扫一扫,分享给好友
KeyStone Architecture Literature Number: SPRUGW1B November 2012 Serial Rapid IO (SRIO) 2.3.2 这节 The direct I/O (Load/Store) module serves as the source of all outgoing direct I/O packets. With direct I/O, the RapidIO packet contains the specific address where the data should be stored or read in the destination device. Direct I/O requires that a RapidIO source device keep a local table of addresses for memory within the destination device. Once these tables are established, the RapidIO source controller uses this data to compute the destination address and insert it into the packet header. The RapidIO destination peripheral extracts the destination address from the received 请问下,LSU_REG1 LSU_REG2这两个寄存器填写的地址是真实的内存地址么?还是逻辑的地址? 另外,发送doorbel包的时候,这两个寄存器填写地址是什么?是不是都为0即可? |
1个回答
填写实际地址,参考SRIO例程中的DIO通信测试
http://www.deyisupport.com/question_answer/dsp_arm/c6000_multicore/f/53/t/47664.aspx |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9353 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
1186浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
GMT+8, 2024-4-19 22:38 , Processed in 0.710751 second(s), Total 69, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
