2731 0 343 1546 2742 0 435 1492 2750 0 355 1516 2731 0 407 1578 2850 186 815 2066 3230 1242 1787 2962 4095 1091 1773 2974 4095 1143 1723 2975 4095 1142 1745 2938 4095 806 1369 2600 3714 0 401 1572 2781 0 347 1482 2726 0 619 1574 2786 0 341 1535 2732 0 365 1592 2755 343 928 2068 3311 1131 1725 2912 4095 1287 1827 2932 4095 1167 1749 2862 4016 1215 1772 2949 4095 743 1367 2498 3743 0 389 1486 2751 0 340 1560 2741 87 515 1578 2768 0 336 1485 2683 0 337 1595 2804 366 969 2157 3288 1057 1712 2867 4043 1159 1772 2818 3999 1151 1793 2932 4095 1271 1838 2978 4095 758 1299 2460 3762 0 433 1531 2732 0 369 1641 2803 0 388 1584 2756 0 309 1532 2738 0 359 1536 2740 但是我把PE4引脚和VCC接到一起,结果是这样的 939 1575 2831 4095 915 1581 2834 4095 927 1581 2833 4095 932 1573 2825 4095 917 1569 2836 4095 914 1571 2831 4095 915 1567 2835 4095 918 1573 2825 4095 924 1573 2833 4095 915 1573 2844 4095 914 1571 2832 4095 927 1575 2834 4095 915 1575 2831 4095 925 1585 2833 4095 921 1575 2820 4095 918 1563 2825 4095 911 1575 2828 4095 939 1583 2833 4095 922 1579 2829 4095 935 1577 2834 4094 924 1571 2821 4095 931 1571 2832 4095 911 1595 2822 4095 920 1569 2828 4095 927 1571 2828 4095 923 1580 2832 4095 942 1577 2833 4095 918 1587 2842 4095 935 1575 2840 4095 918 1569 2828 4095 899 1567 2824 4095 910 1579 2828 4095 926 1575 2828 4095 923 1581 2832 4095 918 1569 2830 4095 929 1575 2829 4095 918 1571 2834 4095 922 1568 2817 4095 915 1567 2827 4095 919 1577 2832 4095 923 1573 2831 4095 903 1571 2828 4095 927 1582 2832 4095 932 1584 2825 4095 927 1568 2825 4095 924 1563 2829 4095 911 1579 2834 4095 925 1571 2826 4095 921 1568 2812 4095 921 1569 2828 4095 908 1561 2825 4095 941 1578 2830 4095 926 1579 2828 4095 919 1571 2831 4095 907 1565 2831 4095 915 1571 2814 4095 923 1571 2832 4095 907 1579 2837 4095 927 1569 2824 4095 931 1593 2846 4095 925 1575 2826 4095 926 1581 2833 4095 923 1577 2829 4095 926 1576 2830 4095 927 1576 2828 4095 909 1568 2814 4095 926 1569 2831 4095 922 1575 2827 4095 926 1570 2829 4095 918 1575 2837 4095 915 1577 2833 4095 919 1581 2832 4095 923 1575 2836 4095 917 1579 2830 4095 930 1575 2830 4095 911 1573 2831 4095 926 1573 2826 4095 926 1583 2831 4095 929 1587 2828 4095 932 1579 2831 4095 922 1568 2830 4088 932 1579 2847 4095 911 1571 2828 4095 918 1571 2828 4095 928 1579 2829 4095 923 1583 2830 4095 923 1587 2833 4095 918 1566 2827 4095 919 1571 2827 4095 919 1570 2827 4095 915 1543 2834 4095 899 1571 2827 4095 927 1557 2826 4095 915 1577 2829 4095 923 1583 2828 4095 920 1573 2824 4095 919 1568 2824 4095 919 1577 2836 4095 923 1573 2833 4095 916 1571 2834 4095 915 1571 2833 4095 915 1575 2829 4095 919 1567 2824 4095 921 1569 2826 4095 923 1575 2825 4095 931 1577 2833 4095 919 1574 2827 4095 923 1579 2825 4095 935 1569 2854 4095 925 1571 2822 4095 916 1575 2820 4095 923 1583 2828 4095 914 1553 2814 4095 919 1567 2830 4095 919 1573 2834 4095 927 15 79 2810 4095 918 1575 2834 4095 926 1571 2831 4095 918 1581 2824 4087 923 1577 2834 4095 923 1575 2830 4095 933 1576 2833 4095 931 1581 2830 4095 927 1585 2828 4094 911 1571 2836 4095 923 1575 2828 4095 919 1577 2830 4095 929 1581 2817 4095 933 1575 2832 4095 919 1583 2828 4095 927 1578 2833 4095 931 1580 2828 4095 930 1577 2826 4095 928 1577 2831 4095 925 1569 2827 4095 931 1581 2830 4095 917 1571 2833 4095 还有接线的时候不是直接PE3、PE2、PE5/PE4吗,谢谢您 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9353 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
1186浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
GMT+8, 2024-4-19 12:29 , Processed in 0.697985 second(s), Total 59, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
