扫一扫,分享给好友
我板子AM335x ICEv2,下载了最新的sy***ios_ind_sdk,想要编译Building Full Feature EtherCAT Application,按照手册说明进行到到第五步,发现ecat_def.h没有TIESC_APPLICATION定义啊,是不是我哪里弄错了。谁有完整版本编译好的给我发一下啊。我邮箱007afei@163.com,谢谢。 5. Define macros in ecat_applEcatStackecat_def.h as required for your application. (a) Ensure that TIESC_HW is set to 1. (b) For running default application, set TIESC_APPLICATION to 1 and CiA402_DEVICE to 0. For SYSBIOS Industrial SDK 02.01.01 User Guide 35 running CiA402 application, set TIESC_APPLICATION to 0 and CiA402_DEVICE to 1. |
3个回答
ind_idk的下载网页上应该就有prebuild image 啊
按照说明build之后发现如下错误: **** Build of configuration am335x_debug for project ecat_appl **** "C:\TI\ccsv6\utils\bin\gmake" -k all 'Building file: ../am335x_app.cfg' 'Invoking: XDCtools' "C:/ti/xdctools_3_31_02_38_core/xs" --xdcpath="C:/ti/bios_6_42_02_29/packages;" xdc.tools.configuro -o configPkg -t gnu.targets.arm.A8F -p ti.platforms.evmAM3359 -r debug -c "C:/TI/ccsv6/tools/compiler/gcc-arm-none-eabi-4_8-2014q3" "../am335x_app.cfg" making package.mak (because of package.bld) ... generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ... configuring am335x_app.xa8fg from package/cfg/am335x_app_pa8fg.cfg ... generating custom ti.sy***ios library makefile ... js: "C:/TI/xdctools_3_31_02_38_core/packages/xdc/cfg/Main.xs", line 48: XDC runtime error: can't find program 'am335x_app.xa8fg's linker command template file: 'C:tiam335x_sy***ios_ind_sdk_1.1.0.10sdk/protocols/ethercat_slave/ecat_appl/ecat_appl.xdt' along the path C:/TI/bios_6_42_02_29/packages;C:/ti/xdctools_3_31_02_38_core/packages;..; gmake.exe: *** [package/cfg/am335x_app_pa8fg.xdl] Error 1 gmake.exe: *** Deleting file `package/cfg/am335x_app_pa8fg.xdl' gmake.exe: *** [package/cfg/am335x_app_pa8fg.xdl] Deleting file `package/cfg/am335x_app_pa8fg.h' gmake.exe: *** [package/cfg/am335x_app_pa8fg.xdl] Deleting file `package/cfg/am335x_app_pa8fg.c' js: "C:/TI/xdctools_3_31_02_38_core/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted. gmake: *** [configPkg/linker.cmd] Error 1 gmake: Target `all' not remade because of errors. **** Build Finished **** 是XDC版本有问题吗?我该怎么解决啊? |
tyewybvwe 发表于 2018-6-21 06:31 你为什么用的gcc编译的,这个不对 如果我的回答解决了您的问题,请确认答案,谢谢!:) |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3645 浏览 4 评论
5031 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1734 浏览 1 评论
9368 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1761浏览 1评论
GMT+8, 2024-4-23 22:31 , Processed in 0.705552 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
