参考官方的csl例程中的dma4,将mcbsp1替换为mcbsp0后dma中断就无法进入了,数据搬移无法进行,不知什么原因?代码如下:
/* * Copyright (C) 2003 Texas Instruments Incorporated * All Rights Reserved */ /* *---------main_dma4.c--------- * This example places the MCBSP in digital loopback mode and * syncs MCBSP receive with DMA channel 4 and MCBSP transmit * with DMA channel 5. * The example uses predefined CSL macros and symbolic * constants to create the initialization values needed for * the MCBSP and DMA control registers to effect the transfer */ #include #include #include #include //---------Global constants--------- #define N 128 //---------Global data definition--------- /* Define transmit and receive buffers */ #pragma DATA_SECTION(xmt,"dmaMem") Uint16 xmt[N]; #pragma DATA_SECTION(rcv,"dmaMem") Uint16 rcv[N]; MCBSP_Config ConfigLoopBack16= [ MCBSP_SPCR1_RMK( MCBSP_SPCR1_DLB_ON, /* DLB = 1 */ MCBSP_SPCR1_RJUST_RZF, /* RJUST = 0 */ MCBSP_SPCR1_CLKSTP_DISABLE, /* CLKSTP = 0 */ MCBSP_SPCR1_DXENA_NA, /* DXENA = 0 */ MCBSP_SPCR1_ABIS_DISABLE, /* ABIS = 0 */ MCBSP_SPCR1_RINTM_RRDY, /* RINTM = 0 */ 0, /* RSYNCER = 0 */ MCBSP_SPCR1_RRST_DISABLE /* RRST = 0 */ ), MCBSP_SPCR2_RMK( MCBSP_SPCR2_FREE_NO, /* FREE = 0 */ MCBSP_SPCR2_SOFT_NO, /* SOFT = 0 */ MCBSP_SPCR2_FRST_FSG, /* FRST = 0 */ MCBSP_SPCR2_GRST_CLKG, /* GRST = 0 */ MCBSP_SPCR2_XINTM_XRDY, /* XINTM = 0 */ 0, /* XSYNCER = N/A */ MCBSP_SPCR2_XRST_DISABLE /* XRST = 0 */ ), MCBSP_RCR1_RMK( MCBSP_RCR1_RFRLEN1_OF(0), /* RFRLEN1 = 0 */ MCBSP_RCR1_RWDLEN1_16BIT /* RWDLEN1 = 5 */ ), MCBSP_RCR2_RMK( MCBSP_RCR2_RPHASE_SINGLE, /* RPHASE = 0 */ MCBSP_RCR2_RFRLEN2_OF(0), /* RFRLEN2 = 0 */ MCBSP_RCR2_RWDLEN2_8BIT, /* RWDLEN2 = 0 */ MCBSP_RCR2_RCOMPAND_MSB, /* RCOMPAND = 0 */ MCBSP_RCR2_RFIG_YES, /* RFIG = 0 */ MCBSP_RCR2_RDATDLY_0BIT /* RDATDLY = 0 */ ), MCBSP_XCR1_RMK( MCBSP_XCR1_XFRLEN1_OF(0), /* XFRLEN1 = 0 */ MCBSP_XCR1_XWDLEN1_16BIT /* XWDLEN1 = 5 */ ), MCBSP_XCR2_RMK( MCBSP_XCR2_XPHASE_SINGLE, /* XPHASE = 0 */ MCBSP_XCR2_XFRLEN2_OF(0), /* XFRLEN2 = 0 */ MCBSP_XCR2_XWDLEN2_8BIT, /* XWDLEN2 = 0 */ MCBSP_XCR2_XCOMPAND_MSB, /* XCOMPAND = 0 */ MCBSP_XCR2_XFIG_YES, /* XFIG = 0 */ MCBSP_XCR2_XDATDLY_0BIT /* XDATDLY = 0 */ ), MCBSP_SRGR1_RMK( MCBSP_SRGR1_FWID_OF(1), /* FWID = 1 */ MCBSP_SRGR1_CLKGDV_OF(1) /* CLKGDV = 1 */ ), MCBSP_SRGR2_RMK( MCBSP_SRGR2_GSYNC_FREE, /* FREE = 0 */ MCBSP_SRGR2_CLKSP_RISING, /* CLKSP = 0 */ MCBSP_SRGR2_CLKSM_INTERNAL, /* CLKSM = 1 */ MCBSP_SRGR2_FSGM_DXR2XSR, /* FSGM = 0 */ MCBSP_SRGR2_FPER_OF(15) /* FPER = 0 */ ), MCBSP_MCR1_DEFAULT, MCBSP_MCR2_DEFAULT, MCBSP_PCR_RMK( MCBSP_PCR_IDLEEN_RESET, /* IDLEEN = 0 */ MCBSP_PCR_XIOEN_SP, /* XIOEN = 0 */ MCBSP_PCR_RIOEN_SP, /* RIOEN = 0 */ MCBSP_PCR_FSXM_INTERNAL, /* FSXM = 1 */ MCBSP_PCR_FSRM_EXTERNAL, /* FSRM = 0 */ MCBSP_PCR_CLKXM_OUTPUT, /* CLKXM = 1 */ MCBSP_PCR_CLKRM_INPUT, /* CLKRM = 0 */ MCBSP_PCR_SCLKME_NO, /* SCLKME = 0 */ 0, /* DXSTAT = N/A */ MCBSP_PCR_FSXP_ACTIVEHIGH, /* FSXP = 0 */ MCBSP_PCR_FSRP_ACTIVEHIGH, /* FSRP = 0 */ MCBSP_PCR_CLKXP_RISING, /* CLKXP = 0 */ MCBSP_PCR_CLKRP_FALLING /* CLKRP = 0 */ ), MCBSP_RCERA_DEFAULT, MCBSP_RCERB_DEFAULT, MCBSP_RCERC_DEFAULT, MCBSP_RCERD_DEFAULT, MCBSP_RCERE_DEFAULT, MCBSP_RCERF_DEFAULT, MCBSP_RCERG_DEFAULT, MCBSP_RCERH_DEFAULT, MCBSP_XCERA_DEFAULT, MCBSP_XCERB_DEFAULT, MCBSP_XCERC_DEFAULT, MCBSP_XCERD_DEFAULT, MCBSP_XCERE_DEFAULT, MCBSP_XCERF_DEFAULT, MCBSP_XCERG_DEFAULT, MCBSP_XCERH_DEFAULT ]; /* Create DMA Receive Side Configuration */ DMA_Config dmaRcvConfig = [ DMA_DMACSDP_RMK( DMA_DMACSDP_DSTBEN_NOBURST, DMA_DMACSDP_DSTPACK_OFF, DMA_DMACSDP_DST_DARAM, DMA_DMACSDP_SRCBEN_NOBURST, DMA_DMACSDP_SRCPACK_OFF, DMA_DMACSDP_SRC_PERIPH, DMA_DMACSDP_DATATYPE_16BIT ), /* DMACSDP */ DMA_DMACCR_RMK( DMA_DMACCR_DSTAMODE_POSTINC, DMA_DMACCR_SRCAMODE_CONST, DMA_DMACCR_ENDPROG_ON, DMA_DMACCR_REPEAT_OFF, DMA_DMACCR_AUTOINIT_OFF, DMA_DMACCR_EN_STOP, DMA_DMACCR_PRIO_LOW, DMA_DMACCR_FS_DISABLE, DMA_DMACCR_SYNC_REVT1 ), /* DMACCR */ DMA_DMACICR_RMK( DMA_DMACICR_BLOCKIE_OFF, DMA_DMACICR_LASTIE_OFF, DMA_DMACICR_FRAMEIE_ON, DMA_DMACICR_FIRSTHALFIE_OFF, DMA_DMACICR_DROPIE_OFF, DMA_DMACICR_TIMEOUTIE_OFF ), /* DMACICR */ (DMA_AdrPtr)(MCBSP_ADDR(DRR10)), /* DMACSSAL */ 0, /* DMACSSAU */ (DMA_AdrPtr)&rcv, /* DMACDSAL */ 0, /* DMACDSAU */ N, /* DMACEN */ 1, /* DMACFN */ 0, /* DMACFI */ 0 /* DMACEI */ ]; /* Create DMA Transmit Side Configuration */ DMA_Config dmaXmtConfig = [ DMA_DMACSDP_RMK( DMA_DMACSDP_DSTBEN_NOBURST, DMA_DMACSDP_DSTPACK_OFF, DMA_DMACSDP_DST_PERIPH, DMA_DMACSDP_SRCBEN_NOBURST, DMA_DMACSDP_SRCPACK_OFF, DMA_DMACSDP_SRC_DARAM, DMA_DMACSDP_DATATYPE_16BIT ), /* DMACSDP */ DMA_DMACCR_RMK( DMA_DMACCR_DSTAMODE_CONST, DMA_DMACCR_SRCAMODE_POSTINC, DMA_DMACCR_ENDPROG_ON, DMA_DMACCR_REPEAT_OFF, DMA_DMACCR_AUTOINIT_OFF, DMA_DMACCR_EN_STOP, DMA_DMACCR_PRIO_LOW, DMA_DMACCR_FS_DISABLE, DMA_DMACCR_SYNC_XEVT1 ), /* DMACCR */ DMA_DMACICR_RMK( DMA_DMACICR_BLOCKIE_OFF, DMA_DMACICR_LASTIE_OFF, DMA_DMACICR_FRAMEIE_ON, DMA_DMACICR_FIRSTHALFIE_OFF, DMA_DMACICR_DROPIE_OFF, DMA_DMACICR_TIMEOUTIE_OFF ), /* DMACICR */ (DMA_AdrPtr)&xmt[1], /* DMACSSAL */ 0, /* DMACSSAU */ (DMA_AdrPtr)(MCBSP_ADDR(DXR10)), /* DMACDSAL */ 0, /* DMACDSAU */ N, /* DMACEN */ 1, /* DMACFN */ 0, /* DMACFI */ 0 /* DMACEI */ ]; /* Define a DMA_Handle object to be used with DMA_open function */ DMA_Handle hDmaRcv, hDmaXmt; /* Define a MCBSP_Handle object to be used with MCBSP_open function */ MCBSP_Handle hMcbsp; volatile Uint16 transferComplete = FALSE; Uint16 err = 0; Uint16 old_intm; Uint16 xmtEventId, rcvEventId; //---------Function prototypes--------- /* Reference start of interrupt vector table */ /* This symbol is defined in file, vectors.s55 */ extern void VECSTART(void); /* Protoype for interrupt functions */ interrupt void dmaXmtIsr(void); interrupt void dmaRcvIsr(void); void taskFxn(void); //---------main routine--------- void main(void) [ Uint16 i; /* Initialize CSL library - This is REQUIRED !!! */ CSL_init(); /* Set IVPD/IVPH to start of interrupt vector table */ IRQ_setVecs((Uint32)(&VECSTART)); for (i = 0; i <= N - 1; i++) [ xmt = i + 1; rcv = 0; ] /* Call function to effect transfer */ taskFxn(); ] void taskFxn(void) [ Uint16 srcAddrHi, srcAddrLo; Uint16 dstAddrHi, dstAddrLo; Uint16 i; /* By default, the TMS320C55xx compiler assigns all data symbols word */ /* addresses. The DMA however, expects all addresses to be byte */ /* addresses. Therefore, we must shift the address by 2 in order to */ /* change the word address to a byte address for the DMA transfer. */ srcAddrHi = (Uint16)(((Uint32)(MCBSP_ADDR(DRR10))) >> 15) & 0xFFFFu; srcAddrLo = (Uint16)(((Uint32)(MCBSP_ADDR(DRR10))) << 1) & 0xFFFFu; dstAddrHi = (Uint16)(((Uint32)(&rcv)) >> 15) & 0xFFFFu; dstAddrLo = (Uint16)(((Uint32)(&rcv)) << 1) & 0xFFFFu; dmaRcvConfig.dmacssal = (DMA_AdrPtr)srcAddrLo; dmaRcvConfig.dmacssau = srcAddrHi; dmaRcvConfig.dmacdsal = (DMA_AdrPtr)dstAddrLo; dmaRcvConfig.dmacdsau = dstAddrHi; srcAddrHi = (Uint16)(((Uint32)(&xmt[0])) >> 15) & 0xFFFFu; srcAddrLo = (Uint16)(((Uint32)(&xmt[0])) << 1) & 0xFFFFu; dstAddrHi = (Uint16)(((Uint32)(MCBSP_ADDR(DXR10))) >> 15) & 0xFFFFu; dstAddrLo = (Uint16)(((Uint32)(MCBSP_ADDR(DXR10))) << 1) & 0xFFFFu; dmaXmtConfig.dmacssal = (DMA_AdrPtr)srcAddrLo; dmaXmtConfig.dmacssau = srcAddrHi; dmaXmtConfig.dmacdsal = (DMA_AdrPtr)dstAddrLo; dmaXmtConfig.dmacdsau = dstAddrHi; /* Open MCBSP Port 1 and set registers to their power on defaults */ hMcbsp = MCBSP_open(MCBSP_PORT0, MCBSP_OPEN_RESET); /* Open DMA channels 4 & 5 and set regs to power on defaults */ hDmaRcv = DMA_open(DMA_CHA4,DMA_OPEN_RESET); hDmaXmt = DMA_open(DMA_CHA5,DMA_OPEN_RESET); /* Get interrupt event associated with DMA receive and transmit */ xmtEventId = DMA_getEventId(hDmaXmt); rcvEventId = DMA_getEventId(hDmaRcv); /* Temporarily disable interrupts and clear any pending */ /* interrupts for MCBSP transmit */ old_intm = IRQ_globalDisable(); /* Clear any pending interrupts for DMA channels */ IRQ_clear(xmtEventId); IRQ_clear(rcvEventId); /* Enable DMA interrupt in IER register */ IRQ_enable(xmtEventId); IRQ_enable(rcvEventId); /* Set Start Of Interrupt Vector Table */ IRQ_setVecs(0x10000); /* Place DMA interrupt service addresses at associate vector */ IRQ_plug(xmtEventId,&dmaXmtIsr); IRQ_plug(rcvEventId,&dmaRcvIsr); /* Write values from configuration structure to MCBSP control regs */ MCBSP_config(hMcbsp, &ConfigLoopBack16); /* Write values from configuration structure to DMA control regs */ DMA_config(hDmaRcv,&dmaRcvConfig); DMA_config(hDmaXmt,&dmaXmtConfig); #if 0 /* Take MCBSP transmit and receive out of reset */ MCBSP_start(hMcbsp, MCBSP_XMIT_START | MCBSP_RCV_START, 0u); /* Prime MCBSP DXR */ while (!(MCBSP_xrdy(hMcbsp)))[ ; ] MCBSP_write16(hMcbsp,xmt[0]); /* Enable all maskable interrupts */ IRQ_globalEnable(); /* Enable DMA */ DMA_start(hDmaRcv); DMA_start(hDmaXmt); /* Start Sample Rate Generator and Enable Frame Sync */ MCBSP_start(hMcbsp, MCBSP_SRGR_START | MCBSP_SRGR_FRAMESYNC, 0x300u); #else /* Enable all maskable interrupts */ IRQ_globalEnable(); /* Start Sample Rate Generator and Enable Frame Sync */ MCBSP_start(hMcbsp, MCBSP_SRGR_START | MCBSP_SRGR_FRAMESYNC, 0x300u); /* Enable DMA */ DMA_start(hDmaRcv); DMA_start(hDmaXmt); /* Take MCBSP transmit and receive out of reset */ MCBSP_start(hMcbsp, MCBSP_XMIT_START | MCBSP_RCV_START, 0u); #endif /* Wait for DMA transfer to be complete */ while (!transferComplete)[ ; ] /*------------------------------------------* * Compare values *------------------------------------------*/ for(i = 0; i <= N - 1; i++)[ if (rcv != xmt)[ ++err; break; ] ] printf ("%sn",err?"TEST FAILED" : "TEST PASSED"); /* Restore status of global interrupt enable flag */ IRQ_globalRestore(old_intm); /* We're done with MCBSP and DMA , so close them */ MCBSP_close(hMcbsp); DMA_close(hDmaRcv); DMA_close(hDmaXmt); ] interrupt void dmaXmtIsr(void) [ DMA_stop(hDmaXmt); IRQ_disable(xmtEventId); ] interrupt void dmaRcvIsr(void) [ DMA_stop(hDmaRcv); IRQ_disable(rcvEventId); transferComplete = TRUE; ] /////下面是vectors_dma4.s55的内容未修改 * * Copyright (C) 2003 Texas Instruments Incorporated * All Rights Reserved * * *---------vectors_dma4.s55--------- * * Assembly file to set up interrupt vector table * .sect ".vectors" *------------------------------------------------------------------------------ * Global symbols defined here and exported out of this file *------------------------------------------------------------------------------ .global _VECSTART *------------------------------------------------------------------------------ * Global symbols referenced in this file but defined somewhere else. * Remember that your interrupt service routines need to be referenced here. *------------------------------------------------------------------------------ .ref _c_int00 .def nmi, int0, int1, int2, int3, int4, int5, int6 .def int7, int8, int9, int10, int11, int12, int13 .def int14, int15, int16, int17, int18, int19, int20 .def int21, int22, int23, int24, int25, int26, int27 .def int28, int29 _VECSTART: .ivec _c_int00,use_reta nmi .ivec no_isr nop_16 int0 .ivec no_isr nop_16 int1 .ivec no_isr nop_16 int2 .ivec no_isr nop_16 int3 .ivec no_isr nop_16 int4 .ivec no_isr nop_16 int5 .ivec no_isr nop_16 int6 .ivec no_isr nop_16 int7 .ivec no_isr nop_16 int8 .ivec no_isr nop_16 int9 .ivec no_isr nop_16 int10 .ivec no_isr nop_16 int11 .ivec no_isr nop_16 int12 .ivec no_isr nop_16 int13 .ivec no_isr nop_16 int14 .ivec no_isr nop_16 int15 .ivec no_isr nop_16 int16 .ivec no_isr nop_16 int17 .ivec no_isr nop_16 int18 .ivec no_isr nop_16 int19 .ivec no_isr nop_16 int20 .ivec no_isr nop_16 int21 .ivec no_isr nop_16 int22 .ivec no_isr nop_16 int23 .ivec no_isr nop_16 int24 .ivec no_isr nop_16 int25 .ivec no_isr nop_16 int26 .ivec no_isr nop_16 int27 .ivec no_isr nop_16 int28 .ivec no_isr nop_16 int29 .ivec no_isr nop_16 *------------------------------------------------------------------------------ * This is a dummy interrupt service routine used to initialize the IST. *------------------------------------------------------------------------------ .text .def no_isr no_isr: b #no_isr *------------------------------------------------------------------------------ |
7 个讨论
vuywsdfwf 发表于 2018-7-30 08:26 你好,我还做了以下数据回环实验:mcbsp1+dma2dma3 正常;mcbsp0+dma0dma2 无法进dma中断;mcbsp2+dma4dma5 无法进dma中断 ;是否mcbsp和dma通道的使用是有限制的? |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1898 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3648 浏览 4 评论
5032 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1736 浏览 1 评论
9382 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
669浏览 2评论
714浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
676浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1773浏览 1评论
GMT+8, 2024-4-25 06:18 , Processed in 0.726082 second(s), Total 62, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
