发 帖
【四旋翼飞行器】76小时吃透四轴算法!史上最强软硬结合实战项目,👉戳此立抢👈
[问答] 温度控制PID系统中,继电器不工作,电路图和程序如下,谢谢啦~
744 单片机 温度控制 PID 继电器 温度传感器
分享
#include
#include
#include
#include
#define  uchar  unsigned  char
#define  uint   unsigned  int
sbit  DATA = P1^1; //DS18B20接入口
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//共阴极字型码
int temp;  //温度值
int ss;                //中间的一个变量
int dd;
int j;
uchar data b;//定时器中断次数
uchar data buf[4];//字型显示中间变量
int alARMH=400;          //默认报警值
int alarmL=-500;
//定义开关的接入口
sbit  k1=P2^5;//+
sbit  k2=P2^6;//-
sbit  k3=P2^7;//确认
sbit  bell=P1^0;
sbit  Red=P1^6;                                //nouse
sbit output=P3^5;
unsigned int s;
unsigned char high_time,low_time,count=0;
bit set=0;
bit Flag=0;
int n;
unsigned char set_temp;
struct PID {
unsigned int  SetPoint; // 设定目标 Desired Value
unsigned int  Proportion; // 比例常数 Proportional Const
unsigned int  Integral; // 积分常数 Integral Const
unsigned int  Derivative; // 微分常数 Derivative Const
unsigned int  LastError; // Error[-1]
unsigned int  PrevError; // Error[-2]
unsigned int  SumError; // Sums of Errors
struct PID spid; // the control PID
unsigned int rout;//the reaction of PID
unsigned int rin;//the feedback of PID
//函数的声明区
void key_to1();                                //键盘++
void key_to2();                           //键盘--
void delay(uint);                //延时
void key();                                 //按键扫描子程序
void Show();                         //显示
//函数的定义区
/*延时子函数*/
void delay(uint num)
        while(num--) ;
void Show()
{            if(temp>=0)
                        display();//显示函数
                if(temp<0)
                        display00();
void PIDInit(struct PID *pp)         //jie gou  bian liang chu shi hua
        memset(pp,0,sizeof(struct PID));
unsigned int PIDCalc( struct PID *pp, unsigned int NextPoint )
        unsigned int dError,Error;
        Error=pp->SetPoint-NextPoint; // 偏差EK,设定值减去当前采样值
        pp->SumError+=Error; // 积分,历史偏差累加
        dError=pp->LastError-pp->PrevError; // 当前微分,偏差相减
        pp->PrevError=pp->LastError;
        pp->LastError=Error;
        return (pp->Proportion * Error // 比例项
                   + pp->Integral * pp->SumError // 积分项
                   + pp->Derivative * dError); // 微分项
compare_temper()
        unsigned char i;
        if(set_temp>temp)
                if(set_temp-temp>1)
                        high_time=100;
                        low_time=0;
                else
                        for(i=0;i<10;i++)
                         int ReadTemperature();
                         rin=s;
                         rout=PIDCalc(&spid,rin);
                        if(        high_time<=100)
                                high_time=(unsigned char)(rout/800);
                        else
                                high_time=100;
                                low_time=(100-high_time);
        else if(set_temp<=temp)
         if(temp-set_temp>1)
                high_time=0;
                low_time=100;
         else
          for(i=0;i<10;i++)
                   rin=s;
                   rout=PIDCalc( &spid, rin );
          if(high_time<100)
                   high_time=(unsigned char) (rout/10000);
                else
                         high_time=0;
void  main()
    TCON=0x01;
    TMOD=0X01;
        TH0=(65536-5000)/256;
        TL0=(65536-5000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        EX0=1;
        for(n=0;n<500;n++)//显示启动LOGo"- - - -"
        {bell=0;logo();}
         Red=0;
        while(1)
            key();
                ss=ReadTemperature();
        Show();
                alarm();
                if(Flag==1)
                {bell=!bell;}  //蜂鸣器滴滴响
                else {bell=0;}
void sever_T1() interrupt        1 using 1  //control the turn of electict
        if(++count<=(high_time))
                output=1;
        else if(count<=100)
                output=0;
        else
                count=0;
                TH0=0X2f;
                TL0=0Xe0;
void time0(void) interrupt 1 using 1  //每隔10ms执行一次此子程序
{        TH0=(65536-5000)/256;
        temp=ss;
恒温燃气热水器硬件设计.PDF
下载积分: 积分 -1 分
143.3 KB, 下载次数: 14, 下载积分: 积分 -1 分
2018-6-1 15:41:34   评论 分享淘帖 邀请回答
1个回答
谢谢楼主的分享学习了
2018-6-10 10:23:11 评论
举报
撰写答案
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
高级模式
您需要登录后才可以回帖 登录 | 注册
我要提问
课程
    关闭
    站长推荐 上一条 /8 下一条
    快速回复 返回顶部 返回列表
