U-Boot# bootm 0x82000000 - 0x83000000 ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.14.26-g07d13c6-dirty Created: 2015-09-28 6:30:28 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4383352 Bytes = 4.2 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK ## Flattened Device Tree blob at 83000000 Booting using the fdt blob at 0x83000000 Loading Kernel Image ... OK Loading Device Tree to 8fff3000, end 8ffff8d7 ... OK Starting kernel ... 内存与nand都为128M - 0x08000000,文件系统未配置 内核版本为3.14.26,nandflash启动 内核配置为 Make ARCH=arm CROSS_COMPILE=/opt/arm-arago-linux-gcc-ti/i686-arago-linux/usr/bin/arm-linux-gnueabihf- -j8 omap2plus_defconfig Boot options ---> Default kernel command string 将root=/dev/mmcblk0p2 rootwait console=ttyO2,115200 修改为:root=/dev/mmcblk0p2 rootwait console=ttyO0,115200 启动代码为默认 bootcmd=run findfdt; run mmcboot;setenv mmcdev 1; setenv bootpart 1:2; run mmcbo ot;run nandboot; 最后会执行run nandboot echo Booting from nand ...; run nandargs; nand read $[fdtaddr] NAND.u-b oot-spl-os; nand read $[loadaddr] NAND.kernel; bootz $[loadaddr] - $[fdtaddr] nandargs=setenv bootargs console=$[console] $[optargs] root=$[nandroot] rootfsty pe=$[nandrootfstype] console=ttyO0,115200n8 nandroot=ubi0:rootfs rw ubi.mtd=NAND.file-system,2048 nandrootfstype=ubifs rootwait=1 |
6个回答
dts采用am335x-evm.dts
改动为 memory [ device_type = "memory"; reg = <0x80000000 0x08000000>; /* 128 MB */ ]; &gpmc [ status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&nandflash_pins_default>; pinctrl-1 = <&nandflash_pins_sleep>; ranges = <0 0 0x08000000 0x08000000>; /* CS0: NAND */ partition@9 [ label = "NAND.file-system"; reg = <0x00A00000 0x07600000>; |
建议先参考下我们的这个相关总结: http://www.deyisupport.com/question_answer/dsp_arm/sitara_arm/f/25/t/51326.aspx |
344868615qq 发表于 2018-6-21 05:55 我使用的sdk-08.00.00.00,里面的是linux-3.14的版本 加载内核只加载到starting kernel。。。 ①不适用于rtc的情况 ②而且我使用的是linux-3.14的版本,附加链接中linux-2.6的例子也不适用 |
48K栓 发表于 2018-6-21 06:04 板子用的是ddr3,范围是0x80000000 - 0x88000000, 我想问一下,这句调试正常吗 Loading Device Tree to 8fff3000, end 8ffff8d7 ... OK |
48K栓 发表于 2018-6-21 06:22 问题已经解决了,就是怀疑的这个地方, 因为我的ddr是128M的,从代码可以看出如果没设置bootm_size为0x0800 0000,则默认的寻址范围为0x1000 0000, 超过内存的范围,所以内核没加载 |
48K栓 发表于 2018-6-21 06:22 这样的问题,多半要先调试下ddr3的稳定性,请问做了ddr3 software leveling吗,也就是调试ddr3的参数。 如果我的回答解决了您的问题,请确认答案,谢谢!:) |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9353 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
1186浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
GMT+8, 2024-4-20 00:53 , Processed in 0.637549 second(s), Total 76, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
