我采用XDS100v2 USB Emulator在CCSV5下调试DM365开发板。不知为什么在run下执行debug后,总是出现以下错误信息: ARM9: GEL Output: DM365EVM ARM Startup Sequence ARM9: GEL Output: Disable IRQ/FIQ ARM9: GEL Output: Flush Cache ARM9: GEL Output: Disable MMU ARM9: GEL Output: Disable IRQ/FIQ ARM9: GEL Output: Flush Cache ARM9: GEL Output: Disable MMU ARM9: GEL Output: Setup Power Modules (All on)...ARM9: GEL Output: [Done] ARM9: GEL Output: Setup PinMux...ARM9: GEL Output: [Done] ARM9: GEL Output: Setup PLL0...ARM9: GEL: Error while executing OnTargetConnect(): Target failed to write memory at 0x01C40900 at (*(pll_ctl)&=~(0x0001)) [evmdm365.gel:500] at Setup_PLL1() [evmdm365.gel:124] at OnTargetConnect() . ARM9: Error: (Error -1029 @ 0x2B5F) Invalid data read from ICECrusher register. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.872.0) ARM9: Failed Software Reset ARM9: Error: (Error -1029 @ 0x2B5F) Invalid data read from ICECrusher register. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.872.0) ARM9: Unable to determine target status after 20 attempts ARM9: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging 检查.GEL文件,没有发现什么问题。在targetConfigs下检查EVMDM365.ccxml, 设置没有什么问题, 可是连接测试出错。请问这是什么原因啊。谢了! |
2个回答
这个问题,请将 XDS100v2仿真器的JTAG TCLK设置为:adaptive with user specified limit 。
如果我的回复解决了您的问题,请点击下面的标签“是”。 |
kingnet_52004 发表于 2018-6-22 04:39 Titan, 谢谢!正如你说的,问题解决了! |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1872 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3614 浏览 4 评论
5020 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1725 浏览 1 评论
9311 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
654浏览 2评论
697浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
651浏览 1评论
1178浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1174浏览 1评论
GMT+8, 2024-3-29 09:21 , Processed in 0.627582 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
