谁有AM335X GPIO2的时钟配置函数void GPIO2Moduleclkconfig(void)?或者告诉我下怎么从GPIO1的时钟中修改,startware里面没有,多谢!!! |
3个回答
无论是GPIO123,配置都差不多,大概就是看GPIO在哪一个时钟源下面,一步一步打开就好,下面是GPIO1的配置例程
void GPIO1ModuleClkConfig(void) [ /* Configuring L3 Interface Clocks. */ /* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) |= CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE; /* Waiting for MODULEMODE field to reflect the written value. */ while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE != (HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) & CM_PER_L3_CLKCTRL_MODULEMODE)); /* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) |= CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE; /* Waiting for MODULEMODE field to reflect the written value. */ while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE != (HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) & CM_PER_L3_INSTR_CLKCTRL_MODULEMODE)); /* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) |= CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP; /* Waiting for CLKTRCTRL field to reflect the written value. */ while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP != (HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) & CM_PER_L3_CLKSTCTRL_CLKTRCTRL)); /* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) |= CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP; /*Waiting for CLKTRCTRL field to reflect the written value. */ while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP != (HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) & CM_PER_L3S_CLKSTCTRL_CLKTRCTRL)); /* Writing to MODULEMODE field in CM_PER_OCPWP_CLKCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_CLKCTRL) |= CM_PER_OCPWP_CLKCTRL_MODULEMODE_ENABLE; /* Waiting for MODULEMODE field to reflect the written value. */ while(CM_PER_OCPWP_CLKCTRL_MODULEMODE_ENABLE != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_CLKCTRL) & CM_PER_OCPWP_CLKCTRL_MODULEMODE)); /* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) |= CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP; /*Waiting for CLKTRCTRL field to reflect the written value. */ while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) & CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL)); /* Checking fields for necessary values. */ /* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0. */ while((CM_PER_L3_CLKCTRL_IDLEST_FUNC << CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!= (HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) & CM_PER_L3_CLKCTRL_IDLEST)); /* ** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain the ** desired value. */ while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC << CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!= (HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) & CM_PER_L3_INSTR_CLKCTRL_IDLEST)); /* ** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to ** attain the desired value. */ while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) & CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK)); /* ** Waiting for STBYST bit in CM_PER_OCPWP_CLKCTRL register to attain ** the desired value. */ /* while((CM_PER_OCPWP_CLKCTRL_STBYST_FUNC << CM_PER_OCPWP_CLKCTRL_STBYST_SHIFT) != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_CLKCTRL) & CM_PER_OCPWP_CLKCTRL_STBYST)); */ /* ** Waiting for IDLEST field in CM_PER_OCPWP_CLKCTRL register to attain the ** desired value. */ while((CM_PER_OCPWP_CLKCTRL_IDLEST_FUNC << CM_PER_OCPWP_CLKCTRL_IDLEST_SHIFT) != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_CLKCTRL) & CM_PER_OCPWP_CLKCTRL_IDLEST)); /* ** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL ** register to attain the desired value. */ while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) & CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK)); /* ** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register ** to attain the desired value. */ while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) & CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK)); /* Configuring L4 Interface Clocks. */ /* Writing to MODULEMODE field of CM_PER_L4LS_CLKCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) |= CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE; /* Waiting for MODULEMODE field to reflect the written value. */ while(CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE != (HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) & CM_PER_L4LS_CLKCTRL_MODULEMODE)); /* Writing to CLKTRCTRL field of CM_PER_L4LS_CLKSTCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) |= CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP; /* Waiting for CLKTRCTRL field to reflect the written value. */ while(CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP != (HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) & CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL)); /* Verifying if other configurations are correct. */ /* ** Waiting for IDLEST field in CM_PER_L4LS_CLKCTRL register to attain the ** desired value. */ while((CM_PER_L4LS_CLKCTRL_IDLEST_FUNC << CM_PER_L4LS_CLKCTRL_IDLEST_SHIFT) != (HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) & CM_PER_L4LS_CLKCTRL_IDLEST)); /* ** Waiting for CLKACTIVITY_L4LS_GCLK bit in CM_PER_L4LS_CLKSTCTRL register ** to attain the desired value. */ while(CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) & CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK)); /* ** Waiting for CLKACTIVITY_OCPWP_L4_GCLK bit in CM_PER_OCPWP_L3_CLKSTCTRL ** register to attain the desired value. */ /* while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) & CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK)); */ /* Performing configurations for GPIO1 instance. */ /* Writing to MODULEMODE field of CM_PER_GPIO1_CLKCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_GPIO1_CLKCTRL) |= CM_PER_GPIO1_CLKCTRL_MODULEMODE_ENABLE; /* Waiting for MODULEMODE field to reflect the written value. */ while(CM_PER_GPIO1_CLKCTRL_MODULEMODE_ENABLE != (HWREG(SOC_CM_PER_REGS + CM_PER_GPIO1_CLKCTRL) & CM_PER_GPIO1_CLKCTRL_MODULEMODE)); /* ** Writing to OPTFCLKEN_GPIO_1_GDBCLK bit in CM_PER_GPIO1_CLKCTRL ** register. */ HWREG(SOC_CM_PER_REGS + CM_PER_GPIO1_CLKCTRL) |= CM_PER_GPIO1_CLKCTRL_OPTFCLKEN_GPIO_1_GDBCLK; /* ** Waiting for OPTFCLKEN_GPIO_1_GDBCLK bit to reflect the desired ** value. */ while(CM_PER_GPIO1_CLKCTRL_OPTFCLKEN_GPIO_1_GDBCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_GPIO1_CLKCTRL) & CM_PER_GPIO1_CLKCTRL_OPTFCLKEN_GPIO_1_GDBCLK)); /* ** Waiting for IDLEST field in CM_PER_GPIO1_CLKCTRL register to attain the ** desired value. */ while((CM_PER_GPIO1_CLKCTRL_IDLEST_FUNC << CM_PER_GPIO1_CLKCTRL_IDLEST_SHIFT) != (HWREG(SOC_CM_PER_REGS + CM_PER_GPIO1_CLKCTRL) & CM_PER_GPIO1_CLKCTRL_IDLEST)); /* ** Waiting for CLKACTIVITY_GPIO_1_GDBCLK bit in CM_PER_L4LS_CLKSTCTRL ** register to attain desired value. */ while(CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_GPIO_1_GDBCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) & CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_GPIO_1_GDBCLK)); ] |
uuwufydsw 发表于 2018-6-21 07:55 对比GPIO1配置的,好像还是不行,希望搞过的人帮看看,多谢! void GPIO2ModuleClkConfig(void) [ /* Configuring L3 Interface Clocks. */ /* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) |= CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE; /* Waiting for MODULEMODE field to reflect the written value. */ while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE != (HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) & CM_PER_L3_CLKCTRL_MODULEMODE)); /* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) |= CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE; /* Waiting for MODULEMODE field to reflect the written value. */ while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE != (HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) & CM_PER_L3_INSTR_CLKCTRL_MODULEMODE)); /* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) |= CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP; /* Waiting for CLKTRCTRL field to reflect the written value. */ while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP != (HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) & CM_PER_L3_CLKSTCTRL_CLKTRCTRL)); /* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) |= CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP; /*Waiting for CLKTRCTRL field to reflect the written value. */ while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP != (HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) & CM_PER_L3S_CLKSTCTRL_CLKTRCTRL)); /* Writing to MODULEMODE field in CM_PER_OCPWP_CLKCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_CLKCTRL) |= CM_PER_OCPWP_CLKCTRL_MODULEMODE_ENABLE; /* Waiting for MODULEMODE field to reflect the written value. */ while(CM_PER_OCPWP_CLKCTRL_MODULEMODE_ENABLE != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_CLKCTRL) & CM_PER_OCPWP_CLKCTRL_MODULEMODE)); /* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) |= CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP; /*Waiting for CLKTRCTRL field to reflect the written value. */ while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) & CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL)); /* Checking fields for necessary values. */ /* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0. */ while((CM_PER_L3_CLKCTRL_IDLEST_FUNC << CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!= (HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKCTRL) & CM_PER_L3_CLKCTRL_IDLEST)); /* ** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain the ** desired value. */ while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC << CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!= (HWREG(SOC_CM_PER_REGS + CM_PER_L3_INSTR_CLKCTRL) & CM_PER_L3_INSTR_CLKCTRL_IDLEST)); /* ** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to ** attain the desired value. */ while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_L3_CLKSTCTRL) & CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK)); /* ** Waiting for STBYST bit in CM_PER_OCPWP_CLKCTRL register to attain ** the desired value. */ /* while((CM_PER_OCPWP_CLKCTRL_STBYST_FUNC << CM_PER_OCPWP_CLKCTRL_STBYST_SHIFT) != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_CLKCTRL) & CM_PER_OCPWP_CLKCTRL_STBYST)); */ /* ** Waiting for IDLEST field in CM_PER_OCPWP_CLKCTRL register to attain the ** desired value. */ while((CM_PER_OCPWP_CLKCTRL_IDLEST_FUNC << CM_PER_OCPWP_CLKCTRL_IDLEST_SHIFT) != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_CLKCTRL) & CM_PER_OCPWP_CLKCTRL_IDLEST)); /* ** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL ** register to attain the desired value. */ while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) & CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK)); /* ** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register ** to attain the desired value. */ while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_L3S_CLKSTCTRL) & CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK)); /* Configuring L4 Interface Clocks. */ /* Writing to MODULEMODE field of CM_PER_L4LS_CLKCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) |= CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE; /* Waiting for MODULEMODE field to reflect the written value. */ while(CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE != (HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) & CM_PER_L4LS_CLKCTRL_MODULEMODE)); /* Writing to CLKTRCTRL field of CM_PER_L4LS_CLKSTCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) |= CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP; /* Waiting for CLKTRCTRL field to reflect the written value. */ while(CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP != (HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) & CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL)); /* Verifying if other configurations are correct. */ /* ** Waiting for IDLEST field in CM_PER_L4LS_CLKCTRL register to attain the ** desired value. */ while((CM_PER_L4LS_CLKCTRL_IDLEST_FUNC << CM_PER_L4LS_CLKCTRL_IDLEST_SHIFT) != (HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKCTRL) & CM_PER_L4LS_CLKCTRL_IDLEST)); /* ** Waiting for CLKACTIVITY_L4LS_GCLK bit in CM_PER_L4LS_CLKSTCTRL register ** to attain the desired value. */ while(CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) & CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK)); /* ** Waiting for CLKACTIVITY_OCPWP_L4_GCLK bit in CM_PER_OCPWP_L3_CLKSTCTRL ** register to attain the desired value. */ /* while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_OCPWP_L3_CLKSTCTRL) & CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK)); */ /* Performing configurations for GPIO2 instance. */ /* Writing to MODULEMODE field of CM_PER_GPIO1_CLKCTRL register. */ HWREG(SOC_CM_PER_REGS + CM_PER_GPIO2_CLKCTRL) |= CM_PER_GPIO2_CLKCTRL_MODULEMODE_ENABLE; /* Waiting for MODULEMODE field to reflect the written value. */ while(CM_PER_GPIO2_CLKCTRL_MODULEMODE_ENABLE != (HWREG(SOC_CM_PER_REGS + CM_PER_GPIO2_CLKCTRL) & CM_PER_GPIO2_CLKCTRL_MODULEMODE)); /* ** Writing to OPTFCLKEN_GPIO_1_GDBCLK bit in CM_PER_GPIO1_CLKCTRL ** register. */ HWREG(SOC_CM_PER_REGS + CM_PER_GPIO2_CLKCTRL) |= CM_PER_GPIO2_CLKCTRL_OPTFCLKEN_GPIO_2_GDBCLK; /* ** Waiting for OPTFCLKEN_GPIO_1_GDBCLK bit to reflect the desired ** value. */ while(CM_PER_GPIO2_CLKCTRL_OPTFCLKEN_GPIO_2_GDBCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_GPIO2_CLKCTRL) & CM_PER_GPIO2_CLKCTRL_OPTFCLKEN_GPIO_2_GDBCLK)); /* ** Waiting for IDLEST field in CM_PER_GPIO1_CLKCTRL register to attain the ** desired value. */ while((CM_PER_GPIO2_CLKCTRL_IDLEST_FUNC << CM_PER_GPIO2_CLKCTRL_IDLEST_SHIFT) != (HWREG(SOC_CM_PER_REGS + CM_PER_GPIO2_CLKCTRL) & CM_PER_GPIO2_CLKCTRL_IDLEST)); /* ** Waiting for CLKACTIVITY_GPIO_1_GDBCLK bit in CM_PER_L4LS_CLKSTCTRL ** register to attain desired value. */ while(CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_GPIO_2_GDBCLK != (HWREG(SOC_CM_PER_REGS + CM_PER_L4LS_CLKSTCTRL) & CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_GPIO_2_GDBCLK)); ] |
首先GPIO1配置之后,是可以正常工作的么? |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1872 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3614 浏览 4 评论
5020 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1725 浏览 1 评论
9311 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
654浏览 2评论
697浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
651浏览 1评论
1178浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1174浏览 1评论
GMT+8, 2024-3-29 16:20 , Processed in 0.864461 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
