发 帖
张飞软硬开源基于STM32 BLDC直流无刷电机驱动器开发视频套件, 👉戳此立抢👈
[问答] PROTEUS上硬件连接如图,该段程序在51上测试能实现刷屏功能,移植到ARM后则驱动不了,时序也有问题,请问如何解决?
817 proteus ARM
分享
proteus上硬件连接如图,该段程序在51上测试能实现刷屏功能,移植到ARM后则驱动不了,时序也有问题。
2018-7-10 14:16:14   评论 分享淘帖 邀请回答
9个回答
- FB-EDU-PARM-LPC2138 User Function file
- Author: yelx
- Date: 2018-06-04
- Guangzhou Windway
* 文件名:LCDTEST.C
* 功能:显示图像,显示汉字,显示字符
#include "Config.h"
#include "Target.h"
#include "iolpc2134.h"
#define     RED          0XF800
#define     GREEN        0X07E0
#define     BLUE         0X001F
#define     WHITE        0XFFFF
#define LCD_MOSI (1<<6)
#define LCD_MISO (1<<5)
#define cs (1<<2)
#define sck (1<<4)
#define dc (1<<3)
#define rst (1<<1)
/*---------------延时子程序----------------*/
void delay (uint16 us)
  while(us--);
void delay_ms (uint16 ms)
  uint16 i,j;
  for(i=0;i<ms;i++)
  for(j=0;j<3000;j++)
unsigned char qufan(unsigned char k)
unsigned char a,b,c,d,e,f,g,h;
a=k&0x01;a<<7;
b=k&0x02;b<<5;
c=k&0x04;c<<3;
d=k&0x08;d<<1;
e=k&0x10;e>>1;
f=k&0x20;f>>3;
g=k&0x40;g>>5;
h=k&0x80;h>>7;
k=(((((((a|b)|c)|d)|e)|f)|g)|h);
return k;
unsigned char SPI_RW(unsigned char byte)
        unsigned char bit_ctr;
        for(bit_ctr=0;bit_ctr<8;bit_ctr++)
                IO0CLR=sck;
                //qufan(byte);
                IO0PIN=(IO0PIN&0XFFFFFFFE|byte);
                byte=(byte<<1);
                IO0SET=sck;
                byte|=LCD_MISO;
        return byte;
void LCD_CD_DATA(unsigned char val)
        IO0CLR=cs;
        IO0SET=dc;
        SPI_RW(val);
        IO0SET=cs;
void LCD_CD_REG(unsigned char reg)
        IO0CLR=cs;
        IO0CLR=dc;
        SPI_RW(reg);
        IO0SET=cs;
void LCD_Init()
        IO0CLR=rst;
        delay_ms(50);
        IO0SET=rst;
        delay_ms(120);
        LCD_CD_REG(0xCF);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0xC1);
        LCD_CD_DATA(0X30);
        LCD_CD_REG(0xED);
        LCD_CD_DATA(0x64);
        LCD_CD_DATA(0x03);
        LCD_CD_DATA(0X12);
        LCD_CD_DATA(0X81);
        LCD_CD_REG(0xE8);
        LCD_CD_DATA(0x85);
        LCD_CD_DATA(0x10);
        LCD_CD_DATA(0x7A);
        LCD_CD_REG(0xCB);
        LCD_CD_DATA(0x39);
        LCD_CD_DATA(0x2C);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x34);
        LCD_CD_DATA(0x02);
        LCD_CD_REG(0xF7);
        LCD_CD_DATA(0x20);
        LCD_CD_REG(0xEA);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_REG(0xC0);    //Power control
        LCD_CD_DATA(0x1B);   //VRH[5:0]
        LCD_CD_REG(0xC1);    //Power control
        LCD_CD_DATA(0x01);   //SAP[2:0];BT[3:0]
        LCD_CD_REG(0xC5);    //VCM control
        LCD_CD_DATA(0x30);          //3F
        LCD_CD_DATA(0x30);          //3C
        LCD_CD_REG(0xC7);    //VCM control2
        LCD_CD_DATA(0XB7);
        LCD_CD_REG(0x36);    // Memory Access Control
        LCD_CD_DATA(0x48);
        LCD_CD_REG(0x3A);
        LCD_CD_DATA(0x55);
        LCD_CD_REG(0xB1);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x1A);
        LCD_CD_REG(0xB6);    // Display Function Control
        LCD_CD_DATA(0x0A);
        LCD_CD_DATA(0xA2);
        LCD_CD_REG(0xF2);    // 3Gamma Function Disable
        LCD_CD_DATA(0x00);
        LCD_CD_REG(0x26);    //Gamma curve selected
        LCD_CD_DATA(0x01);
        LCD_CD_REG(0xE0);    //Set Gamma
        LCD_CD_DATA(0x0F);
        LCD_CD_DATA(0x2A);
        LCD_CD_DATA(0x28);
        LCD_CD_DATA(0x08);
        LCD_CD_DATA(0x0E);
        LCD_CD_DATA(0x08);
        LCD_CD_DATA(0x54);
        LCD_CD_DATA(0XA9);
        LCD_CD_DATA(0x43);
        LCD_CD_DATA(0x0A);
        LCD_CD_DATA(0x0F);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_REG(0XE1);    //Set Gamma
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x15);
        LCD_CD_DATA(0x17);
        LCD_CD_DATA(0x07);
        LCD_CD_DATA(0x11);
        LCD_CD_DATA(0x06);
        LCD_CD_DATA(0x2B);
        LCD_CD_DATA(0x56);
        LCD_CD_DATA(0x3C);
        LCD_CD_DATA(0x05);
        LCD_CD_DATA(0x10);
        LCD_CD_DATA(0x0F);
        LCD_CD_DATA(0x3F);
        LCD_CD_DATA(0x3F);
        LCD_CD_DATA(0x0F);
        LCD_CD_REG(0x2B);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x01);
        LCD_CD_DATA(0x3f);
        LCD_CD_REG(0x2A);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0xef);
        LCD_CD_REG(0x11); //Exit Sleep
        delay_ms(120);
        LCD_CD_REG(0x29); //display on
void LCD_SetArea(unsigned int stx,unsigned int sty,unsigned int endx,unsigned int endy)
        LCD_CD_REG(0x2A);
        LCD_CD_DATA(stx>>8);
        LCD_CD_DATA(stx&0xff);
        LCD_CD_DATA(endx>>8);
        LCD_CD_DATA(endx&0xff);
        LCD_CD_REG(0x2B);
        LCD_CD_DATA(sty>>8);
        LCD_CD_DATA(sty&0xff);
        LCD_CD_DATA(endy>>8);
        LCD_CD_DATA(endy&0xff);
void LcdWirteColorData(unsigned int color)
        IO0CLR=cs;
        IO0SET=dc;
        SPI_RW(color>>8);
        SPI_RW(color);
        IO0SET=cs;
void LCD_Clear(unsigned int color)
        unsigned int i,j;
        LCD_SetArea(0,0,239,319);
        LCD_CD_REG(0x2C);
        for(i=0;i<320;i++)
                for(j=0;j<240;j++)
                        LcdWirteColorData(color);
void main()
        TargetResetInit();
        PINSEL0 = 0x00000000;                                 // 设置PIN0为GPIO
        PINSEL1 = 0x00000000;                                // 设置PIN1为GPIO
        IO0DIR  = 0xfffffffF;
        delay_ms(100);
        //spi_init();
        LCD_Init();
        while(1)
                LCD_Clear(RED);
                delay_ms(300);
                LCD_Clear(BLUE);
                delay_ms(300);
                LCD_Clear(GREEN);
                delay_ms(300);
2018-7-10 14:17:01 评论
举报
怀疑是数据输出上出问题i
2018-7-10 14:18:10 评论
举报
2018-7-10 19:22:56 评论
举报
像截图上的,SPI的MOSI口没有数据输出,在51上是没问题的
2018-7-13 12:00:09 评论
举报
换SPI数据寄存器将数据发送到总线上实现了正常的时序
2018-7-17 10:28:31 评论
举报
目前时序正常但是显示屏黑屏,目测初始化程序有问题
2018-7-17 10:29:03 评论
举报
* 文件名:SPIDISP.C
* 功能:使用硬件SPI接口输出显示。(硬件:TFT ILI9341显示)
#include "Config.h"
#include "Target.h"
#define     RED          0XF800
#define     BLUE         0X001F
#define     YELLOW       0XFFE0
#define ssel0 (1<<7)
#define sck (1<<4)
#define dc (1<<3)
#define cs (1<<2)
void  delay_ms(uint32  dly)
{  uint32  i;
   for(; dly>0; dly--)
      for(i=0; i<9000; i++);
* 名称:MSpiIni()
* 功能:初始化SPI接口,设置为主机。
* 入口参数:无
* 出口参数:无
void  MSpiInit(void)
   S0SPCCR = 0x52;                     // 设置SPI时钟分频82
   S0SPCR = 0x30;                   // 设置SPI接口模式,MSTR=1 主模式,CPOL=1 SCK低有效,
                                   //CPHA=0 SCK第一个时钟沿采样,LSBF=0 位7在先 ,SPIE=0 中断被禁止
* 名称:SPI_RW()
* 功能:向SPI总线发送数据。
* 入口参数:data        待发送的数据
* 出口参数:返回值为读取的数据
uint8  SPI_RW(uint8 data)
   uint8 temp = S0SPDR;
   S0SPDR = data;
   while( 0==(S0SPSR&0x80) );                // 等待SPIF置位,即等待数据发送完毕
   return(S0SPDR);
        IO0SET=dc;
        IO0CLR=cs;
        SPI_RW(val);
        IO0SET=cs;
        IO0CLR=dc;
        IO0CLR=cs;
        SPI_RW(reg);
        IO0SET=cs;
void LCD_Init()
        LCD_CD_REG(0xCF);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0xC1);
        LCD_CD_DATA(0X30);
        LCD_CD_REG(0xED);
        LCD_CD_DATA(0x64);
        LCD_CD_DATA(0x03);
        LCD_CD_DATA(0X12);
        LCD_CD_DATA(0X81);
        LCD_CD_REG(0xE8);
        LCD_CD_DATA(0x85);
        LCD_CD_DATA(0x10);
        LCD_CD_DATA(0x7A);
        LCD_CD_REG(0xCB);
        LCD_CD_DATA(0x39);
        LCD_CD_DATA(0x2C);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x34);
        LCD_CD_DATA(0x02);
        LCD_CD_REG(0xF7);
        LCD_CD_DATA(0x20);
        LCD_CD_REG(0xEA);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0XB7);
        LCD_CD_DATA(0x48);
        LCD_CD_REG(0x3A);
        LCD_CD_DATA(0x55);
        LCD_CD_REG(0xB1);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x1A);
        LCD_CD_DATA(0x0A);
        LCD_CD_DATA(0xA2);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x01);
        LCD_CD_DATA(0x0F);
        LCD_CD_DATA(0x2A);
        LCD_CD_DATA(0x28);
        LCD_CD_DATA(0x08);
        LCD_CD_DATA(0x0E);
        LCD_CD_DATA(0x08);
        LCD_CD_DATA(0x54);
        LCD_CD_DATA(0XA9);
        LCD_CD_DATA(0x43);
        LCD_CD_DATA(0x0A);
        LCD_CD_DATA(0x0F);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x15);
        LCD_CD_DATA(0x17);
        LCD_CD_DATA(0x07);
        LCD_CD_DATA(0x11);
        LCD_CD_DATA(0x06);
        LCD_CD_DATA(0x2B);
        LCD_CD_DATA(0x56);
        LCD_CD_DATA(0x3C);
        LCD_CD_DATA(0x05);
        LCD_CD_DATA(0x10);
        LCD_CD_DATA(0x0F);
        LCD_CD_DATA(0x3F);
        LCD_CD_DATA(0x3F);
        LCD_CD_DATA(0x0F);
        LCD_CD_REG(0x2B);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x01);
        LCD_CD_DATA(0x3f);
        LCD_CD_REG(0x2A);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0x00);
        LCD_CD_DATA(0xef);
        delay_ms(120);
        LCD_CD_REG(0x2A);
        LCD_CD_REG(0x2B);
        IO0SET=dc;
        IO0CLR=cs;
        SPI_RW(color>>8);
        SPI_RW(color);
        IO0SET=cs;
        unsigned int i,j;
        LCD_CD_REG(0x2C);
        for(i=0;i<320;i++)
                for(j=0;j<240;j++)
void main()
        TargetResetInit();
        PINSEL0=(PINSEL0&(~(0XFF<<8)))|(0x55<<8);            // 设置连接4线SPI
        IO0DIR  = 0xffffffff;
        IO0SET  = ssel0;
        MSpiInit();
        delay_ms(100);
        LCD_Init();
        while(1)
                LCD_Clear(RED);
                delay_ms(300);
                LCD_Clear(BLUE);
                delay_ms(300);
                LCD_Clear(GREEN);
                delay_ms(300);
2018-7-17 10:32:11 评论
举报
2018-7-17 10:34:21 评论
举报
解决了,PROTEUS模型问题
2018-7-18 13:55:40 评论
举报
撰写答案
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
高级模式
您需要登录后才可以回帖 登录 | 注册
我要提问
课程
    关闭
    站长推荐 上一条 /8 下一条
    快速回复 返回顶部 返回列表
