新购买了一套TMDXIDK5718,官网上下载了SDK,文件是ti-processor-sdk-android-am57xx-evm-04.02.00.09-Linux-x86-Install.bin, 然后通过statted guide(processors.wiki.ti.com/.../Processor_SDK_Android_Getting_Started_Guide)操作,一直未能成功。请各位帮忙看看是什么原因,谢谢! 第5步Run the Setup Script,串口信息如下: zhubinbin@zhubinbin-VirtualBox:~/ti-processor-sdk-android-am57xx-evm-04.02.00.09$ sudo ./setup.sh Just a simple wrapper over the fastboot.sh to set the appropriate paths. --------------------------------------------------------------------------------" This step will set up minicom (serial communication application) for SDK development For boards that contain a USB-to-Serial converter on the board such as: * BeagleBone * Beaglebone Black * AM335x EVM-SK * AM57xx EVM * K2H, K2L, and K2E EVMs the port used for minicom will be automatically detected. By default Ubuntu will not recognize this device. Setup will add a udev rule to /etc/udev/ so that from now on it will be recognized as soon as the board is plugged in. For other boards, the serial will defualt to /dev/ttyS0. Please update based on your setup. -------------------------------------------------------------------------------- NOTE: If your using any of the above boards simply hit enter and the correct port will be determined automatically at a later step. For all other boards select the serial port that the board is connected to. Which serial port do you want to use with minicom? [ /dev/ttyUSB0 ] Copied existing /home/zhubinbin/.minirc.dfl to /home/zhubinbin/.minirc.dfl.old Configuration saved to /home/zhubinbin/.minirc.dfl. You can change it further from inside minicom, see the Software Development Guide for more information. -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- This step will set up the u-boot variables for booting the EVM. -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Would you like to create a minicom script to configure the board (y/n)? [ y ] y Successfully wrote /home/zhubinbin/ti-processor-sdk-android-am57xx-evm-04.02.00.09/bin/setupBoard.minicom Detecting connection to board... /dev/ttyUSB2 -------------------------------------------------------------------------------- Would you like to run the setup script now (y/n)? Please connect the USB and USB/serial cables as described in the Quick Start Guide. Once answering 'y' on the prompt below, you will have 300 seconds to connect the board and power cycle it before the setup times out. After successfully executing this script, your EVM will be set up. After power cycling the board, you will be able to connect to it by executing 'minicom -w' or by using the 'adb' utility. If you prefer a windows host, you can set up Tera Term as explained in the Software Developer's Guide. [ y ] y Welcome to minicom 2.7 OPTIONS: I18n Compiled on Jan 1 2014, 17:13:19. Port /dev/ttyUSB2, 10:10:56 Press CTRL-A Z for help on special keys U-Boot SPL 2016.05-g6f6aaabf5a (Dec 23 2017 - 13:14:49) DRA722-GP ES2.0 Trying to boot from MMC1 no pinctrl for hs200_1_8v no pinctrl for ddr_1_8v no pinctrl for hs200_1_8v reading args spl_load_image_fat_os: error reading image args, err - -1 reading u-boot.img reading u-boot.img reading u-boot.img reading u-boot.img U-Boot 2016.05-g6f6aaabf5a (Dec 23 2017 - 13:14:49 -0500) CPU : DRA722-GP ES2.0 Model: TI AM5718 IDK Board: AM571x IDK REV 1.3B DRAM: 1 GiB MMC: mmc@4809c000: fail to find sdr104 mode FDT_ERR_NOTFOUND no pinctrl for sdr104 mmc@4809c000: fail to find ddr50 mode FDT_ERR_NOTFOUND no pinctrl for ddr50 mmc@4809c000: fail to find sdr50 mode FDT_ERR_NOTFOUND no pinctrl for sdr50 mmc@4809c000: fail to find sdr25 mode FDT_ERR_NOTFOUND no pinctrl for sdr25 mmc@4809c000: fail to find sdr12 mode FDT_ERR_NOTFOUND no pinctrl for sdr12 OMAP SD/MMC: 0, OMAP SD/MMC: 1 ** First descriptor is NOT a primary desc on 1:1 ** GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645 part_get_info_efi: *** ERROR: Invalid GPT *** GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645 part_get_info_efi: *** ERROR: Invalid Backup GPT *** ERROR: cannot find partition: 'userdata' at /oe/bld/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/am57xx_evm-li nux-gnueabi/u-boot-ti-android/2016.05+gitAUTOINC+6f6aaabf5a-r0/git/arch/ARM/cpu/ armv7/omap-common/utils.c:199/mmc_get_part_size() Warning: fastboot.userdata_size: unable to calc SCSI: SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst scanning bus for devices... Found 0 device(s). Net: eth0: ethernet@48484000 Hit any key to stop autobo 0 =>env default -f -a ## Resetting to default environment =>setenv partitions $[partitions_android] =>setenv bootpart 0:1 =>setenv rootpart 0:2 =>setenv bootdir =>setenv devtype mmc =>setenv finduuid 'part uuid $[devtype] $[rootpart] uuid' =>setenv optargs $[bootargs] =>setenv dofastboot 1 =>saveenv Saving Environment to MMC... Writing to MMC(1)... done =>reset resetting ... U-Boot SPL 2016.05-g6f6aaabf5a (Dec 23 2017 - 13:14:49) DRA722-GP ES2.0 Trying to boot from MMC1 no pinctrl for hs200_1_8v no pinctrl for ddr_1_8v no pinctrl for hs200_1_8v reading args spl_load_image_fat_os: error reading image args, err - -1 reading u-boot.img reading u-boot.img reading u-boot.img reading u-boot.img U-Boot 2016.05-g6f6aaabf5a (Dec 23 2017 - 13:14:49 -0500) CPU : DRA722-GP ES2.0 Model: TI AM5718 IDK Board: AM571x IDK REV 1.3B DRAM: 1 GiB MMC: mmc@4809c000: fail to find sdr104 mode FDT_ERR_NOTFOUND no pinctrl for sdr104 mmc@4809c000: fail to find ddr50 mode FDT_ERR_NOTFOUND no pinctrl for ddr50 mmc@4809c000: fail to find sdr50 mode FDT_ERR_NOTFOUND no pinctrl for sdr50 mmc@4809c000: fail to find sdr25 mode FDT_ERR_NOTFOUND no pinctrl for sdr25 mmc@4809c000: fail to find sdr12 mode FDT_ERR_NOTFOUND no pinctrl for sdr12 OMAP SD/MMC: 0, OMAP SD/MMC: 1 ** First descriptor is NOT a primary desc on 1:1 ** GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645 part_get_info_efi: *** ERROR: Invalid GPT *** GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645 part_get_info_efi: *** ERROR: Invalid Backup GPT *** ERROR: cannot find partition: 'userdata' at /oe/bld/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/am57xx_evm-li nux-gnueabi/u-boot-ti-android/2016.05+gitAUTOINC+6f6aaabf5a-r0/git/arch/arm/cpu/ armv7/omap-common/utils.c:199/mmc_get_part_size() Warning: fastboot.userdata_size: unable to calc SCSI: SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst scanning bus for devices... Found 0 device(s). Net: Warning: ethernet@48484000 using MAC address from ROM eth0: ethernet@48484000 Hit any key to stop autoboot: 0 Boot fastboot requested, resetting dofastboot ... Saving Environment to MMC... Writing to redundant MMC(1)... done Booting into fastboot ... /home/zhubinbin/ti-processor-sdk-android-am57xx-evm-04.02.00.09 You can manually run minicom in the future with this setup script using: $ minicom -S /home/zhubinbin/ti-processor-sdk-android-am57xx-evm-04.02.00.09/bin/setupBoard.minicom -------------------------------------------------------------------------------- Fastboot: ./fastboot Image location: /home/zhubinbin/ti-processor-sdk-android-am57xx-evm-04.02.00.09/board-support/prebuilt-images/ No device detected. Please ensure that fastboot is running on the target device ti-processor-sdk-android-am57xx-evm-04.02.00.09-Linux-x86-Install.bin |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9353 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
1186浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
GMT+8, 2024-4-19 19:48 , Processed in 1.121836 second(s), Total 70, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
