芯片:TM4C1294NCPDT 我在freertos任务中调用ROM_UpdateEMAC()函数,发现启动不了bootloader。但是在创建或初始化函数中调用ROM_UpdateEMAC()函数就可以启动bootloader。有知道原因的吗?谢谢!!! |
7个回答
还有可能是任务权限不够的原因。你查查M4的指南,看看需要什么权限呢。
我的可以哟! if(g_bFirmwareUpdate) [ // // Transfer control to the bootloader. // SoftwareUpdateBegin(g_ui32SysClock); ] |
您好,可以共享下你的简单工程代码吗?希望学习一下 |
上次进这个网站,不能回复,老是说网页有一个错误; void SoftwareUpdateInit(tSoftwareUpdateRequested pfnCallback) [ uint32_t ui32User0, ui32User1; // // Remember the callback function pointer we have been given. // g_pfnUpdateCallback = pfnCallback; // // Get the MAC address from the user registers in NV ram. // FlashUserGet(&ui32User0, &ui32User1); // // Convert the 24/24 split MAC address from NV ram into a MAC address // array. // g_pui8MACAddr[0] = ui32User0 & 0xff; g_pui8MACAddr[1] = (ui32User0 >> 8) & 0xff; g_pui8MACAddr[2] = (ui32User0 >> 16) & 0xff; g_pui8MACAddr[3] = ui32User1 & 0xff; g_pui8MACAddr[4] = (ui32User1 >> 8) & 0xff; g_pui8MACAddr[5] = (ui32User1 >> 16) & 0xff; // // Set up a UDP PCB to allow us to receive the magic packets sent from // LMFlash. These may be sent to port 9 from any port on the source // machine so we do not call udp_connect here (since this causes lwIP to // filter any packet that did not originate from port 9 too). // g_psMagicPacketPCB = udp_new(); udp_recv(g_psMagicPacketPCB, SoftwareUpdateUDPReceive, NULL); udp_bind(g_psMagicPacketPCB, IP_ADDR_ANY, MPACKET_PORT); ] void SoftwareUpdateRequestCallback(void) [ UARTprintf("receive udp magic!n"); g_bFirmwareUpdate = true; ] //***************************************************************************** // // Setup lwIP raw API services that are provided by the application. The // services provided in this application are - http server, locator service // and Telnet server/client. // //***************************************************************************** void SetupServices(void *pvArg) [ .................................... ................................... // // Start the remote software update module. // SoftwareUpdateInit(SoftwareUpdateRequestCallback); .............................. ............................. ] 再加上上一个回复的内容(run in task)! |
huangdajiang 发表于 2018-6-11 04:10 TI的社区就是有这个问题,是不是服务器不在大陆呢?刷新一下就好了。你这个是测试好的代码么?我有空跑跑看 |
可以的! 有时间请帮我看看RFC2217的问题! 谢谢 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1872 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3613 浏览 4 评论
5019 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1725 浏览 1 评论
9311 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
653浏览 2评论
694浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
651浏览 1评论
1178浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1174浏览 1评论
GMT+8, 2024-3-29 00:41 , Processed in 0.779885 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
