买了一个beaglebone black的开发板,需要进行gpmc的开发。使用的内核版本是3.8.13。 想请下gpmc驱动如何开发? 谢谢! |
12个回答
gpmc要接什么外设?可以参考gpevm的NAND驱动部分。
需要接2个fpga和4个双口RAM。 “gpevm的NAND驱动部分”这个在哪里能找到? 谢谢! |
你先参考下am335x-evm.dts中的gpmc部分 |
Jian Zhou:您好! 我用的内核是bb-black-debian-kernel-3.8,其中的am335x-evm.dts里面并无gpmc相关内容。 你是指的am33xx.dtsi中的gpmc吗? am33xx.dtsi中gpmc(内容好象不足以参考): gpmc: gpmc@50000000 [ compatible = "ti,am3352-gpmc"; ti,hwmods = "gpmc"; reg = <0x50000000 0x01000000>; interrupts = <100>; gpmc,num-cs = <7>; gpmc,num-waitpins = <2>; #address-cells = <2>; #size-cells = <1>; status = "disabled"; ]; 是否能告诉我哪里可以找到你说的gpmc内容? 谢谢! |
hongqiaolian 发表于 2018-6-21 03:58 请您下载TI的Linux SDK: http://software-dl.ti.com/sitara_linux/esd/AM335xSDK/08_00_00_00/index_FDS.html |
344868615qq 发表于 2018-6-21 04:06 Jian Zhou:您好! 我下载了SDK,依照其中的am335x_evm.dts修改如下: 引脚复用: nandflash_pins_default: nandflash_pins_default [ pinctrl-single,pins = < 0x0 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad0.gpmc_ad0 */ 0x4 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad1.gpmc_ad1 */ 0x8 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad2.gpmc_ad2 */ 0xc (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad3.gpmc_ad3 */ 0x10 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad4.gpmc_ad4 */ 0x14 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad5.gpmc_ad5 */ 0x18 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad6.gpmc_ad6 */ 0x1c (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad7.gpmc_ad7 */ 0x20 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad8.gpmc_ad8 */ 0x24 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad9.gpmc_ad9 */ 0x28 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad10.gpmc_ad10 */ 0x2c (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad11.gpmc_ad11 */ 0x30 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad12.gpmc_ad12 */ 0x34 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad13.gpmc_ad13 */ 0x38 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad14.gpmc_ad14 */ 0x3c (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad15.gpmc_ad15 */ 0xa4 (PIN_OUTPUT | MUX_MODE1) /* lcd_data1.gpmc_a1 */ 0xa8 (PIN_OUTPUT | MUX_MODE1) /* lcd_data2.gpmc_a2 */ 0xac (PIN_OUTPUT | MUX_MODE1) /* lcd_data3.gpmc_a3 */ 0xb0 (PIN_OUTPUT | MUX_MODE1) /* lcd_data4.gpmc_a4 */ 0xb4 (PIN_OUTPUT | MUX_MODE1) /* lcd_data5.gpmc_a5 */ 0xb8 (PIN_OUTPUT | MUX_MODE1) /* lcd_data6.gpmc_a6 */ 0xbc (PIN_OUTPUT | MUX_MODE1) /* lcd_data7.gpmc_a7 */ 0xe0 (PIN_OUTPUT | MUX_MODE1) /* lcd_vsync.gpmc_a8 */ 0xe4 (PIN_OUTPUT | MUX_MODE1) /* lcd_hsync.gpmc_a9 */ 0xe8 (PIN_OUTPUT | MUX_MODE1) /* lcd_pclk.gpmc_a10 */ 0xec (PIN_OUTPUT | MUX_MODE1) /* lcd_ac_bias_en.gpmc_a11 */ 0xc0 (PIN_OUTPUT | MUX_MODE1) /* lcd_data8.gpmc_a12 */ 0xc4 (PIN_OUTPUT | MUX_MODE1) /* lcd_data9.gpmc_a13 */ 0xc8 (PIN_OUTPUT | MUX_MODE1) /* lcd_data10.gpmc_a14 */ 0xcc (PIN_OUTPUT | MUX_MODE1) /* lcd_data11.gpmc_a15 */ 0xd0 (PIN_OUTPUT | MUX_MODE1) /* lcd_data12.gpmc_a16 */ 0xd4 (PIN_OUTPUT | MUX_MODE1) /* lcd_data13.gpmc_a17 */ 0xd8 (PIN_OUTPUT | MUX_MODE1) /* lcd_data14.gpmc_a18 */ 0xdc (PIN_OUTPUT | MUX_MODE1) /* lcd_data15.gpmc_a19 */ 0x70 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_wait0.gpmc_wait0 */ 0x74 (PIN_OUTPUT | MUX_MODE2) /* gpmc_wpn.gpmc_csn5 */ 0x78 (PIN_OUTPUT | MUX_MODE2) /* gpmc_be1n.gpmc_csn6 */ 0x7c (PIN_OUTPUT | MUX_MODE0) /* gpmc_csn0.gpmc_csn0 */ 0x80 (PIN_OUTPUT | MUX_MODE0) /* gpmc_csn1.gpmc_csn1 */ 0x84 (PIN_OUTPUT | MUX_MODE1) /* gpmc_cs2.gpmc_be1n */ 0x88 (PIN_OUTPUT | MUX_MODE0) /* gpmc_cs3.gpmc_cs3 */ 0x8c (PIN_OUTPUT | MUX_MODE0) /* gpmc_clk.gpmc_clk */ 0x90 (PIN_OUTPUT | MUX_MODE0) /* gpmc_advn_ale.gpmc_advn_ale */ 0x94 (PIN_OUTPUT | MUX_MODE0) /* gpmc_oen_ren.gpmc_oen_ren */ 0x98 (PIN_OUTPUT | MUX_MODE0) /* gpmc_wen.gpmc_wen */ 0x9c (PIN_OUTPUT | MUX_MODE0) /* gpmc_be0n_cle.gpmc_be0n_cle */ >; ]; nandflash_pins_sleep: nandflash_pins_sleep [ pinctrl-single,pins = < 0x0 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x4 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x8 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xc (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x20 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x24 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x28 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x2c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x30 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x34 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x38 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x3c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xa4 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xa8 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xac (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xb0 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xb4 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xb8 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xbc (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xe0 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xe4 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xe8 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xec (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xc0 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xc4 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xc8 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xcc (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xd0 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xd4 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xd8 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xdc (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x70 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x74 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x78 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x7c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x80 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x84 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x88 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x8c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x90 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x94 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x98 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x9c (PIN_INPUT_PULLDOWN | MUX_MODE7) >; ]; 节点定义: &gpmc [ status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&nandflash_pins_default>; pinctrl-1 = <&nandflash_pins_sleep>; ranges = <0 0 0x00000000 0x10000000 /* CS0: NAND 256M */ 1 0 0x13000000 0x1000000 /* CS1: dual_business 16M*/ 2 0 0x11000000 0x2000000 /* CS3: fpga_modem 16M*/ 3 0 0x15000000 0x1000000 /* CS5: dual_maindem_out 16M*/ 4 0 0x16000000 0x1000000 /* CS6: dual_auxdem_out 16M*/ >; nand@0,0 [ reg = <0 0 0>; /* CS0, offset 0 */ ti,nand-ecc-opt = "bch8"; ti,elm-id = <&elm>; nand-bus-width = <8>; gpmc,device-width = <1>; gpmc,sync-clk-ps = <0>; gpmc,cs-on-ns = <0>; gpmc,cs-rd-off-ns = <44>; gpmc,cs-wr-off-ns = <44>; gpmc,adv-on-ns = <6>; gpmc,adv-rd-off-ns = <34>; gpmc,adv-wr-off-ns = <44>; gpmc,we-on-ns = <0>; gpmc,we-off-ns = <40>; gpmc,oe-on-ns = <0>; gpmc,oe-off-ns = <54>; gpmc,access-ns = <64>; gpmc,rd-cycle-ns = <82>; gpmc,wr-cycle-ns = <82>; gpmc,wait-on-read = "true"; gpmc,wait-on-write = "true"; gpmc,bus-turnaround-ns = <0>; gpmc,cycle2cycle-delay-ns = <0>; gpmc,clk-activation-ns = <0>; gpmc,wait-monitoring-ns = <0>; gpmc,wr-access-ns = <40>; gpmc,wr-data-mux-bus-ns = <0>; /* MTD partition table */ /* All SPL-* partitions are sized to minimal length * which can be independently programmable. For * NAND flash this is equal to size of erase-block */ #address-cells = <1>; #size-cells = <1>; partition@0 [ label = "NAND.SPL"; reg = <0x00000000 0x000020000>; ]; partition@1 [ label = "NAND.SPL.backup1"; reg = <0x00020000 0x00020000>; ]; partition@2 [ label = "NAND.SPL.backup2"; reg = <0x00040000 0x00020000>; ]; partition@3 [ label = "NAND.SPL.backup3"; reg = <0x00060000 0x00020000>; ]; partition@4 [ label = "NAND.u-boot-spl-os"; reg = <0x00080000 0x00040000>; ]; partition@5 [ label = "NAND.u-boot"; reg = <0x000C0000 0x00100000>; ]; partition@6 [ label = "NAND.u-boot-env"; reg = <0x001C0000 0x00020000>; ]; partition@7 [ label = "NAND.u-boot-env.backup1"; reg = <0x001E0000 0x00020000>; ]; partition@8 [ label = "NAND.kernel"; reg = <0x00200000 0x00800000>; ]; partition@9 [ label = "NAND.file-system"; reg = <0x00A00000 0x0F600000>; ]; ]; dual_business@1,0 [ reg = <0 0 0>; /* CS1, offset 0 */ nand-bus-width = <16>; gpmc,device-width = <1>; gpmc,sync-clk-ps = <0>; gpmc,cs-on-ns = <0>; gpmc,cs-rd-off-ns = <44>; gpmc,cs-wr-off-ns = <44>; gpmc,adv-on-ns = <6>; gpmc,adv-rd-off-ns = <34>; gpmc,adv-wr-off-ns = <44>; gpmc,we-on-ns = <0>; gpmc,we-off-ns = <40>; gpmc,oe-on-ns = <0>; gpmc,oe-off-ns = <54>; gpmc,access-ns = <64>; gpmc,rd-cycle-ns = <82>; gpmc,wr-cycle-ns = <82>; gpmc,wait-on-read = "true"; gpmc,wait-on-write = "true"; gpmc,bus-turnaround-ns = <0>; gpmc,cycle2cycle-delay-ns = <0>; gpmc,clk-activation-ns = <0>; gpmc,wait-monitoring-ns = <0>; gpmc,wr-access-ns = <40>; gpmc,wr-data-mux-bus-ns = <0>; ]; fpga_modem@2,0 [ reg = <0 0 0>; /* CS3, offset 0 */ nand-bus-width = <16>; gpmc,device-width = <1>; gpmc,sync-clk-ps = <0>; gpmc,cs-on-ns = <0>; gpmc,cs-rd-off-ns = <44>; gpmc,cs-wr-off-ns = <44>; gpmc,adv-on-ns = <6>; gpmc,adv-rd-off-ns = <34>; gpmc,adv-wr-off-ns = <44>; gpmc,we-on-ns = <0>; gpmc,we-off-ns = <40>; gpmc,oe-on-ns = <0>; gpmc,oe-off-ns = <54>; gpmc,access-ns = <64>; gpmc,rd-cycle-ns = <82>; gpmc,wr-cycle-ns = <82>; gpmc,wait-on-read = "true"; gpmc,wait-on-write = "true"; gpmc,bus-turnaround-ns = <0>; gpmc,cycle2cycle-delay-ns = <0>; gpmc,clk-activation-ns = <0>; gpmc,wait-monitoring-ns = <0>; gpmc,wr-access-ns = <40>; gpmc,wr-data-mux-bus-ns = <0>; ]; dual_maindem_out@3,0 [ reg = <0 0 0>; /* CS5, offset 0 */ nand-bus-width = <16>; gpmc,device-width = <1>; gpmc,sync-clk-ps = <0>; gpmc,cs-on-ns = <0>; gpmc,cs-rd-off-ns = <44>; gpmc,cs-wr-off-ns = <44>; gpmc,adv-on-ns = <6>; gpmc,adv-rd-off-ns = <34>; gpmc,adv-wr-off-ns = <44>; gpmc,we-on-ns = <0>; gpmc,we-off-ns = <40>; gpmc,oe-on-ns = <0>; gpmc,oe-off-ns = <54>; gpmc,access-ns = <64>; gpmc,rd-cycle-ns = <82>; gpmc,wr-cycle-ns = <82>; gpmc,wait-on-read = "true"; gpmc,wait-on-write = "true"; gpmc,bus-turnaround-ns = <0>; gpmc,cycle2cycle-delay-ns = <0>; gpmc,clk-activation-ns = <0>; gpmc,wait-monitoring-ns = <0>; gpmc,wr-access-ns = <40>; gpmc,wr-data-mux-bus-ns = <0>; ]; dual_auxdem_out@4,0 [ reg = <0 0 0>; /* CS6, offset 0 */ nand-bus-width = <16>; gpmc,device-width = <1>; gpmc,sync-clk-ps = <0>; gpmc,cs-on-ns = <0>; gpmc,cs-rd-off-ns = <44>; gpmc,cs-wr-off-ns = <44>; gpmc,adv-on-ns = <6>; gpmc,adv-rd-off-ns = <34>; gpmc,adv-wr-off-ns = <44>; gpmc,we-on-ns = <0>; gpmc,we-off-ns = <40>; gpmc,oe-on-ns = <0>; gpmc,oe-off-ns = <54>; gpmc,access-ns = <64>; gpmc,rd-cycle-ns = <82>; gpmc,wr-cycle-ns = <82>; gpmc,wait-on-read = "true"; gpmc,wait-on-write = "true"; gpmc,bus-turnaround-ns = <0>; gpmc,cycle2cycle-delay-ns = <0>; gpmc,clk-activation-ns = <0>; gpmc,wait-monitoring-ns = <0>; gpmc,wr-access-ns = <40>; gpmc,wr-data-mux-bus-ns = <0>; ]; 不知道这样做对不对? 其中的: reg = <0 0 0>; /* CS6, offset 0 */ nand-bus-width = <16>; gpmc,device-width = <1>; gpmc,sync-clk-ps = <0>; 部份应该如何进行修改? 谢谢! |
@Jian Zhou 还有什么资料可以学习的吗? 谢谢! |
@ Jian Zhou 才看到了ti-gpmc.txt,总算明白了dts中的这些是什么了。 不过, nand@0,0 [ reg = <0 0 0>; /* CS0, offset 0 */ 里面这个reg的三个参数不太明白。前面两个对应的应该是rangs中的前两个”地址“,第三个是什么? 谢谢! |
学习下这个: http://blog.csdn.net/lichengtongxiazai/article/details/38941997 |
344868615qq 发表于 2018-6-21 05:21 Jian Zhou:您好! 感谢你那么晚还给我发信息! 相似内容的文章看过两个,或许是看得不够仔细吧。我再仔细看看。 谢谢! |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1898 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3648 浏览 4 评论
5032 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1736 浏览 1 评论
9382 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
669浏览 2评论
714浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
676浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1773浏览 1评论
GMT+8, 2024-4-25 03:43 , Processed in 0.514643 second(s), Total 57, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
