扫一扫,分享给好友
操作为:
./scripts/prepare-kernel.sh --arch=ARM --linux=/home/hello/work/kernel/linux-3.2.0-psp04.06.00.11 --ipipe=/home/hello/work/kernel/xenomai-3.0-rc4/kernel/cobalt/arch/arm/patches/ipipe-core-3.2.21-arm-4.patch 但是提示: prepare-kernel.sh: Unable to patch kernel 3.2.21 with ipipe-core-3.2.21-arm-4.patch. 这是怎么回事?谢谢、 |
3个回答
感觉是版本不匹配啊,具体要看下xenomai的版本说明。 |
感谢你的回答。 这句话可以看出来,kernel 3.2.21 with ipipe-core-3.2.21-arm-4.patch 内核版本是 3.2.21 补丁是也是支持3.2.21的。根据楼上的提示可以看到是缺少某个文件导致的。 再次感谢你的回答! |
感谢你的回答,在sh文件看到是缺少文件导致的。谢谢你的提示、 下面是sh文件的内容: if test -r $linux_tree/include/linux/ipipe.h; then if test x$verbose = x1; then echo "I-pipe found - bypassing patch." fi else if test x$ipipe_patch = x; then # Pick ipipe-core-* patches based on the highest numbered # sequence/release number. default_ipipe_patch="`( ls $xenomai_root/kernel/cobalt/arch/$linux_arch/patches/ipipe-core-$linux_version*-$linux_arch-*|sort -r ) 2>/dev/null | head -n1`" fi if test x$default_ipipe_patch = x; then if test x$verbose = x1; then echo "$me: no default I-pipe patch found." >&2 fi default_ipipe_patch=/dev/null fi while test x$ipipe_patch = x; do if test x$usedefault = x; then echo -n "I-pipe patch [default $default_ipipe_patch]: " read ipipe_patch fi if test x$ipipe_patch = x; then ipipe_patch=$default_ipipe_patch fi if test ! -r "$ipipe_patch" -o x$ipipe_patch = x/dev/null; then echo "$me: cannot read I-pipe patch from $ipipe_patch" >&2 usedefault= ipipe_patch= fi done patchdir=`dirname $ipipe_patch`; patchdir=`cd $patchdir && pwd` ipipe_patch=$patchdir/`basename $ipipe_patch` curdir=$PWD cd $linux_tree && patch --dry-run -p1 -f < $ipipe_patch || [ cd $curdir; echo "$me: Unable to patch kernel $linux_version$linux_EXTRAVERSION with `basename $ipipe_patch`." >&2 exit 2; ] patch -p1 -f -s < $ipipe_patch cd $curdir fi |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9353 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
1761浏览 1评论
GMT+8, 2024-4-20 15:28 , Processed in 0.557601 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
