下面是STM32 NAND闪存成功读取ID程序:(这里我采用的是库代码与裸寄存器操作)
- #include "stm32f10x.h"
- #include "stm32f10x_flash.h"
- #define SET_CLE GPIO_SetBits(GPIOD, GPIO_Pin_6)
- #define CLR_CLE GPIO_ResetBits(GPIOD, GPIO_Pin_6)
- #define SET_ALE GPIO_SetBits(GPIOD, GPIO_Pin_5)
- #define CLR_ALE GPIO_ResetBits(GPIOD, GPIO_Pin_5)
- #define SET_CE GPIO_SetBits(GPIOD, GPIO_Pin_7)
- #define CLR_CE GPIO_ResetBits(GPIOD, GPIO_Pin_7)
- #define SET_WE GPIO_SetBits(GPIOD, GPIO_Pin_14)
- #define CLR_WE GPIO_ResetBits(GPIOD, GPIO_Pin_14)
- #define SET_RE GPIO_SetBits(GPIOD, GPIO_Pin_15)
- #define CLR_RE GPIO_ResetBits(GPIOD, GPIO_Pin_15)
- void mysysinit(void);//系统时钟初始
- void my_USART_init(void);//初始化
- void my_send_byte(unsigned char send_date); //发送一个字节
- GPIO_InitTypeDef GPIO_InitStructure;
- void READ_NAND_ID(void);
- void delay_1us(uint32_t);
- void my_NAND_INIT(void ); //nand flash 初始化
- void wait_NAND_readay(void);
- int main()
- mysysinit();//RCC初始化,系统时钟设置72MHZ
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能APB2的GPIO_D时钟
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//使能APB2的GPIO_D时钟
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能APB2的GPIO_B时钟
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);//使能APB2的GPIO_E时钟
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);//使能APB2的GPIO_E时钟
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//使能APB1的USART2时钟
- /* led*/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9| GPIO_Pin_10| GPIO_Pin_11;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- /* 设置PB.5用于控制NAND的为上拉输入 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- my_USART_init();
- wait_NAND_readay();
- GPIO_SetBits(GPIOD, GPIO_Pin_8);
- my_send_byte(0);
- my_send_byte(1);
- my_send_byte(2);
- my_send_byte(3);
- READ_NAND_ID();
- while(1);
- /*等待芯片不忙*/
- void wait_NAND_readay()
- uint8_t wait=0;//忙闲信号
- //等待芯片不忙
- do
- { wait=GPIO_ReadOutputDataBit(GPIOB, GPIO_Pin_5);//读取忙闲引脚
- while(0x00==wait);
- /*读取NAND闪存的ID序列号串口发送*/
- void READ_NAND_ID()
- uint8_t a=0,b=0,c=0,d=0;
- /* 设置PD口用于控制NAND的为输出 */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6| GPIO_Pin_7| GPIO_Pin_14| GPIO_Pin_15;
- /*设置PE口得低八位为输出*/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1| GPIO_Pin_2| GPIO_Pin_3| GPIO_Pin_4|GPIO_Pin_7 | GPIO_Pin_6| GPIO_Pin_7;
- GPIO_Init(GPIOE, &GPIO_InitStructure);
- //delay_1us(1000000);
- CLR_CE;//开启片选
- SET_CLE;//命令锁存开启
- CLR_WE;//写使能
- CLR_ALE;//地址锁存关闭
- SET_RE;//读关闭
- GPIO_Write(GPIOE, 0x90); //读ID命令
- SET_WE;//关闭写
- CLR_CLE;
- SET_ALE;
- CLR_WE;
- GPIO_Write(GPIOE, 0x00); //地址00
- SET_WE;
- /*设置PE口得低八位为输入*/
- CLR_ALE; //注意啊,这里一定把他放在下面应为是有时间要求的;时序图TAR=15纳秒之后才是RE的操作;
- //读出的结果是AD F1 80 1D ,2011年8月26日,与天津第四项目部宿舍
- CLR_RE;
- a=(GPIOE->IDR);
- SET_RE;
- CLR_RE;
- b=(GPIOE->IDR);
- SET_RE;
- CLR_RE;
- c=(GPIOE->IDR);
- SET_RE;
- CLR_RE;
- d=(GPIOE->IDR);//delay_1us(1);
- SET_RE;
- SET_CE;//关闭片选
- my_send_byte(a);
- my_send_byte(b);
- my_send_byte(c);
- my_send_byte(d);
- 延时函数
- 形参:uint8_t time
- 功能:延时数值为time值
- void delay_1us(uint32_t time)
- { uint32_t b,c;
- for(c=time;c;c--) //定时=time*3*333.6=time*1000.8ns
- for(b=8;b;b--); //8*13.9*3= 333.6
- 发送一个字节函数通过串口
- void my_send_byte(unsigned char send_date )
- while( (USART1->SR&0x00000080)!=0x80);//发送寄存器为空
- USART1->DR=send_date;
- 初始化串口
- void my_USART_init()
- /*USART2的优先级设为5*/
- NVIC->IP[37]=5;
- /*开启38号中断即USART2,关闭其他所有外部的中断*/
- NVIC->ISER[1]=0x00000020;
- /*设置复用模式下的引脚模式为全双工:TX输出推挽复用,RX为输入上拉模式,速度50MHZ*/
- GPIOA->CRH=0x000008b0;
- /* 1.开启USART,
- USART1->CR1=0x2000;
- /* 1.关闭局域网模式
- * 2.1个停止位
- * 3.CK引脚禁能
- USART1->CR2=0;
- /* 1.关闭调制解调模式
- * 2.关闭DMA模式
- * 3.关闭智能卡、红外模式
- * 4.关闭错误中断
- USART1->CR3=0;
- /* 波特率设置
- 2011年8月11日
- 王均伟
- 天津第四项目部宿舍
- BRR中的第四位(DIV_Fraction)作为小数,高12位(DIV_MANtissa)作为整数部分,
- 1,根据公式:波特率=fck/16*usardiv,其中usardivBRR寄存器的值,所以变形得:USARDIV=fck/16*波特率
- 2.算出来BRR寄存器的值后就要把这个值变成16进制数据写入BRR寄存器中,
- 遵循以下规则:
- 小数部分*16=DIV_Fraction或者取近似的值
- 整数部分直接=DIV_MANtissa
- 3.把这个16进制值写入BRR寄存器
- 例如我要算波特率设成9600bps的BRR寄存器值,
- 1.先求USARDIV=36000000/16*9600=234.375
- 2.换成十六进制:DIV_Fraction=16*0.375=0x6
- DIV_MANtissa=234=0xea
- 3.组合并写入寄存器
- USART2->BRR=0x0ea6;值得注意的是这里是16位半字操作,所以不要以为是32位。
- USART1->BRR=0x0ea6;
- /* 1.开启USART
- * 2.开启接收完毕中断
- * 3.开启发送功能
- * 4.开启接收功能
- USART1->CR1=0x202c;
- void mysysinit()//系统初始化程序
- ErrorStatus HSEStartUpStatus;//说明标志位
- RCC_DeInit();//所有外设全部缺省设置
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready and if Time out is reached exit */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)//启动成功
- /*这两条FLASH指令必须加上,不知为啥?不加上就运行几秒后出错,参照系统初始化*/
- /* Enable The Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//FLASH缓存开启
- /* Configure the Latency cycle: Set 2 Latency cycles */
- FLASH_SetLatency(FLASH_Latency_2); //设置FLASH这些位表示SYSCLK(系统时钟)周期与闪存访问时间的比例,为010:两个等待状态,当 48MHz < SYSCLK ≤ 72MHz
- /* Set PLL clock output to 72MHz using HSE (8MHz) as entry clock */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//外部时钟为8M,PLL的输入时钟=8MHZ,倍频系数9,
- /* Configure HCLK such as HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);//设置了啦AHB分频器的分频系数=1,即HCLK=SYSCLK=72MHZ
- /* Configure PCLK1 such as PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);//设置了APB1外设的时钟频率最大是36M这里是APB1的分频器设为2,PCLK1=HCLK/2=72/2=36MHZ正好是最大值
- /* Configure PCLK2 such as PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);//设置PLCK2=HCLK=72MHZ,的APB2分频器=1
- /* Select the PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//设置了SYSCLK的提供者为PLL,频率由上面算出=72MHZ
- /* disable PLL Ready interrupt */
- RCC_ITConfig(RCC_IT_PLLRDY, DISABLE);//PLL中断关闭
- RCC_ITConfig(RCC_IT_HSERDY,DISABLE);//HSE中断关闭
- RCC_ITConfig(RCC_IT_HSIRDY, DISABLE); //HSI中断关闭
- RCC_ITConfig(RCC_IT_LSERDY, DISABLE); //LSE中断关闭
- RCC_ITConfig(RCC_IT_LSIRDY, DISABLE); //LSI中断关闭
- /* PLL clock divided by 1.5 used as USB clock source */
- RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);//设置USB的时钟为=72、1.5=48mhz
- /* Configure ADCCLK such as ADCCLK = PCLK2/2 */
- RCC_ADCCLKConfig(RCC_PCLK2_Div2);//设置ADC时钟=PCLK2/2= 36MHZ
- /* disable the LSE */
- RCC_LSEConfig(RCC_LSE_OFF);//外部低速晶振关闭
- /*DISable the RTC clock */
- RCC_RTCCLKCmd(DISABLE);
- /* DISable the Clock Security System */
- RCC_ClockSecuritySystemCmd(DISABLE);
- /* Enable the PLL */
- RCC_PLLCmd(ENABLE);//使能PLL
- /* PLL ans system clock config */
- else
- /* Add here some code to deal with this error */
