关于AD9910低温下加电异常技术咨询(Help needed regarding the fault of AD9910 at power-on in low temperature condition)现象描述:低温下(-40℃~0℃)AD9910反复加电30次左右出现一次故障,无输出信号。AD9910仅使用分频功能,参考为480M单音信号,输出为26~30M单音信号。(Fault description: AD9910 is used for frequency-dividing, with reference input of 480MHz, and output of 26~30MHz single tone signal. There is one fault ( with no output signal) out of 30 times at time of power-on in low temperature(-40℃~0℃) )使用通用SPI控制发数,SCLK,SDIO和I/O_UPDAT时序如下:Data was sent by general SPI interface, and the timing sequence of SCLK,SDIO Vs. I/O_UPDAT is as follows:[/url]
红色是SCLK,黄色是SDIO,绿色是I/O_UPDAT。 red-SCLK, yellow-SDIO, green- I/O_UPDAT[url=https://ezchina.analog.com/servlet/JiveServlet/showImage/2-55787-22400/pastedImage_2.png] 上图展开 [/url] 观测SCLK与I/O_UPDAT交汇点。watching the intersection of SCLK and I/O_UPDAT咨询1:请问SCLK,SDIO与I/O_UPDAT如上图配置是否存在问题?question 1: Is the parameter setting-up of SCLK,SDIO Vs. I/O_UPDAT is correct as being shown above将SCLK和I/O_UPDAT时序改为如下后低温未出现故障现象。when the timing sequence was changed as being shown followed, there was no fault at time of power-on in low temperature.[url=https://ezchina.analog.com/servlet/JiveServlet/showImage/2-55787-22401/pastedImage_3.png] 黄色为SCLK,绿色为I/O_UPDAT。yellow--SCLK, green--I/O_UPDAT将I/O_UPDAT在时钟完成2个周期后在置高Once the I/O_UPDAT was set to high after 2 periods of SCLK, there was no fault at time of power-on in low temperature. our second question was: is there a delay required for I/O_UPDAT regarding SCLK signal? if yes, how to set up the time delay?咨询2:更改时序后未出现故障,是否因为I/O_UPDAT与SCLK之间要求有延时,请问延时如何控制? |
相关推荐 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
376 浏览 0 评论
736 浏览 1 评论
940 浏览 1 评论
1325 浏览 1 评论
各位老师,请教《模电》问题: 为什么说“分母s的一次项系数大于0时,电路才能稳定工作”
1688 浏览 1 评论
13798 浏览 145 评论
【小车设计挑战赛系列】各类智能小车开源设计资料,原理图、代码齐全
208241 浏览 134 评论
14460 浏览 48 评论
GMT+8, 2024-4-20 04:58 , Processed in 1.048320 second(s), Total 58, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
