z-stack_linux_gateway 在BB Black上运行./zigbeeHWgw bbb 出现错误
完全按照ti发布的z-stack_linux_gateway 的文档上操作。但在运行时还是出现了 一下错误,请问这个问题是可执行程序和BB Black上的系统不兼容么?还有有其他原因...... root@beaglebone:~/z-stack_linux_gateway_ARM_binaries_38883# ls app misc protobuf servers tools root@beaglebone:~/z-stack_linux_gateway_arm_binaries_38883# cd servers/ root@beaglebone:~/z-stack_linux_gateway_arm_binaries_38883/servers# ls config.ini NPI_Gateway.cfg OTA_SRVR_arm track_servers gateway_config.tlg NPI_lnx_arm_server sample_app_ota.cfg zigbeeHAgw GATEWAY_SRVR_arm NWKMGR_SRVR_arm start_application ZLSZNP_arm root@beaglebone:~/z-stack_linux_gateway_arm_binaries_38883/servers# ./zigbeeHAgw bbb running zigbeegw.scr on an ARM resetting beaglebone black sleeping 6 seconds after reset... Using serial port: /dev/ttyACM0 zbSocProcessRpc: CMD0:41, CMD1:80, not handled Received System version. Transport Protocol Version: 2 Product ID: 0 Software Release: 2.6.1 Software Revision: 38724 done Starting the ZigBee gateway subsystem deviceKey = 0 (0 ) devPath = '/dev/ttyACM0' logPath = './NpiLnxLog.txt' ... freeing memory (ret 0) Port: 2533 Following IP addresses are available: ./zigbeeHAgw: line 324: 676 Segmentation fault $NPI_CMD NPI started (pid 676) at Thu Nov 12 21:30:07 UTC 2015 connect: Connection refused [ZSTACKZNP_SRVR/MAIN] ERROR: ERROR: signal 11 was trigerred: [ZSTACKZNP_SRVR/MAIN] ERROR: Fault address: (nil) [ZSTACKZNP_SRVR/MAIN] ERROR: Fault reason: address not mapped to object [ZSTACKZNP_SRVR/MAIN] ERROR: Stack trace unavailable [ZSTACKZNP_SRVR/MAIN] ERROR: Executing original handler... ./zigbeeHAgw: line 351: 681 Segmentation fault $ZLSZNP_CMD ZLSZNP started (pid 681) at Thu Nov 12 21:30:12 UTC 2015 [NWK_MGR/MAIN] : there are 2 args [NWK_MGR/MAIN] : argv[0] = ./NWKMGR_SRVR_arm [NWK_MGR/MAIN] : argv[1] = 127.0.0.1:2536 connect: Connection refused [NWK_MGR/MAIN] ERROR: ERROR: signal 11 was trigerred: [NWK_MGR/MAIN] ERROR: Fault address: (nil) [NWK_MGR/MAIN] ERROR: Fault reason: address not mapped to object [NWK_MGR/MAIN] ERROR: Stack trace unavailable [NWK_MGR/MAIN] ERROR: Executing original handler... ./zigbeeHAgw: line 407: 684 Segmentation fault $NWKMGR_CMD $NWKMGR_RESTART_FLAG NETWORK MANAGER started (pid 684) at Thu Nov 12 21:30:13 UTC 2015 connect: Connection refused connect: Connection refused |
2 个讨论
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1872 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3613 浏览 4 评论
5019 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1725 浏览 1 评论
9311 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
654浏览 2评论
697浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
651浏览 1评论
1178浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1174浏览 1评论
GMT+8, 2024-3-29 06:26 , Processed in 0.801331 second(s), Total 69, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
