扫一扫,分享给好友
在28035CLA中定义了一个数组,发现数组过大时,CLA无法进入中断,但是查看.map文件内存尚有剩余,把数组减小,CLA可以正常工作,有没有办法改变CLA内存,使得内存中可以放置更多的数组? |
9个回答
F28035的CLA的数据RAM和程序RAM是固定大小的,请参考memory map进行分配和使用。
If a post answers your question, please mark it with the "verify answer" button. |
szbliy 发表于 2018-6-14 07:34 你好,为什么查看.map还是有剩余的,但是就是不运行? |
你这样问我不知道怎么回答你,因为我不知道你使用了哪个RAM区,没看到你的.map,也不知道你的CLA里内存是如何配置的。 如果需要深究,请提供更多详细的信息才能帮你分析。 If a post answers your question, please mark it with the "verify answer" button. |
szbliy 发表于 2018-6-14 08:01 一、变量定义: typedef struct [ int vector; float Uab; //ab电压 float Uca; //ac电压 float Ucb; //bc电压 float Uabold[5]; float Ucaold[5]; float Ucbold[5]; float Uref; float Ia; //a电流 float Ib; //b电流 float Ic; //c电流 float PCBTemperature; //控制板温度 float Udhis[180]; float Uqhis[180]; ]AD_REG; #define AD_DEFAULTS [0,0,0,0,0,0,0,0,0,0,0,0,0,0] 二、CLA.C文件 /* * adc.h * * Created on: 2016-11-22 Author : ZHANGZIYING * * */ #include "DSP28x_Project.h" // DSP28x Headerfile #include "DSP2803x_Cla_defines.h" #include "cla.h" #pragma DATA_SECTION(ad,"Cla1DataRam0") AD_REG ad = AD_DEFAULTS; #pragma DATA_SECTION(state,"Cla1DataRam0") STATE_REG state = STATE_DEFAULTS; #pragma DATA_SECTION(index,"Cla1DataRam0") Uint16 index = 0; #pragma DATA_SECTION(PCBTemperature,"Cla1ToCpuMsgRAM") float PCBTemperature = 0; #pragma DATA_SECTION(Uab,"Cla1ToCpuMsgRAM") float Uab = 0; #pragma DATA_SECTION(Ubc,"Cla1ToCpuMsgRAM") float Ubc = 0; #pragma DATA_SECTION(Uca,"Cla1ToCpuMsgRAM") float Uca = 0; #pragma DATA_SECTION(Ia,"Cla1ToCpuMsgRAM") float Ia = 0; #pragma DATA_SECTION(Ib,"Cla1ToCpuMsgRAM") float Ib = 0; #pragma DATA_SECTION(Ic,"Cla1ToCpuMsgRAM") float Ic = 0; #pragma DATA_SECTION(Period,"CpuToCla1MsgRAM") float Period = 0; #pragma DATA_SECTION(grid_alpha,"Cla1ToCpuMsgRAM") float grid_alpha = 0; #pragma DATA_SECTION(RunEnableFlag,"CpuToCla1MsgRAM") Uint16 RunEnableFlag = 0; #pragma DATA_SECTION(lock_flag,"Cla1ToCpuMsgRAM") Uint16 lock_flag = 0; #pragma DATA_SECTION(postive_negetive_flag,"Cla1ToCpuMsgRAM") Uint16 postive_negetive_flag = 0; #pragma DATA_SECTION(cnt,"Cla1DataRam0") Uint16 cnt = 0; #pragma DATA_SECTION(Ud,"Cla1DataRam0") float Ud = 0; #pragma DATA_SECTION(Uq,"Cla1DataRam0") float Uq = 0; #pragma DATA_SECTION(Udfil,"Cla1DataRam0") float Udfil = 0; #pragma DATA_SECTION(Uqfil,"Cla1DataRam0") float Uqfil = 0; /* #pragma DATA_SECTION(Udhis,"Cla1DataRam0") //这样定义有问题,数据过大,CLA不运行,所以定义改在AD结构体中,具体原因不详,注意!!! float Udhis[100] = [0]; #pragma DATA_SECTION(Uqhis,"Cla1DataRam0") float Uqhis[100] =[0]; */ void ConfigCla(void) [ /* Assign user defined ISR to the PIE vector table */ EALLOW; //PieVectTable.CLA1_INT1 = &cla1_task1_isr; //PieVectTable.CLA1_INT2 = &cla1_task2_isr; //PieVectTable.CLA1_INT3 = &cla1_task3_isr; // PieVectTable.CLA1_INT4 = &cla1_task4_isr; //PieVectTable.CLA1_INT5 = &cla1_task5_isr; //PieVectTable.CLA1_INT6 = &cla1_task6_isr; //PieVectTable.CLA1_INT7 = &cla1_task7_isr; PieVectTable.CLA1_INT8 = &cla1_task8_isr; EDIS; //Copy over the CLA code and Tables memcpy(&Cla1funcsRunStart, &Cla1funcsLoadStart, (Uint32)&Cla1funcsLoadSize); memcpy(&Cla1mathTablesRunStart, &Cla1mathTablesLoadStart, (Uint32)&Cla1mathTablesLoadSize); /* Compute all CLA task vectors */ EALLOW; //Cla1Regs.MVECT1 = (Uint16)((Uint32)&Cla1Task1 - (Uint32)&Cla1Prog_Start); //Cla1Regs.MVECT2 = (Uint16)((Uint32)&Cla1Task2 - (Uint32)&Cla1Prog_Start); //Cla1Regs.MVECT3 = (Uint16)((Uint32)&Cla1Task3 - (Uint32)&Cla1Prog_Start); //Cla1Regs.MVECT4 = (Uint16)((Uint32)&Cla1Task4 - (Uint32)&Cla1Prog_Start); //Cla1Regs.MVECT5 = (Uint16)((Uint32)&Cla1Task5 - (Uint32)&Cla1Prog_Start); //Cla1Regs.MVECT6 = (Uint16)((Uint32)&Cla1Task6 - (Uint32)&Cla1Prog_Start); //Cla1Regs.MVECT7 = (Uint16)((Uint32)&Cla1Task7 - (Uint32)&Cla1Prog_Start); Cla1Regs.MVECT8 = (Uint16)((Uint32)&Cla1Task8 - (Uint32)&Cla1Prog_Start); EDIS; // Mapping CLA tasks /* All tasks are enabled and will be started by an ePWM trigger * Map CLA program memory to the CLA and enable software breakpoints */ EALLOW; //Cla1Regs.MPISRCSEL1.bit.PERINT1SEL = CLA_INT1_EPWM1INT; //CLA_INT1_ADCINT1 work seccessfully //Cla1Regs.MPISRCSEL1.bit.PERINT2SEL = CLA_INT2_ADCINT1; ; //Cla1Regs.MPISRCSEL1.bit.PERINT3SEL = CLA_INT3_NONE; //Cla1Regs.MPISRCSEL1.bit.PERINT4SEL = CLA_INT4_EPWM4INT; //Cla1Regs.MPISRCSEL1.bit.PERINT5SEL = CLA_INT5_NONE; //Cla1Regs.MPISRCSEL1.bit.PERINT6SEL = CLA_INT6_NONE; //Cla1Regs.MPISRCSEL1.bit.PERINT7SEL = CLA_INT7_NONE; Cla1Regs.MPISRCSEL1.bit.PERINT8SEL = CLA_INT8_CPUTIMER0INT; Cla1Regs.MIER.bit.INT8 = 1; //Task8 interrupt is enabled EDIS; /* Enable CLA interrupts at the group and subgroup levels */ PieCtrlRegs.PIEIER11.bit.INTx8 = 1; IER = (M_INT11 ); /* Switch the CLA program space to the CLA and enable software forcing * Also switch over CLA data ram 0 and 1 */ EALLOW; Cla1Regs.MMEMCFG.bit.PROGE = 1; //一旦存储器被 CLA 代码初始化,主 CPU 就通过写 1 到 MMEMCFG[PROGE]位将其映射到 CLA 程序空间 Cla1Regs.MCTL.bit.IACKE = 1; //Enable the instruction (IACK #0x0001: Write a 1 to MIFRC bit 0 to force task 1) Cla1Regs.MMEMCFG.bit.RAM0E = CLARAM0_ENABLE; //一旦存储器被 CLA 代码初始化,主 CPU 就将其映射到 CLA 空间。两个存储块可以分别通过 MMEMCFG[RAM0E]和 MMEMCFG[RAM1E]位被映射 Cla1Regs.MMEMCFG.bit.RAM1E = CLARAM1_ENABLE; EDIS; ] //########################################################################### // CLA ISRs //########################################################################### __interrupt void cla1_task8_isr( void) [ PieCtrlRegs.PIEACK.bit.ACK11 = 1; ] 三、F28035_CLA_C.cmd文件 /* //########################################################################### // // FILE: F28035_CLA_C.cmd // // TITLE: Linker Command File For F28035 Device // //########################################################################### // $TI Release: F2803x C/C++ Header Files and Peripheral Examples V128 $ // $Release Date: March 30, 2013 $ //########################################################################### */ /* ====================================================== // For Code Composer Studio V2.2 and later // --------------------------------------- // In addition to this memory linker command file, // add the header linker command file directly to the project. // The header linker command file is required to link the // peripheral structures to the proper locations within // the memory map. // // The header linker files are found in // // For BIOS applications add: DSP2803x_Headers_BIOS.cmd // For nonBIOS applications add: DSP2803x_Headers_nonBIOS.cmd ========================================================= */ /* ====================================================== // For Code Composer Studio prior to V2.2 // -------------------------------------- // 1) Use one of the following -l statements to include the // header linker command file in the project. The header linker // file is required to link the peripheral structures to the proper // locations within the memory map */ /* Uncomment this line to include file only for non-BIOS applications */ /* -l DSP2803x_Headers_nonBIOS.cmd */ /* Uncomment this line to include file only for BIOS applications */ /* -l DSP2803x_Headers_BIOS.cmd */ /* 2) In your project add the path to library search path under project->build options, linker tab, library search path (-i). /*========================================================= */ /* Define the memory block start/length for the F28035 PAGE 0 will be used to organize program sections PAGE 1 will be used to organize data sections Notes: Memory blocks on F2803x are uniform (ie same physical memory) in both PAGE 0 and PAGE 1. That is the same memory region should not be defined for both PAGE 0 and PAGE 1. Doing so will result in corruption of program and/or data. L0 memory block is mirrored - that is it can be accessed in high memory or low memory. For simplicity only one instance is used in this linker file. Contiguous SARAM memory blocks or flash sectors can be be combined if required to create a larger memory block. */ _Cla1Prog_Start = _Cla1funcsRunStart; -heap 0x200 -stack 0x200 // Define a size for the CLA scratchpad area that will be used // by the CLA compiler for local symbols and temps // Also force references to the special symbols that mark the // scratchpad are. CLA_SCRATCHPAD_SIZE = 0x100; --undef_sym=__cla_scratchpad_end --undef_sym=__cla_scratchpad_start MEMORY [ PAGE 0: /* Program Memory */ /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */ RAMM0 : origin = 0x000050, length = 0x0003B0 /* on-chip RAM block M0 */ RAML3 : origin = 0x009000, length = 0x001000 /* on-chip RAM block L3 */ OTP : origin = 0x3D7800, length = 0x000400 /* on-chip OTP */ FLASHH : origin = 0x3E8000, length = 0x002000 /* on-chip FLASH */ FLASHG : origin = 0x3EA000, length = 0x002000 /* on-chip FLASH */ FLASHF : origin = 0x3EC000, length = 0x002000 /* on-chip FLASH */ FLASHE : origin = 0x3EE000, length = 0x002000 /* on-chip FLASH */ FLASHD : origin = 0x3F0000, length = 0x002000 /* on-chip FLASH */ FLASHC : origin = 0x3F2000, length = 0x002000 /* on-chip FLASH */ FLASHA : origin = 0x3F6000, length = 0x001F80 /* on-chip FLASH */ CSM_RSVD : origin = 0x3F7F80, length = 0x000076 /* Part of FLASHA. Program with all 0x0000 when CSM is in use. */ BEGIN : origin = 0x3F7FF6, length = 0x000002 /* Part of FLASHA. Used for "boot to Flash" bootloader mode. */ CSM_PWL_P0 : origin = 0x3F7FF8, length = 0x000008 /* Part of FLASHA. CSM password locations in FLASHA */ IQTABLES : origin = 0x3FE000, length = 0x000B50 /* IQ Math Tables in Boot ROM */ IQTABLES2 : origin = 0x3FEB50, length = 0x00008C /* IQ Math Tables in Boot ROM */ IQTABLES3 : origin = 0x3FEBDC, length = 0x0000AA /* IQ Math Tables in Boot ROM */ ROM : origin = 0x3FF27C, length = 0x000D44 /* Boot ROM */ RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM */ VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM */ PAGE 1 : /* Data Memory */ /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */ /* Registers remain on PAGE1 */ BOOT_RSVD : origin = 0x000000, length = 0x000050 /* Part of M0, BOOT rom will use this for stack */ RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */ RAML0 : origin = 0x008000, length = 0x000800 /* on-chip RAM block L0 */ CLARAM0 : origin = 0x008800, length = 0x000800 // CLARAM1 : origin = 0x008C00, length = 0x000400 CLA1_MSGRAMLOW : origin = 0x001480, length = 0x000080 CLA1_MSGRAMHIGH : origin = 0x001500, length = 0x000080 FLASHB : origin = 0x3F4000, length = 0x002000 /* on-chip FLASH */ ] /* Allocate sections to memory blocks. Note: codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code execution when booting to flash ramfuncs user defined section to store functions that will be copied from Flash into RAM */ SECTIONS [ /* Allocate program areas: */ .cinit : > FLASHA PAGE = 0 .pinit : > FLASHA, PAGE = 0 .text : > FLASHC PAGE = 0 codestart : > BEGIN PAGE = 0 ramfuncs : LOAD = FLASHD, RUN = RAMM0, LOAD_START(_RamfuncsLoadStart), LOAD_SIZE(_RamfuncsLoadSize), RUN_START(_RamfuncsRunStart), PAGE = 0 csmpasswds : > CSM_PWL_P0 PAGE = 0 csm_rsvd : > CSM_RSVD PAGE = 0 /* Allocate uninitalized data sections: */ .stack : > RAMM1 PAGE = 1 .cio : > RAML0 PAGE = 1 .sysmem : > RAMM1 PAGE = 1 .ebss : > RAML0 PAGE = 1 .esysmem : > RAML0 PAGE = 1 /* Initalized sections go in Flash */ /* For SDFlash to program these, they must be allocated to page 0 */ .econst : > FLASHA PAGE = 0 .switch : > FLASHA PAGE = 0 /* Allocate IQ math areas: */ IQmath : > FLASHA PAGE = 0 /* Math Code */ IQmathTables : > IQTABLES, PAGE = 0, TYPE = NOLOAD .bss_cla : > CLARAM0, PAGE = 1 Cla1Prog : LOAD = FLASHE, RUN = RAML3, LOAD_START(_Cla1funcsLoadStart), LOAD_END(_Cla1funcsLoadEnd), RUN_START(_Cla1funcsRunStart), LOAD_SIZE(_Cla1funcsLoadSize), PAGE = 0 Cla1ToCpuMsgRAM : > CLA1_MSGRAMLOW, PAGE = 1 CpuToCla1MsgRAM : > CLA1_MSGRAMHIGH, PAGE = 1 Cla1DataRam0 : > CLARAM0, PAGE = 1 // Cla1DataRam1 : > CLARAM1, PAGE = 1 GROUP : LOAD = FLASHB, RUN = CLARAM0, LOAD_START(_Cla1mathTablesLoadStart), LOAD_END(_Cla1mathTablesLoadEnd), RUN_START(_Cla1mathTablesRunStart), LOAD_SIZE(_Cla1mathTablesLoadSize), PAGE = 1 [ CLA1mathTables .const_cla ] CLAscratch : [ *.obj(CLAscratch) . += CLA_SCRATCHPAD_SIZE; *.obj(CLAscratch_end) ] > CLARAM0, PAGE = 1 /* Uncomment the section below if calling the IQNexp() or IQexp() functions from the IQMath.lib library in order to utilize the relevant IQ Math table in Boot ROM (This saves space and Boot ROM is 1 wait-state). If this section is not uncommented, IQmathTables2 will be loaded into other memory (SARAM, Flash, etc.) and will take up space, but 0 wait-state is possible. */ /* IQmathTables2 : > IQTABLES2, PAGE = 0, TYPE = NOLOAD [ IQmath.lib ] */ /* Uncomment the section below if calling the IQNasin() or IQasin() functions from the IQMath.lib library in order to utilize the relevant IQ Math table in Boot ROM (This saves space and Boot ROM is 1 wait-state). If this section is not uncommented, IQmathTables2 will be loaded into other memory (SARAM, Flash, etc.) and will take up space, but 0 wait-state is possible. */ /* IQmathTables3 : > IQTABLES3, PAGE = 0, TYPE = NOLOAD [ IQmath.lib ] */ /* .reset is a standard section used by the compiler. It contains the */ /* the address of the start of _c_int00 for C Code. /* /* When using the boot ROM this section and the CPU vector */ /* table is not needed. Thus the default type is set here to */ /* DSECT */ .reset : > RESET, PAGE = 0, TYPE = DSECT vectors : > VECTORS PAGE = 0, TYPE = DSECT ] /* //=========================================================================== // End of file. //=========================================================================== */ 四、.map文件 ****************************************************************************** TMS320C2000 Linker PC v6.1.0 ****************************************************************************** >> Linked Wed Dec 28 20:23:12 2016 OUTPUT FILE NAME: ENTRY POINT SYMBOL: "_c_int00" address: 003f325b MEMORY CONFIGURATION name origin length used unused attr fill ---------------------- -------- --------- -------- -------- ---- -------- PAGE 0: RAMM0 00000050 000003b0 00000021 0000038f RWIX RAML3 00009000 00001000 00000670 00000990 RWIX OTP 003d7800 00000400 00000000 00000400 RWIX FLASHH 003e8000 00002000 00000000 00002000 RWIX FLASHG 003ea000 00002000 00000000 00002000 RWIX FLASHF 003ec000 00002000 00000000 00002000 RWIX FLASHE 003ee000 00002000 00000670 00001990 RWIX FLASHD 003f0000 00002000 00000021 00001fdf RWIX FLASHC 003f2000 00002000 000015a8 00000a58 RWIX FLASHA 003f6000 00001f80 00000595 000019eb RWIX CSM_RSVD 003f7f80 00000076 00000000 00000076 RWIX BEGIN 003f7ff6 00000002 00000002 00000000 RWIX CSM_PWL_P0 003f7ff8 00000008 00000000 00000008 RWIX IQTABLES 003fe000 00000b50 00000b50 00000000 RWIX IQTABLES2 003feb50 0000008c 00000000 0000008c RWIX IQTABLES3 003febdc 000000aa 00000000 000000aa RWIX ROM 003ff27c 00000d44 00000000 00000d44 RWIX RESET 003fffc0 00000002 00000000 00000002 RWIX VECTORS 003fffc2 0000003e 00000000 0000003e RWIX PAGE 1: BOOT_RSVD 00000000 00000050 00000000 00000050 RWIX RAMM1 00000400 00000400 00000200 00000200 RWIX DEV_EMU 00000880 00000105 00000004 00000101 RWIX SYS_PWR_CTL 00000985 00000003 00000003 00000000 RWIX FLASH_REGS 00000a80 00000060 00000008 00000058 RWIX CSM 00000ae0 00000010 00000010 00000000 RWIX ADC_RESULT 00000b00 00000020 00000020 00000000 RWIX CPU_TIMER0 00000c00 00000008 00000008 00000000 RWIX CPU_TIMER1 00000c08 00000008 00000008 00000000 RWIX CPU_TIMER2 00000c10 00000008 00000008 00000000 RWIX PIE_CTRL 00000ce0 00000020 0000001a 00000006 RWIX PIE_VECT 00000d00 00000100 00000100 00000000 RWIX CLA1 00001400 00000080 00000040 00000040 RWIX CLA1_MSGRAMLOW 00001480 00000080 00000012 0000006e RWIX CLA1_MSGRAMHIGH 00001500 00000080 00000004 0000007c RWIX ECANA 00006000 00000040 00000034 0000000c RWIX ECANA_LAM 00006040 00000040 00000040 00000000 RWIX ECANA_MOTS 00006080 00000040 00000040 00000000 RWIX ECANA_MOTO 000060c0 00000040 00000040 00000000 RWIX ECANA_MBOX 00006100 00000100 00000100 00000000 RWIX COMP1 00006400 00000020 00000014 0000000c RWIX COMP2 00006420 00000020 00000014 0000000c RWIX COMP3 00006440 00000020 00000014 0000000c RWIX EPWM1 00006800 00000040 00000040 00000000 RWIX EPWM2 00006840 00000040 00000040 00000000 RWIX EPWM3 00006880 00000040 00000040 00000000 RWIX EPWM4 000068c0 00000040 00000040 00000000 RWIX EPWM5 00006900 00000040 00000040 00000000 RWIX EPWM6 00006940 00000040 00000040 00000000 RWIX EPWM7 00006980 00000040 00000040 00000000 RWIX ECAP1 00006a00 00000020 00000020 00000000 RWIX HRCAP1 00006ac0 00000020 00000020 00000000 RWIX HRCAP2 00006ae0 00000020 00000020 00000000 RWIX EQEP1 00006b00 00000040 00000040 00000000 RWIX LINA 00006c00 00000080 0000004a 00000036 RWIX GPIOCTRL 00006f80 00000040 00000040 00000000 RWIX GPIODAT 00006fc0 00000020 00000020 00000000 RWIX GPIOINT 00006fe0 00000020 0000000c 00000014 RWIX SYSTEM 00007010 00000020 00000020 00000000 RWIX SPIA 00007040 00000010 00000010 00000000 RWIX SCIA 00007050 00000010 00000010 00000000 RWIX NMIINTRUPT 00007060 00000010 00000010 00000000 RWIX XINTRUPT 00007070 00000010 00000010 00000000 RWIX ADC 00007100 00000080 00000050 00000030 RWIX SPIB 00007740 00000010 00000010 00000000 RWIX I2CA 00007900 00000040 00000022 0000001e RWIX RAML0 00008000 00000800 00000244 000005bc RWIX CLARAM0 00008800 00000800 0000066c 00000194 RWIX PARTID 003d7e80 00000001 00000001 00000000 RWIX FLASHB 003f4000 00002000 00000228 00001dd8 RWIX CSM_PWL 003f7ff8 00000008 00000008 00000000 RWIX SECTION ALLOCATION MAP output attributes/ section page origin length input sections -------- ---- ---------- ---------- ---------------- .pinit 0 003f6000 00000000 UNINITIALIZED Cla1Prog 0 003ee000 00000670 RUN ADDR = 00009000 003ee000 00000300 sample.obj (Cla1Prog:retain) 003ee300 00000262 sample.obj (Cla1Prog) 003ee562 00000040 CLAlog10.obj (Cla1Prog) 003ee5a2 0000003a CLAmath.lib : CLAcos.obj (Cla1Prog) 003ee5dc 0000003a : CLAln.obj (Cla1Prog) 003ee616 0000003a : CLAsin.obj (Cla1Prog) 003ee650 00000020 : CLAsqrt.obj (Cla1Prog) ramfuncs 0 003f0000 00000021 RUN ADDR = 00000050 003f0000 0000001d DSP2803x_SysCtrl.obj (ramfuncs) 003f001d 00000004 DSP2803x_usDelay.obj (ramfuncs) .text 0 003f2000 000015a8 003f2000 000003d7 modbus.obj (.text) 003f23d7 000002f4 protec_state.obj (.text) 003f26cb 000001c3 epwm.obj (.text) 003f288e 000001a9 DSP2803x_Adc.obj (.text) 003f2a37 0000017c DSP2803x_DefaultIsr.obj (.text:retain) 003f2bb3 00000146 DSP2803x_SysCtrl.obj (.text) 003f2cf9 000000ec DSP2803x_EPwm.obj (.text) 003f2de5 0000008f adc.obj (.text) 003f2e74 00000083 rts2800_ml.lib : fd_mpy.obj (.text) 003f2ef7 00000083 : fs_div.obj (.text) 003f2f7a 0000007b DSP2803x_ECan.obj (.text) 003f2ff5 00000078 rts2800_ml.lib : fs_add.obj (.text) 003f306d 00000073 gpio.obj (.text) 003f30e0 0000005a rts2800_ml.lib : fs_mpy.obj (.text) 003f313a 0000004b cla.obj (.text) 003f3185 0000004a ecap.obj (.text) 003f31cf 00000047 sci.obj (.text) 003f3216 00000045 main.obj (.text) 003f325b 00000044 rts2800_ml.lib : boot.obj (.text) 003f329f 0000003b DSP2803x_CpuTimers.obj (.text) 003f32da 0000002c ecap.obj (.text:retain) 003f3306 00000029 rts2800_ml.lib : fs_tol.obj (.text) 003f332f 00000028 DSP2803x_PieCtrl.obj (.text) 003f3357 00000027 epwm.obj (.text:retain) 003f337e 00000025 rts2800_ml.lib : fs_toi.obj (.text) 003f33a3 00000023 timer.obj (.text) 003f33c6 00000021 timer.obj (.text:retain) 003f33e7 00000021 rts2800_ml.lib : fs_toul.obj (.text) 003f3408 00000021 : memcpy_ff.obj (.text) 003f3429 0000001f : fd_tol.obj (.text) 003f3448 0000001d : i_tofd.obj (.text) 003f3465 0000001c DSP2803x_Sci.obj (.text) 003f3481 0000001c rts2800_ml.lib : fs_tofd.obj (.text) 003f349d 0000001a : l_tofs.obj (.text) 003f34b7 00000019 : args_main.obj (.text) 003f34d0 00000019 : exit.obj (.text) 003f34e9 00000019 : prolog.obj (.text) 003f3502 00000017 crc.obj (.text) 003f3519 00000017 rts2800_ml.lib : fs_cmp.obj (.text) 003f3530 00000014 DSP2803x_ECap.obj (.text) 003f3544 00000013 DSP2803x_Gpio.obj (.text) 003f3557 00000013 rts2800_ml.lib : ul_tofs.obj (.text) 003f356a 00000011 DSP2803x_PieVect.obj (.text) 003f357b 0000000c rts2800_ml.lib : epilog.obj (.text) 003f3587 00000009 cla.obj (.text:retain) 003f3590 00000009 rts2800_ml.lib : _lock.obj (.text) 003f3599 00000008 DSP2803x_CodeStartBranch.obj (.text) 003f35a1 00000007 DSP2803x_DisInt.obj (.text) .econst 0 003f6000 00000304 003f6000 00000100 DSP2803x_PieVect.obj (.econst) 003f6100 00000100 crc.obj (.econst:_auchCRCHi) 003f6200 00000100 crc.obj (.econst:_auchCRCLo) 003f6300 00000004 modbus.obj (.econst) .cinit 0 003f6304 00000236 003f6304 000000c9 protec_state.obj (.cinit) 003f63cd 00000097 cla.obj (.cinit) 003f6464 00000089 modbus.obj (.cinit) 003f64ed 00000020 pwm_run_stop.obj (.cinit) 003f650d 0000000d epwm.obj (.cinit) 003f651a 0000000a rts2800_ml.lib : _lock.obj (.cinit) 003f6524 0000000a : exit.obj (.cinit) 003f652e 00000005 main.obj (.cinit) 003f6533 00000005 timer.obj (.cinit) 003f6538 00000002 --HOLE-- [fill = 0] IQmath 0 003f653a 0000005b 003f653a 00000047 IQmath.lib : IQ10div.obj (IQmath) 003f6581 00000014 : IQ10toF.obj (IQmath) codestart * 0 003f7ff6 00000002 003f7ff6 00000002 DSP2803x_CodeStartBranch.obj (codestart) IQmathTables * 0 003fe000 00000b50 NOLOAD SECTION 003fe000 00000b50 IQmath.lib : IQmathTables.obj (IQmathTables) .reset 0 003fffc0 00000002 DSECT 003fffc0 00000002 rts2800_ml.lib : boot.obj (.reset) vectors 0 003fffc2 00000000 DSECT .stack 1 00000400 00000200 UNINITIALIZED 00000400 00000200 --HOLE-- DevEmuRegsFile * 1 00000880 00000004 UNINITIALIZED 00000880 00000004 DSP2803x_GlobalVariableDefs.obj (DevEmuRegsFile) SysPwrCtrlRegsFile * 1 00000985 00000003 UNINITIALIZED 00000985 00000003 DSP2803x_GlobalVariableDefs.obj (SysPwrCtrlRegsFile) FlashRegsFile * 1 00000a80 00000008 UNINITIALIZED 00000a80 00000008 DSP2803x_GlobalVariableDefs.obj (FlashRegsFile) CsmRegsFile * 1 00000ae0 00000010 UNINITIALIZED 00000ae0 00000010 DSP2803x_GlobalVariableDefs.obj (CsmRegsFile) AdcResultFile * 1 00000b00 00000020 UNINITIALIZED 00000b00 00000020 DSP2803x_GlobalVariableDefs.obj (AdcResultFile) CpuTimer0RegsFile * 1 00000c00 00000008 UNINITIALIZED 00000c00 00000008 DSP2803x_GlobalVariableDefs.obj (CpuTimer0RegsFile) CpuTimer1RegsFile * 1 00000c08 00000008 UNINITIALIZED 00000c08 00000008 DSP2803x_GlobalVariableDefs.obj (CpuTimer1RegsFile) CpuTimer2RegsFile * 1 00000c10 00000008 UNINITIALIZED 00000c10 00000008 DSP2803x_GlobalVariableDefs.obj (CpuTimer2RegsFile) PieCtrlRegsFile * 1 00000ce0 0000001a UNINITIALIZED 00000ce0 0000001a DSP2803x_GlobalVariableDefs.obj (PieCtrlRegsFile) PieVectTableFile * 1 00000d00 00000100 UNINITIALIZED 00000d00 00000100 DSP2803x_GlobalVariableDefs.obj (PieVectTableFile) EmuKeyVar * 1 00000d00 00000001 UNINITIALIZED 00000d00 00000001 DSP2803x_GlobalVariableDefs.obj (EmuKeyVar) EmuBModeVar * 1 00000d01 00000001 UNINITIALIZED 00000d01 00000001 DSP2803x_GlobalVariableDefs.obj (EmuBModeVar) FlashCallbackVar * 1 00000d02 00000002 UNINITIALIZED 00000d02 00000002 DSP2803x_GlobalVariableDefs.obj (FlashCallbackVar) FlashScalingVar * 1 00000d04 00000002 UNINITIALIZED 00000d04 00000002 DSP2803x_GlobalVariableDefs.obj (FlashScalingVar) Cla1RegsFile * 1 00001400 00000040 UNINITIALIZED 00001400 00000040 DSP2803x_GlobalVariableDefs.obj (Cla1RegsFile) Cla1ToCpuMsgRAM * 1 00001480 00000012 UNINITIALIZED 00001480 00000012 cla.obj (Cla1ToCpuMsgRAM) CpuToCla1MsgRAM * 1 00001500 00000004 UNINITIALIZED 00001500 00000004 cla.obj (CpuToCla1MsgRAM) ECanaRegsFile * 1 00006000 00000034 UNINITIALIZED 00006000 00000034 DSP2803x_GlobalVariableDefs.obj (ECanaRegsFile) ECanaLAMRegsFile * 1 00006040 00000040 UNINITIALIZED 00006040 00000040 DSP2803x_GlobalVariableDefs.obj (ECanaLAMRegsFile) ECanaMOTSRegsFile * 1 00006080 00000040 UNINITIALIZED 00006080 00000040 DSP2803x_GlobalVariableDefs.obj (ECanaMOTSRegsFile) ECanaMOTORegsFile * 1 000060c0 00000040 UNINITIALIZED 000060c0 00000040 DSP2803x_GlobalVariableDefs.obj (ECanaMOTORegsFile) ECanaMboxesFile * 1 00006100 00000100 UNINITIALIZED 00006100 00000100 DSP2803x_GlobalVariableDefs.obj (ECanaMboxesFile) Comp1RegsFile * 1 00006400 00000014 UNINITIALIZED 00006400 00000014 DSP2803x_GlobalVariableDefs.obj (Comp1RegsFile) Comp2RegsFile * 1 00006420 00000014 UNINITIALIZED 00006420 00000014 DSP2803x_GlobalVariableDefs.obj (Comp2RegsFile) Comp3RegsFile * 1 00006440 00000014 UNINITIALIZED 00006440 00000014 DSP2803x_GlobalVariableDefs.obj (Comp3RegsFile) EPwm1RegsFile * 1 00006800 00000040 UNINITIALIZED 00006800 00000040 DSP2803x_GlobalVariableDefs.obj (EPwm1RegsFile) EPwm2RegsFile * 1 00006840 00000040 UNINITIALIZED 00006840 00000040 DSP2803x_GlobalVariableDefs.obj (EPwm2RegsFile) EPwm3RegsFile * 1 00006880 00000040 UNINITIALIZED 00006880 00000040 DSP2803x_GlobalVariableDefs.obj (EPwm3RegsFile) EPwm4RegsFile * 1 000068c0 00000040 UNINITIALIZED 000068c0 00000040 DSP2803x_GlobalVariableDefs.obj (EPwm4RegsFile) EPwm5RegsFile * 1 00006900 00000040 UNINITIALIZED 00006900 00000040 DSP2803x_GlobalVariableDefs.obj (EPwm5RegsFile) EPwm6RegsFile * 1 00006940 00000040 UNINITIALIZED 00006940 00000040 DSP2803x_GlobalVariableDefs.obj (EPwm6RegsFile) EPwm7RegsFile * 1 00006980 00000040 UNINITIALIZED 00006980 00000040 DSP2803x_GlobalVariableDefs.obj (EPwm7RegsFile) ECap1RegsFile * 1 00006a00 00000020 UNINITIALIZED 00006a00 00000020 DSP2803x_GlobalVariableDefs.obj (ECap1RegsFile) HRCap1RegsFile * 1 00006ac0 00000020 UNINITIALIZED 00006ac0 00000020 DSP2803x_GlobalVariableDefs.obj (HRCap1RegsFile) HRCap2RegsFile * 1 00006ae0 00000020 UNINITIALIZED 00006ae0 00000020 DSP2803x_GlobalVariableDefs.obj (HRCap2RegsFile) EQep1RegsFile * 1 00006b00 00000040 UNINITIALIZED 00006b00 00000040 DSP2803x_GlobalVariableDefs.obj (EQep1RegsFile) LinaRegsFile * 1 00006c00 0000004a UNINITIALIZED 00006c00 0000004a DSP2803x_GlobalVariableDefs.obj (LinaRegsFile) GpioCtrlRegsFile * 1 00006f80 00000040 UNINITIALIZED 00006f80 00000040 DSP2803x_GlobalVariableDefs.obj (GpioCtrlRegsFile) GpioDataRegsFile * 1 00006fc0 00000020 UNINITIALIZED 00006fc0 00000020 DSP2803x_GlobalVariableDefs.obj (GpioDataRegsFile) GpioIntRegsFile * 1 00006fe0 0000000c UNINITIALIZED 00006fe0 0000000c DSP2803x_GlobalVariableDefs.obj (GpioIntRegsFile) SysCtrlRegsFile * 1 00007010 00000020 UNINITIALIZED 00007010 00000020 DSP2803x_GlobalVariableDefs.obj (SysCtrlRegsFile) SpiaRegsFile * 1 00007040 00000010 UNINITIALIZED 00007040 00000010 DSP2803x_GlobalVariableDefs.obj (SpiaRegsFile) SciaRegsFile * 1 00007050 00000010 UNINITIALIZED 00007050 00000010 DSP2803x_GlobalVariableDefs.obj (SciaRegsFile) NmiIntruptRegsFile * 1 00007060 00000010 UNINITIALIZED 00007060 00000010 DSP2803x_GlobalVariableDefs.obj (NmiIntruptRegsFile) XIntruptRegsFile * 1 00007070 00000010 UNINITIALIZED 00007070 00000010 DSP2803x_GlobalVariableDefs.obj (XIntruptRegsFile) AdcRegsFile * 1 00007100 00000050 UNINITIALIZED 00007100 00000050 DSP2803x_GlobalVariableDefs.obj (AdcRegsFile) SpibRegsFile * 1 00007740 00000010 UNINITIALIZED 00007740 00000010 DSP2803x_GlobalVariableDefs.obj (SpibRegsFile) I2caRegsFile * 1 00007900 00000022 UNINITIALIZED 00007900 00000022 DSP2803x_GlobalVariableDefs.obj (I2caRegsFile) .ebss 1 00008000 00000244 UNINITIALIZED 00008000 000001ce modbus.obj (.ebss) 000081ce 00000018 DSP2803x_CpuTimers.obj (.ebss) 000081e6 0000000c pwm_run_stop.obj (.ebss) 000081f2 00000004 epwm.obj (.ebss) 000081f6 00000004 rts2800_ml.lib : _lock.obj (.ebss) 000081fa 00000004 : exit.obj (.ebss) 000081fe 00000002 main.obj (.ebss) 00008200 00000042 protec_state.obj (.ebss) 00008242 00000002 timer.obj (.ebss) Cla1DataRam0 * 1 00008800 00000340 UNINITIALIZED 00008800 00000340 cla.obj (Cla1DataRam0) CLAscratch * 1 00008d68 00000104 UNINITIALIZED 00008d68 00000002 CLAlog10.obj (CLAscratch) 00008d6a 00000100 --HOLE-- 00008e6a 00000002 CLAmath.lib : CLAsqrt.obj (CLAscratch) PartIdRegsFile * 1 003d7e80 00000001 UNINITIALIZED 003d7e80 00000001 DSP2803x_GlobalVariableDefs.obj (PartIdRegsFile) CLA1mathTables * 1 003f4000 00000228 RUN ADDR = 00008b40 003f4000 00000156 CLAmath.lib : CLASinCosTable.obj (CLA1mathTables) 003f4156 000000d2 : CLAlnTable.obj (CLA1mathTables) .const_cla * 1 003f4228 00000000 UNINITIALIZEDRUN ADDR = 00008d68 CsmPwlFile * 1 003f7ff8 00000008 UNINITIALIZED 003f7ff8 00000008 DSP2803x_GlobalVariableDefs.obj (CsmPwlFile) GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name address name -------- ---- 003f2000 .text 003f34d0 C$$EXIT 00000100 CLA_SCRATCHPAD_SIZE 003f2e74 FD$$MPY 003f3429 FD$$TOL 003f2ffa FS$$ADD 003f3519 FS$$CMP 003f2ef7 FS$$DIV 003f30e0 FS$$MPY 003f2ff5 FS$$SUB 003f3481 FS$$TOFD 003f337e FS$$TOI 003f3306 FS$$TOL 003f33e7 FS$$TOUL 003f3448 I$$TOFD 003f349d L$$TOFS 003f3557 UL$$TOFS 003f2bae _ADCINT1_ISR 003f2ba9 _ADCINT2_ISR 003f2ba4 _ADCINT3_ISR 003f2b9f _ADCINT4_ISR 003f2b9a _ADCINT5_ISR 003f2b95 _ADCINT6_ISR 003f2b90 _ADCINT7_ISR 003f2b8b _ADCINT8_ISR 003f2b86 _ADCINT9_ISR 003f28d2 _AdcChanSelect 003f292a _AdcConversion 003f2a12 _AdcOffsetSelfCal 00007100 _AdcRegs 00000b00 _AdcResult 00009348 _AdcSample 00009462 _AverageCalc 003f2b81 _CLA1_INT1_ISR 003f2b7c _CLA1_INT2_ISR 003f2b77 _CLA1_INT3_ISR 003f2b72 _CLA1_INT4_ISR 003f2b6d _CLA1_INT5_ISR 003f2b68 _CLA1_INT6_ISR 003f2b63 _CLA1_INT7_ISR 003f2b5e _CLA1_INT8_ISR 00008c9c _CLABIAS 00008c9a _CLALNV10 00008c96 _CLALNV2 00008c98 _CLALNVe 00008c9e _CLALN_TABLE_MASK1 00008ca0 _CLALN_TABLE_MASK2 00008ca2 _CLALnTable 00008d68 _CLALnTableEnd 000095a2 _CLAcos 00008b80 _CLAcosTable 00008c82 _CLAcosTableEnd 000095dc _CLAln 00009562 _CLAlog10 00009616 _CLAsin 00008b40 _CLAsinTable 00008c40 _CLAsinTableEnd 00008b40 _CLAsincosTable 00008c96 _CLAsincosTableEnd 00008c8a _CLAsincosTable_Coef0 00008c8c _CLAsincosTable_Coef1 00008c8e _CLAsincosTable_Coef1_pos 00008c90 _CLAsincosTable_Coef2 00008c92 _CLAsincosTable_Coef3 00008c94 _CLAsincosTable_Coef3_neg 00008b80 _CLAsincosTable_Cos0 00008b40 _CLAsincosTable_Sin0 00008c88 _CLAsincosTable_TABLE_MASK 00008c82 _CLAsincosTable_TABLE_SIZE 00008c84 _CLAsincosTable_TABLE_SIZEDivTwoPi 00008c86 _CLAsincosTable_TwoPiDivTABLE_SIZE 00009650 _CLAsqrt 003f3502 _CRC16 00009000 _Cla1Prog_Start 00001400 _Cla1Regs 00009000 _Cla1Task8 003ee670 _Cla1funcsLoadEnd 00000670 _Cla1funcsLoadSize 003ee000 _Cla1funcsLoadStart 00009000 _Cla1funcsRunStart 003f4228 _Cla1mathTablesLoadEnd 00000228 _Cla1mathTablesLoadSize 003f4000 _Cla1mathTablesLoadStart 00008b40 _Cla1mathTablesRunStart 00006400 _Comp1Regs 00006420 _Comp2Regs 00006440 _Comp3Regs 003f2de5 _ConfigAdc 003f313a _ConfigCla 003f32b4 _ConfigCpuTimer 003f31b4 _ConfigEcap 003f285c _ConfigEpwm 003f33a3 _Config_CPUTimer 000081de _CpuTimer0 00000c00 _CpuTimer0Regs 000081ce _CpuTimer1 00000c08 _CpuTimer1Regs 000081d6 _CpuTimer2 00000c10 _CpuTimer2Regs 003f7ff8 _CsmPwl 00000ae0 _CsmRegs 003f2ccb _CsmUnlock 003f2b59 _DATALOG_ISR 003f35a1 _DSP28x_DisableInt 003f35a5 _DSP28x_RestoreInt 0000006d _DSP28x_usDelay 00000880 _DevEmuRegs 003f2bf5 _DisableDog 003f2b54 _ECAN0INTA_ISR 003f2b4f _ECAN1INTA_ISR 003f2b4a _ECAP1_INT_ISR 00006040 _ECanaLAMRegs 000060c0 _ECanaMOTORegs 00006080 _ECanaMOTSRegs 00006100 _ECanaMboxes 00006000 _ECanaRegs 00006a00 _ECap1Regs 003f2b45 _EMPTY_ISR 003f2b40 _EMUINT_ISR 003f2b3b _EPWM1_INT_ISR 003f2b36 _EPWM1_TZINT_ISR 003f2b31 _EPWM2_INT_ISR 003f2b2c _EPWM2_TZINT_ISR 003f2b27 _EPWM3_INT_ISR 003f2b22 _EPWM3_TZINT_ISR 003f2b1d _EPWM4_INT_ISR 003f2b18 _EPWM4_TZINT_ISR 003f2b13 _EPWM5_INT_ISR 003f2b0e _EPWM5_TZINT_ISR 003f2b09 _EPWM6_INT_ISR 003f2b04 _EPWM6_TZINT_ISR 003f2aff _EPWM7_INT_ISR 003f2afa _EPWM7_TZINT_ISR 00006800 _EPwm1Regs 00006840 _EPwm2Regs 00006880 _EPwm3Regs 000068c0 _EPwm4Regs 00006900 _EPwm5Regs 00006940 _EPwm6Regs 00006980 _EPwm7Regs 003f2af5 _EQEP1_INT_ISR 00006b00 _EQep1Regs 00000d01 _EmuBMode 00000d00 _EmuKey 003f334e _EnableInterrupts 003f2bfd _ExtOscSel 00000a80 _FlashRegs 00000d04 _Flash_CPUScaleFactor 00000d02 _Flash_CallbackPtr 003f26b8 _GpiO_state 00006f80 _GpioCtrlRegs 00006fc0 _GpioDataRegs 00006fe0 _GpioIntRegs 00009300 _Grid_postive_negetive 003f2af0 _HRCAP1_INT_ISR 003f2aeb _HRCAP2_INT_ISR 00006ac0 _HRCap1Regs 00006ae0 _HRCap2Regs 003f2ae6 _I2CINT1A_ISR 003f2ae1 _I2CINT2A_ISR 00007900 _I2caRegs 003f2adc _ILLEGAL_ISR 003f2ad7 _INT13_ISR 003f2ad2 _INT14_ISR 003fead8 _IQ10mpyRndSatTable 003feacc _IQ11mpyRndSatTable 003feac0 _IQ12mpyRndSatTable 003feab4 _IQ13mpyRndSatTable 003feaa8 _IQ14mpyRndSatTable 003fea9c _IQ15mpyRndSatTable 003fea90 _IQ16mpyRndSatTable 003fea84 _IQ17mpyRndSatTable 003fea78 _IQ18mpyRndSatTable 003fea6c _IQ19mpyRndSatTable 003feb44 _IQ1mpyRndSatTable 003fea60 _IQ20mpyRndSatTable 003fea54 _IQ21mpyRndSatTable 003fea48 _IQ22mpyRndSatTable 003fea3c _IQ23mpyRndSatTable 003fea30 _IQ24mpyRndSatTable 003fea24 _IQ25mpyRndSatTable 003fea18 _IQ26mpyRndSatTable 003fea0c _IQ27mpyRndSatTable 003fea00 _IQ28mpyRndSatTable 003fe9f4 _IQ29mpyRndSatTable 003feb38 _IQ2mpyRndSatTable 003fe9e8 _IQ30mpyRndSatTable 003feb2c _IQ3mpyRndSatTable 003feb20 _IQ4mpyRndSatTable 003feb14 _IQ5mpyRndSatTable 003feb08 _IQ6mpyRndSatTable 003feafc _IQ7mpyRndSatTable 003feaf0 _IQ8mpyRndSatTable 003feae4 _IQ9mpyRndSatTable 003fe824 _IQatan2HalfPITable 003fe862 _IQatan2Table 003fe9e8 _IQatan2TableEnd 003fe100 _IQcosTable 003fe502 _IQcosTableEnd 003fe502 _IQdivRoundSatTable 003fe510 _IQdivTable 003fe712 _IQdivTableEnd 003fe712 _IQisqrtRoundSatTable 003fe722 _IQisqrtTable 003fe824 _IQisqrtTableEnd 003fe9e8 _IQmpyRndSatTable 003feb50 _IQmpyRndSatTableEnd 003fe000 _IQsinTable 003fe400 _IQsinTableEnd 003fe712 _IQsqrtRoundSatTable 003fe722 _IQsqrtTable 003fe824 _IQsqrtTableEnd 0000148c _Ia 00008236 _Ia_OVER_ALARM 0000148e _Ib 00008238 _Ib_OVER_ALARM 00001484 _Ic 00008240 _Ic_OVER_ALARM 003f28b4 _InitAdc 003f288e _InitAdcAio 003f329f _InitCpuTimers 003f2f95 _InitECan 003f2f7a _InitECanGpio 003f2f95 _InitECana 003f2f7a _InitECanaGpio 003f3543 _InitECap 003f3530 _InitECap1Gpio 003f3530 _InitECapGpio 003f3185 _InitECapture 003f2de4 _InitEPwm 003f281a _InitEPwm1Example 003f2d36 _InitEPwm1Gpio 003f27da _InitEPwm2Example 003f2d4c _InitEPwm2Gpio 003f279a _InitEPwm3Example 003f2d62 _InitEPwm3Gpio 003f2755 _InitEPwm4Example 003f2d7a _InitEPwm4Gpio 003f2710 _InitEPwm5Example 003f2d92 _InitEPwm5Gpio 003f26cb _InitEPwm6Example 003f2da8 _InitEPwm6Gpio 003f2dbe _InitEPwm7Gpio 003f2dd5 _InitEPwmGpio 003f2d1e _InitEPwmSyncGpio 00000050 _InitFlash 003f3544 _InitGpio 003f23c5 _InitModbus 003f306d _InitMyGpio 003f2c63 _InitPeripheralClocks 003f332f _InitPieCtrl 003f356a _InitPieVectTable 003f2c15 _InitPll 003f3480 _InitSci 003f3465 _InitSciGpio 003f320a _InitScia 003f3465 _InitSciaGpio 003f2ca8 _InitSysCtrl 003f2cf9 _InitTzGpio 003f2be5 _IntOsc1Sel 003f2bd1 _IntOsc2Sel 003f2acd _LIN0INTA_ISR 003f2ac8 _LIN1INTA_ISR 003f2ac3 _LUF_ISR 003f2abe _LVF_ISR 00006c00 _LinaRegs 003f215a _ModbusCommunication 000080c0 _ModbusModule 00008040 _ModbusRxTxValue 003f2079 _ModbusSlaveReadRegAnswer 00008002 _ModbusSlaveReadRegAnswerFlg 003f2049 _ModbusSlaveSetNRegAnswer 00008003 _ModbusSlaveSetNRegAnswerFlg 003f2ab9 _NMI_ISR 00007060 _NmiIntruptRegs 00001488 _PCBTemperature 003f2ab4 _PIE_RESERVED 003d7e80 _PartIdRegs 00001502 _Period 00000ce0 _PieCtrlRegs 00000d00 _PieVectTable 003f6000 _PieVectTableInit 003f23d7 _Protect 003f2aaf _RTOSINT_ISR 003f20ca _RTUSlaveFrameAnalyse 00000021 _RamfuncsLoadSize 003f0000 _RamfuncsLoadStart 00000050 _RamfuncsRunStart 003f201b _ReadSci 00001500 _RunEnableFlag 0000820c _Run_flag_able 003f2aaa _SCIRXINTA_ISR 003f2aa5 _SCITXINTA_ISR 003f2aa0 _SPIRXINTA_ISR 003f2a9b _SPIRXINTB_ISR 003f2a96 _SPITXINTA_ISR 003f2a91 _SPITXINTB_ISR 00007050 _SciaRegs 003f2bc7 _ServiceDog 00007040 _SpiaRegs 00007740 _SpibRegs 00008004 _StartMode 00008001 _StopMode 00008207 _Stop_flag_able 00007010 _SysCtrlRegs 00000985 _SysPwrCtrlRegs 0000823a _TEMPUTURE_ALARM 003f2a8c _TINT0_ISR 003f2a87 _USER10_ISR 003f2a82 _USER11_ISR 003f2a7d _USER12_ISR 003f2a78 _USER1_ISR 003f2a73 _USER2_ISR 003f2a6e _USER3_ISR 003f2a69 _USER4_ISR 003f2a64 _USER5_ISR 003f2a5f _USER6_ISR 003f2a5a _USER7_ISR 003f2a55 _USER8_ISR 003f2a50 _USER9_ISR 00001486 _Uab 00008220 _Uab_OVER_ALARM 00008224 _Uab_UNDER_ALARM 0000148a _Ubc 00008222 _Ubc_OVER_ALARM 00008226 _Ubc_UNDER_ALARM 00001490 _Uca 00008228 _Uca_OVER_ALARM 0000823e _Uca_UNDER_ALARM 00008806 _Ud 00008802 _Udfil 00008808 _Uq 00008804 _Uqfil 003f2a4b _WAKEINT_ISR 003f2000 _WriteSci 003f2a46 _XINT1_ISR 003f2a41 _XINT2_ISR 003f2a3c _XINT3_ISR 00007070 _XIntruptRegs 003f2bb3 _XtalOscSel 003f653a __IQ10div 003f6581 __IQ10toF 00000600 __STACK_END 00000200 __STACK_SIZE 00000001 __TI_args_main ffffffff ___binit__ ffffffff ___c_args__ 003f6304 ___cinit__ 003f35a8 ___etext__ 003f3408 ___memcpy_ff ffffffff ___pinit__ 003f2000 ___text__ 003f34b7 __args_main 00008e6a __cla_scratchpad_end 00008d68 __cla_scratchpad_start 000081fa __cleanup_ptr 000081fc __dtors_ptr 000081f8 __lock 003f3598 __nop 003f3594 __register_lock 003f3590 __register_unlock 00000400 __stack 000081f6 __unlock 003f34d0 _abort 00008840 _ad 000081ec _angl1 000081ea _angl2 000081f0 _angl3 003f6100 _auchCRCHi 003f6200 _auchCRCLo 003f325b _c_int00 003f3587 _cla1_task8_isr 00008801 _cnt 000081e7 _cnt1 000081e6 _cnt2 000081e9 _cnt3 000081f3 _cnt_en_run 003f33c6 _cpu_timer0_isr 003f32da _ecap1_isr 003f357b _epilog_c28x_1 003f357f _epilog_c28x_2 003f3371 _epwm4_isr 003f3364 _epwm5_isr 003f3357 _epwm6_isr 003f34d2 _exit 00001482 _grid_alpha 00008800 _index 00008006 _index_modbus 00008242 _index_time2 000081f4 _led_fault_cnt 000081f2 _led_run_cnt 00001481 _lock_flag 003f3216 _main 00001480 _postive_negetive_flag 003f34e9 _prolog_c28x_1 003f34ed _prolog_c28x_2 003f34f5 _prolog_c28x_3 003f2a37 _rsvd_ISR 003f3202 _scia_fifo_init 003f31cf _scia_init 0000880a _state 000081e8 _stateword 000081fe _testcntcnt 000081ee _timepwm ffffffff binit 003f6304 cinit 003f7ff6 code_start 003f35a8 etext ffffffff pinit GLOBAL SYMBOLS: SORTED BY Symbol Address address name -------- ---- 00000001 __TI_args_main 00000021 _RamfuncsLoadSize 00000050 _InitFlash 00000050 _RamfuncsRunStart 0000006d _DSP28x_usDelay 00000100 CLA_SCRATCHPAD_SIZE 00000200 __STACK_SIZE 00000228 _Cla1mathTablesLoadSize 00000400 __stack 00000600 __STACK_END 00000670 _Cla1funcsLoadSize 00000880 _DevEmuRegs 00000985 _SysPwrCtrlRegs 00000a80 _FlashRegs 00000ae0 _CsmRegs 00000b00 _AdcResult 00000c00 _CpuTimer0Regs 00000c08 _CpuTimer1Regs 00000c10 _CpuTimer2Regs 00000ce0 _PieCtrlRegs 00000d00 _EmuKey 00000d00 _PieVectTable 00000d01 _EmuBMode 00000d02 _Flash_CallbackPtr 00000d04 _Flash_CPUScaleFactor 00001400 _Cla1Regs 00001480 _postive_negetive_flag 00001481 _lock_flag 00001482 _grid_alpha 00001484 _Ic 00001486 _Uab 00001488 _PCBTemperature 0000148a _Ubc 0000148c _Ia 0000148e _Ib 00001490 _Uca 00001500 _RunEnableFlag 00001502 _Period 00006000 _ECanaRegs 00006040 _ECanaLAMRegs 00006080 _ECanaMOTSRegs 000060c0 _ECanaMOTORegs 00006100 _ECanaMboxes 00006400 _Comp1Regs 00006420 _Comp2Regs 00006440 _Comp3Regs 00006800 _EPwm1Regs 00006840 _EPwm2Regs 00006880 _EPwm3Regs 000068c0 _EPwm4Regs 00006900 _EPwm5Regs 00006940 _EPwm6Regs 00006980 _EPwm7Regs 00006a00 _ECap1Regs 00006ac0 _HRCap1Regs 00006ae0 _HRCap2Regs 00006b00 _EQep1Regs 00006c00 _LinaRegs 00006f80 _GpioCtrlRegs 00006fc0 _GpioDataRegs 00006fe0 _GpioIntRegs 00007010 _SysCtrlRegs 00007040 _SpiaRegs 00007050 _SciaRegs 00007060 _NmiIntruptRegs 00007070 _XIntruptRegs 00007100 _AdcRegs 00007740 _SpibRegs 00007900 _I2caRegs 00008001 _StopMode 00008002 _ModbusSlaveReadRegAnswerFlg 00008003 _ModbusSlaveSetNRegAnswerFlg 00008004 _StartMode 00008006 _index_modbus 00008040 _ModbusRxTxValue 000080c0 _ModbusModule 000081ce _CpuTimer1 000081d6 _CpuTimer2 000081de _CpuTimer0 000081e6 _cnt2 000081e7 _cnt1 000081e8 _stateword 000081e9 _cnt3 000081ea _angl2 000081ec _angl1 000081ee _timepwm 000081f0 _angl3 000081f2 _led_run_cnt 000081f3 _cnt_en_run 000081f4 _led_fault_cnt 000081f6 __unlock 000081f8 __lock 000081fa __cleanup_ptr 000081fc __dtors_ptr 000081fe _testcntcnt 00008207 _Stop_flag_able 0000820c _Run_flag_able 00008220 _Uab_OVER_ALARM 00008222 _Ubc_OVER_ALARM 00008224 _Uab_UNDER_ALARM 00008226 _Ubc_UNDER_ALARM 00008228 _Uca_OVER_ALARM 00008236 _Ia_OVER_ALARM 00008238 _Ib_OVER_ALARM 0000823a _TEMPUTURE_ALARM 0000823e _Uca_UNDER_ALARM 00008240 _Ic_OVER_ALARM 00008242 _index_time2 00008800 _index 00008801 _cnt 00008802 _Udfil 00008804 _Uqfil 00008806 _Ud 00008808 _Uq 0000880a _state 00008840 _ad 00008b40 _CLAsinTable 00008b40 _CLAsincosTable 00008b40 _CLAsincosTable_Sin0 00008b40 _Cla1mathTablesRunStart 00008b80 _CLAcosTable 00008b80 _CLAsincosTable_Cos0 00008c40 _CLAsinTableEnd 00008c82 _CLAcosTableEnd 00008c82 _CLAsincosTable_TABLE_SIZE 00008c84 _CLAsincosTable_TABLE_SIZEDivTwoPi 00008c86 _CLAsincosTable_TwoPiDivTABLE_SIZE 00008c88 _CLAsincosTable_TABLE_MASK 00008c8a _CLAsincosTable_Coef0 00008c8c _CLAsincosTable_Coef1 00008c8e _CLAsincosTable_Coef1_pos 00008c90 _CLAsincosTable_Coef2 00008c92 _CLAsincosTable_Coef3 00008c94 _CLAsincosTable_Coef3_neg 00008c96 _CLALNV2 00008c96 _CLAsincosTableEnd 00008c98 _CLALNVe 00008c9a _CLALNV10 00008c9c _CLABIAS 00008c9e _CLALN_TABLE_MASK1 00008ca0 _CLALN_TABLE_MASK2 00008ca2 _CLALnTable 00008d68 _CLALnTableEnd 00008d68 __cla_scratchpad_start 00008e6a __cla_scratchpad_end 00009000 _Cla1Prog_Start 00009000 _Cla1Task8 00009000 _Cla1funcsRunStart 00009300 _Grid_postive_negetive 00009348 _AdcSample 00009462 _AverageCalc 00009562 _CLAlog10 000095a2 _CLAcos 000095dc _CLAln 00009616 _CLAsin 00009650 _CLAsqrt 003d7e80 _PartIdRegs 003ee000 _Cla1funcsLoadStart 003ee670 _Cla1funcsLoadEnd 003f0000 _RamfuncsLoadStart 003f2000 .text 003f2000 _WriteSci 003f2000 ___text__ 003f201b _ReadSci 003f2049 _ModbusSlaveSetNRegAnswer 003f2079 _ModbusSlaveReadRegAnswer 003f20ca _RTUSlaveFrameAnalyse 003f215a _ModbusCommunication 003f23c5 _InitModbus 003f23d7 _Protect 003f26b8 _GpiO_state 003f26cb _InitEPwm6Example 003f2710 _InitEPwm5Example 003f2755 _InitEPwm4Example 003f279a _InitEPwm3Example 003f27da _InitEPwm2Example 003f281a _InitEPwm1Example 003f285c _ConfigEpwm 003f288e _InitAdcAio 003f28b4 _InitAdc 003f28d2 _AdcChanSelect 003f292a _AdcConversion 003f2a12 _AdcOffsetSelfCal 003f2a37 _rsvd_ISR 003f2a3c _XINT3_ISR 003f2a41 _XINT2_ISR 003f2a46 _XINT1_ISR 003f2a4b _WAKEINT_ISR 003f2a50 _USER9_ISR 003f2a55 _USER8_ISR 003f2a5a _USER7_ISR 003f2a5f _USER6_ISR 003f2a64 _USER5_ISR 003f2a69 _USER4_ISR 003f2a6e _USER3_ISR 003f2a73 _USER2_ISR 003f2a78 _USER1_ISR 003f2a7d _USER12_ISR 003f2a82 _USER11_ISR 003f2a87 _USER10_ISR 003f2a8c _TINT0_ISR 003f2a91 _SPITXINTB_ISR 003f2a96 _SPITXINTA_ISR 003f2a9b _SPIRXINTB_ISR 003f2aa0 _SPIRXINTA_ISR 003f2aa5 _SCITXINTA_ISR 003f2aaa _SCIRXINTA_ISR 003f2aaf _RTOSINT_ISR 003f2ab4 _PIE_RESERVED 003f2ab9 _NMI_ISR 003f2abe _LVF_ISR 003f2ac3 _LUF_ISR 003f2ac8 _LIN1INTA_ISR 003f2acd _LIN0INTA_ISR 003f2ad2 _INT14_ISR 003f2ad7 _INT13_ISR 003f2adc _ILLEGAL_ISR 003f2ae1 _I2CINT2A_ISR 003f2ae6 _I2CINT1A_ISR 003f2aeb _HRCAP2_INT_ISR 003f2af0 _HRCAP1_INT_ISR 003f2af5 _EQEP1_INT_ISR 003f2afa _EPWM7_TZINT_ISR 003f2aff _EPWM7_INT_ISR 003f2b04 _EPWM6_TZINT_ISR 003f2b09 _EPWM6_INT_ISR 003f2b0e _EPWM5_TZINT_ISR 003f2b13 _EPWM5_INT_ISR 003f2b18 _EPWM4_TZINT_ISR 003f2b1d _EPWM4_INT_ISR 003f2b22 _EPWM3_TZINT_ISR 003f2b27 _EPWM3_INT_ISR 003f2b2c _EPWM2_TZINT_ISR 003f2b31 _EPWM2_INT_ISR 003f2b36 _EPWM1_TZINT_ISR 003f2b3b _EPWM1_INT_ISR 003f2b40 _EMUINT_ISR 003f2b45 _EMPTY_ISR 003f2b4a _ECAP1_INT_ISR 003f2b4f _ECAN1INTA_ISR 003f2b54 _ECAN0INTA_ISR 003f2b59 _DATALOG_ISR 003f2b5e _CLA1_INT8_ISR 003f2b63 _CLA1_INT7_ISR 003f2b68 _CLA1_INT6_ISR 003f2b6d _CLA1_INT5_ISR 003f2b72 _CLA1_INT4_ISR 003f2b77 _CLA1_INT3_ISR 003f2b7c _CLA1_INT2_ISR 003f2b81 _CLA1_INT1_ISR 003f2b86 _ADCINT9_ISR 003f2b8b _ADCINT8_ISR 003f2b90 _ADCINT7_ISR 003f2b95 _ADCINT6_ISR 003f2b9a _ADCINT5_ISR 003f2b9f _ADCINT4_ISR 003f2ba4 _ADCINT3_ISR 003f2ba9 _ADCINT2_ISR 003f2bae _ADCINT1_ISR 003f2bb3 _XtalOscSel 003f2bc7 _ServiceDog 003f2bd1 _IntOsc2Sel 003f2be5 _IntOsc1Sel 003f2bf5 _DisableDog 003f2bfd _ExtOscSel 003f2c15 _InitPll 003f2c63 _InitPeripheralClocks 003f2ca8 _InitSysCtrl 003f2ccb _CsmUnlock 003f2cf9 _InitTzGpio 003f2d1e _InitEPwmSyncGpio 003f2d36 _InitEPwm1Gpio 003f2d4c _InitEPwm2Gpio 003f2d62 _InitEPwm3Gpio 003f2d7a _InitEPwm4Gpio 003f2d92 _InitEPwm5Gpio 003f2da8 _InitEPwm6Gpio 003f2dbe _InitEPwm7Gpio 003f2dd5 _InitEPwmGpio 003f2de4 _InitEPwm 003f2de5 _ConfigAdc 003f2e74 FD$$MPY 003f2ef7 FS$$DIV 003f2f7a _InitECanGpio 003f2f7a _InitECanaGpio 003f2f95 _InitECan 003f2f95 _InitECana 003f2ff5 FS$$SUB 003f2ffa FS$$ADD 003f306d _InitMyGpio 003f30e0 FS$$MPY 003f313a _ConfigCla 003f3185 _InitECapture 003f31b4 _ConfigEcap 003f31cf _scia_init 003f3202 _scia_fifo_init 003f320a _InitScia 003f3216 _main 003f325b _c_int00 003f329f _InitCpuTimers 003f32b4 _ConfigCpuTimer 003f32da _ecap1_isr 003f3306 FS$$TOL 003f332f _InitPieCtrl 003f334e _EnableInterrupts 003f3357 _epwm6_isr 003f3364 _epwm5_isr 003f3371 _epwm4_isr 003f337e FS$$TOI 003f33a3 _Config_CPUTimer 003f33c6 _cpu_timer0_isr 003f33e7 FS$$TOUL 003f3408 ___memcpy_ff 003f3429 FD$$TOL 003f3448 I$$TOFD 003f3465 _InitSciGpio 003f3465 _InitSciaGpio 003f3480 _InitSci 003f3481 FS$$TOFD 003f349d L$$TOFS 003f34b7 __args_main 003f34d0 C$$EXIT 003f34d0 _abort 003f34d2 _exit 003f34e9 _prolog_c28x_1 003f34ed _prolog_c28x_2 003f34f5 _prolog_c28x_3 003f3502 _CRC16 003f3519 FS$$CMP 003f3530 _InitECap1Gpio 003f3530 _InitECapGpio 003f3543 _InitECap 003f3544 _InitGpio 003f3557 UL$$TOFS 003f356a _InitPieVectTable 003f357b _epilog_c28x_1 003f357f _epilog_c28x_2 003f3587 _cla1_task8_isr 003f3590 __register_unlock 003f3594 __register_lock 003f3598 __nop 003f35a1 _DSP28x_DisableInt 003f35a5 _DSP28x_RestoreInt 003f35a8 ___etext__ 003f35a8 etext 003f4000 _Cla1mathTablesLoadStart 003f4228 _Cla1mathTablesLoadEnd 003f6000 _PieVectTableInit 003f6100 _auchCRCHi 003f6200 _auchCRCLo 003f6304 ___cinit__ 003f6304 cinit 003f653a __IQ10div 003f6581 __IQ10toF 003f7ff6 code_start 003f7ff8 _CsmPwl 003fe000 _IQsinTable 003fe100 _IQcosTable 003fe400 _IQsinTableEnd 003fe502 _IQcosTableEnd 003fe502 _IQdivRoundSatTable 003fe510 _IQdivTable 003fe712 _IQdivTableEnd 003fe712 _IQisqrtRoundSatTable 003fe712 _IQsqrtRoundSatTable 003fe722 _IQisqrtTable 003fe722 _IQsqrtTable 003fe824 _IQatan2HalfPITable 003fe824 _IQisqrtTableEnd 003fe824 _IQsqrtTableEnd 003fe862 _IQatan2Table 003fe9e8 _IQ30mpyRndSatTable 003fe9e8 _IQatan2TableEnd 003fe9e8 _IQmpyRndSatTable 003fe9f4 _IQ29mpyRndSatTable 003fea00 _IQ28mpyRndSatTable 003fea0c _IQ27mpyRndSatTable 003fea18 _IQ26mpyRndSatTable 003fea24 _IQ25mpyRndSatTable 003fea30 _IQ24mpyRndSatTable 003fea3c _IQ23mpyRndSatTable 003fea48 _IQ22mpyRndSatTable 003fea54 _IQ21mpyRndSatTable 003fea60 _IQ20mpyRndSatTable 003fea6c _IQ19mpyRndSatTable 003fea78 _IQ18mpyRndSatTable 003fea84 _IQ17mpyRndSatTable 003fea90 _IQ16mpyRndSatTable 003fea9c _IQ15mpyRndSatTable 003feaa8 _IQ14mpyRndSatTable 003feab4 _IQ13mpyRndSatTable 003feac0 _IQ12mpyRndSatTable 003feacc _IQ11mpyRndSatTable 003fead8 _IQ10mpyRndSatTable 003feae4 _IQ9mpyRndSatTable 003feaf0 _IQ8mpyRndSatTable 003feafc _IQ7mpyRndSatTable 003feb08 _IQ6mpyRndSatTable 003feb14 _IQ5mpyRndSatTable 003feb20 _IQ4mpyRndSatTable 003feb2c _IQ3mpyRndSatTable 003feb38 _IQ2mpyRndSatTable 003feb44 _IQ1mpyRndSatTable 003feb50 _IQmpyRndSatTableEnd ffffffff ___binit__ ffffffff ___c_args__ ffffffff ___pinit__ ffffffff binit ffffffff pinit [409 symbols] |
下次提供这类信息的时候,请不要简单地粘贴代码在回帖里,可以使用添加附件的形式。 你需要我们高效地帮你解决问题,也请考虑一下如何会比较方便我们查看和对比。 . 你的问题应该在于内存分配的页处理上,对于变量和数组来说,编译器会以页(data page)进行分配,你可以查看指令集手册spru430搜索该关键字了解。 简单来说,它是以64个words为单位进行分配,因此地址是按照尾数0x40的倍数来处理的。 . 以你现在的情况为例来说明,你定义了index,cnt,Udfil,Uqfil,Ud和Uq共6个单变量,后4个为float型,因此剩余64-(2+4*2)=54个word的空间。 你没有提供state结构体的定义,但我猜测它的大小应该是小于54个word,因此它会紧接着从0x880a开始分配,然后剩余一些“碎片”是浪费的。 但是ad的大小远远超出0x40,那么它是从0x8840开始分配内存的,直到下一个CLAsinTable也是从尾数为0x40的地址0x8b40开始。 00008800 _index 00008801 _cnt 00008802 _Udfil 00008804 _Uqfil 00008806 _Ud 00008808 _Uq 0000880a _state 00008840 _ad 00008b40 _CLAsinTable . 当你使用数组定义且超出0x40的大小时,比如你屏蔽掉的部分,Udhis数组大小100,对应word数是200,它是大于0x40即64的,那么该数组将会占用4个独立的页,即它的第一个元素必然是放在尾数为0x40开始的地址,然后剩余的4*0x40-200=56个word的空间是浪费,紧接着又从下一个地址尾数为0x40倍数的空间分配Uqhis数组,同样是连续4个页。这样的结果就是,你有大量的空间像碎片一样被浪费,然后导致后面的CLAMathTable和scratchpad没有足够的空间来分配。 . 建议的做法是,像你现在一样将多个变量和数组放在一个结构体里,或者尽可能将数组定义在0x40以内。 If a post answers your question, please mark it with the "verify answer" button. |
szbliy 发表于 2018-6-14 08:31 非常感谢您的帮助,很细心的讲解! 以后我也会注意询问时整理好资料! 感谢! |
有另外两点可能需要补充说明的: 1. 即便是结构体,它的内存分配所遵循的规则和数组也是一样的,也就是说会按照0x40的倍数进行分配,只是结构体可以把很多变量和数组捆绑在一起,因此用户可以尽可能使结构体的总大小在接近0x40倍数的范围,从而节省空间不浪费; 2. 上面提到的数组或结构体尽可能在0x40大小范围以内,应该纠正为在0x40倍数的大小范围内,当然目的还是尽可能少地产生“碎片”。 If a post answers your question, please mark it with the "verify answer" button. |
szbliy 发表于 2018-6-14 08:01 你好,我想咨询一个问题,28035定时器中断问题。 TI官方给的定时器0中断程序是 void InitCpuTimers(void) [ /* 初始化CPU Timer 0 */ CpuTimer0.RegsAddr = &CpuTimer0Regs; // 初始化地址指针指向CPU定时器T0的寄存器CpuTimer0Regs CpuTimer0Regs.PRD.all = 0xFFFFFFFF; // 初始化T0的周期寄存器 TIMER0PRD=0xFFFFFFFF CpuTimer0Regs.TPR.all = 0; // 初始化T0的预分频寄存器 TIMER0TPR = 0(定时器的时钟与SYSCLKOUT相同),即T0计数器每隔1个SYSCLKOUT减1。 CpuTimer0Regs.TPRH.all = 0; CpuTimer0Regs.TCR.bit.TSS = 1; // T0计数器停止计数 CpuTimer0Regs.TCR.bit.TRB = 1; // 重载T0计数器:将周期寄存器中的值载入到定时器计数器中 CpuTimer0.InterruptCount = 0; // 复位T0定时器中断次数计数器 CpuTimer0.InterruptCount ] void ConfigCpuTimer(struct CPUTIMER_VARS *Timer, float Freq, float Period) [ Uint32 PeriodInClocks; /* 配置定时器周期寄存器 */ Timer->CPUFreqInMHz = Freq; Timer->PeriodInUSec = Period; PeriodInClocks = (long) (Freq * Period); Timer->RegsAddr->PRD.all = PeriodInClocks - 1; // Counter decrements PRD+1 times each period /* 配置定时器的预分频寄存器 */ Timer->RegsAddr->TPR.all = 0; // 定时器时钟频率Freq = SYSCLKOUT / (TDDRH:TDDR+1)。此处Set pre-scale counter to divide by 1 (SYSCLKOUT): Timer->RegsAddr->TPRH.all = 0; /* 配置定时器的控制寄存器 */ Timer->RegsAddr->TCR.bit.TSS = 1; // 1 = Stop timer, 0 = Start/Restart Timer Timer->RegsAddr->TCR.bit.TRB = 1; // 1 = reload timer Timer->RegsAddr->TCR.bit.SOFT = 0; Timer->RegsAddr->TCR.bit.FREE = 0; // Timer Free Run Disabled Timer->RegsAddr->TCR.bit.TIE = 1; // 0 = Disable/ 1 = Enable Timer Interrupt /* 清定时器的中断次数计数器 */ Timer->InterruptCount = 0; ] 如果我想设定100US中断一次,那么调用ConfigCpuTimer(&CpuTimer0, 60, 100); 我的问题是:如果我现在想让定时器0的中断频率与电网频率一致,电网频率假如是Freq,在50Hz左右波动,此时改如何设置CPUtimer0呢? |
已在下面帖子回复。建议如下一样,新问题另起一帖,另外,还是麻烦尽量不要粘贴代码,上传附件更方便。 http://www.deyisupport.com/question_answer/microcontrollers/c2000/f/56/p/123433/343037.aspx#343037 If a post answers your question, please mark it with the "verify answer" button. |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1897 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3647 浏览 4 评论
5031 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1734 浏览 1 评论
9372 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
669浏览 2评论
714浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
675浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1771浏览 1评论
GMT+8, 2024-4-24 12:55 , Processed in 0.759915 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
