自己新做的板子,第一次用多核芯片,很多不懂的,目前在调试,GEL初始化时出现问题。
板子芯片是6655,和FPGA相连,FPGA给复位信号后能正常复位,GEL文件用的是C6657L GEL,想在它的基础上改的。直接用C6657L GEL,得到的结果如下: C66xx_0: GEL Output: Setup_Memory_Map... C66xx_0: GEL Output: Setup_Memory_Map... Done. C66xx_0: GEL Output: Connecting Target... C66xx_0: GEL Output: DSP core #0 C66xx_0: GEL Output: C6657L GEL file Ver is 1.003 C66xx_0: GEL Output: Global Default Setup... C66xx_0: GEL Output: Setup Cache... C66xx_0: GEL Output: L1P = 32K C66xx_0: GEL Output: L1D = 32K C66xx_0: GEL Output: L2 = ALL SRAM C66xx_0: GEL Output: Setup Cache... Done. C66xx_0: GEL Output: Main PLL (PLL1) Setup ... C66xx_0: GEL Output: PLL in Bypass ... C66xx_0: GEL Output: PLL1 Setup for DSP @ 1000.0 MHz. C66xx_0: GEL Output: SYSCLK2 = 333.3333 MHz, SYSCLK5 = 200.0 MHz. C66xx_0: GEL Output: SYSCLK8 = 15.625 MHz. C66xx_0: GEL Output: PLL1 Setup... Done. C66xx_0: GEL Output: Power on all PSC modules and DSP domains... C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=12, md=4! C66xx_0: GEL Output: Power on all PSC modules and DSP domains... Done. C66xx_0: GEL Output: DDR3 PLL (PLL2) Setup ... C66xx_0: GEL Output: DDR3 PLL Setup... Done. C66xx_0: GEL Output: DDR3 Init begin (1333 auto) C66xx_0: GEL Output: XMC Setup ... Done C66xx_0: GEL Output: DDR3 initialization is complete. C66xx_0: GEL Output: DDR3 Init done C66xx_0: GEL Output: DDR3 memory test... Started C66xx_0: GEL Output: DDR3 memory test... Failed C66xx_0: GEL Output: Main PLL (PLL1) Setup ... C66xx_0: GEL Output: PLL not in Bypass, Enable BYPASS in the PLL Controller... C66xx_0: GEL Output: PLL1 Setup for DSP @ 1000.0 MHz. C66xx_0: GEL Output: SYSCLK2 = 333.3333 MHz, SYSCLK5 = 200.0 MHz. C66xx_0: GEL Output: SYSCLK8 = 15.625 MHz. C66xx_0: GEL Output: PLL1 Setup... Done. C66xx_0: GEL Output: DDR3 PLL (PLL2) Setup ... C66xx_0: GEL Output: DDR3 PLL Setup... Done. C66xx_0: GEL Output: DDR3 Init begin (1333 auto) C66xx_0: GEL Output: XMC Setup ... Done C66xx_0: GEL Output: DDR3 initialization is complete. C66xx_0: GEL Output: DDR3 Init done C66xx_0: GEL Output: DDR3 memory test... Started C66xx_0: GEL Output: DDR3 memory test... Failed C66xx_0: GEL Output: PLL and DDR3 Initialization failed ... 用示波器测试SYSCLKOUT引脚,得到的信号频率是33.3MHz(主时钟的1/6),所以证明PLL进行了10倍频,芯片工作在200MHz上。 然后我觉得可能是PLL时钟的问题,板子上的晶振是20MHz的,同时供给CLKN/P和DDRCLKN/P,不知道有没有问题,GEL文件里CLKN/P默认是100MHz,DDRCLKN/P默认是50MHz,所以把PLL1_M、PLL1_D改为了99、0,把PLL2M、PLL2D改为199、2,想把coreclk设置到1GHz,把DDR工作时钟设定666.7MHz,得到如下结果: C66xx_0: GEL Output: Global Default Setup... C66xx_0: GEL Output: Setup Cache... C66xx_0: GEL Output: L1P = 32K C66xx_0: GEL Output: L1D = 32K C66xx_0: GEL Output: L2 = ALL SRAM C66xx_0: GEL Output: Setup Cache... Done. C66xx_0: GEL Output: Main PLL (PLL1) Setup ... C66xx_0: GEL Output: PLL in Bypass ... C66xx_0: GEL Output: PLL1 Setup for DSP @ 1000.0 MHz. C66xx_0: GEL Output: SYSCLK2 = 333.3333 MHz, SYSCLK5 = 200.0 MHz. C66xx_0: GEL Output: SYSCLK8 = 15.625 MHz. C66xx_0: GEL Output: PLL1 Setup... Done. C66xx_0: GEL Output: Power on all PSC modules and DSP domains... C66xx_0: Trouble Writing Memory Block at 0x2350a0c on Page 0 of Length 0x4: (Error -1060 @ 0x2350A0C) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C66xx_0: GEL: Error while executing OnTargetConnect(): Target failed to write 0x02350A0C at *(mdctl)=((*(mdctl)&~(0x1f))|state) [6655.gel:1210] at Set_PSC_State(0, 3, 0x3) [6655.gel:1643] at Set_Psc_All_On() [6655.gel:775] at Global_Default_Setup_Silent() [6655.gel:510] at OnTargetConnect() . C66xx_0: Trouble Reading Register ControlRegisters_CSR: (Error -1060 @ 0x41) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C66xx_0: GEL Output: Invalidate All Cache... C66xx_0: Trouble Writing Memory Block at 0x1845028 on Page 0 of Length 0x4: (Error -1060 @ 0x1845028) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C66xx_0: GEL: Error calling OnPreFileLoaded(): Target failed to write 0x01845028 C66xx_0: Trouble Writing Memory Block at 0x880106e0 on Page 0 of Length 0x94: (Error -1060 @ 0x64) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C66xx_0: Error: (Error -1060 @ 0x0) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C66xx_0: Trouble Reading Register PC: (Error -1060 @ 0x5F) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C66xx_0: GEL: File: D:NTSC20132013workdsptest3Debugtest3.out: Load failed. C66xx_0: GEL Output: Invalidate All Cache... C66xx_0: Trouble Writing Memory Block at 0x1845028 on Page 0 of Length 0x4: (Error -1060 @ 0x1845028) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C66xx_0: GEL: Error calling OnPreFileLoaded(): Target failed to write 0x01845028 C66xx_0: Trouble Writing Memory Block at 0x880106e0 on Page 0 of Length 0x94: (Error -1060 @ 0x64) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C66xx_0: Error: (Error -1060 @ 0x0) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) C66xx_0: Trouble Reading Register PC: (Error -1060 @ 0x5F) Device is not responding to the request. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) 请问各位这可能是什么问题啊? |
4 个讨论
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9353 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
1186浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
GMT+8, 2024-4-20 00:44 , Processed in 0.410316 second(s), Total 41, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
