发 帖
原厂入驻New
[资料] MY-IMX8M-CB314 硬件参数详细介绍
2018-7-26 16:16:31  1342 imx8
分享
MY-IMX8M-CB314 硬件介绍
  • 1MY-iMX8M_CB314视图(MY-iMX8M_CB314 view)
    • 1.1正面(front view)
    • 1.2背面(rear view)
    • 1.3尺寸(size)
  • 2MY-iMX8M_CB314参数(MY-iMX8M_CB314 parameter)
    • 2.1主控平台详细参数(Master control platform detaiLED parameters)
    • 2.2硬件配置(hardware configuration)
    • 2.3温度范围(temperature range)
      • 2.3.1工作温度(Operating temperature)
      • 2.3.2存储温度(storage temperature)
    • 2.4操作系统支持(operating system supported)
    • 2.5硬件接口(hardware inteRFace)
    • 2.6供电电源(Power Supply)
    • 2.7管脚定义(definition of pin)
    • 2.8管脚详细功能说明(instruction of detailed function of pins)
      • 2.8.1表1(form 1)
      • 2.8.2表2(form 2)
正面(front view)
背面(rear view)
尺寸(size)
主控平台详细参数(Master control platform detailed parameters)
  • 1. 异构多核,四核Cortex™-A53,单个Cortex-M4,主频最高达1.5GHz;
Heterogeneous multi-core, quad-core CortexTM-A53, single Cortex-M4, up to 1.5GHz;
  • 2. OpenGL/E 3.1,OpenGL 3.0,Vulkan,OpenCL 1.1;
  • 3. 双独立显示,MIPI-DSI,HDMI 2.0a;
Dual independent display,MIPI-DSI,HDMI 2.0a;
  • 4. 支持VP9/h265/H264/MPEG2/mpeg4p2/VC1/VP8/RV9/AVS/AVS+/H263/DIVX以及MJPEG-8x8 视频解码,4K,高达60Hz;
Support VP9/H265/H264/MPEG2/MPEG4p2/VC1/VP8/RV9/AVS/AVS+/H263/DIVX and MJPEG-8x8 video decoding, 4K, up to 60Hz;
  • 5. 6xI2S/SAI(20+通道,每个通道32位@384KHz),SPDIF Tx/Rx,DSD512;
6xI2S/SAI (20+ channels, 32 bits @384KHz per channel), SPDIF Tx/Rx, DSD512;
Dual camera support, mipi-csi (every 4 channels);
Support LPDDR4, DDR4, DDR3L, Quad SPI with XIP;
  • 8. 带PHY的双USB 3.0 C型;
Dual USB 3.0 C with PHY;
  • 9. 提供L1子状态的双PCIe,具有从低功耗模式的快速唤醒功能;
Provide double PCIe of L1 substate with quick wake function from low power consumption mode.
10. Gigabit Ethernet controller with AVB and EEE support;
  • 11. 支持MLC NAND Flash,EMMC 5.0;
Support MLC NAND Flash, EMMC 5.0;
核心板主型号
(cord board model)
CPU内存容量
(Memory)
存储容量
(Storage)
启动方式
(boot mode)
烧录方式
(burning mode)
其它
(others)
MY-IMX8M_CB314MIMX8MQ6DVAJZAA1G/2GeMMC:4G~32GeMMC拨码进入
(Dial-up entry)
标配:内存2G,存储16G
(standard configuration:memory 2G,storage 16G)
  • 消费级:
commercial grade:
0°C ~ +90 °C
-40°C ~ +125°C
  • 内核:Linux-4.9.88
kernel: Linux-4.9.88
  • 内核:Andorid 8.0
kernel:Andorid 8.0
  • 内核:FreeRTOS
kernel:FreeRTOS
硬件接口(hardware interface)
显示模块
(display module)
HDMI1路(1 way)
MIPI-CSI2路(2 way)
以太网
(Ethernet)
RGMII1路(1 way)
音频
(audio)
SAI6路(6 way)
PCI ExpressPCle2路(2 way)
存储
(storage)
SD/MMC卡
(SD/MMC card)
2路(2 way)
Nand Flash1路(1 way)
USBUSB 2.02路(2 way)
USB 3.02路(2 way)
SPISPI3路(3 way)
UARTUART4路(4 way)
ADCADC2路(2 way)
12C12C4路(4 way)
调试
(debug)
JTAG1路(1 way)
供电电源(Power Supply)
5V输入(5V input)
Pin NO.Pin Name管脚电压
(Pin voltage)
Pin NO.Pin Name管脚电压
(Pin voltage)
P1GND0VS1GND0V
P2GND0VS2RGMII_INT1.8V
P3GND0VS3NFC_WAKE1.8V
P4RGMII_RXD23.3VS4NFC_REG_ON3.3V
P5RGMII_TXD13.3VS5SPI0_CSn03.3V
P6RGMII_RXD33.3VS6SPI0_CSn03.3.V
P7RGMII_RXDV3.3VS7NFC_HOST_WAKE3.3V
P8RGMII_TXD03.3VS8SDMMC_D33.3V
P9RGMII_TXEN3.3VS9SDMMC_CMD3.3V
P10RGMII_RXER3.3VS10SDMMC_D23.3V
P11GND0VS11SDMMC_DET3.3V
P12RGMII_CLK3.3VS12SDMMC_D13.3V
P13GND0VS13SDMMC_CLK3.3V
P14RGMII_RXD03.3VS14SDMMC_D03.3V
P15RGMII_RXD13.3VS15SDMMC_WP3.3V
P16RGMII_TXD23.3VS16FLASH0_ALE1.8V
P17RGMII_TXD33.3VS17FLASH0_CLE1.8V
P18RGMII_TXCLK3.3VS18FLASH0_RDY1.8V
P19RGMII_RXCLK3.3VS19FLASH0_CS01.8V
P20RGMII_MDC3.3VS20MIPI_RST1.8V
P21RGMII_MDIO3.3VS21UART1_CTS3.3V
P22RGMII_RST3.3VS22UART1_RX3.3V
P23RGMII_CRS3.3VS23UART1_TX3.3V
P24GND0VS24UART1_RTS3.3V
P25SDIO0_D32.2VS25GPIO5_C23.3V
P26SDIO0_CMD2.2VS26SPI0_TXD3.3V
P27SDIO0_D02.2VS27SPI0_RXD3.3V
P28SDIO0_D22.2VS28SPI0_CSn13.3V
P29SDIO0_D12.2VS29WIFI_REG_ON2.2V
P30SDIO0_CLK2.2VS30BT_HOST_WAKE2.2V
P31GND0VS31GPIO4_D32.2V
P32GND0VS32WIFI_HOST_WAKE2.2V
P33GND0VS33BT_RST2.2V
P34GND0VS34BT_WAKE2.2V
P35GND0VS35GND0V
P36GND0VS36GND0V
P37UART0_CTS2.2VS37I2S0_CLK3.3V
P38UART0_RTS2.2VS38GND0V
P39UART0_TXD2.2VS39I2S0_SCLK3.3V
P40UART0_RXD2.2VS40I2S0_SDI3.3V
P41I2C2_SCL3.3VS41I2S0_LRCK_TX3.3V
P42I2C2_SDA3.3VS42I2S0_LRCK_RX3.3V
P43SPDIF_TX3.3VS43I2S0_SDO03.3V
P44GND0VS44I2S0_SDO33.3V
P45EDP_TX0P1.8VS45I2S0_SDO23.3V
P46EDP_TX0N1.8VS46I2S0_SDO13.3V
P47GND0VS47HDMI_HPD1.8V
P48EDP_TX1P1.8VS48GND0V
P49EDP_TX1N1.8VS49HDMI_TXCP1.8V
P50GND0VS50HDMI_TXCN1.8V
P51EDP_TX2P1.8VS51GND0V
P52EDP_TX2N1.8VS52HDMI_TX0P1.8V
P53GND0VS53HDMI_TX0N1.8V
P54EDP_TX3P1.8VS54GND0V
P55EDP_TX3N1.8VS55HDMI_TX1N1.8V
P56GND0VS56HDMI_TX1P1.8V
P57EDPAUXP1.8VS57GND0V
P58EDPAUXN1.8VS58HDMI_TX2N1.8V
P59GND0VS59HDMI_TX2P1.8V
P60MIPI_RX_D0N1.8VS60GND0V
P61MIPI_RX_D0P1.8VS61MIPI_TX/RX_D0P1.8V
P62GND0VS62MIPI_TX/RX_D0N1.8V
P63MIPI_RX_D1N1.8VS63GND0V
P64MIPI_RX_D1P1.8VS64MIPI_TX/RX_D1P1.8V
P65GND0VS65MIPI_TX/RX_D1N1.8V
P66MIPI_RX_CLKN1.8VS66GND0V
P67MIPI_RX_CLKP1.8VS67MIPI_TX/RX_CLKP1.8V
P68GND0VS68MIPI_TX/RX_CLKN1.8V
P69MIPI_RX_D2N1.8VS69GND1.8V
P70MIPI_RX_D2P1.8VS70MIPI_TX/RX_D2P1.8V
P71GND0VS71MIPI_TX/RX_D2N1.8V
P72MIPI_RX_D3N1.8VS72GND0V
P73MIPI_RX_D3P1.8VS73MIPI_TX/RX_D3P1.8V
P74GND0VS74MIPI_TX/RX_D3N1.8V
P75GND0VS75GND0V
P76LVDS_D4P3.3VS76GND0V
P77LVDS_D4N3.3VS77GND0V
P78LVDS_D3P3.3VS78MIPI_TX_D1P1.8V
P79LVDS_D3N3.3VS79MIPI_TX_D1N1.8V
P80LVDS_D2P3.3VS80GND0V
P81LVDS_D2N3.3VS81MIPI_TX_D0P1.8V
P82LVDS_CLK0P3.3VS82MIPI_TX_D0N1.8V
P83LVDS_CLK0N3.3VS83GND0V
P84LVDS_D1P3.3VS84MIPI_TX_CLKP1.8V
P85LVDS_D1N3.3VS85MIPI_TX_CLKN1.8V
P86LVDS_D0P3.3VS86GND0V
P87LVDS_D0N3.3VS87MIPI_TX_D2P1.8V
P88LVDS_D8P3.3VS88MIPI_TX_D2N1.8V
P89LVDS_D8N3.3VS89GND0V
P90LVDS_D9N3.3VS90MIPI_TX_D3P1.8V
P91LVDS_D9P3.3VS91MIPI_TX_D3N1.8V
P92LVDS_D7N3.3VS92GND0V
P93LVDS_D7P3.3VS93CIF_D51.8V
P94LVDS_CLK1N3.3VS94CIF_D11.8V
P95LVDS_CLK1P3.3VS95CIF_D21.8V
P96LVDS_D6P3.3VS96CIF_D31.8V
P97LVDS_D6N3.3VS97CIF_D01.8V
P98LVDS_D5P3.3VS98CIF_CLK1.8V
P99LVDS_D5N3.3VS99CIF_D71.8V
P100LCDC0_VSYNC3.3VS100CIF_D41.8V
P101GND0VS101CIF_D61.8V
P102LCDC0_DCLK3.3VS102CIF_PDN11.8V
P103GND0VS103CIF_CLKO1.8V
P104LCDC0_HSYNC3.3VS104CIF_VSYNC1.8V
P105LCDC0_DEN3.3VS105CIF_PDN01.8V
P106I2C3_SCL1.8VS106CIF_HREF1.8V
P107I2C3_SDA1.8VS107GND0V
P108GPIO2_B61.8VS108UART3_TX3.3V
P109GPIO2_B51.8VS1095V_DRV3.3V
P110GND0VS110GYR_INT3.3V
P111ADC_IN01.8VS111EDP_BL3.3V
P112ADC_IN21.8VS112UART3_CTS3.3V
P113RECOVER1.8VS113FLASH_TRIGOUT3.3V
P114GND0VS114LCDC_BL3.3V
P115efuse_PWR3.3VS115TOUCH_RST3.3V
P116PMUGPIO0_B53.3VS116LCD_EN3.3V
P117OTG_VBUS_DRV3.3VS117LCD_RST3.3V
P118PHONE_CTL3.3VS118TOUCH_INT3.3V
P119UART2_RXD3.3VS119I2C1_SCL3.3V
P120UART2_TXD3.3Vs120I2C1_SDA3.3V
P121HDMI_CEC3.3VS121GSEN_INT3.3V
P122SPK_CTL3.3VS122SPI2_MISO3.3V
P123FLASH_EN3.3VS123SPI2_CLK3.3V
P124UART3_RTS3.3VS124SPI2_nCS03.3V
P125EDP_HPD3.3VS125SPI2_MOSI3.3V
P126UART3_RX3.3VS126JTAG_TCK3.3V
P127BL_EN3.3VS127JTAG_TDO3.3V
P128LED43.3VS128JTAG_TDI3.3V
P129LED33.3VS129JTAG_TMS3.3V
P130LED23.3VS130nJTAG_TRST3.3V
P131LED13.3VS131USB2UART_nRST3.3V
P132KEY_VOL_N3.3VS132OTG_ID3.3V
P133KEY_VOL_P3.3VS133OTG_DET3.3V
P134I2C5_SDA3.3VS134GND0V
P135I2C5_SCL3.3VS135HOST1_DP5V
P136I2C4_SDA3.3VS136HOST1_DM5V
P137I2C4_SCL3.3VS137GND0V
P138PWR_KEY5VS138HOST2_DP5V
P139RESET_KEY5VS139HOST2_DM5V
P140PMIC_PWRON5VS140GND0V
P141OTP_RESET3.3VS141OTG_DP5V
P142HSIC_STROBE1.0VS142OTG_DM5V
P143HSIC_DATA1.0VS143GND
P144RTC_CLKOUT232.768KHzS144VCC_EFUSE3.0V
P145GND0VS145VCCA_333.3V
P146GND0VS146VCC18_DVP1.8V
P147GND0VS147VCC28_DVP2.8V
P148GND0VS148RTC_PWRIN3.4V
P149GND0VS149VCC_181.8V
P150GND0VS150VCC_IO3.3V
P151GND0VS151VCC_IO3.3V
P152GND0VS1525VIN5V
P153GND0VS1535VIN5V
P154GND0VS1545VIN5V
P155GND0VS1555VIN5V
P156GND0VS1565VIN5V
S1575VIN5V
S1585VIN5V
表1(form 1)
Pin NO.Pin NameCPU Ball Name功能描述
(functional description)
管脚电压
(Pin voltage)
P15V_CORE————5V(input)
P2
P3
P4
P5
P6GND——————
P7
P8
P9
P10
P11CSI_P1_DP3D21MIPI_CSI1_D3_P1.8V
P12CSI_P1_DN3C21MIPI_CSI1_D3_N
P13GND——————
P14CSI_P1_DP1D22MIPI_CSI1_D1_P1.8V
P15CSI_P1_DN1C22MIPI_CSI1_D1_N
P16GND——————
P17CSI_P1_DP2C23MIPI_CSI1_D2_P1.8V
P18CSI_P1_DN2B24MIPI_CSI1_D2_N
P19GND——————
P20CSI_P1_DP0B23MIPI_CSI1_D0_P1.8V
P21CSI_P1_DN0A23MIPI_CSI1_D0_N
P22GND——————
P23CSI_P1_CKPB22MIPI_CSI1_CLK_P1.8V
P24CSI_P1_CKNA22MIPI_CSI1_CLK_N
P25GND——————
P26CSI_P2_DP2B21MIPI_CSI2_D2_P1.8V
P27CSI_P2_DN2A21MIPI_CSI2_D2_N
P28GND——————
P29CSI_P2_DP1B20MIPI_CSI2_D1_P1.8V
P30CSI_P2_DN1A20MIPI_CSI2_D1_N
P31GND——————
P32CSI_P2_CKPB19MIPI_CSI2_CLK_P1.8V
P33CSI_P2_CKNA19MIPI_CSI2_CLK_N
P34GND——————
P35CSI_P2_DN3C19MIPI_CSI2_D3_N1.8V
P36CSI_P2_DP3D19MIPI_CSI2_D3_P
P37GND——————
P38CSI_P2_DP0D20MIPI_CSI2_D0_P1.8V
P39CSI_P2_DN0C20MIPI_CSI2_D0_N
P40GND——————
P41
P42
P43UART3_CTSB4ECSPI1_MISO3.3V
UART3_CTS_B
GPIO5_IO08
P44UART3_RTSD4ECSPI1_SS03.3V
UART3_RTS_B
GPIO5_IO09
P45UART3_TXDB7UART3_TXD3.3V
UART1_RTS_B
GPIO5_IO27
P46UART3_RXDA6UART3_RX3.3V
UART1_CTS_B
GPIO5_IO26
P47UART2_TXDD6UART2_TX3.3V
ECSPI3_SS0
GPIO5_IO25
P48UART2_RXDB6UART2_RX3.3V
ECSPI3_MISO
GPIO5_IO24
P49UART1_TXDD6UART1_TX3.3V
ECSPI3_MOSI
GPIO5_IO23
P50UART1_RXDC7UART1_RX3.3V
ECSPI3_SCLK
GPIO5_IO22
P51GND——————
P52SPDIF_EXT_CLKE6SPDIF1_EXT_CLK3.3V
PWM1_OUT
GPIO5_IO05
P53GND——————
P54SPDIF_EXT_TXF6SPDIF1_OUT3.3V
PWM3_OUT
GPIO5_IO03
P55SPDIF_RXG6SPDIF1_IN3.3V
PWM2_OUT
GPIO5_IO04
P56GND——————
P57SAI1_MCLKA3SAI1_MCLK3.3V
SAI5_MCLK
SAI1_TX_BCLK
GPIO4_IO20
P58GND——————
P59SAI1_TXD6B3SAI1_TX_DATA63.3V
SAI6_RX_SYNC
SAI6_TX_SYNC
CORESIGHT_TRACE14
GPIO4_IO18
SRC_BOOT_CFG14
P60SAI1_TXD2B2SAI1_TX_DATA33.3V
SAI5_TX_DATA3
CORESIGHT_TRACE11
GPIO4_IO15
SRC_BOOT_CFG11
P61SAI1_TXD5C2SAI1_TX_DATA53.3V
SAI6_RX_DATA0
SAI6_TX_DATA0
CORESIGHT_TRACE13
GPIO4_IO17
SRC_BOOT_CFG13
P62SAI1_TXD7C1SAI1_TX_DATA73.3V
SAI6_MCLK
CORESIGHT_TRACE15
GPIO4_IO19
SRC_BOOT_CFG15
P63SAI1_TXD4D2SAI1_TX_DATA43.3V
SAI6_RX_BCLK
SAI6_TX_BCLK
CORESIGHT_TRACE12
GPIO4_IO16
SRC_BOOT_CFG12
P64SAI1_TXD3D1SAI1_TX_DATA33.3V
SAI5_TX_DATA3
CORESIGHT_TRACE11
GPIO4_IO15
SRC_BOOT_CFG11
P65SAI1_TXD1E2SAI1_TX_DATA13.3V
SAI5_TX_DATA1
CORESIGHT_TRACE9
GPIO4_IO13
SRC_BOOT_CFG9
P66SAI1_TXCE1SAI1_TX_BCLK3.3V
SAI5_TX_BCLK
CORESIGHT_EVENTI
GPIO4_IO11
P67SAI1_TXD0F2SAI1_TX_DATA03.3V
SAI5_TX_DATA0
CORESIGHT_TRACE8
GPIO4_IO12
SRC_BOOT_CFG8
P68SAI1_RXD5F1SAI1_RX_DATA53.3V
SAI6_TX_DATA0
SAI6_RX_DATA0
SAI1_RX_SYNC
CORESIGHT_TRACE5
GPIO4_IO07
SRC_BOOT_CFG5
P69SAI1_RXD6G2SAI1_RX_DATA63.3V
SAI6_TX_SYNC
SAI6_RX_SYNC
CORESIGHT_TRACE6
GPIO4_IO08
SRC_BOOT_CFG6
P70SAI1_RXD7G1SAI1_RX_DATA73.3V
SAI6_MCLK
SAI1_TX_SYNC
SAI1_TX_DATA4
CORESIGHT_TRACE7
GPIO4_IO09
SRC_BOOT_CFG7
P71SAI1_RXD2H2SAI1_RX_DATA23.3V
SAI5_RX_DATA2
SAI5_RX_DATA2
GPIO4_IO04
SRC_BOOT_CFG2
P72SAI1_TXFSH1SAI1_TX_SYNC3.3V
SAI5_TX_SYNC
CORESIGHT_EVENTO
GPIO4_IO10
P73SAI1_RXD3J2SAI1_RX_DATA33.3V
SAI5_RX_DATA3
CORESIGHT_TRACE3
GPIO4_IO05
SRC_BOOT_CFG3
P74GND——————
P75
P76SAI1_RXD4G2SAI1_RX_DATA43.3V
SAI6_TX_BCLK
SAI6_RX_BCLK
CORESIGHT_TRACE4
GPIO4_IO06
SRC_BOOT_CFG4
P77SAI1_RXD0K2SAI1_RX_DATA03.3V
SAI5_RX_DATA0
CORESIGHT_TRACE0
GPIO4_IO00
SRC_BOOT_CFG0
P78SAI1_RXCK1SAI1_RX_BCLK3.3V
SAI5_RX_BCLK
CORESIGHT_TRACE_CTL
GPIO4_IO01
P79SAI1_RXD1L2SAI1_RX_DATA13.3V
SAI5_RX_DATA1
CORESIGHT_TRACE1
GPIO4_IO03
SRC_BOOT_CFG1
P80SAI1_RXFSL1SAI1_RX_SYNC3.3V
SAI5_RX_SYNC
CORESIGHT_TRACE_CLK
GPIO4_IO00
P81GND——————
P82HDMI_DDC_SDAP3HDMI_DDC_SDA1.8V
P83HDMI_DDC_SCLP3HDMI_DDC_SCL
P84GND——————
P85HDMI_CLKNM2HDMI_TX_N_LN_31.8V
P86HDMI_CLKPM1HDMI_TX_P_LN_3
P87GND——————
P88HDMI_TXN2N1HDMI_TX_N_LN_21.8V
P89HDMI_TXP2N2HDMI_TX_P_LN_2
P90GND——————
P91HDMI_TXN0T2HDMI_TX_N_LN_01.8V
P92HDMI_TXP0T1HDMI_TX_P_LN_0
P93GND——————
P94HDMI_TXP1U2HDMI_TX_P_LN_11.8V
P95HDMI_TXN1U1HDMI_TX_N_LN_1
P96GND——————
P97HDMI_AUXNv2HDMI_AUX_N1.8V
P98HDMI_TXN1V1HDMI_AUX_P
P99GND——————
P100HDMI_HPDW2HDMI_HPD1.8V
P101GND——————
P102HDMI_CECW3HDMI_CEC1.8V
P103JTAG_NTRSTU6JTAG_TRST_B3.3V
P104JTAG_TDOU5JTAG_TDO3.3V
P105JTAG_TCKT5JTAG_TCK3.3V
P106JTAG_TMSV5JTAG_TMS3.3V
P107JTAG_TDIW5JTAG_TDI3.3V
P108I2C2_SDAF7I2C2_SDA3.3V
ENET1_1588_EVENT1_OUT
GPIO5_IO17
P109I2C2_SCLG7I2C2_SCL3.3V
ENET1_1588_EVENT1_IN
GPIO5_IO16
P110I2C1_SDAE8I2C1_SDA3.3V
ENET1_MDIO
GPIO5_IO15
P111I2C1_SCLE7I2C1_SCL3.3V
ENET1_MDC
GPIO5_IO14
P112I2C3_SCLG8I2C3_SCL3.3V
PWM4_OUT
GPT2_CLK
GPIO5_IO18
P113I2C3_SDAE9I2C3_SDA3.3V
PWM3_OUT
GPT3_CLK
GPIO5_IO19
P114GND——————
P115WL_REG_OND7UART4_TX3.3V
UART2_RTS_B
PCIE2_CLKREQ_B
GPIO5_IO29
P116WL_NPERSTC6UART4_RX3.3V
UART2_CTS_B
PCIE1_CLKREQ_B
GPIO5_IO28
P117WIFI_PCIE_NCLKREQ——————
P118PCIE1_NCLKREQF8I2C4_SCL3.3V
PWM2_OUT
PCIE1_CLKREQ_B
GPIO5_IO20
P119PCIE2_NCLKREQF9I2C4_SDA3.3V
PWM1_OUT
PCIE2_CLKREQ_B
GPIO5_IO21
P120PCIE_NCLKREQ——————
P121GND——————
P122PCIE2_RXPD25PCIE2_RXN_P3.3V
P123PCIE2_RXND24PCIE2_RXN_N
P124GND——————
P125PCIE2_REF_CLKN_CNF24PCIE2_REF_PAD_CLK_N3.3V
P126PCIE2_REF_CLKP_CNF25PCIE2_REF_PAD_CLK_P
P127GND——————
P128PCIE2_TXPE25PCIE2_TXN_P3.3V
P129PCIE2_TXNE24PCIE2_TXN_N
P130GND——————
P131
P132
P133
P134PCIE1_RXNH24PCIE1_RXN_N3.3V
P135PCIE1_RXPH25PCIE1_RXN_P
P136GND——————
P137PCIE1_TXNJ24PCIE1_TXN_N3.3V
P138PCIE1_TXPJ25PCIE1_TXN_P
P139GND——————
P140WIFI_PCIE_CLKN——————
P141WIFI_PCIE_CLKP——————
P142GND——————
P143
P144
P145
P146CLK1_PR23CLK1_P1.8V(input)
P147CLK1_NT23CLK1_N
P148GND——————
P149POR_BW20SRC_POR_B3.3V
P150WL_NWAKEM20RAWNAND_DQS3.3V
QSPI_A_DQS
GPIO3_IO14
P151WIFI_PCIE_CLKP——————
P152PMIC_STBY_REQV21CCM_PMIC_STBY_REQ3.3V
P153ONOFFW21XTALOSC_ONOFF3.3V
P154BOOT_MODE1V6SRC_BOOT_MODE13.3V
P155BOOT_MODE0W6SRC_BOOT_MODE03.3V
P156GND——————
表2(form 2)
管脚电压
(Pin voltage)
S15V_CORE————5V(input)
S2
S3
S4
S5
S6GND——————
S7
S8
S9
S10
S11VDD_PHY_3V3————3.3V(input)
S12
S13VDD_PHY_1V8————1.8V(input)
S14GND——————
S15
S16
S17DSI_DN2A18MIPI_DSI_D2_N1.8V
S18DSI_DP2B18MIPI_DSI_D2_P
S19GND——————
S20DSI_DN0A17MIPI_DSI_D0_N1.8V
S21DSI_DP0B17MIPI_DSI_D0_P
S22GND——————
S23DSI_DN1A16MIPI_DSI_D1_N1.8V
S24DSI_DP1B16MIPI_DSI_D1_P
S25GND——————
S26DSI_DN3A15MIPI_DSI_D3_N1.8V
S27DSI_DP3B15MIPI_DSI_D3_P
S28GND——————
S29DSI_CKPD16MIPI_DSI_CLK_P1.8V
S30DSI_CKNC16MIPI_DSI_CLK_N
S31GND——————
S32Usb1_IDC16USB1_ID3.3V
S33USB1_DNB14USB1_DN3.3V
S34USB1_DPA14USB1_DP3.3V
S35USB1_VBUSD14USB1_VBUS3.3V
S36GND——————
S37USB1_TXNB13USB1_TXN3.3V
S38USB1_TXPA13USB1_TXP
S39GND——————
S40USB1_RXNB12USB1_RXN3.3V
S41USB1_RXPA12USB1_RXP
S42GND——————
S43USB2_IDC9USB2_ID3.3V
S44USB2_DNB10USB2_DN
S45USB2_DPA10USB2_DP3.3V
S46USB2_VBUSD9USB2_VBUS
S47GND——————
S48USB2_TXNB9USB2_TXN3.3V
S49USB2_TXPA9USB2_TXP
S50GND——————
S51USB2_RXNB8USB2_RXN3.3V
S52USB2_RXPA8USB2_RXP
S53GND——————
S54USB1_SS_SELK19RAWNAND_RE_B3.3V
QSPI_B_DQS
GPIO3_IO15
S55DSI_END5ECSPI1_SCLK3.3V
UART3_RX
GPIO5_IO06
S56PCIE_NDISC5ECSPI2_SCLK3.3V
UART4_RX
GPIO5_IO10
S57PCIE_NWAKEE5ECSPI2_MOSI3.3V
UART4_TX
GPIO5_IO11
S58BT_RF_KILLA5ECSPI2_SS03.3V
UART4_RTS_B
GPIO5_IO13
S59PCIE_NRSTB5ECSPI2_MISO3.3V
UART4_CTS_B
GPIO5_IO12
S60DSI_TS_NINTA4ECSPI1_MISO3.3V
UART3_TX
GPIO5_IO07
S61GND——————
S62SAI2_RXDH6SAI2_RX_DATA03.3V
SAI5_TX_DATA0
GPIO4_IO23
S63SAI2_TXDG5SAI2_TX_DATA03.3V
SAI5_TX_DATA3
GPIO4_IO26
S64SAI2_RXCH3SAI2_RX_BCLK3.3V
SAI5_TX_BCLK
GPIO4_IO22
S65SAI2_MCLKH5SAI2_MCLK3.3V
SAI5_MCLK
GPIO4_IO27
S66GND——————
S67SAI2_RXFSJ4SAI2_RX_SYNC3.3V
SAI5_TX_SYNC
GPIO4_IO21
S68SAI2_TXCJ5SAI2_TX_BCLK3.3V
SAI5_TX_DATA2
GPIO4_IO25
S69SAI2_TXFSH4SAI2_TX_SYNC3.3V
SAI5_TX_DATA1
GPIO4_IO24
S70GND——————
S71SAI3_RXFSG4SAI3_RX_SYNC3.3V
GPT1_CAPTURE1
SAI5_RX_SYNC
GPIO4_IO28
S72SAI3_RXDF3SAI3_RX_DATA03.3V
GPT1_COMPARE1
SAI5_RX_DATA0
GPIO4_IO30
S73SAI3_RXCF4SAI3_RX_BCLK3.3V
GPT1_CAPTURE2
SAI5_RX_BCLK
GPIO4_IO29
S74SAI3_TXDC3SAI3_TX_DATA03.3V
GPT1_COMPARE3
SAI5_RX_DATA3
GPIO5_IO01
S75GND——————
S76
S77SAI3_TXCC4SAI3_TX_BCLK3.3V
GPT1_COMPARE2
SAI5_RX_DATA2
GPIO5_IO00
S78SAI3_TXFSG3SAI3_TX_SYNC3.3V
GPT1_CLK
SAI5_RX_DATA1
GPIO4_IO31
S79SAI3_MCLKD3SAI3_MCLK3.3V
PWM4_OUT
SAI5_MCLK
GPIO5_IO02
S80GND——————
S81SAI5_MCLKK4SAI5_MCLK3.3V
SAI1_TX_BCLK
SAI4_MCLK
GPIO3_IO25
S82GND——————
S83SAI5_RXD3K5SAI5_RX_DATA33.3V
SAI1_TX_DATA5
SAI1_TX_SYNC
SAI5_TX_DATA0
GPIO3_IO24
S84SAI5_RXD1L4SAI5_RX_DATA13.3V
SAI1_TX_DATA3
SAI1_TX_SYNC
SAI5_TX_SYNC
GPIO3_IO22
S85GND——————
S86SAI5_RXCL5SAI5_RX_BCLK3.3V
SAI1_TX_DATA1
GPIO3_IO20
S87GND——————
S88SAI5_RXD2M4SAI5_RX_DATA23.3V
SAI1_TX_DATA4
SAI1_TX_SYNC
SAI5_TX_BCLK
GPIO3_IO23
S89SAI5_RXD0M5SAI5_RX_DATA03.3V
SAI1_TX_DATA2
GPIO3_IO21
S90SAI5_RXFSN4SAI5_RX_SYNC3.3V
SAI1_TX_DATA0
GPIO3_IO19
S91GND——————
S92
S93NWDOGR4GPIO1_IO023.3V
WDOG1_WDOG_B
WDOG1_WDOG_ANY
S94DSI_BL_PWMT7GPIO1_IO013.3V
PWM1_OUT
ANAMIX_REF_CLK_24M
CCM_EXT_CLK2
S95REF_CLK_32KT6GPIO1_IO003.3V
CCM_ENET_PHY_REF_CLK_ROOT
ANAMIX_REF_CLK_32K
CCM_EXT_CLK1
S96GND——————
S97CLKO_25MHZK7GPIO1_IO143.3V
USB2_OTG_PW
PWM3_OUT
CCM_CLKO1
S98CLKO2J6GPIO1_IO153.3V
USB2_OTG_OC
PWM4_OUT
CCM_CLKO2
S99ENET_WOLK7GPIO1_IO103.3V
USB1_OTG_ID
S100AUD_NMUTEN7GPIO1_IO083.3V
ENET1_1588_EVENT0_IN
USDHC2_RESET_B
S101PWM_LEDK6GPIO1_IO133.3V
USB1_OTG_OC
PWM2_OUT
S102ENET_NINTL6GPIO1_IO113.3V
USB2_OTG_ID
CCM_PMIC_READY
S103ENET_NRSTM6GPIO1_IO093.3V
ENET1_1588_EVENT0_OUT
SDMA2_EXT_EVENT0
S104IR_CAPL7GPIO1_IO123.3V
USB1_OTG_PWR
SDMA2_EXT_EVENT1
S105CSI_P1_PWDNP4GPIO1_IO033.3V
USDHC1_VSELECT
SDMA1_EXT_EVENT0
S106CSI_NRSTN5GPIO1_IO063.3V
ENET1_MDC
USDHC1_CD_B
CCM_EXT_CLK3
S107CSI_P2_PWDNP7GPIO1_IO053.3V
M4_NMI
CCM_PMIC_READY
S108SD2_VSELECTP5GPIO1_IO043.3V
USDHC2_VSELECT
SDMA1_EXT_EVENT1
S109GND——————
S110ENET_RD0U19ENET1_RGMII_RD02.5V
GPIO1_IO26
S111ENET_RD0U21ENET1_RGMII_RD02.5V
GPIO1_IO27
S112ENET_RX_CTLT21ENET1_RGMII_RX_CTL2.5V
GPIO1_IO24
S113ENET_RD2U20ENET1_RGMII_RD22.5V
GPIO1_IO28
S114ENET_RD3V19ENET1_RGMII_RD32.5V
GPIO1_IO29
S115ENET_RXCT20ENET1_RGMII_RXC2.5V
ENET1_RX_ER
GPIO1_IO25
S116GND——————
S117ENET_TD1R21ENET1_RGMII_TD12.5V
GPIO1_IO20
S118ENET_TD0R20ENET1_RGMII_TD02.5V
GPIO1_IO21
S119ENET_TD3P20ENET1_RGMII_TD32.5V
GPIO1_IO18
S120ENET_TXCT19ENET1_RGMII_TXC2.5V
ENET1_TX_ER
GPIO1_IO23
S121ENET_TD2R19ENET1_RGMII_TD22.5V
ENET1_TX_CLK
GPIO1_IO19
S122ENET_TX_CTLP19ENET1_RGMII_TX_CTL2.5V
GPIO1_IO22
S123GND——————
S124ENET_MDION19ENET1_MDIO2.5V
GPIO1_IO17
S125ENET_MDCN20ENET1_MDC2.5V
GPIO1_IO16
S126GND——————
S127SDIO_WAKEM21USDHC2_WP3.3V
GPIO2_IO20
S128SD2_DATA2P22USDHC2_DATA23.3V
GPIO2_IO17
S129SD2_NRSTR22USDHC2_RESET_B3.3V
GPIO2_IO1
S130SD2_DATA1N21USDHC2_DATA13.3V
GPIO2_IO16
S131SD2_DATA0N22USDHC2_DATA03.3V
GPIO2_IO15
S132SD2_CMDM22USDHC2_CMD3.3V
GPIO2_IO14
S133SD2_DATA3P21USDHC2_DATA33.3V
GPIO2_IO18
S134SD2_NCDL21USDHC2_CD_B3.3V
GPIO2_IO12
S135GND——————
S136SD2_CLKL22USDHC2_CLK3.3V
GPIO2_IO13
S137GND——————
S138
S139QSPIA_NSS0H19RAWNAND_CE0_B3.3V
QSPI_A_SS0_B
GPIO3_IO01
S140NAND_DATA3J21RAWNAND_DATA033.3V
QSPI_A_DATA3
GPIO3_IO09
S141NAND_DATA1J20RAWNAND_DATA013.3V
QSPI_A_DATA1
GPIO3_IO07
S142NAND_DATA2H22RAWNAND_DATA023.3V
QSPI_A_DATA2
GPIO3_IO08
S143GND——————
S144QSPIA_SCLKG19RAWNAND_ALE3.3V
QSPI_A_SCLK
GPIO3_IO00
S145GND——————
S146NAND_DATA0G20RAWNAND_DATA003.3V
QSPI_A_DATA0
GPIO3_IO06
S147NAND_NREADYK20RAWNAND_READY_B3.3V
GPIO3_IO16
S148NAND_DATA7M19RAWNAND_DATA073.3V
QSPI_B_DATA3
GPIO3_IO13
S149NAND_DATA4L20RAWNAND_DATA043.3V
QSPI_B_DATA0
GPIO3_IO10
S150NAND_NWPK21RAWNAND_WP_B3.3V
GPIO3_IO18
S151NAND_DATA5J22RAWNAND_DATA053.3V
QSPI_B_DATA1
GPIO3_IO11
S152NAND_NWEK22RAWNAND_WE_B3.3V
GPIO3_IO17
S153NAND_NCE3H20RAWNAND_CE3_B3.3V
QSPI_B_SS1_B
GPIO3_IO04
S154BT_DEV_WAKEG21RAWNAND_CE1_B3.3V
QSPI_A_SS1_B
GPIO3_IO02
S155NAND_CLEH21RAWNAND_CLE3.3V
QSPI_B_SCLK
GPIO3_IO05
S156NAND_DATA6L19RAWNAND_DATA063.3V
QSPI_B_DATA2
GPIO3_IO12
S157TCPC_NINTF21RAWNAND_CE2_B3.3V
QSPI_B_SS0_B
GPIO3_IO03
S158GND——————
</div>
1
分享淘帖 显示全部楼层
高级模式
您需要登录后才可以回帖 登录 | 注册
关闭
站长推荐 上一条 /10 下一条
快速回复 返回顶部 返回列表
