发 帖
【四旋翼飞行器】76小时吃透四轴算法!史上最强软硬结合实战项目,👉戳此立抢👈
FFT-LED算法led频谱显示程序
2018-7-5 06:35:22  483 FFT LED
分享
FFT-LED算法led频谱显示,抄自网路
  • //电脑音量推荐设置为40%,手机及MP4等要高一些
  • #include <STC12C5A60S2.h>
  • #include<intrins.h>
  • #define SAMPLE_NUM 128
  • #define LOG 6
  • #define tiME 2048           //中断
  • #define FFT_OUT_MIN 0
  • #define FFT_OUT_MAX        7
  • #define OFF L1=L2=L3=L4=L5=L6=L7=L8=L9=L10=L11=L12=L13=L14=L15=L16=L17=L18=L19=L20=L21=L22=L23=L24=1;
  • #define ADC_POWER   0x80            //ADC power control bit
  • #define ADC_FLAG    0x10            //ADC complete flag
  • #define ADC_START   0x08            //ADC start control bit
  • //#define ADC_SPEEDLL 0x00            //420 clocks
  • //#define ADC_SPEEDL  0x20            //280 clocks
  • #define ADC_SPEEDH  0x40            //140 clocks
  • //#define ADC_SPEEDHH 0x60            //70 clocks
  • //采样存储序列表
  • unsigned char code BRTable[SAMPLE_NUM] ={0, 64, 32, 96, 16, 80, 48, 112,
  • 8, 72, 40, 104, 24, 88, 56, 120,
  • 4, 68, 36, 100, 20, 84, 52, 116,
  • 12, 76, 44, 108, 28, 92, 60, 124,
  • 2, 66, 34, 98, 18, 82, 50, 114,
  • 10, 74, 42, 106, 26, 90, 58, 122,
  • 6, 70, 38, 102, 22, 86, 54, 118,
  • 14, 78, 46, 110, 30, 94, 62, 126,
  • 1, 65, 33, 97, 17, 81, 49, 113,
  • 9, 73, 41, 105, 25, 89, 57, 121,
  • 5, 69, 37, 101, 21, 85, 53, 117,
  • 13, 77, 45, 109, 29, 93, 61, 125,
  • 3, 67, 35, 99, 19, 83, 51, 115,
  • 11, 75, 43, 107, 27, 91, 59, 123,
  • 7, 71, 39, 103, 23, 87, 55, 119,
  • 15, 79, 47, 111, 31, 95, 63, 127};
  • char code sin_tabb[SAMPLE_NUM] = {0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70, 75, 80, 85, 89, 94, 98, 102,
  • 105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126, 126, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112,
  • 108, 105, 102, 98, 94, 89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30,
  • -36, -42, -48, -54, -59, -65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121,
  • -123, -124, -125, -126, -126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102,
  • -98, -94, -89, -85, -80, -75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6};
  • char code cos_tabb[SAMPLE_NUM] = {127, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112, 108, 105, 102, 98, 94,
  • 89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30, -36, -42, -48, -54, -59,
  • -65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121, -123, -124, -125, -126, -
  • 126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102, -98, -94, -89, -85, -80,
  • -75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6, 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70,
  • 75, 80, 85, 89, 94, 98, 102, 105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126};
  • xdata unsigned char result[128];
  • xdata unsigned char temp[128];
  • xdata unsigned char num[128];
  • unsigned char anum,timernum,timernum2,lednum3,Ltime,t;//用于分离
  • unsigned char lednum[]={0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};//0-7的显示数组  P2组控制
  • int xdata FftReal[SAMPLE_NUM];
  • int xdata FftImage[SAMPLE_NUM];
  • unsigned char code musicdisplay[]={
  •         0x00,0x00,
  •         0xFE,0x40,0x30,0x40,0xFE,0x00, // -M-
  •         0xFC,0x02,0x02,0x02,0xFC,0x00, // -U-
  •         0x64,0x92,0x92,0x92,0x4C,0x00, // -S-
  •         0x00,0x82,0xFE,0x82,0x00,0x00, // -I-
  •         0x7C,0x82,0x82,0x82,0x44,0x00, // -C-
  •         0x00,0x00,0x00,
  •         0xFE,0x82,0x82,0x82,0x7C,0x00, // -D-
  •         0xFE,0x90,0x90,0x90,0x60,0x00, // -P-
  •         0xFE,0x02,0x02,0x02,0x02,0x00, // -L-
  •         0x3E,0x48,0x88,0x48,0x3E,0x00, // -A-
  •         0xC0,0x20,0x1E,0x20,0xC0,0x00, // -Y-
  •         0x00,0x00,0x00,0x00,0x00,0x00,
  •         0x00,0x00,0x00,0x00,0x00,0x00};
  • #define LED P2
  • #define pwm 9
  • sbit L24=P3^2;
  • sbit L23=P3^1;
  • sbit L22=P3^0;
  • sbit L21=P4^7;
  • sbit L20=P1^7;
  • sbit L19=P1^6;
  • sbit L18=P1^5;
  • sbit L17=P1^4;
  • sbit L16=P3^3;
  • sbit L15=P3^4;
  • sbit L14=P3^5;
  • sbit L13=P3^6;
  • sbit L12=P3^7;
  • sbit L11=P0^2;
  • sbit L10=P0^1;
  • sbit L9=P0^0;
  • sbit L8=P0^3;
  • sbit L7=P0^4;
  • sbit L6=P0^5;
  • sbit L5=P0^6;
  • sbit L4=P0^7;
  • sbit L3=P4^6;
  • sbit L2=P4^5;
  • sbit L1=P4^4;
  • void delay(unsigned char a)
  •         unsigned int i;
  •         while(--a)
  •                 for(i=0;i<50;i++);
  • void off()
  •         LED = 0x00;
  •         OFF
  • //        delay(10-pwm);
  • void display(unsigned char i,unsigned char dat)
  •         P2=dat;
  •         switch(i)
  •                 case 1:L1=0;break;
  •                 case 2:L2=0;break;
  •                 case 3:L3=0;break;
  •                 case 4:L4=0;break;
  •                 case 5:L5=0;break;
  •                 case 6:L6=0;break;
  •                 case 7:L7=0;break;
  •                 case 8:L8=0;break;
  •                 case 9:L9=0;break;
  •                 case 10:L10=0;break;
  •                 case 11:L11=0;break;
  •                 case 12:L12=0;break;
  •                 case 13:L13=0;break;
  •                 case 14:L14=0;break;
  •                 case 15:L15=0;break;
  •                 case 16:L16=0;break;
  •                 case 17:L17=0;break;
  •                 case 18:L18=0;break;
  •                 case 19:L19=0;break;
  •                 case 20:L20=0;break;
  •                 case 21:L21=0;break;
  •                 case 22:L22=0;break;
  •                 case 23:L23=0;break;
  •                 case 24:L24=0;break;
  •         delay(pwm);
  •         off();
  • void show_musicdisplay()
  •         unsigned char a,b,c;
  •         for(c=0;c<80;c++)
  •                 for(b=12;b>0;b--)
  •                            for(a=1;a<25;a++)
  •                                 display(a,musicdisplay[a-1+c]);
  • void FFT_process()                          //下落迟滞
  •         unsigned char i;
  •         for(i=0;i<24;i++)
  •                 if(result < temp)
  •                         num++;
  •                         if(num == 1)
  •                                 if(temp[0]==0&&temp[1]==0&&temp[2]==0&&temp[3]==0&&temp[4]==0&&temp[5]==0&&temp[6]==0&&temp[7]==0&&temp[8]==0&&temp[9]==0&&temp[10]==0&&temp[11]==0&&temp[12]==0&&temp[13]==0&&temp[14]==0&&temp[15]==0&&temp[16]==0&&temp[17]==0&&temp[18]==0&&temp[19]==0&&temp[20]==0&&temp[21]==0&&temp[22]==0&&temp[23]==0&&temp[24]==0);
  •                                 else
  •                                         result = --temp;
  •                                         num = 0;
  •                 else
  •                         num = 0;
  • void disp()
  • //        unsigned char i,j,buff;
  •         timernum++;
  •         if(timernum == 25)
  •                 timernum = 1;
  •            OFF
  •         FFT_process();
  •         /*for(i=0;i<16;i++)
  •                 for(j=i+1;j<16;j++)
  •                         if(result[j] > result)
  •                                 buff = result;
  •                                 result = result[j];
  •                                 result[j] = buff;
  •         switch(timernum)
  •                 case 1:anum = result[0];L1=0;break;
  •                 case 2:anum = result[1];L2=0;break;
  •                 case 3:anum = result[2];L3=0;break;
  •                 case 4:anum = result[3];L4=0;break;
  •                 case 5:anum = result[4];L5=0;break;
  •                 case 6:anum = result[5];L6=0;break;
  •                 case 7:anum = result[6];L7=0;break;
  •                 case 8:anum = result[7];L8=0;break;
  •                 case 9:anum = result[8];L9=0;break;
  •                 case 10:anum = result[9];L10=0;break;
  •                 case 11:anum = result[10];L11=0;break;
  •                 case 12:anum = result[11];L12=0;break;
  •                 case 13:anum = result[12];L13=0;break;
  •                 case 14:anum = result[13];L14=0;break;
  •                 case 15:anum = result[14];L15=0;break;
  •                 case 16:anum = result[15];L16=0;break;
  •                 case 17:anum = result[16];L17=0;break;
  •                 case 18:anum = result[17];L18=0;break;
  •                 case 19:anum = result[18];L19=0;break;
  •                 case 20:anum = result[19];L20=0;break;
  •                 case 21:anum = result[20];L21=0;break;
  •                 case 22:anum = result[21];L22=0;break;
  •                 case 23:anum = result[22];L23=0;break;
  •                 case 24:anum = result[23];L24=0;break;
  •         if(anum >= 8)
  •                 anum = FFT_OUT_MAX;
  •         LED = lednum[anum];
  • void ADC_init()
  •         P1ASF = 0x01;                   //Open 8 channels ADC function
  •     ADC_RES = 0;                    //Clear previous result
  •         ADC_RESL= 0;
  •     ADC_CONTR = ADC_POWER | ADC_SPEEDH;
  •     delay(5);                       //ADC power-on and delay
  • float ADC_read()
  • //delay(10);
  •     ADC_CONTR = ADC_POWER | ADC_SPEEDH  | ADC_START;
  •     _nop_();                        //至少要延时4个时钟周期
  •     _nop_();
  •     _nop_();
  •     _nop_();
  •         _nop_();
  •     while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag
  •     ADC_CONTR &= ~ADC_FLAG;         //关闭ADC
  •     return (ADC_RES*4+ADC_RESL);                 //Return ADC result
  • short sqrt_16(unsigned long M)
  •     unsigned int N,i;
  •     unsigned long tmp,ttp;
  •     if( M == 0 )
  •         return 0;
  •     N = 0;
  •     tmp = (M >> 30);
  •     M <<= 2;
  •     if( tmp > 1 )
  •         N++;
  •         tmp -= N;
  •     for( i=15; i>0; i-- )
  •         N <<= 1;
  •         tmp <<= 2;
  •         tmp += (M >> 30);
  •         ttp = N;
  •         ttp = (ttp<<1)+1;
  •         M <<= 2;
  •         if( tmp >= ttp )
  •             tmp -= ttp;
  •             N ++;
  •     return N;
  • void FFT()
  •     register unsigned char i,bb,j,k,p;
  •     register short TR,TI,temp;
  •     unsigned long ulReal,ulImage;
  •         unsigned char max;
  •     for(i=0;i<SAMPLE_NUM;i++)
  •                 FftReal[BRTable] = ADC_read();
  •         FftImage = 0;
  •     for(i=1;i<=LOG;i++)
  •         bb=1;
  •         bb <<= (i-1);
  •         for(j=0;j<=bb-1;j++)
  •             p=1;
  •             p <<= (LOG-i);
  •             p = p*j;
  •             for(k=j;k<SAMPLE_NUM;k=k+2*bb)
  •                 TR=FftReal[k];TI=FftImage[k];temp=FftReal[k+bb];
  •                 FftReal[k]=FftReal[k]+((FftReal[k+bb]*cos_tabb[p])>>7)+((FftImage[k+bb]*sin_tabb[p])>>7);
  •                 FftImage[k]=FftImage[k] - ((FftReal[k+bb]*sin_tabb[p])>>7)+((FftImage[k+bb]*cos_tabb[p])>>7);
  •                 FftReal[k+bb]=TR-((FftReal[k+bb]*cos_tabb[p])>>7)-((FftImage[k+bb]*sin_tabb[p])>>7);
  •                 FftImage[k+bb]=TI+((temp*sin_tabb[p])>>7)-((FftImage[k+bb]*cos_tabb[p])>>7);
  •                 FftReal[k] >>= 1;
  •                 FftImage[k] >>= 1;
  •                 FftReal[k+bb] >>= 1;
  •                 FftImage[k+bb] >>= 1;
  •    for(i=0;i<24;i++)
  •         ulReal = FftReal[i+1];
  •         ulReal *= ulReal;
  •         ulImage = FftImage[i+1];
  •         ulImage *= ulImage;
  •         result = sqrt_16(ulReal+ulImage);
  • /*        for(i=0;i<17;i++)
  •                 while(result > FFT_OUT_MAX)
  •                 for(i=0;i<17;i++)
  •                         result =result -1;
  •         while(result == FFT_OUT_MIN)
  •                 for(i=0;i<24;i++)
  •                         result =result +1;
  •         for(i=0;i<24;i++)
  •                 if(result > FFT_OUT_MAX)
  •                         result = FFT_OUT_MAX;
  •                         if(result > max)
  •                 max = result;
  •         //局部增益        */        /*
  •                 /*if(max >= 4)
  •                 for(i=1;i<24;i++)
  •                         if(result >= 2)
  •                                 result+=1;          */
  • void init()
  •         P2M0=0XFF;
  •         P2M1=0X00;
  •         P3M0=0XFF;
  •         P3M1=0X00;
  •         P1M0=0XFE;
  •         P1M1=0X01;
  •         P4SW=0x70;
  •         ADC_init();
  •         //AUXR |= 0x80;                //定时器时钟1T模式
  •         TMOD=0x01;
  •         TH0=(65535-TIME)/256;
  •         TL0=(65535-TIME)%256;
  •     EA=1;
  •         ET0=1;
  •         show_musicdisplay();
  •         TR0=1;
  • void main()
  •         init();
  •     while(1)
  •         FFT();
  • void timer0() interrupt 1
  •         unsigned char i;
  •         t++;
  •         if(t == 24)
  •                 for(i=0;i<24;i++)
  •                         temp = result;
  •                 t = 0;
  •         disp();
        FFT-LED.rar
2018-7-5 06:35:22   评论 分享淘帖
只有小组成员才能发言,加入小组>>
466个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /7 下一条
快速回复 返回顶部 返回列表
