导入3.3工程,然后编译,为啥报错?
Buildfile generation error occurred.. This project's device is not supported by compiler version 8.2.2: - See 'Help > Install New Software' and select 'Code Generation Tools Updates' to check if required compiler is available through a CCS update. - Visit CCS App Center to get the latest compiler support. - Or download and install the required compiler [http://software-dl.ti.com/codegen/non-esd/downloads], then register it with CCS through 'Preferences > CCS > Build > Compilers'. Build stopped.. Description Resource Path Location Type This project's device is not supported by compiler version 8.2.2. See 'Help > Install New Software' and select 'Code Generation Tools Updates' to check if required compiler is available through a CCS update. Visit CCS App Center to get the latest compiler support. Or download and install the required compiler, then register it with CCS through 'Preferences > CCS > Build > Compilers'. NANDWriter_DSP properties Problems |
5 个讨论
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1872 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3614 浏览 4 评论
5020 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1725 浏览 1 评论
9311 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
654浏览 2评论
697浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
651浏览 1评论
1178浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1174浏览 1评论
GMT+8, 2024-3-29 06:53 , Processed in 0.773778 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
