可以读取下面三个内部信号。
可以参考SDK中的adcbufcontinuous和adcsinglechannel例程,按你的需求调整一下ADC channel就可以了。 * # Supported Internal Signals # * Below is a table of internal signals that can be measured using the ADC. * Since we are not connecting to a DIO, there is no DIO to internal signal mapping. The DIO field in the channel lookup table should be marked PIN_UNASSIGNED. * This table can be used to create virtual channel entries in the ADCBufCC26XX_adcChannelLut table in the board file. * * | DIO | Internal Signal CompBInput | * |--------------------|-------------------------------| * | PIN_UNASSIGNED | ADC_COMPB_IN_DCOUPL | * | PIN_UNASSIGNED | ADC_COMPB_IN_VSS | * | PIN_UNASSIGNED | ADC_COMPB_IN_VDDS | |
一种用ADC,精度高点,参考ADC single channel例程
http://dev.ti.com/tirex/#/?link=Software%2FSimpleLink%20CC13x0%20SDK%2FExamples%2FDevelopment%20Tools%2FCC1310%20LaunchPad%2FTI%20Drivers%2Fadcsinglechannel%2FTI-RTOS%2FCCS%20Compiler%2Fadcsinglechannel 另外一种方法用Battery monitor,精度低,只有6位ADC |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1897 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3647 浏览 4 评论
5031 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1734 浏览 1 评论
9372 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
669浏览 2评论
714浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
676浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1772浏览 1评论
GMT+8, 2024-4-24 20:12 , Processed in 0.839002 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
